  3. Entwicklung
  4. Adapter Entwicklung - cheerio - $ is not defined
    5.6k
5 Beiträge 2 Kommentatoren 781 Aufrufe
    darkiop
    ich möchte in einem Adapter cheerio einsetzen mittels $ den DOM auslesen, das Skript funktioniert außerhalb des Adapters ohne Fehler.
    Wieso gibt es hier Probleme?
    /* jshint -W097 */ // jshint strict:false
    /*jslint node: true */
    'use strict';
    // https://nodejs.org/api/child_process.html
    const {
        exec
    } = require('child_process');
    var utils = require(__dirname + '/lib/utils'); // Get common adapter utils
    var adapter = new utils.Adapter('stiebel-lwz');
    // is called when adapter shuts down - callback has to be called under any circumstances!
    adapter.on('unload', function (callback) {
        try {
            adapter.log.info('cleaned everything up...');
            callback();
        } catch (e) {
            callback();
    // is called if a subscribed object changes
    adapter.on('objectChange', function (id, obj) {
        // Warning, obj can be null if it was deleted
        adapter.log.info('objectChange ' + id + ' ' + JSON.stringify(obj));
    // is called if a subscribed state changes
    adapter.on('stateChange', function (id, state) {
        // Warning, state can be null if it was deleted
        adapter.log.info('stateChange ' + id + ' ' + JSON.stringify(state));
         * SENDE PARAMETER AN ISG
        // Sende Parameter an ISGweb
        var parameter, wert;
        function set_isg_para(isgweburl, parameter, wert) {
            exec('bash /opt/iobroker/node_modules/iobroker.stiebel-lwz/isg_set.sh ' + isgweburl + ' ' + parameter + ' ' + wert, (err, stdout, stderr) => {
                if (err) {
                    console.error(err);
                    return;
                console.log(stdout);
        // BETRIEBSART
        if (id == adapter.name + '.' + adapter.instance + '.Start.Betriebsart') {
            adapter.log.info('Setze Betriebsart auf: ' + state.val);
            set_isg_para(adapter.config.isgIP, 'BETRIEBSART', state.val);
        // LUEFTUNGSSTUFEN
        else if (id == adapter.name + '.' + adapter.instance + '.Einstellungen.Lueften.Lueftungsstufen.STUFE_TAG') {
            adapter.log.info('Setze Lueftungsstufe STUFE-TAG auf: ' + state.val);
            set_isg_para(adapter.config.isgIP, 'LUEFTERSTUFETAG', state.val);
        // RAUM TEMP TAG
        else if (id == adapter.name + '.' + adapter.instance + '.Einstellungen.Heizen.Raumtemperaturen_HK1.RAUMTEMP_TAG') {
            adapter.log.info('Setze Raumtemperaturen_HK1 RAUMTEMP. TAG auf: ' + state.val);
            set_isg_para(adapter.config.isgIP, 'RAUMTEMPTAG', state.val);
        // WARMWASSER TEMP TAG
        else if (id == adapter.name + '.' + adapter.instance + '.Einstellungen.Warmwasser.WW-Temperaturen.WW_SOLL_TAG') {
            adapter.log.info('Setze WW-Temperaturen WW SOLL TAG auf: ' + state.val);
            set_isg_para(adapter.config.isgIP, 'WARMWASSERTEMPTAG', state.val);
    // is called when databases are connected and adapter received configuration.
    adapter.on('ready', function () {
        main();
    function main() {
        // Ausgabe der eingestellten IP im Log
        adapter.log.info('isgIP: ' + adapter.config.isgIP);
         * LESE PARAMETER AUS ISG
        // Lade aktuelle Betriebsart bei Start in Objekt
        function load_isg_parameters() {
            // https://github.com/IonicaBizau/cheerio-req
            const cheerioReq = require("cheerio-req");
            // BETRIEBSART
            cheerioReq('http://' + adapter.config.isgIP, (err, $) => {
                var betriebsart = $('input#aval39').val();
                adapter.setState('Start.Betriebsart', betriebsart, true);
                adapter.log.info('Aktuelle Betriebsart:' + betriebsart);
        } // end of load_isg_parameters()
        // TEST
        function ISG() {
            var cheerio = require('cheerio');
            request('http://' + adapter.config.isgIP + '/?s=1,0', function (error, response, body) {
                $ = cheerio.load(body);
                var d = $("td.value");
                //console.log('tds: ' + d);
                // The parseFloat() function parses a string and returns a floating point number.
