  4. Iobroker Adapter Harmony
    6.3k
3 Beiträge 2 Kommentatoren 553 Aufrufe
  • X Offline
    X Offline
    xxxspxxx
    Hi zusammen,
    ich versuche aktuell in ioBroker den Harmony Adapter zu installieren. Leider kommt es immer zu einen Fehler 13
    $ ./iobroker add harmony  --host raspberrypi
    NPM version: 4.6.1
    npm install iobroker.harmony --production --save --prefix "/opt/iobroker" (System call)
    npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
    npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
    npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
    npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
    npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:42:5
    npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5
    npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:284:29
    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:152:21)
    npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:152:21) code: 'ENOGIT' }
    npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
    npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
    npm ERR! code ENOGIT
    npm ERR! not found: gitnpm ERR!
    npm ERR! Failed using git.
    npm ERR! This is most likely not a problem with npm itself.
    npm ERR! Please check if you have git installed and in your PATH.
    npm ERR!     /root/.npm/_logs/2018-11-08T09_48_16_923Z-debug.log
    host.raspberrypi install adapter harmony
    NPM version: 4.6.1
    npm
    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:152:21)npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
         at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
    npm
    npm
    npm
     ERR! code ENOGIT
    npm
    ERR! npm
     ERR!
     Failed using git.npm
    ERR!
     This is most likely not a problem with npm itself.npm
     ERR!
    npm
    ERR! A complete log of this run can be found in:
    npm
    ERR!     /root/.npm/_logs/2018-11-08T09_48_34_042Z-debug.log
    NPM version: 4.6.1
    npm
     addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
    npm WARN
    addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:42:5
    npm
    npm
    npm
     ERR!
     code ENOGIT
    npm ERR!
     Failed using git.npm ERR! This is most likely not a problem with npm itself.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-11-08T09_48_52_411Z-debug.log
    ERROR: host.raspberrypi Cannot install harmony
    ERROR: process exited with code 13</https:></https:></https:>
    könnt ihr mir vielleicht weiterhelfen woher der Fehler kommen könnte?
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      Würde sagen dir fehlt „GIT“ auf deiner Installation:
      Siehe Zeile 4 in deinem Log.
      Oder hier:
      • X Offline
        X Offline
        xxxspxxx
        danke habe ich irgendwie überlesen. Hat funktioniert.
