  4. Probleme mit node-red adapter
    6.5k
2 Beiträge 1 Kommentatoren 307 Aufrufe
  • V Offline
    V Offline
    vlink
    ich habe seit einiger Zeit massive Probleme mit dem Node-Red Adapter. Stürzt ständig ab.
    Mein System läuft unter Windows 10.
    JS-Controller 1.5.3
    Admin 3.5.10
    node-red 1.7.1
    Hier das Log:
    node-red.0 2018-12-16 22:25:35.482 warn 16 Dec 22:25:35 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
    node-red.0 2018-12-16 22:25:19.130 info Starting node-red: –max-old-space-size=256 C:\ioBroker\node_modules\iobroker.node-red/node_modules/node-red/red.js -v --settings C:\ioBroker\node_modules\iobroker.node-red/userdata/settings.js
    node-red.0 2018-12-16 22:25:14.078 info node-red exited with 1
    node-red.0 2018-12-16 22:25:12.441 warn
    node-red.0 2018-12-16 22:25:12.441 warn 16 Dec 22:25:12 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0 2018-12-16 22:25:12.432 warn
    node-red.0 2018-12-16 22:25:12.432 warn 16 Dec 22:25:12 - [warn] –----------------------------------------------------
    node-red.0 2018-12-16 22:25:12.429 warn
    node-red.0 2018-12-16 22:25:12.429 warn 16 Dec 22:25:12 - [warn] [node-red-node-feedparser/feedparse] Error: Cannot find module 'sax'
    node-red.0 2018-12-16 22:25:12.424 warn
    node-red.0 2018-12-16 22:25:12.424 warn 16 Dec 22:25:12 - [warn] [node-red/tail] Not currently supported on Windows.
    node-red.0 2018-12-16 22:25:12.418 warn
    node-red.0 2018-12-16 22:25:12.418 warn 16 Dec 22:25:12 - [warn] –----------------------------------------------------
    node-red.0 2018-12-16 22:25:02.169 warn
    node-red.0 2018-12-16 22:25:02.169 warn 16 Dec 22:25:02 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
    node-red.0 2018-12-16 22:24:44.875 info Starting node-red: –max-old-space-size=256 C:\ioBroker\node_modules\iobroker.node-red/node_modules/node-red/red.js -v --settings C:\ioBroker\node_modules\iobroker.node-red/userdata/settings.js
    node-red.0 2018-12-16 22:24:39.874 info node-red exited with 1
    node-red.0 2018-12-16 22:24:38.907 warn
    node-red.0 2018-12-16 22:24:38.907 warn 16 Dec 22:24:38 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0 2018-12-16 22:24:38.897 warn
    node-red.0 2018-12-16 22:24:38.897 warn 16 Dec 22:24:38 - [info] Settings file : C:\ioBroker\node_modules\iobroker.node-red\userdata\settings.js
    node-red.0 2018-12-16 22:24:38.897 warn 16 Dec 22:24:38 - [warn] –----------------------------------------------------
    node-red.0 2018-12-16 22:24:38.896 warn
    node-red.0 2018-12-16 22:24:38.896 warn 16 Dec 22:24:38 - [warn] [node-red-node-feedparser/feedparse] Error: Cannot find module 'sax'
    node-red.0 2018-12-16 22:24:38.892 warn
    node-red.0 2018-12-16 22:24:38.892 warn 16 Dec 22:24:38 - [warn] [node-red/tail] Not currently supported on Windows.
    node-red.0 2018-12-16 22:24:38.885 warn
    node-red.0 2018-12-16 22:24:38.885 warn 16 Dec 22:24:38 - [warn] –----------------------------------------------------
    node-red.0 2018-12-16 22:24:28.814 warn
    node-red.0 2018-12-16 22:24:28.814 warn 16 Dec 22:24:28 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
    node-red.0 2018-12-16 22:24:12.727 info Starting node-red: –max-old-space-size=256 C:\ioBroker\node_modules\iobroker.node-red/node_modules/node-red/red.js -v --settings C:\ioBroker\node_modules\iobroker.node-red/userdata/settings.js
    node-red.0 2018-12-16 22:24:07.722 info node-red exited with 1
    node-red.0 2018-12-16 22:24:06.669 warn
    node-red.0 2018-12-16 22:24:06.669 warn 16 Dec 22:24:06 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0 2018-12-16 22:24:06.659 warn
    node-red.0 2018-12-16 22:24:06.659 warn 16 Dec 22:24:06 - [warn] –----------------------------------------------------
    node-red.0 2018-12-16 22:24:06.659 warn 16 Dec 22:24:06 - [warn] [node-red-node-feedparser/feedparse] Error: Cannot find module 'sax'
    node-red.0 2018-12-16 22:24:06.659 warn 16 Dec 22:24:06 - [warn] [node-red/tail] Not currently supported on Windows.
    node-red.0 2018-12-16 22:24:06.658 warn
    node-red.0 2018-12-16 22:24:06.658 warn 16 Dec 22:24:06 - [warn] –----------------------------------------------------
    node-red.0 2018-12-16 22:23:55.546 warn
    node-red.0 2018-12-16 22:23:55.546 warn 16 Dec 22:23:55 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
    node-red.0 2018-12-16 22:23:41.716 info Starting node-red: –max-old-space-size=256 C:\ioBroker\node_modules\iobroker.node-red/node_modules/node-red/red.js -v --settings C:\ioBroker\node_modules\iobroker.node-red/userdata/settings.js
    node-red.0 2018-12-16 22:23:36.674 info node-red exited with 1
    node-red.0 2018-12-16 22:23:35.062 error no connection to objects DB
    Weiß jemand was hier falsch ist?
    Vielen Dank!
    • V Offline
      V Offline
      vlink
      Jemand noch eine Idee hier??
      Vielen Dank!
