  4. Node Red Fehler Installation
2 Beiträge 2 Kommentatoren 498 Aufrufe
  • J Offline
    JakeGisbanGin
    Hallo liebe Gemeinde,
    hat jemand eine Idee, was ich tun kann?
    $ ./iobroker add node-red
    NPM version: 4.6.1
    npm install iobroker.node-red --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
    npm
    WARN
    deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
    npm
     WARN deprecated mimelib@0.3.1: This project is unmaintained
    npm
     WARN deprecated mailcomposer@2.1.0: This project is unmaintained
    npm WARN deprecated buildmail@2.0.0: This project is unmaintained
    node-pre-gyp
     ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v2.0.1/bcrypt_lib-v2.0.1-node-v64-linux-arm-glibc.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bcrypt@2.0.1 and node@10.11.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
    ../src/bcrypt_node.cc: In function ‘char {anonymous}::ToCharVersion(v8::Local<v8::string>)’:../src/bcrypt_node.cc:66:30: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value value(str);
    In file included from /home/pi/.node-gyp/10.11.0/include/node/v8.h:26:0,                 from /home/pi/.node-gyp/10.11.0/include/node/node.h:63,
                     from ../node_modules/nan/nan.h:51,
                     from ../src/bcrypt_node.cc:1:
    /home/pi/.node-gyp/10.11.0/include/node/v8.h:2888:28: note: declared here
                       explicit Utf8Value(Local <v8::value>obj));
    /home/pi/.node-gyp/10.11.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    In file included from ../node_modules/nan/nan.h:192:0,                 from ../src/epoll.cc:15:
    ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe <bool>Nan::ForceSet(v8::Local<v8::object>, v8::Local<v8::value>, v8::Local<v8::value>, v8::PropertyAttribute)’:
    ../node_modules/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
       return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
    In file included from ../src/epoll.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’:
    ../node_modules/nan/nan.h:835:60: warning: ‘v8::Local <v8::value>node::MakeCallback(v8::Isolate*, v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, func, argc, argv);
    In file included from ../src/epoll.cc:12:0:
    /home/pi/.node-gyp/10.11.0/include/node/node.h:175:50: note: declared here
                     NODE_EXTERN v8::Local <v8::value>MakeCallback(
    /home/pi/.node-gyp/10.11.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
         __attribute__((deprecated(message))) declarator
    In file included from ../src/epoll.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::string>, int, v8::Local<v8::value>*)’:
    ../node_modules/nan/nan.h:850:62: warning: ‘v8::Local <v8::value>node::MakeCallback(v8::Isolate*, v8::Local<v8::object>, v8::Local<v8::string>, int, v8::Local<v8::value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, symbol, argc, argv);
    /home/pi/.node-gyp/10.11.0/include/node/node.h:168:50: note: declared here
    ../node_modules/nan/nan.h: In function ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, const char*, int, v8::Local<v8::value>*)’:
    ../node_modules/nan/nan.h:865:62: warning: ‘v8::Local <v8::value>node::MakeCallback(v8::Isolate*, v8::Local<v8::object>, const char*, int, v8::Local<v8::value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, method, argc, argv);
    /home/pi/.node-gyp/10.11.0/include/node/node.h:161:50: note: declared here
    In file included from ../src/epoll.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Local <v8::value>Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::object>, int, v8::Local<v8::value>*) const’:
    ../node_modules/nan/nan.h:1479:5: warning: ‘v8::Local <v8::value>node::MakeCallback(v8::Isolate*, v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
    make: *** [Release/obj.target/epoll/src/epoll.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
    gyp ERR! System Linux 4.14.70-v7+
    gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/epoll
    gyp ERR! node -v v10.11.0
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/epoll):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    host.raspi install adapter node-red
    got /opt/iobroker/node_modules/iobroker.node-red/admin
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    host.raspi object system.adapter.node-red created
    host.raspi create instance node-red
    host.raspi object node-red.0 created
    host.raspi object system.adapter.node-red.0.outputCount created
    host.raspi object system.adapter.node-red.0.inputCount created
    host.raspi object system.adapter.node-red.0.uptime created
    host.raspi object system.adapter.node-red.0.memRss created
    host.raspi object system.adapter.node-red.0.memHeapTotal created
    host.raspi object system.adapter.node-red.0.memHeapUsed created
    host.raspi object system.adapter.node-red.0.connected created
    host.raspi object system.adapter.node-red.0.alive created
    host.raspi object system.adapter.node-red.0 created
    process exited with code 0</v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::object></v8::value></v8::value></v8::value></v8::object></v8::value></v8::value></v8::object></v8::value></v8::value></v8::value></v8::string></v8::object></v8::value></v8::value></v8::string></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::object></bool></v8::value></v8::value></v8::string>
    • apollon77A Offline
      Nur eine Warnung bzw Optionale Dependencies … Kein Fehler
