  4. Dash Button Adapter lässt sich nicht installieren
    6.4k
23 Beiträge 6 Kommentatoren 4.0k Aufrufe
    martin
    Hallo!
    Ich wollte gerade den Dash-Button Adapter installieren.
    Da bringt er mir folgendes:
    $ ./iobroker url "https://github.com/PArns/ioBroker.amazon-dash/tarball/master" amazon-dash
    install https://github.com/PArns/ioBroker.amazon-dash/tarball/master
    npm install https://github.com/PArns/ioBroker.amazon-dash/tarball/master --production --prefix "/opt/iobroker" (System call)
    npm
     WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security pam_appl.h="">
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.9.59-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v8.11.3
    gyp ERR! node-gyp -v v3.6.0gyp ERR! not ok
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
     #include <dns_sd.h>
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/mdns
    gyp ERR! not ok
    ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
    gyp
     ERR! build error
    gyp
    gyp
    ERR! stack     at ChildProcess.emit (events.js:214:7)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp
     ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap
    gyp
     ERR! not ok
    npm
     WARN
     optional
     SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN
    optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 (node_modules/mdns):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! pcap@2.0.0 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm
    ERR! npm ERR! Failed at the pcap@2.0.0 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!
     A complete log of this run can be found in:npm
     ERR!     /root/.npm/_logs/2018-08-01T19_09_43_177Z-debug.log
    ERROR: Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/amazon-dash/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/amazon-dash/io-package.json'
    process exited with code 0</pcap></dns_sd.h></security>
    Was stimmt da nicht und wie kann ich es beheben?
    • apollon77A Offline
      Mach mal mit sudo.
      Gesendet vom Handy …
        martin
        Was genau meinst du? Ich gehe im iobroker oben auf das Symbol und wähle Amazon-Dash aus, danach installiert er es ja von selbst.
        Was soll ich jetzt genau mit sudo machen?
        • J Offline
          JR99
          Bei mir installiert sich der amazon Dash Adapter ebenfalls nicht.
          Ich habe es sowohl über die normale Installationsfunktion (also "+" und Hinzufügen) getestet, als auch über die "Installation aus eigener URL", dort dann von GitHub.
          Immer dasselbe Ergebnis (s.u.)
          Sogar eine Installation mit
          npm i iobroker.amazon-dash oder
          sudo npm i iobroker.amazon-dash
          schlägt immer fehl.
          Hier die Protokoll-Ausgabe:
          $ ./iobroker add amazon-dash
          NPM version: 3.10.10
          npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
          npm
          WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
          npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
          npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
          npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
          npm WARN addRemoteGit  git+https://github.com/bytzdev/node-socketwatcher.git resetting remote /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de because of error: { Error: not found: git
          npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
          npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: undefined
          npm ERR! Linux 4.9.0-6-amd64
          npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--save" "--prefix" "/opt/iobroker"
          npm ERR! node v6.12.3
          npm ERR! npm  v3.10.10
          npm ERR! code ENOGIT
          npm ERR! not found: git
          npm
          ERR! npm ERR!
           Failed using git.npm ERR! This is most likely not a problem with npm itself.
          npm ERR! Please check if you have git installed and in your PATH.
          npm ERR! Please include the following file with any support request:npm ERR!     /opt/npm-debug.log
          Irgendwie scheint es ein Problem mit git zu geben.
          Irgendwelce Tipps?
          Andere Adapter lassen sich völlig problemlos installieren und aktualisieren, nur der Dash eben nicht.
          Ralf
            @JR99:
            Irgendwie scheint es ein Problem mit git zu geben. `
            Korrekt: Not found!
            @JR99:
            Irgendwelce Tipps? `
            Yepp:
            sudo apt install git
            Rainer
              martin
              /opt/iobroker$ sudo apt install git
              WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
              Paketlisten werden gelesen...
              Abhängigkeitsbaum wird aufgebaut....
              Statusinformationen werden eingelesen....
              git ist schon die neueste Version (1:2.11.0-3+deb9u3).
              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 264 nicht aktualisiert.
              /opt/iobroker$
              npm WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
              gyp
               ERR! build error
              gyp ERR! not ok
               #include <dns_sd.h>
              gyp
               ERR! build error
              gyp ERR! not ok
              gyp
               ERR! build error
              gyp
               ERR!
               System
               Linux 4.9.59-v7+gyp
              gyp ERR! not ok
              npm
               WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
              npm
              npm
              npm
              npm
              npm ERR!     /root/.npm/_logs/2018-08-04T18_32_34_614Z-debug.log
                Das muss mit —unsafe-perm installiert werden in dem Fall.
                Bitte manuell per npm installieren und nicht per Admin und den genannten Parameter mit angeben. Und issue bei js-controller anlegen das der Adapter das braucht. Dann kommt er auf die Liste.
                  martin
                  Und wie genau mache ich das? Kenne mich da leider nicht so gut aus.
                    npm install https://github.com/PArns/ioBroker.amazon-dash/tarball/master --production --prefix "/opt/iobroker" --unsafe-perm
                      js-controller 1.5.0 macht das dann später automatisch.
