  4. Gyp ERR! build error
    6.0k
gyp err
5 Beiträge 4 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • caravandriverC Offline
    caravandriver
    Ich habe auf einem docker Container iobroker installiert. Ich erhalte aber bei vielen Modulen diese gyp ERR. Woran liegt das?
    make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack at emitTwo (events.js:126:13)
    gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 3.10.102
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
    gyp ERR! node -v v8.11.3
    gyp ERR! node-gyp -v v3.7.0
    gyp ERR! not ok
    npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
    iobroker.mobile@0.4.11
    added 1 package from 1 contributor and audited 3065 packages in 98.916s
    found 27 vulnerabilities (19 low, 8 high)
    run `npm audit fix` to fix them, or `npm audit` for details
    DONE iobroker.mobile
    npm WARN deprecated bcrypt@1.0.3: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt
    = v2.0.0 for improved sup
    port for newer bcrypt hashes
    npm WARN deprecated i18next-client@1.10.3: you can use npm instal
    • apollon77A Offline
      Das Log mus snoch länger sein. Bitte vollständig posten. Da fehlt das relevante
      Am Ende ist das eine Abhängigkeit vom js.controller denke ich die aber optional ist
      Damit zwei optionen: Rausfinden was zu fixen ist (meist fehlt irgendein Linux paket oder Header-Files) oder ignorieren und damit leben :-)
      • smartboartS Offline
        smartboartS Offline
        smartboart
        Hast du herausgefunden was das Problem war?
        • smartboartS smartboart
          BBTownB Offline
          BBTownB Offline
          BBTown
          @smartboart in einem anderen Thread gab es einen Hinweis, dass die GYP Error Meldungen womöglich etwas mit einer "Python Installation" zu tun haben könnten??!!
            smartboartS Offline
            smartboart
            Danke für den Hinweis..
            apt-get install python-dev ergab bei mir nur das schon alles aktuell ist....
