  4. Problem mit Lineargauge
    5.8k
2 Beiträge 2 Kommentatoren 266 Aufrufe
    magifox
    ich habe mich an einem Lineargauge versucht.
    Es sollte z.B. eine Temperaturanzeige sein.
    Den Anzeigebereich bekomme ich hin.
    Aber der Temperaturzeiger wandert ganz unmotiviert rauf und runter, was ich mir nicht erkären kann.
    Ich hab mal den Link mit angehängt
    > [{"id":"7456e22e.53c7a4","type":"linear-gauge","z":"cf0397b4.11ca5","group":"fa1d670b.114248","order":0,"width":"2","height":"5","name":" T1","colorLowArea":"#ffffc0","colorMidArea":"#99ff99","colorHighArea":"#ff8080","unit":"°","x":410,"y":100,"wires":[object Object]},{"id":"c1f0da53.36ed2","type":"change","z":"cf0397b4.11ca5","name":"","rules":[{"t":"set","p":"highlimit","pt":"msg","to":"100","tot":"num"},{"t":"set","p":"lowlimit","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"setpoint","pt":"msg","to":"100","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":240,"y":100,"wires":[["7456e22e.53c7a4"]]},{"id":"4c18b6a2.7c7368","type":"ui_slider","z":"cf0397b4.11ca5","name":"","label":"slider","group":"fa1d670b.114248","order":0,"width":0,"height":0,"passthru":true,"outs":"all","topic":"","min":0,"max":"100","step":1,"x":70,"y":100,"wires":[["c1f0da53.36ed2"]]},{"id":"fa1d670b.114248","type":"ui_group","z":"","name":"Diele","tab":"4e003873.de05e","disp":true,"width":"6","collapse":false},{"id":"4e003873.de05e","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
    https://flows.nodered.org/node/node-red … ineargauge
    • G Offline
      Garf
      Ich habe des Lineargauge bei mir leider nicht installatiert und kann mir so deinen Flow nicht wirklich ansehen. Es gibt doch ein Beispiel auf der von die verlinkten Seite. Funktioniert dies den bei dir?
      Hast Du diesen Hinweis gelesen?
      > ****<size size="120">Node-Red v19.4 or greater Node-Red-dashboard v2.13.0 or greater</size>****
