  4. SQL History 0.1.2 Fehler "ECONNREFUSED"
7 Beiträge 3 Kommentatoren 2.3k Aufrufe
  • eric2905E Offline
    eric2905E Offline
    eric2905
    Moin zusammen,
    habe heute früh das Update des "SQL History" Adapter auf die Version 0.1.2 durchgeführt …
    Log schmiss Fehlermeldungen (hab ich Esel nicht gesichert ... war was mit NPM ....) und nun habe ich einen Verbindungsfehler zur DB.
    sql.0	2015-12-23 05:03:42	error	sql.0 Error: connect ECONNREFUSED
    sql.0	2015-12-23 05:03:38	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:03:37	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:03:22	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:03:12	error	sql.0 Error: connect ECONNREFUSED
    sql.0	2015-12-23 05:03:07	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:02:55	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:02:51	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:02:45	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:02:42	error	sql.0 Error: connect ECONNREFUSED
    sql.0	2015-12-23 05:02:36	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:02:24	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:02:21	warn	sql.0 No connection to DB
    sql.0	2015-12-23 05:02:19	warn	sql.0 No connection to DB
    sql-0	2015-12-23 05:02:13	warn	No connection to DB
    sql-0	2015-12-23 05:02:12	error	Error: connect ECONNREFUSED
    sql-0	2015-12-23 05:02:06	warn	No connection to DB
    TypeError:	2015-12-23 05:02:02	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:212:12)
    TypeError:	2015-12-23 05:02:02	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:254:10)
    TypeError:	2015-12-23 05:02:02	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    TypeError:	2015-12-23 05:02:02	error	at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
    TypeError:	2015-12-23 05:02:02	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1930:34)
    TypeError:	2015-12-23 05:02:02	error	at Adapter.emit (events.js:95:17)
    TypeError:	2015-12-23 05:02:02	error	at Adapter._client (/opt/iobroker/node_modules/iobroker.sql/main.js:70:5)
    TypeError:	2015-12-23 05:02:02	error	at processMessage (/opt/iobroker/node_modules/iobroker.sql/main.js:379:9)
    TypeError:	2015-12-23 05:02:02	error	at getHistory (/opt/iobroker/node_modules/iobroker.sql/main.js:781:16)
    TypeError:	2015-12-23 05:02:02	error	at getId (/opt/iobroker/node_modules/iobroker.sql/main.js:589:16)
    TypeError:	2015-12-23 05:02:02	error	Cannot call method 'borrow' of null
    message	2015-12-23 05:02:02	error	messagebox.system.adapter.sql.0 [object Object] Cannot call method 'borrow' of null
    Jemand eine Ahnung / Idee?
    Danke und Gruß,
    Eric
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Nachtrag:
      Habe die SQL-Instanz gelöscht (fehlerfrei) und dann versucht wieder eine neue Instanz zu installieren / aktivieren:
      $ ./iobroker add sql
      host.cubietruck create instance sql
      ERROR: host.cubietruck error: reading io-package.json Error: ENOENT, no such file or directory '/opt/iobroker/node_modules/iobroker.sql/io-package.json'
      ERROR: process exited with code 20
      Im Verzeichnis "/opt/iobroker/node_modules/iobroker.sql" ist wiederum ein Ordner "node_modules", aber kein File "io-package.json"
      Die Date ist im gesamten Pfad (find . -name io-package.json) nicht zu finden.
      Gruß,
      Eric
      • BluefoxB Offline
        BluefoxB Offline
        @eric2905:
        Nachtrag:
        Gruß,
        Eric `
        cd /opt/iobroker
        iobroker stop sql
        npm install iobroker.sql
        iobroker upload sql
        iobroker start sql
        Welche Einstellungen hast du?
        2995_meross_log.txt
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Im SQL-Adapter sind die Einstellungen wie vor dem Update drin:
          Host: localhost
          Port: 0
          User und Pwd: wie im mySQL definiert
          Den Rest probiere ich nachher, wenn ich zu Hause bin.
          Gruß,
          Eric
          • eric2905E Offline
            eric2905E Offline
            eric2905
            Hi Bluefox,
            hat nichts gebracht - immer noch der Fehler.
            Habe schon DB gedropped und user gelöscht und neu angelegt, usw.
            Erst nachdem ich mySQL komplett deinstalliert und neu installiert habe, funktioniert es wieder.
            Gruß,
            Eric
            • BluefoxB Offline
              BluefoxB Offline
              @eric2905:
              Hi Bluefox,
              Erst nachdem ich mySQL komplett deinstalliert und neu installiert habe, funktioniert es wieder. `
              Komisch… :?
              • H Offline
                Habedere
                Servus,
                stehe eben auch vor dem Problem...
                Habe schon eine neue Instanz installiert und die alten Einstellungen importiert - no way.
                Auch der externe Zugriff vom Lappy auf die Datenbank funzt nicht.
                Jemand noch eine Idee?
                mfg
                PS:
                SQL 1.9.5
                Node.js v8.16.0
                NPM v6.4.1
                PPS:
                sql.0	2019-09-28 21:12:44.467	error	Error: connect ECONNREFUSED 127.0.0.1:3306
                sql.0	2019-09-28 21:12:14.451	error	Error: connect ECONNREFUSED 127.0.0.1:3306
                sql.0	2019-09-28 21:12:14.142	info	starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.sql, node: v8.16.0
                sql.0	2019-09-28 21:12:14.065	info	States connected to redis: 127.0.0.1:6379
                Hab dann in den Einstellungen bei Localhost mal Port 6379 versucht - "Connection Timeout"
                PPPS:
                Für alle die das Problem auch haben - bei mir hat wie folgt geholfen:
                Neustarten von MySQL:
                sudo service mysql restart
