  4. Kein Zugriff nach Total restore
    6.3k
10 Beiträge 2 Kommentatoren 955 Aufrufe
  • J Offline
    Jacke
    Hallo ich habe ein total restore gemacht. Habe aber kein Zugriff auf 8081 und 8082.
    Linux ioBroker-RasPi 4.14.71-v7+ #1145 SMP Fri Sep 21 15:38:35 BST 2018 armv7l
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Mon Oct 15 12:25:19 2018 from 192.168.1.61
    SSH is enabled and the default password for the 'pi' user has not been changed.
    This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
    pi@ioBroker-RasPi:~ $ cd /opt/iobroker
    pi@ioBroker-RasPi:/opt/iobroker $ node node_modules/iobroker.admin/admin.js --logs
    module.js:550
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.admin/admin.js'
        at Function.Module._resolveFilename (module.js:548:15)
        at Function.Module._load (module.js:475:25)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
        at bootstrap_node.js:625:3
    pi@ioBroker-RasPi:/opt/iobroker $ iobroker list instances
    system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    system.adapter.backitup.0              : backitup    -  enabled
    system.adapter.daswetter.0             : daswetter   -  enabled
    system.adapter.denon.0                 : denon       -  enabled
    system.adapter.discovery.0             : discovery   - disabled
    system.adapter.fakeroku.0              : fakeroku    - disabled
    system.adapter.firetv.0                : firetv      - disabled
    system.adapter.flot.0                  : flot        -  enabled
    system.adapter.harmony.0               : harmony     - disabled
    system.adapter.history.0               : history     -  enabled
    system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png -  enabled
    system.adapter.javascript.0            : javascript  -  enabled
    system.adapter.mihome-vacuum.0         : mihome-vacuum -  enabled, port: 54321
    system.adapter.milight.0               : milight     - disabled, port: 5987
    system.adapter.mobile.0                : mobile      - disabled
    system.adapter.ping.0                  : ping        - disabled
    system.adapter.rpi2.0                  : rpi2        - disabled
    system.adapter.s7.0                    : s7          -  enabled
    system.adapter.smartmeter.0            : smartmeter  -  enabled
    system.adapter.smartmeter.1            : smartmeter  -  enabled
    system.adapter.socketio.0              : socketio    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    system.adapter.sql.0                   : sql         - disabled
    system.adapter.vis-bars.0              : vis-bars    -  enabled
    system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges -  enabled
    system.adapter.vis-fancyswitch.0       : vis-fancyswitch -  enabled
    system.adapter.vis-google-fonts.0      : vis-google-fonts -  enabled
    system.adapter.vis-history.0           : vis-history -  enabled
    system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
    system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd -  enabled
    system.adapter.vis-justgage.0          : vis-justgage -  enabled
    system.adapter.vis-lcars.0             : vis-lcars   -  enabled
    system.adapter.vis-metro.0             : vis-metro   -  enabled
    system.adapter.vis-players.0           : vis-players -  enabled
    system.adapter.vis-plumb.0             : vis-plumb   -  enabled
    system.adapter.vis-rgraph.0            : vis-rgraph  -  enabled
    system.adapter.vis-weather.0           : vis-weather -  enabled
    system.adapter.vis.0                   : vis         -  enabled
    system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Ich sehe nicht was fehlt ich stehe da auf dem Schlauch. Habe nach dem restore 3 Std gewartet bevor ich etwas gemacht habe.
    Gesendet von meinem Redmi Note 5 mit Tapatalk
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Nach einem Restore müssen erst alle Adapter nachgeladen und die Instanzen eingerichtet werden - das kann durchaus lange dauern.
      Wie lange hast Du gewartet?
      Gruß,
      Eric
      • J Offline
        Jacke
        Ca 3 Std. Was heißt denn überhaupt gewartet. Zerschießt mann es sich wenn man die Oberfläche aufruft? Das habe ich mach drei Std. Gemacht. Dann bin ich für 5 Std. Schlafen gegangen habe nochmal geschaut und nachdem nichts war habe ich rebootet
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Warum startest Du denn ioBroker so:
          ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201810 ... 3d6b1b.jpg">https://uploads.tapatalk-cdn.com/20181015/4a58fe543aef579e2245928fdc3d6b1b.jpg</link_text>" />
          Normalerweise wird er mit
          iobroker start
          oder
          sudo iobroker start
          gestartet.
          Gruß,
          Eric
          Gesendet von iPhone mit Tapatalk~~
          • J Offline
            Jacke
            Habe 8ch auch gemacht brächte nichts dann habe ich diese Anleitung versucht
            • eric2905E Offline
              eric2905E Offline
              eric2905
              Was hast Du versucht?
              Mit oder ohne sudo?
              Welche Anleitung?
              Und welche Fehler kommen beim normalen Weg?
              Bitte etwas mehr Infos ….
              Gruß,
              Eric
              • J Offline
                Jacke
                Ich habe das hier versucht
                http://www.iobroker.net/docu/?page_id=3928&lang=de
                iobroker Start mit und ohne sudo us dem verzeichnis heraus. Er zeigt mir auch dann eine pid sieht also alles ok aus.