                        martin
                        Klappt leider immer noch nicht.
                        > iobroker.amazon-dash@0.2.9 preinstall /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
                        The following additional packages will be installed:
                          libpcap0.8 libpcap0.8-dev
                        Die folgenden NEUEN Pakete werden installiert:
                          libpcap-dev libpcap0.8 libpcap0.8-dev
                        0 aktualisiert, 3 neu installiert, 0 zu entfernen und 264 nicht aktualisiert.
                        Es müssen 369 kB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 916 kB Plattenplatz zusätzlich benutzt.
                        Holen:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libpcap0.8 armhf 1.8.1-3 [123 kB]
                        Holen:2 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian stretch/main armhf libpcap0.8-dev armhf 1.8.1-3 [220 kB]
                        Holen:3 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian stretch/main armhf libpcap-dev all 1.8.1-3 [25,4 kB]
                        debconf: kann Oberfläche nicht initialisieren: Dialog
                        debconf: (Die Dialog-Oberfläche funktioniert nicht auf einem Dumb-Terminal, einem Emacs-Shellbuffer oder ohne ein steuerndes Terminal.)
                        debconf: greife zurück auf die Oberfläche: Readline
                        debconf: kann Oberfläche nicht initialisieren: Readline
                        debconf: (Diese Oberfläche bedarf eines steuernden Terminals.)
                        debconf: greife zurück auf die Oberfläche: Teletype
                        dpkg-preconfigure: kann Stdin nicht wieder öffnen:
                        Es wurden 369 kB in 0 s geholt (385 kB/s).
                        Vormals nicht ausgewähltes Paket libpcap0.8:armhf wird gewählt.
                        (Lese Datenbank ...
                        (Lese Datenbank ... 5% (Lese Datenbank ... 10%
                        (Lese Datenbank ... 15% (Lese Datenbank ... 20% (Lese Datenbank ... 25% (Lese Datenbank ... 30% (Lese Datenbank ... 35% (Lese Datenbank ... 40% (Lese Datenbank ... 45% (Lese Datenbank ... 50% (Lese Datenbank ... 55%
                        (Lese Datenbank ... 60%
                        (Lese Datenbank ... 65%
                        (Lese Datenbank ... 70%
                        (Lese Datenbank ... 75%
                        (Lese Datenbank ... 80%
                        (Lese Datenbank ... 85%
                        (Lese Datenbank ... 90%
                        (Lese Datenbank ... 95%
                        (Lese Datenbank ... 100% (Lese Datenbank ...
                        120689 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../libpcap0.8_1.8.1-3_armhf.deb ...
                        Entpacken von libpcap0.8:armhf (1.8.1-3) ...
                        Vormals nicht ausgewähltes Paket libpcap0.8-dev wird gewählt.
                        Vorbereitung zum Entpacken von .../libpcap0.8-dev_1.8.1-3_armhf.deb ...
                        Entpacken von libpcap0.8-dev (1.8.1-3) ...
                        Vormals nicht ausgewähltes Paket libpcap-dev wird gewählt.
                        Vorbereitung zum Entpacken von .../libpcap-dev_1.8.1-3_all.deb ...
                        Entpacken von libpcap-dev (1.8.1-3) ...
                        Trigger für libc-bin (2.24-11+deb9u1) werden verarbeitet ...
                        Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                        libpcap0.8:armhf (1.8.1-3) wird eingerichtet ...
                        libpcap0.8-dev (1.8.1-3) wird eingerichtet ...
                        libpcap-dev (1.8.1-3) wird eingerichtet ...
                        > socketwatcher@0.3.0 install /opt/iobroker/node_modules/socketwatcher
                        > node-gyp rebuild
                        make: Verzeichnis „/opt/iobroker/node_modules/socketwatcher/build“ wird betreten
                          CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
                          SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
                          COPY Release/socketwatcher.node
                        make: Verzeichnis „/opt/iobroker/node_modules/socketwatcher/build“ wird verlassen
                        > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
                        > node-gyp rebuild
                        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
                          CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                        #include <security pam_appl.h="">^
                        authenticate_pam.target.mk:93: die Regel für Ziel „Release/obj.target/authenticate_pam/authenticate_pam.o“ scheiterte
                        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
                        gyp
                        ERR!
                        gyp ERR! not ok
                        > mdns@2.4.0 install /opt/iobroker/node_modules/mdns
                        > node-gyp rebuild
                        make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird betreten
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
                        #include <dns_sd.h>^
                        dns_sd_bindings.target.mk:150: die Regel für Ziel „Release/obj.target/dns_sd_bindings/src/dns_sd.o“ scheiterte
                        make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird verlassen
                        gyp
                        ERR! build error
                        gyp
                        gyp ERR!
                        gyp
                        gyp
                        gyp
                        gyp
                        gyp
                        v3.6.0
                        gyp ERR!
