  4. Sonos radio favoriten
    5.4k
1 Beiträge 1 Kommentatoren 524 Aufrufe
    ticket
    Hallo, habe mal ni frage, ich sitze schon ewig dabei meine radiosender (favoriten ) zum laufen zu bekommen.klappt einfach nicht. hier mal n auszug vom log. vielleicht kann ja einer helfen. m.f.g.
    2018-09-12 19:02:11.308 - info: javascript.0 script.js.common.Skript1: Neuer Sonos Sender über VIS eingestellt: Blue Note 101
    2018-09-12 19:02:11.349 - error: sonos.0 Cannot replaceWithFavorite: Error: Favorite not found
    2018-09-12 19:02:11.910 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.state with {"val":"play","ack":false,"ts":1536771731909,"q":0,"from":"system.adapter.javascript.0","lc":1536771676045}
    2018-09-12 19:02:18.956 - info: javascript.0 script.js.common.Skript1: Neuer Sonos Sender über VIS eingestellt: N-JOY 94.2 (Top 40)
    2018-09-12 19:02:18.956 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.favorites_set with {"val":"N-JOY 94.2 (Top 40)","ack":false,"ts":1536771738955,"q":0,"from":"system.adapter.web.0","lc":1536771738955}
    2018-09-12 19:02:18.987 - error: sonos.0 Cannot replaceWithFavorite: Error: Favorite not found
    2018-09-12 19:02:19.558 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.state with {"val":"play","ack":false,"ts":1536771739557,"q":0,"from":"system.adapter.javascript.0","lc":1536771676045}
    2018-09-12 19:02:27.179 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.favorites_set with {"val":"Deutschlandradio Kultur","ack":false,"ts":1536771747178,"q":0,"from":"system.adapter.web.0","lc":1536771747178}
    2018-09-12 19:02:27.179 - info: javascript.0 script.js.common.Skript1: Neuer Sonos Sender über VIS eingestellt: Deutschlandradio Kultur
    2018-09-12 19:02:27.214 - error: sonos.0 Cannot replaceWithFavorite: Error: Favorite not found
    2018-09-12 19:02:27.782 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.state with {"val":"play","ack":false,"ts":1536771747781,"q":0,"from":"system.adapter.javascript.0","lc":1536771676045}
    2018-09-12 19:02:31.291 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.favorites_set with {"val":"MegaStarFM","ack":false,"ts":1536771751290,"q":0,"from":"system.adapter.web.0","lc":1536771751290}
    2018-09-12 19:02:31.291 - info: javascript.0 script.js.common.Skript1: Neuer Sonos Sender über VIS eingestellt: MegaStarFM
    2018-09-12 19:02:31.339 - error: sonos.0 Cannot replaceWithFavorite: Error: Favorite not found
    2018-09-12 19:02:31.894 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.state with {"val":"play","ack":false,"ts":1536771751892,"q":0,"from":"system.adapter.javascript.0","lc":1536771676045}
    2018-09-12 19:02:36.595 - info: sonos.0 try to control id sonos.0.root.192_168_178_xx.volume with {"val":18,"ack":false,"ts":1536771756594,"q":0,"from":"system.adapter.web.0","lc":1536771756594}