                • J Offline
                  Jacke
                  So habe neu augesetzt dann root backup eingespielt und weder unter 8081 noch unter 8082 was zu erreichen
                  pi@ioBroker-RasPi:~ $ ps -A | grep iobroker
                   1006 ?        00:00:12 iobroker.js-con
                  pi@ioBroker-RasPi:/opt/iobroker $ netstat -n -a -p TCP
                  (Es konnten nicht alle Prozesse identifiziert werden; Informationen über
                  nicht-eigene Processe werden nicht angezeigt; Root kann sie anzeigen.)
                  Aktive Internetverbindungen (Server und stehende Verbindungen)
                  Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      -
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      -
                  tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      -
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
                  tcp        0    272 192.168.1.43:22         192.168.1.23:57198      VERBUNDEN   -
                  tcp6       0      0 :::22                   :::*                    LISTEN      -
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           -
                  udp        0      0 0.0.0.0:50005           0.0.0.0:*                           -
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           -
                  udp        0      0 0.0.0.0:46703           0.0.0.0:*                           -
                  udp6       0      0 :::5353                 :::*                                -
                  udp6       0      0 :::49592                :::*                                -
                  raw6       0      0 :::58                   :::*                    7           -
                  Aktive Sockets in der UNIX-Domäne (Server und stehende Verbindungen)
                  Proto RefCnt Flags       Type       State         I-Node   PID/Program name     Pfad
                  unix  2      [ ]         DGRAM                    12079    815/systemd          /run/user/1000/systemd/notify
                  unix  2      [ ACC ]     STREAM     HÖRT         12083    815/systemd          /run/user/1000/systemd/private
                  unix  2      [ ACC ]     STREAM     HÖRT         7990     -                    /run/thd.socket
                  unix  2      [ ACC ]     STREAM     HÖRT         12088    815/systemd          /run/user/1000/gnupg/S.gpg-agent.extra
                  unix  2      [ ACC ]     STREAM     HÖRT         7992     -                    /var/run/avahi-daemon/socket
                  unix  2      [ ACC ]     STREAM     HÖRT         12091    815/systemd          /run/user/1000/gnupg/S.gpg-agent.browser
                  unix  2      [ ACC ]     STREAM     HÖRT         7995     -                    /var/run/dbus/system_bus_socket
                  unix  2      [ ACC ]     STREAM     HÖRT         12093    815/systemd          /run/user/1000/gnupg/S.gpg-agent.ssh
                  unix  2      [ ACC ]     STREAM     HÖRT         12095    815/systemd          /run/user/1000/gnupg/S.gpg-agent
                  unix  2      [ ACC ]     STREAM     HÖRT         11127    -                    /var/run/dhcpcd.sock
                  unix  2      [ ACC ]     STREAM     HÖRT         11129    -                    /var/run/dhcpcd.unpriv.sock
                  unix  3      [ ]         DGRAM                    7311     -                    /run/systemd/notify
                  unix  2      [ ]         DGRAM                    7313     -                    /run/systemd/cgroups-agent
                  unix  2      [ ACC ]     STREAM     HÖRT         7317     -                    /run/systemd/private
                  unix  8      [ ]         DGRAM                    7324     -                    /run/systemd/journal/dev-log
                  unix  2      [ ACC ]     SEQPAKET   HÖRT         7330     -                    /run/udev/control
                  unix  2      [ ACC ]     STREAM     HÖRT         7336     -                    /run/systemd/journal/stdout
                  unix  7      [ ]         DGRAM                    7338     -                    /run/systemd/journal/socket
                  unix  2      [ ACC ]     STREAM     HÖRT         7340     -                    /run/systemd/fsck.progress
                  unix  2      [ ]         DGRAM                    7347     -                    /run/systemd/journal/syslog
                  unix  2      [ ]         DGRAM                    11203    -                    /var/run/wpa_supplicant/wlan0
                  unix  2      [ ]         DGRAM                    11208    -                    /var/run/wpa_supplicant/p2p-dev-wlan0
                  unix  3      [ ]         STREAM     VERBUNDEN     16536    -
                  unix  3      [ ]         DGRAM                    577      -
                  unix  3      [ ]         DGRAM                    578      -
                  unix  3      [ ]         DGRAM                    576      -
                  unix  3      [ ]         STREAM     VERBUNDEN     16535    -
                  unix  2      [ ]         DGRAM                    570      -
                  unix  3      [ ]         STREAM     VERBUNDEN     634      -
                  unix  2      [ ]         DGRAM                    222      -
                  unix  2      [ ]         DGRAM                    16525    -
                  unix  3      [ ]         DGRAM                    579      -
                  unix  3      [ ]         STREAM     VERBUNDEN     9592     -                    /run/systemd/journal/stdout
                  unix  3      [ ]         STREAM     VERBUNDEN     682      -
                  unix  3      [ ]         STREAM     VERBUNDEN     9588     -                    /run/systemd/journal/stdout
                  unix  2      [ ]         DGRAM                    8071     -
                  unix  3      [ ]         STREAM     VERBUNDEN     8074     -
                  unix  3      [ ]         STREAM     VERBUNDEN     8075     -
                  unix  3      [ ]         STREAM     VERBUNDEN     11352    -
                  unix  3      [ ]         STREAM     VERBUNDEN     11217    -                    /run/systemd/journal/stdout
                  unix  3      [ ]         DGRAM                    7315     -
                  unix  3      [ ]         DGRAM                    7316     -
                  unix  3      [ ]         STREAM     VERBUNDEN     11223    -                    /var/run/dbus/system_bus_socket
                  unix  3      [ ]         STREAM     VERBUNDEN     9649     -                    /run/systemd/journal/stdout
                  unix  3      [ ]         STREAM     VERBUNDEN     11357    -
                  unix  3      [ ]         STREAM     VERBUNDEN     7491     -                    /run/systemd/journal/stdout
                  unix  3      [ ]         STREAM     VERBUNDEN     8048     -
                  unix  2      [ ]         DGRAM                    11355    -
                  unix  3      [ ]         STREAM     VERBUNDEN     756      -                    /var/run/dbus/system_bus_socket
                  unix  3      [ ]         STREAM     VERBUNDEN     7489     -
                  unix  3      [ ]         STREAM     VERBUNDEN     8079     -
                  unix  3      [ ]         DGRAM                    12081    815/systemd
                  unix  3      [ ]         STREAM     VERBUNDEN     8082     -                    /run/systemd/journal/stdout
                  unix  2      [ ]         DGRAM                    2031     -
                  unix  2      [ ]         DGRAM                    9838     -
                  unix  3      [ ]         STREAM     VERBUNDEN     753      -
                  unix  3      [ ]         STREAM     VERBUNDEN     752      -
                  unix  2      [ ]         DGRAM                    1936     -
                  unix  3      [ ]         DGRAM                    12082    815/systemd
                  unix  3      [ ]         STREAM     VERBUNDEN     755      -                    /var/run/dbus/system_bus_socket
                  unix  3      [ ]         STREAM     VERBUNDEN     740      -
                  unix  3      [ ]         STREAM     VERBUNDEN     13018    -                    /run/systemd/journal/stdout
                  unix  2      [ ]         DGRAM                    12067    815/systemd
                  unix  3      [ ]         STREAM     VERBUNDEN     10116    -
                  unix  2      [ ]         DGRAM                    12064    -
                  unix  2      [ ]         DGRAM                    927      -
                  unix  3      [ ]         STREAM     VERBUNDEN     9719     -
                  unix  3      [ ]         STREAM     VERBUNDEN     12060    815/systemd
                  unix  3      [ ]         STREAM     VERBUNDEN     12458    -                    /run/systemd/journal/stdout
                  unix  2      [ ]         DGRAM                    733      -
                  unix  3      [ ]         STREAM     VERBUNDEN     754      -                    /var/run/dbus/system_bus_socket
                  unix  3      [ ]         STREAM     VERBUNDEN     11111    -
                  unix  3      [ ]         STREAM     VERBUNDEN     7972     -                    /run/systemd/journal/stdout
                  unix  3      [ ]         DGRAM                    8473     -
                  unix  3      [ ]         STREAM     VERBUNDEN     583      -                    /run/systemd/journal/stdout
                  unix  3      [ ]         DGRAM                    8474     -
                  unix  3      [ ]         STREAM     VERBUNDEN     11007    -
                  unix  2      [ ]         DGRAM                    11132    -
                  unix  3      [ ]         STREAM     VERBUNDEN     10922    -
                  pi@ioBroker-RasPi:/opt/iobroker $ node -v
                  v8.11.1
                  pi@ioBroker-RasPi:/opt/iobroker $ npm -v
                  5.8.0
                  pi@ioBroker-RasPi:/opt/iobroker $ ^C
                  • J Offline
                    Jacke
                    wenn ich das eingebe
                    cd /opt/iobroker
                    cat log/iobroker.JJJJ-MM-TT.log
                    bekomme ich diese ausgabe
                    2018-10-15 20:31:12.238  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:12.238  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:12.239  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:12.239  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:12.240  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:12.240  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:12.240  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:12.241  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:12.241  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:12.241  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:12.242  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:12.242  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:12.242  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:12.243  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:12.243  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:12.243  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:12.244  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:12.244  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:12.244  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:12.245  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:12.245  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:12.245  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:12.246  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:31:18.244  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:18.245  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:18.245  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:18.246  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:18.246  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:18.246  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:18.247  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:18.247  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:18.247  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:18.248  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:18.248  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:18.248  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:18.249  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:18.249  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:18.249  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:18.250  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:18.250  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:18.250  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:18.251  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:18.251  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:18.251  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:18.252  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:18.252  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:31:24.250  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:24.251  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:24.252  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:24.252  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:24.252  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:24.253  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:24.253  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:24.253  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:24.254  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:24.254  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:24.254  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:24.255  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:24.255  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:24.255  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:24.256  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:24.256  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:24.256  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:24.257  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:24.257  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:24.257  