  4. Hilfe, IOBroker startet nicht mehr
    1.0k
    6.1k
7 Beiträge 2 Kommentatoren 872 Aufrufe
    stefan0875
    Hallo zusammen
    vielleicht kein jemand hier schnell helfen.
    Letzte Nacht hat mein ioBroker plötzlich seinen Dienst quittiert.
    Seitdem bekomme ich ihn auch nicht mehr neu gestartet.
    Beim Versuch zu starten sehe ich im Logfile:
    2018-07-24 17:23:38.268  - ESC[32minfoESC[39m: host.raspberrypi iobroker.js-controller version 1.2.3 js-controller starting
    2018-07-24 17:23:38.284  - ESC[32minfoESC[39m: host.raspberrypi Copyright (c) 2014-2017 bluefox, 2014 hobbyquaker
    2018-07-24 17:23:38.286  - ESC[32minfoESC[39m: host.raspberrypi hostname: raspberrypi, node: v6.12.0
    2018-07-24 17:23:38.288  - ESC[32minfoESC[39m: host.raspberrypi ip addresses: 192.168.178.57 2a0a:a541:b4:0:a752:7dbc:c335:1062 fe80::cc4a:3a69:51f8:fcc0
    2018-07-24 17:23:38.461  - ESC[32minfoESC[39m: host.raspberrypi  inMem-states listening on port 9000
    2018-07-24 17:23:38.881  - ESC[32minfoESC[39m: host.raspberrypi  inMem-objects listening on port 9001
    2018-07-24 17:23:38.906  - ESC[32minfoESC[39m: host.raspberrypi InMemoryDB connected
    2018-07-24 17:23:38.947  - ESC[32minfoESC[39m: host.raspberrypi 23 instances found
    2018-07-24 17:23:38.983  - ESC[32minfoESC[39m: host.raspberrypi starting 20 instances
    2018-07-24 17:23:39.041  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.admin.0 started with pid 1785
    2018-07-24 17:23:41.937  - ESC[32minfoESC[39m: admin.0 starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.0
    2018-07-24 17:23:41.990  - ESC[32minfoESC[39m: admin.0 requesting all states
    2018-07-24 17:23:41.995  - ESC[32minfoESC[39m: admin.0 requesting all objects
    2018-07-24 17:23:43.637  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.admin-beta.0 started with pid 1795
    2018-07-24 17:23:48.739  - ESC[31merrorESC[39m: admin.0 no connection to states DB: Connection timeout
    2018-07-24 17:23:51.343  - ESC[31merrorESC[39m: admin-beta.0 no connection to objects DB
    Das Logfile von letzter Nacht bis jetzt:
    2018-07-24 16:17:13.533  - ESC[32minfoESC[39m: host.raspberrypi Copyright (c) 2014-2017 bluefox, 2014 hobbyquaker
    2018-07-24 16:17:13.535  - ESC[32minfoESC[39m: host.raspberrypi hostname: raspberrypi, node: v6.12.0
    2018-07-24 16:17:13.538  - ESC[32minfoESC[39m: host.raspberrypi ip addresses: 2a0a:a541:b4:0:a752:7dbc:c335:1062 fe80::cc4a:3a69:51f8:fcc0
    2018-07-24 17:08:07.354  - ESC[32minfoESC[39m: host.raspberrypi  inMem-states listening on port 9000
    2018-07-24 17:08:08.048  - ESC[32minfoESC[39m: host.raspberrypi  inMem-objects listening on port 9001
    2018-07-24 17:08:08.093  - ESC[32minfoESC[39m: host.raspberrypi InMemoryDB connected
    2018-07-24 17:08:08.148  - ESC[32minfoESC[39m: host.raspberrypi 23 instances found
    2018-07-24 17:08:08.213  - ESC[32minfoESC[39m: host.raspberrypi starting 20 instances
    2018-07-24 17:08:08.335  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.admin.0 started with pid 1161
    2018-07-24 17:08:12.246  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.admin-beta.0 started with pid 1234
    2018-07-24 17:08:16.235  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.discovery.0 started with pid 1240
    2018-07-24 17:08:22.620  - ESC[31merrorESC[39m: discovery.0 no connection to objects DB
    2018-07-24 17:08:23.545  - ESC[31merrorESC[39m: admin-beta.0 no connection to objects DB
    2018-07-24 17:10:44.212  - ESC[32minfoESC[39m: host.raspberrypi iobroker.js-controller version 1.2.3 js-controller starting
    2018-07-24 17:10:44.229  - ESC[32minfoESC[39m: host.raspberrypi Copyright (c) 2014-2017 bluefox, 2014 hobbyquaker
    2018-07-24 17:10:44.230  - ESC[32minfoESC[39m: host.raspberrypi hostname: raspberrypi, node: v6.12.0
    2018-07-24 17:10:44.233  - ESC[32minfoESC[39m: host.raspberrypi ip addresses: 192.168.178.57 2a0a:a541:b4:0:a752:7dbc:c335:1062 fe80::cc4a:3a69:51f8:fcc0
    2018-07-24 17:10:44.407  - ESC[32minfoESC[39m: host.raspberrypi  inMem-states listening on port 9000
    2018-07-24 17:10:44.833  - ESC[32minfoESC[39m: host.raspberrypi  inMem-objects listening on port 9001
    2018-07-24 17:10:44.858  - ESC[32minfoESC[39m: host.raspberrypi InMemoryDB connected
    2018-07-24 17:10:44.898  - ESC[32minfoESC[39m: host.raspberrypi 23 instances found
    2018-07-24 17:10:44.935  - ESC[32minfoESC[39m: host.raspberrypi starting 20 instances
    2018-07-24 17:10:44.991  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.admin.0 started with pid 1350
    2018-07-24 17:10:45.442  - ESC[32minfoESC[39m: admin.0 starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.0
    2018-07-24 17:10:45.505  - ESC[32minfoESC[39m: admin.0 requesting all states
    2018-07-24 17:10:45.510  - ESC[32minfoESC[39m: admin.0 requesting all objects
    2018-07-24 17:10:52.643  - ESC[31merrorESC[39m: admin.0 no connection to objects DB
    (END)
    Scheinbar läuft die Datenbank nicht: "no connection to objects DB"
    Also wenn jemand spontan eine Idee hat wäre ich sehr dankbar.
