  4. Create Adapter Instanz: Timer.listOnTimeout
    5.4k
3 Beiträge 2 Kommentatoren 1.0k Aufrufe
  • H Offline
    hometm
    ich versuche gerade auf meinem Raspberry Pi (ein alter RPI Version 1) ioBroker zu installieren. Die Instanzierung der meisten Adapter hat ohne Probleme funktioniert. Bei manchen Adaptern wie z.B. vis-keyboard erhalte ich jedoch einen Timeout.
    $ ./iobroker add vis-keyboard
    ERROR:
    ERROR: events.js:72
    ERROR:         throw er; // Unhandled 'error' event              ^
    ERROR: Error: listen EADDRINUSE    at errnoException (net.js:901:11)
        at Server._listen2 (net.js:1039:14)
        at listen (net.js:1061:10)
        at Server.listen (net.js:1127:5)
        at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2494:24)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:144:9
        at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:151:7)
        at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2160:27)
        at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
    ERROR: process exited with code 8
    iobroker	2015-11-17 19:03:56	info	exit 8
    iobroker	2015-11-17 19:03:56	error	at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
    iobroker	2015-11-17 19:03:56	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2160:27)
    iobroker	2015-11-17 19:03:56	error	at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:151:7)
    iobroker	2015-11-17 19:03:56	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:144:9
    iobroker	2015-11-17 19:03:56	error	at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2494:24)
    iobroker	2015-11-17 19:03:56	error	at Server.listen (net.js:1127:5)
    iobroker	2015-11-17 19:03:56	error	at listen (net.js:1061:10)
    iobroker	2015-11-17 19:03:56	error	at Server._listen2 (net.js:1039:14)
    iobroker	2015-11-17 19:03:56	error	Error: listen EADDRINUSE at errnoException (net.js:901:11)
    iobroker	2015-11-17 19:03:55	error	throw er; // Unhandled 'error' event ^
    iobroker	2015-11-17 19:03:55	error	events.js:72
    iobroker	2015-11-17 19:03:40	info	add vis-keyboard
    kennt jemand diesen Fehler?
    Kann dieser Timeout an meiner alten hardware liegen?
    Tobias
    • BluefoxB Offline
      BluefoxB Offline
      @hometm:
      ERROR:
      ERROR: events.js:72
      Tobias `
      hast du schon mal diesen Antwort gelesen?
      http://forum.iobroker.net/viewtopic.php … out#p14505
      • H Offline
        hometm
        Vielen Dank!
        Konnte diesen Post leider nicht über die Suchfunktion finden
        Tobias