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:24.258  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:24.258  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:24.258  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:31:30.257  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:30.257  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:30.258  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:30.258  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:30.259  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:30.259  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:30.259  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:30.260  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:30.260  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:30.260  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:30.262  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:30.262  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:30.263  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:30.263  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:30.264  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:30.264  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:30.264  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:30.265  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:30.265  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:30.265  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:30.266  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:30.266  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:30.266  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:31:36.263  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:36.264  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:36.264  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:36.265  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:36.265  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:36.265  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:36.266  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:36.266  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:36.266  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:36.267  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:36.267  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:36.267  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:36.268  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:36.268  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:36.268  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:36.269  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:36.269  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:36.269  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:36.270  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:36.270  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:36.270  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:36.271  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:36.271  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:31:42.269  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:42.270  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:42.271  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:42.271  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:42.271  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:42.272  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:42.272  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:42.272  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:42.273  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:42.273  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:42.273  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:42.274  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:42.274  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:42.274  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:42.275  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:42.275  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:42.275  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:42.276  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:42.276  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:42.276  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:42.277  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:42.277  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:42.277  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:31:48.276  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:48.277  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:48.277  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:48.277  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:48.278  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:48.278  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:48.278  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:48.279  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:48.279  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:48.279  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:48.280  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:48.280  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:48.280  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:48.281  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:48.285  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:48.285  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:48.286  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:48.286  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:48.286  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:48.287  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:48.287  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:48.287  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:48.288  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:31:54.282  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:31:54.283  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:31:54.283  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:31:54.284  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:31:54.284  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:31:54.284  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:31:54.285  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:31:54.285  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:31:54.285  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:31:54.286  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:31:54.286  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:31:54.286  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:31:54.287  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:31:54.287  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:31:54.287  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:31:54.288  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:31:54.288  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:31:54.288  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:31:54.289  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:31:54.289  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:31:54.289  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:31:54.290  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:31:54.290  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:00.288  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:00.289  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:00.290  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:00.290  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:00.290  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:00.291  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:00.291  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:00.291  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:00.292  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:00.292  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:00.292  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:00.293  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:00.293  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:00.293  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:00.294  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:00.294  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:00.294  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:00.295  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:00.295  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:00.295  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:00.296  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:00.296  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:00.296  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:06.295  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:06.296  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:06.296  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:06.296  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:06.297  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:06.297  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:06.297  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:06.298  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:06.298  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:06.298  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:06.299  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:06.299  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:06.299  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:06.300  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:06.300  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:06.301  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:06.301  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:06.301  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:06.302  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:06.302  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:06.302  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:06.303  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:06.303  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:12.301  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:12.302  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:12.302  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:12.303  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:12.303  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:12.303  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:12.304  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:12.304  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:12.304  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:12.305  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:12.305  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:12.305  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:12.306  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:12.306  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:12.306  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:12.307  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:12.307  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:12.307  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:12.308  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:12.308  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:12.308  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:12.309  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:12.309  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:18.308  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:18.308  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:18.309  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:18.309  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:18.309  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:18.310  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:18.310  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:18.311  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:18.311  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:18.311  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:18.312  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:18.312  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:18.312  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:18.313  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:18.313  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:18.313  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:18.314  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:18.314  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:18.314  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:18.315  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:18.315  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:18.315  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:18.316  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:24.314  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:24.315  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:24.315  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:24.315  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:24.316  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:24.316  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:24.316  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:24.317  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:24.317  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:24.317  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:24.318  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:24.318  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:24.318  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:24.319  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:24.319  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:24.319  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:24.320  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:24.320  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:24.321  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:24.321  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:24.321  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:24.322  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:24.322  