  4. Error npm install dateformat
    5.8k
3 Beiträge 2 Kommentatoren 491 Aufrufe
  • 0 Offline
    0 Offline
    0018
    verwende in einen Script "dateformat" und benötige hierzu das dateformatz module.
    Leider bekomme ich bei der Installation folgende Fehlermeldung:
    pi@BrokerPi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ sudo npm install dateformat
    npm ERR! code ENOLOCAL
    npm ERR! Could not install from "node_modules/dateformat" as it does not contain a package.json file.
    npm ERR!     /root/.npm/_logs/2018-11-13T13_38_26_244Z-debug.log
    Im verweisten Debug-Log steht:
    pi@BrokerPi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ sudo cat /root/.npm/_logs/2018-11-13T13_38_26_244Z-debug.log
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', 'dateformat' ]
    2 info using npm@6.4.1
    3 info using node@v8.12.0
    4 verbose npm-session ec2ae47108ea1e3e
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 silly fetchPackageMetaData error for dateformat@file:node_modules/dateformat Could not install from "node_modules/dateformat" as it does not contain a package.json file.
    8 timing stage:rollbackFailedOptional Completed in 3ms
    9 timing stage:runTopLevelLifecycles Completed in 967ms
    10 verbose stack Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node_modules/dateformat/package.json'
    11 verbose cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules
    12 verbose Linux 4.14.71-v7+
    13 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "dateformat"
    14 verbose node v8.12.0
    15 verbose npm  v6.4.1
    16 error code ENOLOCAL
    17 error Could not install from "node_modules/dateformat" as it does not contain a package.json file.
    18 verbose exit [ 1, true ]
    Hat jemanden einen Rat woran es scheitert?
    Mfg
    0018
    • paul53P Offline
      @0018:
      verwende in einen Script "dateformat" `
      Weshalb verwendest Du nicht die Funktion https://github.com/ioBroker/ioBroker.javascript/blob/master/doc/en/javascript.md#formatdate ?
      NPM-Module für Javascript müssen in der Konfiguration der Javascript-Instanz unter "zusätzliche NPM-Module" eingetragen werden. Sie werden dann automatisch installiert.
      • 0 Offline
        0 Offline
        0018
        Hatte das Script damals hier aus dem Forum, dort war es so implementiert.
        Werde das ganze jetzt auf formatDate umbauen, Danke für den Tipp!
        Mfg
        0018
