  4. TypeError: common.log is not a function
5 Beiträge 2 Kommentatoren 688 Aufrufe
  • Z Offline
    Z Offline
    zimpi
    Guten Abend zusammen.
    Ich habe heute mein iobroker geupdatet. Dabei kam es leider zu Fehlern die ich nicht mehr in der History habe.
    Ein starten von iobroker ist nicht mehr möglich. Es bricht mit folgender Meldung ab.
    Starting iobroker controller daemon...
    /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                throw new Error(msg.error);
    Error: TypeError: common.log is not a function
        at DailyRotateFile.log (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:215:23)
        at transportLog (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston/lib/winston/logger.js:234:15)
        at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/async/lib/async.js:157:13
        at _each (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/async/lib/async.js:57:9)
        at Object.async.each (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/async/lib/async.js:156:9)
        at Logger.log (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston/lib/winston/logger.js:246:9)
        at target.(anonymous function) [as info] (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston/lib/winston/common.js:54:18)
        at init (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2512:12)
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2624:1)
        at Module._compile (module.js:577:32)
        at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at process.nextTick (internal/child_process.js:787:12)
        at _combinedTickCallback (internal/process/next_tick.js:73:7)
        at process._tickCallback (internal/process/next_tick.js:104:9)</anonymous></anonymous>
    Meine Versionen sind wie folgt:
    # npm -v && node -v
    3.10.10
    v6.14.4
    Das ganze läuft auf einem Debian 9.
    Leider habe ich ab hier nicht mehr viel ideen was zu tun ist. Linux ist nicht das Problem. Aber das ganze Node etc. ist leider noch nicht so mein Thema.
    Habt ihr Ideen, was ich tun könnte?
    Gruß und schonmal Danke
    zimpi
    • apollon77A Offline
      Was genau hast du den geupdatet? Welche js-Controller Version nutzt du?
      Gesendet vom Handy …
      • Z Offline
        Z Offline
        zimpi
        Das ist die Version 1.4.2
        Ich habe den iobroker selber aktualisiert.
        • Z Offline
          Z Offline
          zimpi
          Nachdem ich gerade NodeJS neuinstalliert habe und anschließend die reinstall.sh ausgeführt habe.
          Läuft wieder alles.
          Mir ist es nicht ganz klar. Warum das so ist, aber es läuft nun erstmal wieder.
          Danke und Gruß
          zimpi
            Zweiteres bzw ja Controller nochmal drüber installieren wär auch mein Tipp gewesen.
