  4. [Solved)ZigBee Adapter - Startet nicht korrekt - Ampel bleibt rot
    6.3k
2 Beiträge 1 Kommentatoren 707 Aufrufe
  • J Offline
    Jaro22
    Hi Freunde,
    Ich habe nun meine ersten Gehversuche mit dem IO-Broker.
    Nach erfolgreichem Update + Downgrade der NODE JS Version hatte ich gehofft, dass die Probleme mit dem ZigBee Adapter gelöst sind.
    Leider schlägt er immernoch fehl.
    Hier einmal der Auszug aus dem Log:
    host.ioBroker-RasPi 2018-10-19 12:01:39.396 info Restart adapter system.adapter.zigbee.0 because enabled
    host.ioBroker-RasPi 2018-10-19 12:01:39.396 error instance system.adapter.zigbee.0 terminated with code 1 ()
    Caught 2018-10-19 12:01:39.395 error by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    Caught 2018-10-19 12:01:39.395 error by controller[0]: at Module._compile (module.js:652:30)
    Caught 2018-10-19 12:01:39.395 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
    Caught 2018-10-19 12:01:39.394 error by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
    Caught 2018-10-19 12:01:39.394 error by controller[0]: at require (internal/module.js:11:18)
    Caught 2018-10-19 12:01:39.394 error by controller[0]: at Module.require (module.js:596:17)
    Caught 2018-10-19 12:01:39.394 error by controller[0]: at Function.Module._load (module.js:497:3)
    Caught 2018-10-19 12:01:39.393 error by controller[0]: at tryModuleLoad (module.js:505:12)
    Caught 2018-10-19 12:01:39.393 error by controller[0]: at Module.load (module.js:565:32)
    Caught 2018-10-19 12:01:39.393 error by controller[0]: at Object.Module._extensions..node (module.js:681:18)
    Caught 2018-10-19 12:01:39.392 error by controller[0]: Error: /opt/iobroker/node_modules/serialport/build/Release/serialport.node: file too short
    Caught 2018-10-19 12:01:39.392 error by controller[0]: ^
    Caught 2018-10-19 12:01:39.392 error by controller[0]: throw e
    Caught 2018-10-19 12:01:39.391 error by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88
    host.ioBroker-RasPi 2018-10-19 12:01:37.867 info instance system.adapter.zigbee.0 started with pid 569
    host.ioBroker-RasPi 2018-10-19 12:01:37.838 info "system.adapter.zigbee.0" enabled
    host.ioBroker-RasPi 2018-10-19 12:01:37.836 info object change system.adapter.zigbee.0
    host.ioBroker-RasPi 2018-10-19 12:00:53.830 info object change system.adapter.zigbee.0
    cloud.0 2018-10-19 12:00:20.980 info Connection changed: connect
    cloud.0 2018-10-19 12:00:20.733 info Trying to connect as system.user.admin
    host.ioBroker-RasPi 2018-10-19 12:00:11.721 info Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
    Hardware siehe Signatur.
    Raspberry PI 2 B, CC2531 mit Commander FW,
    Neuster IO-Broker installiert,3.4.7
    Ich habe mir mit folgendem Befehl den richtigen Port gesucht:
    ls -la /dev/serial/by-id
    Die Ergebnisse habe ich dann im Adapter eingefügt.
    Habe nun auch mal einige andere Adapter raus geschmissen, damit ich da ein klares Bild zu habe.
    Wer hat so ein Problem schon einmal gesehen? Woran kann das liegen?
    Vielen Dank und beste Grüße,
    Jaro22</anonymous>
    • J Offline
      Jaro22
      Hab es gelöst- IO Broker nochmal komplett neu installiert,
      Die Nodes bzw. die NPM downgrade gemacht.
      2 mal alles neu komiliert mit reinstall.sh
      Danach geht es auf einmal. :)
      Kann geschlossen werden. Danke