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:30.320  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:30.321  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:30.321  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:30.322  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:30.322  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:30.322  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:30.323  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:30.323  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:30.323  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:30.324  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:30.324  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:30.324  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:30.325  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:30.325  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:30.326  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:30.326  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:30.326  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:30.327  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:30.327  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:30.327  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:30.328  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:30.328  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:30.328  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:36.326  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:36.327  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:36.328  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:36.328  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:36.329  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:36.329  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:36.329  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:36.330  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:36.330  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:36.330  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:36.337  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:36.338  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:36.338  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:36.339  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:36.339  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:36.340  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:36.340  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:36.340  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:36.341  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:36.341  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:36.341  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:36.342  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:36.342  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:42.333  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:42.334  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:42.334  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:42.334  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:42.335  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:42.335  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:42.335  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:42.336  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:42.336  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:42.336  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:42.337  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:42.337  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:42.337  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:42.338  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:42.338  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:42.338  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:42.338  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:42.339  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:42.339  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:42.339  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:42.340  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:42.340  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:42.340  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:48.339  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:48.340  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:48.340  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:48.341  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:48.341  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:48.341  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:48.342  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:48.342  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:48.342  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:48.343  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:48.343  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:48.343  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:48.344  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:48.344  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:48.344  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:48.345  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:48.345  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:48.345  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:48.345  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:48.346  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:48.346  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:48.346  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:48.347  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:32:54.345  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:32:54.346  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:32:54.347  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:32:54.347  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:32:54.347  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:32:54.348  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:32:54.348  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:32:54.348  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:32:54.349  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:32:54.349  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:32:54.349  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:32:54.350  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:32:54.350  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:32:54.350  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:32:54.351  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:32:54.351  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:32:54.351  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:32:54.352  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:32:54.352  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:32:54.352  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:32:54.352  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:32:54.353  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:32:54.353  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:00.352  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:00.353  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:00.353  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:00.354  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:00.354  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:00.354  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:00.354  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:00.355  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:00.355  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:00.355  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:00.356  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:00.356  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:00.356  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:00.357  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:00.357  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:00.357  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:00.358  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:00.358  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:00.358  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:00.359  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:00.359  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:00.359  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:00.359  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:06.358  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:06.359  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:06.360  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:06.360  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:06.360  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:06.361  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:06.361  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:06.361  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:06.362  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:06.362  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:06.362  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:06.363  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:06.363  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:06.363  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:06.364  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:06.364  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:06.364  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:06.364  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:06.365  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:06.365  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:06.365  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:06.366  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:06.366  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:12.365  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:12.365  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:12.366  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:12.366  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:12.367  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:12.367  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:12.367  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:12.368  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:12.368  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:12.368  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:12.369  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:12.369  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:12.369  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:12.370  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:12.370  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:12.370  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:12.371  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:12.371  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:12.371  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:12.372  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:12.372  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:12.372  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:12.373  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:18.371  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:18.372  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:18.372  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:18.372  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:18.373  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:18.373  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:18.373  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:18.374  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:18.374  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:18.374  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:18.375  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:18.375  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:18.375  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:18.376  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:18.376  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:18.376  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:18.376  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:18.377  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:18.377  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:18.377  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:18.378  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:18.378  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:18.378  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:24.377  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:24.378  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:24.379  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:24.379  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:24.379  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:24.379  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:24.380  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:24.380  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:24.381  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:24.381  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:24.381  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:24.381  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:24.382  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:24.382  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:24.382  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:24.383  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:24.383  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:24.383  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:24.384  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:24.384  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:24.384  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:24.385  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:24.385  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:30.384  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:30.384  