  4. Amazon Dashbutton
    6.3k
Amazon Dashbutton
3 Beiträge 2 Kommentatoren 551 Aufrufe
  • H Offline
    hofmannha
    Hallo Leute,
    ich versuche verzweifelt den Amazon Dashbutton zu installieren.
    Den Adapter habe ich installiert, aber ich kriege keine Instanz installiert.
    Logfile:
    $ ./iobroker add amazon-dash –host raspberry-iobroker
    NPM version: 3.10.10
    npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
    npm
    WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">^
    compilation terminated.
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
    gyp
    ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack at emitTwo (events.js:106:13)
    gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.9.59-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/pcap
    gyp ERR! node -v v6.12.3
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm
    WARN
    babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    npm
    WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    npm ERR! Linux 4.9.59-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--save" "--prefix" "/opt/iobroker"
    npm ERR! node v6.12.3
    npm ERR! npm v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! pcap@2.1.0 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the pcap@2.1.0 install script 'node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR!
    If you do, this is most likely a problem with the pcap package,npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs pcap
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm owner ls pcap
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! /npm-debug.log
    host.raspberry-iobroker install adapter amazon-dash
    npm
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1gyp
    ERR!
    build error
    gyp
    ERR!
    ERR!
    stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp
    gyp ERR!
    stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! node -v v6.12.3gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm
    WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3
    npm ERR!
    npm ERR!
    Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the pcap package,
    npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    npm
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1gyp ERR! build error
    gyp
    ERR! stack
    gyp ERR!
    stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:106:13)
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap
    gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
    npm
    npm ERR!
    npm v3.10.10npm ERR! code ELIFECYCLE
    npm ERR!
    npm ERR! If you do, this is most likely a problem with the pcap package,npm ERR! not with npm itself.
    ERROR: host.raspberry-iobroker Cannot install amazon-dash
    ERROR: process exited with code 13
    Ich hoffe jemand kann damit etwas anfangen.
    hofmannha</pcap></pcap></pcap>
    • ? Offline
      Install libpcap-dev
      sudo apt-get install libpcap-dev
      • H Offline
        hofmannha
        Das kommt bei der Installation heraus:
        Linux raspberry-iobroker 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7 l
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Thu Oct 25 11:49:01 2018 from 192.168.178.35
        root@raspberry-iobroker:~# iobroker stop
        Stopping iobroker controller daemon…
        iobroker controller daemon stopped.
        Exit code for "killall.sh": 123
        root@raspberry-iobroker:~# sudo apt-get install libpcap-dev
        The following additional packages will be installed:
        libpcap0.8 libpcap0.8-dev
        Die folgenden NEUEN Pakete werden installiert:
        libpcap-dev libpcap0.8 libpcap0.8-dev
        0 aktualisiert, 3 neu installiert, 0 zu entfernen und 151 nicht aktualisiert.
        Es müssen noch 0 B von 369 kB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 916 kB Plattenplatz zusätzlich benutzt.
        Möchten Sie fortfahren? [J/n] j
        dpkg: Fehler: Dateitrigger-Datensatz erwähnt ungültigen Paketnamen »systemd/noaw▒a/etc/i~i4.d systemd/noawait« (für Interesse an Datei »/usr/lib/▒ystemd/catq|og«): ungültiger Paketname in Spezifizierer »systemd/noaw▒a/etc/i~i4.d systemd/noawait«: Zeichen »/« nicht erlaubt (nur Buchstaben, Ziffern und die Zeichen »-+._«)
        E: Sub-process /usr/bin/dpkg returned an error code (2)
