  4. Milight-smart-light Adapter Crasht mit Fehler..
    6.3k
2 Beiträge 2 Kommentatoren 374 Aufrufe
    Mazdaracer121
    Hallo Community. Kann Möglicherweise jemand bei diesem Fehler weiterhelfen?
    Mein Milight adapter crasht leider beim Starten mit Folgendem Log
    host.IoBroker-Chris 2018-10-27 21:31:32.548 info Do not restart adapter system.adapter.milight-smart-light.0 because disabled or deleted
    host.IoBroker-Chris 2018-10-27 21:31:32.548 error instance system.adapter.milight-smart-light.0 terminated with code 3 (Adapter disabled or invalid config)
    milight-smart-light.0 2018-10-27 21:31:32.501 error adapter disabled
    host.IoBroker-Chris 2018-10-27 21:31:14.656 info object change system.adapter.milight-smart-light.0
    host.IoBroker-Chris 2018-10-27 21:31:01.094 info Restart adapter system.adapter.milight-smart-light.0 because enabled
    host.IoBroker-Chris 2018-10-27 21:31:01.094 error instance system.adapter.milight-smart-light.0 terminated with code 0 (OK)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Manager. <anonymous>(C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:244:12)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:319:9)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Socket. <anonymous>(C:\ioBroker\node_modules\iobroker.js-controller\l
    ib\adapter.js:787:25)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at createInstancesObjects (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:748:13)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:788:29
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at initAdapter (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:4990:18)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Adapter.emit (events.js:208:7)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at emitNone (events.js:106:13)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Adapter.adapter.on (C:\ioBroker\node_modules\iobroker.milight-smart-light\main.js:190:3)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at main (C:\ioBroker\node_modules\iobroker.milight-smart-light\main.js:197:21)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at Function.Promise.promisifyAll (C:\ioBroker\node_modules\iobroker.milight-smart-light\node_modules\bluebird\js\release\promisify.js:311:12)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at promisifyAll (C:\ioBroker\node_modules\iobroker.milight-smart-light\node_modules\bluebird\js\release\promisify.js:241:9)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at promisifiableMethods (C:\ioBroker\node_modules\iobroker.milight-smart-light\node_modules\bluebird\js\release\promisify.js:77:5)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: at checkValid (C:\ioBroker\node_modules\iobroker.milight-smart-light\node_modules\bluebird\js\release\promisify.js:54:27)
    Caught 2018-10-27 21:31:01.094 error by controller[0]: See http://goo.gl/MqrFmX
    Caught 2018-10-27 21:31:01.094 error by controller[0]: TypeError: Cannot promisify an API that has normal methods with 'Async'-suffix
    host.IoBroker-Chris 2018-10-27 21:30:59.875 info instance system.adapter.milight-smart-light.0 started with pid 2596
    host.IoBroker-Chris 2018-10-27 21:30:59.875 info "system.adapter.milight-smart-light.0" enabled</anonymous></anonymous>
    Edit by eric2905, Bitte immer CODE- dun gif. auch Spoiler-Tags verwenden.
    • chucky666C Online
      chucky666C Online
      chucky666
      Hallo
      Update auf 0.1.9 vom Github
      Gesendet von iPad mit Tapatalk Pro
