  4. [Gelöst] Fehler bei Multihost-Einrichtung
6 Beiträge 3 Kommentatoren 905 Aufrufe
  • DolomitiD Offline
    DolomitiD Offline
    Dolomiti
    ich habe einen ioBroker neu aufgesetzt mit 8.11.4/4.6.1. Läuft soweit auch. Jetzt wollte ich Multihost einschalten und es kommt folgende Fehlermeldung:
    root@ioBroker-Master:/opt/iobroker# iobroker multihost enable
    Miltihost activated.
    Authentication activated.
    Enter secret phrase for connection:
    Repeat secret phrase for connection:
    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupMultihost.js:139
                                    tools.encryptPhrase(obj.native.secret, password.password, function (encoded) {
    TypeError: Cannot read property 'secret' of undefined
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupMultihost.js:139:64)
        at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
        at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
        at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
        at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)</anonymous></anonymous></anonymous>
    Habe auch mal neugestartet. Gleiches Problem.
    Dolomiti
    Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
    • apollon77A Offline
      Welcher js-controller?
      Gesendet vom Handy …
      • DolomitiD Offline
        DolomitiD Offline
        Dolomiti
        Den letzten: 1.42
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Und welche Version vom Web- und Simple.api-Adapter?
          Gruß,
          Eric
          Von unterwegs getippert
          • DolomitiD Offline
            DolomitiD Offline
            Dolomiti
            beide Adapter waren bei meiner "nackten" Installation nicht installiert. Hatte nur "Admin" und "Discovery" installiert. Web- und Simple.api-Adapter installiert und es funktioniert.
            Danke für die Hilfe
            Dolomiti
              Seit gestern ist die 1.5.0 vom js-controller im latest. versuch bitte mal damit ob es da gefixt ist. Danke