      stefan0875
      Scheinbar gab es letzte Nacht einen OutOfMemory Error:
      von /var/log/messages
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295541] [28266]     0 28266    25489     2727      49       0     2026             0 node
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295547] [ 9795]     0  9795    41063    10589      74       0     1209             0 io.javascript.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295553] [ 9887]     0  9887    34767     4978      55       0        0             0 io.web.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295558] [ 9893]     0  9893    38173     8756      66       0        0             0 io.admin.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295564] [ 9899]     0  9899    36863     7916      64       0        0             0 io.admin-beta.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295570] [ 9905]     0  9905    31291     4187      51       0        0             0 io.history.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295576] [ 9906]     0  9906    33905     4653      56       0        0             0 io.harmony.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295581] [ 9912]     0  9912    31634     3950      52       0        0             0 io.tradfri.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295587] [ 9923]     0  9923    35413     6279      61       0        0             0 io.sonos.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295592] [ 9924]     0  9924    30783     3775      50       0        0             0 io.milight.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295598] [ 9930]     0  9930    30473     3202      50       0        0             0 io.samsung2016.
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295603] [ 9942]     0  9942    30790     3441      52       0        0             0 io.geofency.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295609] [ 9954]     0  9954    30225     3058      47       0        0             0 io.discovery.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295615] [ 9966]     0  9966    31034     3054      51       0        0             0 io.hm-rpc.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295621] [ 9986]     0  9986    31336     3689      52       0        0             0 io.sayit.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295626] [10044]     0 10044    34800     5808      57       0        0             0 io.hm-rega.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295632] [10050]     0 10050    30748     3658      51       0        0             0 io.fakeroku.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295638] [10056]     0 10056    32617     4400      55       0        0             0 io.terminal.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295644] [24231]     0 24231    36680     6917      63       0        0             0 io.telegram.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295649] [24237]     0 24237    36621     6968      64       0        0             0 io.telegram.1
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295655] [24696]     0 24696    35357     5861      57       0        0             0 io.cloud.0
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295664] [25581]     0 25581     1760       84       7       0        5             0 cron
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295670] [25585]     0 25585      477       16       6       0        0             0 sh
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295675] [25586]     0 25586     1270       41       6       0        0             0 autoBackup.sh
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295681] [25588]     0 25588     1271       41       6       0        0             0 autoBackup.sh
      Jul 24 03:00:45 raspberrypi kernel: [5296451.295687] [25589]     0 25589    57954    37380     142       0        0             0 node
      Jul 24 03:00:45 raspberrypi kernel: [5296451.327436] oom_reaper: reaped process 9795 (io.javascript.0), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
        stefan0875
        Nach einem OS Update (apt-get upgrade) startet ioBroker wieder.
        Ich habe dann auch gleich mit "iobroker upgrade" die Installation auf den aktuellsten Stand gebracht.
        Naja, einiges läuft noch nicht, so z.B die Cloud (Alexa) und sayit via Sonos funktioniert nicht mehr.
        Wenigstens die Steuerung meines Badezimmerventilators geht wieder ;)
          @stefan0875:
          sayit via Sonos funktioniert nicht mehr. `
          Hatte ich auch, bitte sonos 1.7.4 aus github installieren
          rainer
            stefan0875
            Kannst du mir kurz sagen, wo ich die finde?
            1.7.2 sehe ich als aktuelle Version
            Danke und Gruß
              @stefan0875:
              wo ich die finde? `
              auf github ;-)
              http://www.iobroker.net/docu/?page_id=5379&lang=de#3_Adapter_aus_eigener_URL_installieren
                stefan0875
                Danke, wie dumm von mir…die Hitze, du weiß schon :-)
                Läuft wieder !
                Jetzt noch die Cloud und dann bin ich zufrieden
