  4. [Gelöst] Installation von Adapter nicht mehr möglich
    1.0k
    6.1k
3 Beiträge 2 Kommentatoren 663 Aufrufe
  • G Offline
    George_Best
    ich kann den Amazon-Dash-Adapters weder in der Web-Oberfläche noch auf Kommandozeile installieren.
    Fehlercode:
    ! $ ./iobroker add amazon-dash
    ! NPM version: 3.10.10
    ! npm install iobroker.amazon-dash –production --save --prefix "/opt/iobroker" (System call)
    ! npm
    ! WARN
    ! addRemoteGit
    ! Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    ! npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
    ! npm WARN addRemoteGit git+https://github.com/bytzdev/node-socketwatcher.git resetting remote /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de because of error: { Error: not found: git
    ! npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: undefinednpm ERR!
    ! npm
    ! ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--save" "--prefix" "/opt/iobroker"
    ! npm ERR! node
    ! v6.14.3npm ERR! npm v3.10.10
    ! npm ERR! code ENOGIT
    ! npm
    ! ERR! not found: gitnpm ERR!
    ! npm ERR! Failed using git.
    ! npm
    ! ERR! This is most likely not a problem with npm itself.npm ERR!
    ! Please check if you have git installed and in your PATH.
    ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ! host.ioBroker-RasPi install adapter amazon-dash
    ! npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
    ! npm
    ! WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm
    ! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: undefined
    ! npm
    ! npm
    ! npm
    ! ERR! argv
    ! "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.14.3
    ! npm
    ! ERR! npm v3.10.10
    ! npm
    ! ERR! code ENOGIT
    ! npm
    ! npm ERR! This is most likely not a problem with npm itself.
    ! npm ERR! Please check if you have git installed and in your PATH.
    ! NPM version: 3.10.10npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
    ! npm
    ! WARN
    ! addRemoteGit Error: not found: gitnpm WARN
    ! addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    ! at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! npm
    ! WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! npm
    ! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: undefined
    ! npm
    ! npm ERR! node v6.14.3
    ! npm
    ! ERR! npm v3.10.10
    ! npm
    ! ERR! /npm-debug.log
    ! ERROR: host.ioBroker-RasPi Cannot install amazon-dash
    ! ERROR: process exited with code 13
    Die Versionen sind:
    npm -v
    3.10.10
    node -v
    v6.14.3
    nodejs -v
    v6.14.3
    Ich kann auch keinen anderen Adapter installieren. Z. B.: Logitech Harmony Adapter.
    identischer Fehlercode:
    ! $ ./iobroker add harmony
    ! npm install iobroker.harmony –production --save --prefix "/opt/iobroker" (System call)
    ! npm
    ! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
    ! npm
    ! WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
    ! npm
    ! ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.14.3
    ! npm ERR! npm v3.10.10
    ! npm
    ! npm
    ! ERR!
    ! host.ioBroker-RasPi install adapter harmony
    ! npm install iobroker.harmony --production --save --prefix "/opt/iobroker" (System call)
    ! npm
    ! npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cd ... ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
    ! npm
    ! npm
    ! npm
    ! npm
    ! ERR! argv
    ! "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--save" "--prefix" "/opt/iobroker"npm
    ! ERR! node v6.14.3
    ! npm
    ! ERR! code ENOGIT
    ! npm ERR! not found: gitnpm ERR!
    ! npm ERR! /npm-debug.log
    ! npm
    ! npm WARN
    ! addRemoteGit
    ! git+https://github.com/swissmanu/ltx.git#cd ... ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm
    ! undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
    ! npm
    ! npm
    ! ERR!
    ! Linux 4.9.35-v7+
    ! npm ERR! argv
    ! "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.14.3
    ! npm ERR! npm v3.10.10npm ERR! code ENOGIT
    ! npm
    ! ERR!
    ! not found: git
    ! npm
    ! ERR! npm ERR! Failed using git.
    ! ERROR: host.ioBroker-RasPi Cannot install harmony
    Hat jemand eine Idee?
      Installation von Adapter nicht mehr möglich stimmt so nicht. Du hast eine Fehlermeldung
      @George_Best:
      ERR! code ENOGIT `
      Und ausgerechnet die zwei Adapter versucht ffür die du GIT benötigst.
      Installiere git
      sudo apt install git
      Und alles wird gut
      Gruß Rainer
      • G Offline
        George_Best
        Servus Rainer,
        vielen, vielen Dank für die rasche Rückmeldung und die hervorragende Hilfe!
        Genau das war es. Ich habe git installiert und schon klappt es mit den Adaptern :D
