  4. Zigbee adapter auf pi3
    6.5k
9 Beiträge 3 Kommentatoren 1.1k Aufrufe
  • L Offline
    lennong
    ich habe ein problem mit dem zigbee adapter auf einem pi 3. Der lässt sich nicht aktivieren. Im log finde ich folgendes:
    host.raspberrypi	2018-12-07 22:18:47.613	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi	2018-12-07 22:18:47.612	error	instance system.adapter.zigbee.0 terminated with code 1 ()
    host.raspberrypi	2018-12-07 22:18:47.612	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/auto-detect.js:16:22)
    host.raspberrypi	2018-12-07 22:18:47.612	error	Caught by controller[0]: at require (internal/module.js:20:19)
    host.raspberrypi	2018-12-07 22:18:47.612	error	Caught by controller[0]: at Module.require (module.js:497:17)
    host.raspberrypi	2018-12-07 22:18:47.612	error	Caught by controller[0]: at Function.Module._load (module.js:438:3)
    host.raspberrypi	2018-12-07 22:18:47.612	error	Caught by controller[0]: at tryModuleLoad (module.js:446:12)
    host.raspberrypi	2018-12-07 22:18:47.611	error	Caught by controller[0]: at Module.load (module.js:487:32)
    host.raspberrypi	2018-12-07 22:18:47.611	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:579:10)
    host.raspberrypi	2018-12-07 22:18:47.611	error	Caught by controller[0]: at Module._compile (module.js:570:32)
    host.raspberrypi	2018-12-07 22:18:47.611	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
    host.raspberrypi	2018-12-07 22:18:47.611	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:93:9)
    host.raspberrypi	2018-12-07 22:18:47.610	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/compiled/6.11.4/linux/arm/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.610	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/default/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.610	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Release/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.610	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Release/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.610	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Debug/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.609	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Debug/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.609	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Release/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.609	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Debug/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.609	error	Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/serialport.node
    host.raspberrypi	2018-12-07 22:18:47.609	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.raspberrypi	2018-12-07 22:18:47.608	error	Caught by controller[0]: ^
    host.raspberrypi	2018-12-07 22:18:47.608	error	Caught by controller[0]: throw err
    host.raspberrypi	2018-12-07 22:18:47.605	error	Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:96
    host.raspberrypi	2018-12-07 22:18:46.391	info	instance system.adapter.zigbee.0 started with pid 6777</anonymous></anonymous>
    hab schon:
    npm cache clean
    npm install iobroker.zigbee
    aber immer noch das gleiche Problem. Woran kann das noch liegen?
    • J Offline
      Jan1
      Na reichlich wenig Infos zu Deinem System.
      Allerdings hatte ich mit dem Adapter auch ein Problem in auf grün zu bekommen. Hab ihn dann einfach gelöscht und noch mal installiert, danach lief er, warum auch immer.
      • L Offline
        lennong
        hab einen pi 3 und einen cc2531 dran stecken.
        dieser wird auch unter /dev/serial/by-id erkannt.
        Neuinstalliert hab ich auch schon so 2-3 mal und neu gebootet auch.
        • apollon77A Offline
          Install log wäre hilfreich. Scheinbar ist die serialport Library nicht korrekt gebaut worden.
          Gesendet vom Handy …
          • L Offline
            lennong
            Ok,
            schau ich mir mal an. wird die lib bei dem zigbee Adapter mit installiert? oder bei der io brokjer Installation?
            • L Offline
              lennong
              ob das das Problem ist?
              npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              • L Offline
                lennong
                also habe alles nochmal ausprobiert. aber immer noch der gleiche Fehler.
                habe einfach mal ein Iobroker image auf eine andere SD karte geflasht und mit dem frischen System funktioniert der Adapter.
                Ist zwar nicht das Thema hier, aber wie bekomme ich denn jetzt meine alten Settings auf das neue System?
                • L Offline
                  lennong
                  Setze jetzt mein neues System auf, damit sollte das Thema hier ja beendet sein.
                    Naja Installlog (ich meine das vollständige) wäre immer noch hilfreich