                // The text property sets or returns the text of an option element.
                // The trim() method removes whitespace from both sides of a string.
                // The .eq() selector selects an element with a specific index number. The index numbers start at 0, so the first element will have the index number 0 (not 1).
                var AUSSENTEMPERATUR = d.eq(6).text().trim();
                AUSSENTEMPERATUR = removeDegreeUnit(AUSSENTEMPERATUR);
                adapter.setState('TEST.AUSSENTEMPERATUR', AUSSENTEMPERATUR, true);
                adapter.log('AUSSENTEMPERATUR: ' + AUSSENTEMPERATUR);
                function checkFalseBool(input, checkvalue) {
                    var result = (input != checkvalue);
                    return Boolean(result);
                function checkTrueBool(input, checkvalue) {
                    var result = input == checkvalue;
                function removeUnit(input, unitLength, unit) {
                    if (unit)
                        unit.valueOf = unit.toSource = unit.toString = input.substring(input.length - unitLength, input.length);
                    var value = input.substring(0, input.length - unitLength);
                    value = value.replace(/,/, ".");
                    return parseFloat(value);
                function removeHourUnit(input, unit) {
                    return removeUnit(input, 2, unit);
                function removePowerUnit(input, unit) {
                    return removeUnit(input, 4);
                function removePressureUnit(input, unit) {
                function removeDegreeUnit(input, unit) {
            }); // end of request()
        } // end of ISG()
        if (adapter.config.loadISGwebParameters === true) {
            load_isg_parameters();
            ISG();
        // in this stiebel-lwz all states changes inside the adapters namespace are subscribed
        adapter.subscribeStates('*');
    } // end of main()
    Log:
    2018-07-13 20:40:59.857 - error: Caught by controller[0]: ReferenceError: $ is not defined
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.stiebel-lwz/stiebel-lwz.js:112:15)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.stiebel-lwz/node_modules/request/request.js:185:22)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at emitTwo (events.js:106:13)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at Request.emit (events.js:191:7)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.stiebel-lwz/node_modules/request/request.js:1157:10)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at emitOne (events.js:96:13)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at Request.emit (events.js:188:7)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.stiebel-lwz/node_modules/request/request.js:1079:12)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at IncomingMessage.g (events.js:292:16)
    2018-07-13 20:40:59.858 - error: Caught by controller[0]: at emitNone (events.js:91:20)
    2018-07-13 20:40:59.858 - error: host.zeus-vm-iobroker instance system.adapter.stiebel-lwz.0 terminated with code 0 (OK)
    • apollon77A Offline
      Ich denke du nutzt es nicht korrekt. Ich finde weder ein
      var $
      Noch ein
      const $
      Kann seien das nur ein var fehlt bei der einen Zuweisung?
      Gesendet vom Handy …
        darkiop
        Das wars, die Deklaration des $. Desweiteren fehlt bei beim adapter.log noch ein .info …
        Ist ioBroker da etwas spezieller? Der Code lief im JS-Adapter auch ohne var/const
          Naja, eher der JavaScript Adapter ist da spezieller.
          Dort läuft alles in einer sandbox und denke eher nicht als „strict“ deklariert was für Adapter eher im Standard do ist. Und all sowas ;-))
            darkiop
            Ok Super, vielen Dank!!
            Komme aktuell bei dem Adapter relativ schnell weiter - wäre super wenn du nochmal drüber schauen könntest und mir meine TODO entsprechend erweitern könntest damit der irgendwann mal offiziell Aufgenommen werden kann.
            Grüße, Thorsten