                        not ok
                        > pcap@2.0.0 install /opt/iobroker/node_modules/pcap
                        > node-gyp rebuild
                        make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
                          CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
                          CXX(target) Release/obj.target/pcap_binding/pcap_session.o
                          SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
                          COPY Release/pcap_binding.node
                        make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
                        iobroker@1.0.0 /opt/iobroker
                        └─┬ iobroker.amazon-dash@0.2.9
                          └─┬ pcap@2.0.0
                            └── socketwatcher@0.3.0  (git+https://github.com/bytzdev/node-socketwatcher.git#d252d3f8c45f565a0a48ebd155d4f9e4666798d9)
                        npm
                        WARN
                        optional
                        npm
                        WARN
                        optional
                        npm
                        WARN
                        optional
                        npm
                        WARN
                        connection lost .................................
                        /opt/iobroker$</dns_sd.h></security>
                          Installatiion ist aber erfolgreich durch. Die Fehler kommen von optionalen Paketen.
                          Probier mal
                            martin
                            Inzwischen ist der Dash-Button-Adapter auch da. Nach der Installation war er noch nicht da.
                            Vielen Dank für eure Hilfe.
                            Ich werde es die nächsten Tage mal testen.
                            Eine Frage noch zum Dash-Button. Soll man mit dem 1 Bestellung bei Amazon tätigen um den Kaufpreis gutgeschrieben zu kriegen oder gleich im iobroker integrieren?
                            • ChaotC Offline
                              ChaotC Offline
                              Chaot
                              Ich habe mehrere Fehlermeldungen bei der Installation, aber am Ende kommt immer die Meldung Adapter installiert mit Code 0 - also sollte das erfolgreich gewesen sein.
                              Der Adapter startet, wird ganz kurz grün und dann rot.
                              Log:
                              host.haus	2018-08-11 23:33:58.158	info	Restart adapter system.adapter.amazon-dash.0 because enabled
                              host.haus	2018-08-11 23:33:58.158	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                              Caught	2018-08-11 23:33:58.158	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2018-08-11 23:33:58.158	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Adapter.emit (events.js:208:7)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at emitNone (events.js:106:13)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
                              Caught	2018-08-11 23:33:58.157	error	by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
                              Caught	2018-08-11 23:33:58.156	error	by controller[0]: Error: socket: Operation not permitted
                              amazon-dash.0	2018-08-11 23:33:58.137	info	terminating
                              amazon-dash.0	2018-08-11 23:33:58.124	info	cleaned everything up...
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at Adapter.emit (events.js:208:7)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at emitNone (events.js:106:13)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
                              amazon-dash.0	2018-08-11 23:33:58.123	error	Error: socket: Operation not permitted
                              amazon-dash.0	2018-08-11 23:33:58.123	error	uncaught exception: socket: Operation not permitted
                              amazon-dash.0	2018-08-11 23:33:58.116	info	starting pcap session on default interface
                              amazon-dash.0	2018-08-11 23:33:58.111	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.11.3
                              amazon-dash.0	2018-08-11 23:33:58.083	info	States connected to redis: 127.0.0.1:6379</anonymous></anonymous></anonymous></anonymous>
                                Unter welchem User läuft denn drin ioBroker?
                                Operation not permitted weißt an sich auf User/rechte Themen hin.
                                • ChaotC Offline
                                  ChaotC Offline
                                  Chaot
                                  Der läuft als Admin.
                                  Kann ich die Rechte ändern? Wie funktioniert das?
                                    Admin? Du meinst root?
                                    • ChaotC Offline
                                      ChaotC Offline
                                      Chaot
                                      Ok, jetzt wird es vermutlich kompliziert
                                      Der im Adapter eingesetzte Nutzer nennt sich Admin.
                                      Allerdings scheint der keine Root-Rechte zu haben wenn ich m ir die Fehlermeldungen bei der Adapterinstallation so anschaue. "…missing permission..."
                                      Wie bekomme ich den Adapter bzw. ioBroker dazu das er rootRechte hat?
                                      Braucht er die zwingend?
                                      Ach, und warum hat der Adapter vorher funktioniert?
                                      • ChaotC Offline
                                        ChaotC Offline
                                        Chaot
                                        :roll: :roll: :roll:
                                        Ich vergesse das immer wieder :roll: :roll: :roll: :roll:
                                        Update des JS Controler und der Dash läuft. :idea:
                                        • ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          Nach dem letzten Update des JS-Controlers auf 1.5.3
                                          funktionieren die blöden Dash Button wieder mal nicht:
                                          host.haus	2018-09-15 22:37:51.275	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:25)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:830:13)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:54)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5290:18)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Adapter.emit (events.js:208:7)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at emitNone (events.js:106:13)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
                                          Caught	2018-09-15 22:37:51.275	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                                          Caught	2018-09-15 22:37:51.274	error	by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
                                          Caught	2018-09-15 22:37:51.274	error	by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
                                          Caught	2018-09-15 22:37:51.274	error	by controller[0]: Error: socket: Operation not permitted
                                          host.haus	2018-09-15 22:37:50.499	info	instance system.adapter.amazon-dash.0 started with pid 2380</anonymous>