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:30.385  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:30.385  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:30.386  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:30.386  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:30.386  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:30.386  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:30.387  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:30.387  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:30.387  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:30.388  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:30.388  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:30.388  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:30.389  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:30.389  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:30.389  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:30.390  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:30.390  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:30.390  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:30.391  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:30.391  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:30.391  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:36.390  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:36.391  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:36.391  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:36.392  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:36.392  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:36.392  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:36.393  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:36.393  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:36.393  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:36.393  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:36.394  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:36.394  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:36.394  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:36.395  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:36.395  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:36.395  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:36.396  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:36.396  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:36.396  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:36.397  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:36.397  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:36.397  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:36.397  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:42.396  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:42.397  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:42.398  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:42.398  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:42.398  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:42.398  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:42.399  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:42.399  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:42.399  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:42.400  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:42.400  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:42.400  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:42.401  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:42.401  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:42.401  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:42.402  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:42.402  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:42.402  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:42.403  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:42.403  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:42.403  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:42.404  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:42.404  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:48.403  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:48.404  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:48.404  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:48.404  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:48.405  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:48.405  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:48.405  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:48.406  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:48.406  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:48.406  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:48.407  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:48.407  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:48.407  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:48.408  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:48.408  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:48.408  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:48.408  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:48.409  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:48.409  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:48.409  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:48.410  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:48.410  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:48.410  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:33:54.409  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:33:54.410  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:33:54.410  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:33:54.411  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:33:54.411  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:33:54.411  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:33:54.412  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:33:54.412  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:33:54.412  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:33:54.412  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:33:54.413  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:33:54.413  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:33:54.413  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:33:54.414  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:33:54.414  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:33:54.414  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:33:54.415  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:33:54.418  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:33:54.418  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:33:54.419  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:33:54.419  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:33:54.419  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:33:54.419  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:00.415  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:00.416  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:00.417  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:00.417  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:00.417  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:00.418  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:00.418  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:00.418  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:00.419  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:00.419  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:00.419  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:00.420  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:00.420  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:00.420  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:00.421  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:00.421  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:00.421  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:00.422  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:00.422  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:00.422  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:00.422  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:00.423  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:00.423  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:06.422  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:06.422  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:06.423  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:06.423  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:06.423  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:06.424  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:06.424  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:06.424  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:06.425  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:06.425  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:06.425  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:06.426  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:06.426  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:06.426  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:06.427  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:06.427  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:06.427  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:06.428  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:06.428  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:06.428  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:06.428  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:06.429  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:06.429  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:12.428  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:12.429  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:12.430  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:12.430  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:12.430  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:12.431  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:12.431  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:12.431  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:12.432  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:12.432  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:12.432  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:12.433  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:12.433  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:12.433  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:12.433  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:12.434  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:12.434  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:12.434  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:12.435  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:12.435  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:12.435  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:12.436  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:12.436  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:18.434  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:18.435  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:18.436  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:18.436  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:18.436  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:18.437  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:18.437  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:18.437  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:18.438  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:18.438  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:18.438  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:18.438  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:18.439  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:18.439  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:18.439  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:18.440  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:18.440  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:18.440  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:18.441  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:18.441  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:18.441  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:18.442  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:18.442  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:24.441  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:24.442  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:24.442  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:24.443  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:24.443  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:24.443  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:24.444  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:24.444  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:24.444  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:24.445  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:24.445  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:24.446  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:24.446  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:24.446  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:24.447  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:24.447  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:24.447  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:24.448  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:24.448  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:24.448  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:24.449  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:24.449  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:24.449  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:30.447  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:30.448  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:30.448  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:30.449  