  4. IoBroker web extension
    6.6k
2 Beiträge 1 Kommentatoren 597 Aufrufe
  • jogibear9988J Offline
    jogibear9988
    auf https://github.com/ioBroker/ioBroker.web
    kann man folgendes lesen:
    Web driver supports extensions. The extension is URL handler, that will be called if such URL request appears. The extensions look like normal adapter, but they have no running process and will be called by web server.
    E.g. the user can activate special proxy adapter and reach other devices (like web cams) in the same web server. It is required to let all services be available under one web server.
    gibts dazu ein Beispiel?
    Check my ioBroker webui - a vis alternative
    see: https://github.com/iobroker-community-adapters/ioBroker.webui
      jogibear9988
      hab nun das gefunden: viewtopic.php?t=8147 hoffe das hilft mir weiter
