  4. YAHKA Error
    6.4k
YAHKA Error
3 Beiträge 2 Kommentatoren 1.1k Aufrufe
    polarqualle
    seid gestern will mein Yahka Adapter nicht mehr starten. Nach einem Reboot von IOBroker bleibt dieser rot. Im log steht folgendes was mir leider überhaupt nicht weiterhilft.
    host.raspberrypi	2018-11-20 06:19:11.389	info	Restart adapter system.adapter.yahka.0 because enabled
    host.raspberrypi	2018-11-20 06:19:11.389	error	instance system.adapter.yahka.0 terminated with code 1 ()
    host.raspberrypi	2018-11-20 06:19:11.389	error	Caught by controller[0]: at Module._compile (module.js:577:32)
    host.raspberrypi	2018-11-20 06:19:11.389	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/ed25519-hap/index.js:1:99)
    host.raspberrypi	2018-11-20 06:19:11.388	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
    host.raspberrypi	2018-11-20 06:19:11.387	error	Caught by controller[0]: at require (internal/module.js:20:19)
    host.raspberrypi	2018-11-20 06:19:11.387	error	Caught by controller[0]: at Module.require (module.js:504:17)
    host.raspberrypi	2018-11-20 06:19:11.387	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
    host.raspberrypi	2018-11-20 06:19:11.387	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    host.raspberrypi	2018-11-20 06:19:11.387	error	Caught by controller[0]: at Module.load (module.js:494:32)
    host.raspberrypi	2018-11-20 06:19:11.387	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:604:18)
    host.raspberrypi	2018-11-20 06:19:11.386	error	Caught by controller[0]: at Error (native)
    host.raspberrypi	2018-11-20 06:19:11.386	error	Caught by controller[0]: Error: Module version mismatch. Expected 48, got 59.
    host.raspberrypi	2018-11-20 06:19:11.386	error	Caught by controller[0]: ^
    host.raspberrypi	2018-11-20 06:19:11.386	error	Caught by controller[0]: throw e
    host.raspberrypi	2018-11-20 06:19:11.385	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88
    host.raspberrypi	2018-11-20 06:19:10.519	info	instance system.adapter.yahka.0 started with pid 6996</anonymous>
    Habe ich ein Proboem mit dem JS-Controller bzw. mit dessen Version?
    JS Controller steht auf Version 1.4.2. Yahka laut Adapter Ansicht auf 0.8.0.
    Hat jemand dazu eine Idee? Freue mich auf jede Info.
    Gruß Tim
    • apollon77A Offline
      Ne scheinbar hast du dein nodejs aktualisiert von einer hauptversion auf eine andere.
      Führe mal im iobroker Verzeichnis ein „npm rebuild“ aus.
      Gesendet vom Handy …
        polarqualle
        Danke dir.. das war des Rätsels Lösung, npm rebuild und iobroker restart und yahka war wieder grün. Frage mich nur wie oder wann ich npm update ausgelöst hab.
        Gruß Tim