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:30.449  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:30.449  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:30.450  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:30.450  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:30.450  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:30.451  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:30.451  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:30.451  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:30.452  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:30.452  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:30.452  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:30.453  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:30.453  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:30.453  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:30.454  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:30.454  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:30.454  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:30.454  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:30.455  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:36.454  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:36.454  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:36.455  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:36.455  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:36.455  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:36.456  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:36.456  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:36.456  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:36.457  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:36.457  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:36.457  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:36.458  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:36.458  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:36.458  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:36.459  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:36.459  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:36.459  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:36.459  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:36.460  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:36.460  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:36.460  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:36.461  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:36.461  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:42.460  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:42.461  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:42.461  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:42.462  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:42.462  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:42.462  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:42.463  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:42.463  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:42.463  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:42.464  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:42.464  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:42.464  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:42.464  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:42.465  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:42.465  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:42.465  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:42.466  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:42.466  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:42.466  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:42.467  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:42.467  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:42.467  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:42.468  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:48.466  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:48.467  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:48.468  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:48.468  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:48.468  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:48.468  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:48.469  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:48.469  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:48.469  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:48.470  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:48.470  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:48.470  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:48.471  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:48.471  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:48.471  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:48.472  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:48.472  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:48.472  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:48.473  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:48.473  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:48.473  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:48.474  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:48.474  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:34:54.472  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:34:54.473  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:34:54.474  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:34:54.474  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:34:54.474  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:34:54.475  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:34:54.475  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:34:54.475  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:34:54.476  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:34:54.476  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:34:54.476  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:34:54.477  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:34:54.477  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:34:54.477  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:34:54.477  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:34:54.478  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:34:54.478  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:34:54.478  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:34:54.479  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:34:54.479  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:34:54.479  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:34:54.480  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:34:54.480  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:35:00.479  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:35:00.480  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:35:00.480  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:35:00.481  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:35:00.481  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:35:00.481  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:35:00.482  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:35:00.482  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:35:00.482  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:35:00.483  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:35:00.483  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:35:00.483  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:35:00.484  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:35:00.484  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:35:00.484  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:35:00.485  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:35:00.485  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:35:00.485  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:35:00.485  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:35:00.486  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:35:00.486  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:35:00.486  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:35:00.487  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:35:06.485  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:35:06.486  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:35:06.487  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:35:06.487  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:35:06.487  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:35:06.487  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:35:06.488  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:35:06.488  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:35:06.488  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:35:06.489  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:35:06.489  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:35:06.489  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:35:06.490  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:35:06.490  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:35:06.490  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:35:06.491  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:35:06.491  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:35:06.491  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:35:06.492  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:35:06.492  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:35:06.492  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:35:06.492  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:35:06.493  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:35:12.491  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:35:12.491  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:35:12.492  - warn: host.ioBroker-RasPi stopInstance system.adapter.admin.0 not running
                    2018-10-15 20:35:12.492  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:35:12.492  - warn: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 not running
                    2018-10-15 20:35:12.493  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:35:12.493  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:35:12.493  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:35:12.494  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:35:12.494  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:35:12.494  - warn: host.ioBroker-RasPi stopInstance system.adapter.web.0 not running
                    2018-10-15 20:35:12.495  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:35:12.495  - warn: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 not running
                    2018-10-15 20:35:12.495  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:35:12.496  - warn: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 not running
                    2018-10-15 20:35:12.496  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:35:12.496  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:35:12.496  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:35:12.497  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:35:12.497  - warn: host.ioBroker-RasPi stopInstance system.adapter.history.0 not running
                    2018-10-15 20:35:12.497  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:35:12.498  - warn: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 not running
                    2018-10-15 20:35:12.498  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:35:34.966  - info: host.ioBroker-RasPi iobroker.js-controller version 1.4.0 js-controller starting
                    2018-10-15 20:35:34.980  - info: host.ioBroker-RasPi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                    2018-10-15 20:35:34.981  - info: host.ioBroker-RasPi hostname: ioBroker-RasPi, node: v8.11.1
                    2018-10-15 20:35:34.990  - info: host.ioBroker-RasPi ip addresses: 192.168.1.43 fe80::da8d:3ca0:f510:e5b1
                    2018-10-15 20:35:35.690  - info: host.ioBroker-RasPi  inMem-objects listening on port 9001
                    2018-10-15 20:35:35.734  - info: host.ioBroker-RasPi InMemoryDB connected
                    2018-10-15 20:35:35.769  - info: host.ioBroker-RasPi 13 instances found
                    2018-10-15 20:35:35.811  - info: host.ioBroker-RasPi starting 8 instances
                    2018-10-15 20:35:35.938  - info: host.ioBroker-RasPi instance system.adapter.admin.0 started with pid 538
                    2018-10-15 20:35:35.972  - info: host.ioBroker-RasPi States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:35:39.851  - info: host.ioBroker-RasPi instance system.adapter.discovery.0 started with pid 545
                    2018-10-15 20:35:44.053  - info: host.ioBroker-RasPi instance system.adapter.web.0 started with pid 551
                    2018-10-15 20:35:44.499  - info: admin.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:35:44.733  - info: admin.0 starting. Version 3.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                    2018-10-15 20:35:44.804  - info: admin.0 requesting all states
                    2018-10-15 20:35:44.811  - info: admin.0 requesting all objects
                    2018-10-15 20:35:45.961  - info: admin.0 received all states
                    2018-10-15 20:35:46.599  - info: discovery.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:35:46.774  - info: discovery.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.11.1
                    2018-10-15 20:35:47.842  - info: host.ioBroker-RasPi instance system.adapter.rpi2.0 started with pid 565
                    2018-10-15 20:35:48.068  - info: web.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:35:48.171  - info: web.0 starting. Version 2.1.9 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
                    2018-10-15 20:35:48.987  - info: admin.0 received all objects
                    2018-10-15 20:36:11.300  - info: admin.0 http server listening on port 8081
                    2018-10-15 20:36:11.301  - info: admin.0 Use link "http://localhost:8081" to configure.
