  4. [gelöst] Neuinstall auf Proxmox VM - ioBroker startet nicht
    6.4k
9 Beiträge 3 Kommentatoren 1.0k Aufrufe
  • H Offline
    hmanfred
    ich habe ioBroker nach Anleitung auf einer VM mit DEBIAN 9.6 istalliert.
    Nach Reboot läuft ioBroker nicht, also:
    user@ioBroker:~$ iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon started. PID: 442
    Dann aber:
    user@ioBroker:~$ iobroker status
    iobroker is not running
    Während der Installation gab es einige Warnungen und Fehlermeldungen (gekürzt auf relevante Ausgaben):
    user@ioBroker:/opt/iobroker$ sudo npm install iobroker --unsafe-perm
    NPM version: 6.4.1
    npm version >= 5: disabling package-lock
    npm install iobroker.discovery@stable --production --save
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm notice created a lockfile as package-lock.json. You should commit this file.
    • iobroker.discovery@1.2.1
      added 210 packages from 90 contributors, removed 39 packages and audited 523 packages in 67.23s
      found 1 low severity vulnerability
      run npm audit fix to fix them, or npm audit for details
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.admin"
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.discovery"
      added 160 packages from 132 contributors and audited 1646 packages in 97.84s
      found 23 vulnerabilities (17 low, 6 high)
      packet folder is: /opt/iobroker/node_modules/iobroker.js-controller | exists: true
      Write "./iobroker start" to start the ioBroker
      Non-critical error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker/lib/../install/linux/iobroker.sh'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
    ! + iobroker@1.1.2
    added 47 packages from 25 contributors and audited 77 packages in 209.006s
    found 0 vulnerabilities
    Nachfolgender Aufruf von npm audit zeigt:
    user@ioBroker:/opt/iobroker$ nnpm audit
    npm ERR! code ELOCKVERIFY
    npm ERR! Errors were found in your package-lock.json, run  npm install  to fix them.
    npm ERR!     Missing: iobroker.admin@^3.4.7
    npm ERR!     Missing: iobroker.discovery@^1.2.1
    npm ERR!     Missing: iobroker.js-controller@^1.4.2
    npm ERR!     /home/user/.npm/_logs/2018-11-18T09_49_07_456Z-debug.log
    Mag sein, dass für viele von euch diese Meldungen selbstredent sind - für mich sind sie es leider nicht. :oops:
    Manfred
    • wendy2702W Online
      wendy2702W Online
      wendy2702
      Also die Warnmeldungen bei der Installation kannst du ignorieren. Habe ich auf einer neuen PI Installation auch bekommen.
      Wenn du iobroker gestartet hast, kommst du dann wirklich nicht auf die Startseite?
      Das iobroker nach reboot nicht läuft wurde im Forum auch schon diskutiert und ich habe dazu gestern ein Issue auf GIT geöffnet.
      https://github.com/ioBroker/ioBroker/issues/73
      Wenn du iobroker gestartet hast, was kommt im logfile?
      Was bringt````
      ps -ef |grep io
      • H Offline
        hmanfred
        @wendy2702:
        Wenn du iobroker gestartet hast, kommst du dann wirklich nicht auf die Startseite? `
        Wie oben bereits gepostet:
        iobroker controller daemon started. PID: 543
        Obwohl die Meldung kommt, dass der iobroker controller daemon gestartet ist, sagt der Status "not running".
        @wendy2702:
        Wenn du iobroker gestartet hast, was kommt im logfile? `
        Das Verzeichnis /opt/iobroker/log ist leer.
        @wendy2702:
        Was bringtps -ef |grep io `
        user@ioBroker:/opt/iobroker/log$ ps -ef |grep io
        root         9     2  0 10:54 ?        00:00:00 [migration/0]
        root        15     2  0 10:54 ?        00:00:00 [migration/1]
        root        30     2  0 10:54 ?        00:00:00 [bioset]
        root        84     2  0 10:54 ?        00:00:00 [bioset]
        root        85     2  0 10:54 ?        00:00:00 [bioset]
        root        86     2  0 10:54 ?        00:00:00 [bioset]
        root        87     2  0 10:54 ?        00:00:00 [bioset]
        root        88     2  0 10:54 ?        00:00:00 [bioset]
        root        89     2  0 10:54 ?        00:00:00 [bioset]
        root        90     2  0 10:54 ?        00:00:00 [bioset]
        root        91     2  0 10:54 ?        00:00:00 [bioset]
        root       101     2  0 10:54 ?        00:00:00 [bioset]
        root       102     2  0 10:54 ?        00:00:00 [bioset]
        message+   377     1  0 10:54 ?        00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
        avahi      383     1  0 10:54 ?        00:00:00 avahi-daemon: running [ioBroker.local]
        user       586   419  0 12:18 pts/0    00:00:00 grep io
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          Steht etwas im Syslog?
          Kann es sein das iobroker nicht die notwendigen Rechte hat?
          Müsste mal mein Test Proxmox starten und schauen wie ich es damals gemacht habe :(
          Eventuell mal drei Sessions öffnen und die logs syslog und iobroker log monitoren während du iobroker startest.
          • H Offline
            hmanfred
            Frag mich nicht warum - jetzt komme ich auf die Webseite.
            "iobroker status" zeigt auch jetzt, dass er läuft. Das war nachweislich (siehe oben) vorher nach scheinbar erfolgreichem Start nicht der Fall.
            Jetzt muss ich nur noch der Ursahce auf die Spur kommen, warum ioBroker beim Start der Maschine nicht hoch kommt.
            • H Offline
              hmanfred
              @wendy2702:
              https://github.com/ioBroker/ioBroker/issues/73 `
              Kann man das irgendwie manuell fixen? Möchte meine Neuinstallation gerne in Richtung Produktivsystem weiterführen.
              • paul53P Offline
                @hmanfred:
                Kann man das irgendwie manuell fixen? `
                https://forum.iobroker.net/viewtopic.php?f=34&t=7019&start=300#p153021. Wenn nicht als User root, dann alle Befehle mit sudo davor.
                • H Offline
                  hmanfred
                  Hat geklappt. Danke! :D
                  • paul53P Offline
                    @hmanfred:
                    Hat geklappt. `
                    Dann markiere bitte das Thema im Betreff des ersten Beitrags als [gelöst].
