  4. Fehler bei Updates und Neuinstallation Plugins?
    1.0k
    6.1k
4 Beiträge 2 Kommentatoren 576 Aufrufe
    butsch
    Ich bekomme Fehler beim updaten von Adaptern, andere lassen sich garnicht installieren:
    iobroker	2018-07-25 17:01:44.659	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    iobroker	2018-07-25 17:01:44.659	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 (node_modules/mdns):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 install: `node-gyp rebuild`
    unifi.1	2018-07-25 17:01:42.562	info	getAccessDevices: 6
    unifi.1	2018-07-25 17:01:42.357	info	getClientDevices: 14
    unifi.1	2018-07-25 17:01:42.318	info	getSiteSysinfo: 1
    unifi.1	2018-07-25 17:01:42.262	info	getSitesStats: default
    unifi.1	2018-07-25 17:01:41.901	info	controller = 192.128.0.11:8443
    unifi.1	2018-07-25 17:01:41.901	info	update_interval = 10
    unifi.1	2018-07-25 17:01:41.901	info	Starting UniFi-Controller query
    iobroker	2018-07-25 17:01:37.790	info	gyp ERR! not ok
    iobroker	2018-07-25 17:01:37.790	info	gyp ERR! node-gyp -v v3.4.0
    iobroker	2018-07-25 17:01:37.790	info	gyp ERR! node -v v6.14.3
    iobroker	2018-07-25 17:01:37.790	info	gyp ERR! cwd /opt/iobroker/node_modules/mdns
    iobroker	2018-07-25 17:01:37.790	info	gyp ERR! System Linux 3.10.0-862.9.1.el7.x86_64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    iobroker	2018-07-25 17:01:37.788	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    iobroker	2018-07-25 17:01:37.788	info	gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    iobroker	2018-07-25 17:01:37.788	info	gyp ERR! stack at emitTwo (events.js:106:13)
    iobroker	2018-07-25 17:01:37.788	info	gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules.bundled/node-gyp/lib/build.js:276:23)
    iobroker	2018-07-25 17:01:37.783	info	ERR! build error
    iobroker	2018-07-25 17:01:37.782	info	gyp
    iobroker	2018-07-25 17:01:37.776	info	make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    Dieses Log enstand beim Update von alexa2 und gar nicht installieren lässt sich leider dash Button Plugin
    Jemand eine Idee oder Tip?
      Sieht für mich erst einmal nicht so schlimm aus.
      Allerdings ist er noch nicht fertig, sondern erst in den make-Prozess eingestiegen um ein nicht verfügbares fertiges Paket selber zu kompilieren.
      Je nach Hardware (welche hast du??) kann das dauern.
      Sorry, sehe gerade, das ist rückwärts sortiert. - alles Gut!
      und beim dash button hab ich so einen verdacht - da bräuchte ich das log
      Rainer
        butsch
        Ok, ich dacht das wäre das Log :-(
        Was genau muss ich tun, um das richtige Log zu Posten?
          Das ist das log von der Installation des unifi Adapters.
          Ich brauche das der Installation des dash button Adapters