                    2018-10-15 20:36:11.675  - info: web.0 socket.io server listening on port 8082
                    2018-10-15 20:36:11.802  - info: admin.0 Request actual repository...
                    2018-10-15 20:36:11.683  - info: web.0 http server listening on port 8082
                    2018-10-15 20:36:11.951  - info: host.ioBroker-RasPi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                    2018-10-15 20:36:13.373  - info: host.ioBroker-RasPi instance system.adapter.socketio.0 started with pid 576
                    2018-10-15 20:36:13.363  - info: rpi2.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:36:13.478  - info: rpi2.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v8.11.1
                    2018-10-15 20:36:15.020  - info: admin.0 Repository received successfully.
                    2018-10-15 20:36:16.307  - info: socketio.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:36:16.414  - info: socketio.0 starting. Version 1.8.6 in /opt/iobroker/node_modules/iobroker.socketio, node: v8.11.1
                    2018-10-15 20:36:16.550  - info: socketio.0 socket.io server listening on port 8084
                    2018-10-15 20:36:21.860  - info: host.ioBroker-RasPi instance system.adapter.history.0 started with pid 646
                    2018-10-15 20:36:22.347  - info: vis.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:36:22.474  - info: vis.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
                    2018-10-15 20:36:22.487  - error: vis.0 No license found for vis. Please get one on https://iobroker.net !
                    2018-10-15 20:36:23.681  - info: host.ioBroker-RasPi instance system.adapter.vis.0 terminated while should be started once
                    2018-10-15 20:36:24.131  - info: history.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:36:24.229  - info: history.0 starting. Version 1.7.3 in /opt/iobroker/node_modules/iobroker.history, node: v8.11.1
                    2018-10-15 20:36:25.326  - info: host.ioBroker-RasPi instance system.adapter.javascript.0 started with pid 660
                    2018-10-15 20:36:33.943  - info: javascript.0 States connected to redis: 127.0.0.1:6379
                    2018-10-15 20:36:34.049  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
                    2018-10-15 20:36:34.072  - info: javascript.0 requesting all states
                    2018-10-15 20:36:34.078  - info: javascript.0 requesting all objects
                    2018-10-15 20:36:34.727  - info: javascript.0 received all states
                    2018-10-15 20:36:37.106  - info: javascript.0 received all objects
                    2018-10-15 20:37:13.772  - info: discovery.0 Found 1 addresses
                    2018-10-15 20:37:14.622  - warn: discovery.0 Mihome err: timeout
                    2018-10-15 20:37:15.116  - warn: discovery.0 MAX! Cube err: timeout
                    2018-10-15 20:37:15.624  - warn: discovery.0 LG TV ERR: timeout
                    2018-10-15 20:37:15.667  - info: discovery.0 Discovery finished. Found new or modified 0 instances
                    2018-10-15 20:37:15.695  - info: discovery.0 Discovery finished
                    2018-10-15 20:39:40.036  - info: host.ioBroker-RasPi received SIGTERM
                    2018-10-15 20:39:40.050  - info: admin.0 terminating http server on port 8081
                    2018-10-15 20:39:40.056  - info: discovery.0 terminating
                    2018-10-15 20:39:40.058  - info: admin.0 terminating
                    2018-10-15 20:39:40.062  - info: web.0 terminating http server on port 8082
                    2018-10-15 20:39:40.070  - info: socketio.0 terminating http server on port 8084
                    2018-10-15 20:39:40.043  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0
                    2018-10-15 20:39:40.044  - info: host.ioBroker-RasPi stopInstance system.adapter.admin.0 killing pid 538
                    2018-10-15 20:39:40.046  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0
                    2018-10-15 20:39:40.047  - info: host.ioBroker-RasPi stopInstance system.adapter.discovery.0 killing pid 545
                    2018-10-15 20:39:40.047  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0
                    2018-10-15 20:39:40.048  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rpc.0 not running
                    2018-10-15 20:39:40.049  - info: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0
                    2018-10-15 20:39:40.049  - warn: host.ioBroker-RasPi stopInstance system.adapter.hm-rega.0 not running
                    2018-10-15 20:39:40.050  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0
                    2018-10-15 20:39:40.051  - info: host.ioBroker-RasPi stopInstance system.adapter.web.0 killing pid 551
                    2018-10-15 20:39:40.059  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0
                    2018-10-15 20:39:40.060  - info: host.ioBroker-RasPi stopInstance system.adapter.rpi2.0 killing pid 565
