  4. Kein zurück? Möchte wieder auf node 6.x
    6.5k
8 Beiträge 4 Kommentatoren 913 Aufrufe
    tgirard
    Kann ich nicht zurück auf node 6.x? Habe es versucht, aber dann lässt sich ioBroker nicht installieren.
    Die aktuelle node 8.x abhängige Version funktioniert leider nicht.
    zB läuft reinstall.sh nicht, sondern gibt folgende Fehler:
    ! > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
    ! > node-gyp rebuild
    ! make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
    ! CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    ! In file included from /usr/include/errno.h:28:0,
    ! from /home/admin/.node-gyp/8.14.0/include/node/uv/errno.h:25,
    ! from /home/admin/.node-gyp/8.14.0/include/node/uv.h:48,
    ! from ../node_modules/nan/nan.h:46,
    ! from ../src/unix_dgram.cc:5:
    ! /usr/include/features.h:367:25: fatal error: sys/cdefs.h: No such file or directory
    ! compilation terminated.
    ! unix_dgram.target.mk:101: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
    ! make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
    ! make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
    ! gyp ERR! build error
    ! gyp ERR! stack Error: make failed with exit code: 2
    ! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    ! gyp ERR! stack at emitTwo (events.js:126:13)
    ! gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    ! gyp ERR! System Linux 4.2.8
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    ! gyp ERR! node -v v8.14.0
    ! gyp ERR! node-gyp -v v3.8.0
    ! gyp ERR! not ok
    ! > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    ! > node rebuild.js
    ! ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
    ! > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
    ! > node iobroker.js setup first
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    ! + iobroker.js-controller@1.4.2
    ! added 158 packages from 126 contributors and audited 1648 packages in 24.422s
    ! found 23 vulnerabilities (17 low, 6 high)
    ! run npm audit fix to fix them, or npm audit for details
    ! DONE iobroker.js-controller
    ! got /opt/iobroker/node_modules/iobroker.discovery/admin
    ! upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    ! upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    ! upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    ! upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    ! upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    ! upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    ! got /opt/iobroker/node_modules/iobroker.admin/admin
    ! upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    ! upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    ! upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    ! upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    ! ./reinstall.sh: line 34: unexpected EOF while looking for matching `"'
    ! ./reinstall.sh: line 37: syntax error: unexpected end of file
    Habe heute sieben mal das Betriebssystem neu installiert. Irgendwie nicht so lustig. Somit aktuell kein ioBroker mehr. Schade….
    Kann irgendjemand helfen? Bitte!
    • lobomauL Offline
      lobomauL Offline
      lobomau
      welche hard- und software?
      Bei linux musst du dich nur an die Anleitung halten. Bei frischem Betriebssystem eigentlich kein Problem:
      http://www.iobroker.net/docu/?page_id=8323&lang=de
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
        tgirard
        habe ich versucht…..
        Ist eine Linus Station auf QNAP, hat bisher problemlos funktioniert. Ubuntu ist 16.04 (neuer geht nicht wegen QNAP).
        Habe bei der Installation unter anderem bekommen:
        ! from /root/.node-gyp/8.14.0/include/node/uv/errno.h:25,
        ! from /root/.node-gyp/8.14.0/include/node/uv.h:48,
        danke schon mal für die Hilfe!
          Hast du denn die build essentials drauf?
          Rainer
            tgirard
            Danke Homoran, darauf bin ich vor 70 Sekunden gestossen… Werde das gleich mal kontrollieren und melde mich!
              tgirard
              ja…. sind (leider) installiert.
              aber der Fehler: usr/include/features.h:367:25: fatal error: sys/cdefs.h: No such file or directory
              => habe Folgendes versucht:
              sudo apt-get --reinstall install libc6 libc6-dev
              werde berichten.
                tgirard
                keine Chance…
                sudo iobroker start
                Starting iobroker controller daemon...
                iobroker controller daemon failed to start: 2
                Error: 2
                Wenn ich nur wüsste, wie ich auf ioBroker mit node 6.x zurück könnte. Dort lief es so schön stabil. Jetzt alles tot. schade, sehr.
                • C Offline
                  ChristianF
                  Hi tigard,
                  wenn Du die Linux Station laufen lassen kannst, sollte Dein NAS auch für die Virtualization Station freigegeben sein. Prüf das doch mal, oder sag hier, welches NAS du hast.
                  In der Virtualization Station kannst Du jede beliebige Linux Distri nutzen, die auf Deiner Architektur läuft. Das ist auch wesentlich ressourcensparender als die Linux Station, die ja m.W. immer ein fully fledged Ubuntu nutzt, oder?
                  Auf meinem NAS laufen vier Debian VMs und eine UTM ohne jede Probleme (mal von dem abgesehen was ich im iobroker so selbst zerhaue).
                  Viele Grüße
                  Christian
