  4. Fehler:NODE-RED - von 0 auf 100 - ERROR: port in use
    1.0k
    6.1k
2 Beiträge 1 Kommentatoren 693 Aufrufe
  • liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    suche dringend hilfe:
    habe mehrere stunden in nede-red programmiert -alles war gut - plötzlich bei deploy - bildschirm (bzw. webseite) friert ein - im log heißt es Port in use. habe nodered neugestartet und sogar am ende den ganzen rechen.
    Fehler:
    ! node-red.0 2018-08-03 13:08:50.220 error 3 Aug 13:08:50 - [error] Error: port in use
    ! node-red.0 2018-08-03 13:08:50.214 error 3 Aug 13:08:50 - [error] Unable to listen on http://127.0.0.1:1880/
    ! node-red.0 2018-08-03 13:08:50.058 warn 3 Aug 13:08:50 - [info] User directory : /opt/iobroker/iobroker-data/node-red/ 3 Aug 13:08:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable 3 Aug 13:08:50 - [info] Flows
    ! node-red.0 2018-08-03 13:08:50.051 debug 3 Aug 13:08:50 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
    ! node-red.0 2018-08-03 13:08:50.044 warn 3 Aug 13:08:50 - [warn] –----------------------------------------------------
    ! node-red.0 2018-08-03 13:08:50.024 warn 3 Aug 13:08:50 - [warn] [nr-regexp-filter/filter-filename] 'filter' already registered by module node-red-contrib-filter-else
    ! node-red.0 2018-08-03 13:08:50.021 warn 3 Aug 13:08:50 - [warn] [node-red/rpi-gpio] Info : Ignoring Raspberry Pi specific node
    ! node-red.0 2018-08-03 13:08:50.014 warn 3 Aug 13:08:50 - [warn] –----------------------------------------------------
    ! node-red.0 2018-08-03 13:08:49.921 debug 3 Aug 13:08:49 - [info] Dashboard version 2.9.6 started at /ui
    ! node-red.0 2018-08-03 13:08:49.562 debug 3 Aug 13:08:49 - [info] Polymer started at /polymer
    ! parser.1 2018-08-03 13:08:46.890 error Cannot read link "http://192.168.178.59:8200": Error: connect ECONNREFUSED 192.168.178.59:8200
    ! node-red.0 2018-08-03 13:08:42.550 debug 3 Aug 13:08:42 - [info] Loading palette nodes
    ! node-red.0 2018-08-03 13:08:41.350 debug 3 Aug 13:08:41 - [info] Linux 4.9.0-4-686-pae ia32 LE
    ! node-red.0 2018-08-03 13:08:41.340 debug 3 Aug 13:08:41 - [info] Node.js version: v8.11.2
    ! node-red.0 2018-08-03 13:08:41.333 debug 3 Aug 13:08:41 - [info] Node-RED version: v0.18.7
    ! node-red.0 2018-08-03 13:08:41.323 debug 3 Aug 13:08:41 - [info] Welcome to Node-RED ===================
    ! node-red.0 2018-08-03 13:08:38.765 info Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    weiß jemand, was da passiert ist - port in use: habe außer node-red nichts gemacht!!! meine installierte verion von node-red-adapter: 1.6.0
    zusätlich installierte nodes über webinterface
    • node-red-contrib-filter-else
    • node-red-contrib-string
    • nr-regexp-filter
    • node-red-contrib-batcher
      liv-in-skyL Offline
      liv-in-sky
      kann man irgendwie die flows abschalten/deaktivieren - unter "/opt/iobroker/iobroker-data/node-red" werden immer wieder die flows von woanders kopiert - ich wolte mal nachsehen, ob in meinen flows etwas falsch ist und sehen, ob node-red ohne meinen neuen flow startet
      ich habe zur zeit des absturzes nichts neues installiert (node-red) noch im iobroker etwas geändert - nur einen flow verändert - vielliecht habe ich da einen fehler gemacht