                    2018-10-15 20:39:40.061  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0
                    2018-10-15 20:39:40.062  - info: host.ioBroker-RasPi stopInstance system.adapter.socketio.0 killing pid 576
                    2018-10-15 20:39:40.063  - info: host.ioBroker-RasPi stopInstance system.adapter.cloud.0
                    2018-10-15 20:39:40.063  - warn: host.ioBroker-RasPi stopInstance system.adapter.cloud.0 not running
                    2018-10-15 20:39:40.064  - info: host.ioBroker-RasPi stopInstance system.adapter.vis.0
                    2018-10-15 20:39:40.065  - info: host.ioBroker-RasPi stopInstance system.adapter.history.0
                    2018-10-15 20:39:40.067  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
                    2018-10-15 20:39:40.068  - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 killing pid 660
                    2018-10-15 20:39:40.069  - info: host.ioBroker-RasPi stopInstance system.adapter.mobile.0
                    2018-10-15 20:39:40.078  - info: javascript.0 terminating
                    2018-10-15 20:39:40.064  - info: web.0 terminated http server on port 8082
                    2018-10-15 20:39:40.083  - info: rpi2.0 terminating
                    2018-10-15 20:39:40.090  - info: web.0 terminating
                    2018-10-15 20:39:40.098  - info: socketio.0 terminating
                    2018-10-15 20:39:40.101  - info: host.ioBroker-RasPi instance system.adapter.discovery.0 terminated with code 0 (OK)
                    2018-10-15 20:39:40.137  - info: host.ioBroker-RasPi instance system.adapter.admin.0 terminated with code 0 (OK)
                    2018-10-15 20:39:40.142  - info: host.ioBroker-RasPi instance system.adapter.socketio.0 terminated with code 0 (OK)
                    2018-10-15 20:39:40.147  - info: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 0 (OK)
                    2018-10-15 20:39:40.152  - info: host.ioBroker-RasPi instance system.adapter.web.0 terminated with code 0 (OK)
                    2018-10-15 20:39:40.156  - info: host.ioBroker-RasPi instance system.adapter.rpi2.0 terminated with code 0 (OK)
                    2018-10-15 20:39:40.320  - info: host.ioBroker-RasPi instance system.adapter.history.0 terminated with code 0 (OK)
                    2018-10-15 20:39:40.321  - info: host.ioBroker-RasPi All instances are stopped.
                    2018-10-15 20:39:40.479  - info: host.ioBroker-RasPi terminated
                    2018-10-15 21:22:32.296  - info: host.ioBroker-RasPi iobroker.js-controller version 1.4.2 js-controller starting
                    2018-10-15 21:22:32.310  - info: host.ioBroker-RasPi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                    2018-10-15 21:22:32.311  - info: host.ioBroker-RasPi hostname: ioBroker-RasPi, node: v8.11.1
                    2018-10-15 21:22:32.320  - info: host.ioBroker-RasPi ip addresses: 192.168.1.43 fe80::da8d:3ca0:f510:e5b1
                    2018-10-15 21:22:32.604  - info: host.ioBroker-RasPi  inMem-states listening on port 9000
                    2018-10-15 21:22:33.455  - info: host.ioBroker-RasPi  inMem-objects listening on port 9001
                    2018-10-15 21:22:33.489  - info: host.ioBroker-RasPi InMemoryDB connected
                    2018-10-15 21:22:33.517  - warn: Host on this system is not possible, because IP address is for states is 0.0.0.0
                    2018-10-15 21:22:33.557  - info: host.ioBroker-RasPi 39 instances found
                    2018-10-15 21:22:33.578  - warn: host.ioBroker-RasPi does not start any instances on this host
                    2018-10-15 21:22:33.678  - warn: host.ioBroker-RasPi multihost service started on 0.0.0.0:50005
                    pi@ioBroker-RasPi:/opt/iobroker $
                    • J Offline
                      Jacke
                      kann es hieran liegen
                      sudo iobroker multihost disable
                      Miltihost deactivated.
                      Please restart ioBroker: "iobroker restart"
                      Miltihost:      disabled
                      Authentication: enabled
                      Objects:        file on 0.0.0.0
                      States:         file on 0.0.0.0
                      pi@ioBroker-RasPi:/opt/iobroker $ iobroker restart
                      iobroker controller daemon is not running
                      Starting iobroker controller daemon...
                      iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
                      Error: Failed to write pidfile (EACCES)
                      pi@ioBroker-RasPi:/opt/iobroker $ iobroker controller daemon is not running^C
                      pi@ioBroker-RasPi:/opt/iobroker $ ^C
                      pi@ioBroker-RasPi:/opt/iobroker $ iobroker status
                      iobroker is running
                      pi@ioBroker-RasPi:/opt/iobroker $ ps -A | grep iobroker
                       1006 ?        00:00:14 iobroker.js-con
