  4. Fehlermeldung Adapter Installation
    6.1k
3 Beiträge 3 Kommentatoren 512 Aufrufe
  • L Offline
    LJSven
    Bei jedem Adapter den ich installieren will, kommt eine Fehlermeldung. Was kann ich dagegen machen?
    2018-07-05 20:54:06.775 - info: iobroker exit 0
    2018-07-05 20:54:37.842 - info: iobroker del cloud
    2018-07-05 20:54:40.593 - info: iobroker Delete adapter "cloud"
    2018-07-05 20:54:40.726 - info: iobroker host.raspberrypi no instances of adapter cloud found
    2018-07-05 20:54:40.809 - info: iobroker host.raspberrypi Counted 1 adapters for cloud
    2018-07-05 20:54:41.355 - info: iobroker host.raspberrypi Counted 1 states of cloud
    2018-07-05 20:54:41.446 - info: iobroker host.raspberrypi Counted 3 states (system.adapter.cloud.*) from states
    2018-07-05 20:54:41.496 - info: iobroker host.raspberrypi Deleting 2 object(s).
    2018-07-05 20:54:41.523 - info: iobroker host.raspberrypi Deleting 3 state(s).
    2018-07-05 20:54:42.478 - error: host.raspberrypi Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/cloud.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/cloud.admin/_data.json'
    2018-07-05 20:54:43.749 - info: iobroker npm uninstall iobroker.cloud --silent --save --prefix "/opt/iobroker" (System call)
    2018-07-05 20:56:17.114 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
    compilation terminated.
    2018-07-05 20:56:17.134 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    2018-07-05 20:56:23.435 - info: iobroker In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    #include
    2018-07-05 20:56:24.140 - info: iobroker make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    2018-07-05 20:56:38.287 - info: iobroker exit 0
    2018-07-05 20:57:10.731 - info: iobroker add cloud
    2018-07-05 20:57:17.665 - info: iobroker NPM version: 5.8.0
    2018-07-05 20:57:21.055 - info: iobroker npm install iobroker.cloud --production --save --prefix "/opt/iobroker" (System call)
    2018-07-05 20:59:04.446 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
    2018-07-05 20:59:04.456 - info: iobroker compilation terminated.
    2018-07-05 20:59:04.464 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    2018-07-05 20:59:04.478 - info: iobroker gyp
    2018-07-05 20:59:04.484 - info: iobroker
    2018-07-05 20:59:04.487 - info: iobroker ERR! build error
    2018-07-05 20:59:04.501 - info: iobroker gyp
    2018-07-05 20:59:04.504 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/lib/build.js:258:23)
    gyp ERR! stack at emitTwo (events.js:106:13)
    gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    2018-07-05 20:59:04.507 - info: iobroker gyp ERR! System Linux 4.14.34-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    2018-07-05 20:59:04.509 - info: iobroker gyp ERR!
    2018-07-05 20:59:04.516 - info: iobroker cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v6.14.3
    gyp ERR! node-gyp -v v3.6.2
    gyp ERR! not ok
    2018-07-05 20:59:10.810 - info: iobroker In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    #include
    2018-07-05 20:59:10.813 - info: iobroker compilation terminated.
    2018-07-05 20:59:10.826 - info: iobroker make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    2018-07-05 20:59:10.848 - info: iobroker gyp
    2018-07-05 20:59:10.870 - info: iobroker ERR!
    2018-07-05 20:59:10.877 - info: iobroker build error
    2018-07-05 20:59:10.880 - info: iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/lib/build.js:258:23)
    gyp ERR! stack
    2018-07-05 20:59:10.885 - info: iobroker at emitTwo (events.js:106:13)gyp ERR!
    2018-07-05 20:59:10.888 - info: iobroker stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! cwd /opt/iobroker/node_modules/mdns
    gyp ERR! not ok
    2018-07-05 20:59:23.951 - info: iobroker npm
    2018-07-05 20:59:23.972 - info: iobroker WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prebuild-install/package.json'
    2018-07-05 20:59:23.979 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 (node_modules/mdns):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 install: `node-gyp rebuild`
    2018-07-05 20:59:25.630 - info: iobroker host.raspberrypi install adapter cloud
    2018-07-05 20:59:25.676 - info: iobroker got /opt/iobroker/node_modules/iobroker.cloud/admin
    2018-07-05 20:59:25.708 - info: iobroker upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
    2018-07-05 20:59:25.918 - info: iobroker upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
    2018-07-05 20:59:26.024 - info: iobroker upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index.html index.html text/html
    2018-07-05 20:59:26.107 - info: iobroker upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
    2018-07-05 20:59:26.177 - info: iobroker upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
    2018-07-05 20:59:26.242 - info: iobroker upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
    2018-07-05 20:59:26.315 - info: iobroker upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
    2018-07-05 20:59:26.788 - info: iobroker host.raspberrypi object system.adapter.cloud created
    • F Offline
      frodo777
      Hallo
      Ich habe das gleiche Problem.
      Gibt es keine Vorschlag was man das machen kann.
        Balu1973
        Diese Fehlermeldungen sind schon nicht ganz einfach zu verstehen. Meistens liegt der Fehler in nicht installierten Paketen (des Betriebssystems).
        Im Log des ersten Beitrages findet sich drei Mal: "Datei oer Verzeichniss nicht gefunden". Das sind die ersten Anlaufstellen.
        Die Dateien pam_appl.h(2x) und dns_sd.h wurden nicht gefunden. Ich gebe diese Dateinamen dann immer bei Google ein und finde dort in der Regel den Namen des fehlenden Paketes. In diesen Fällen:
        pam_appl.h –> pam-devel
        dns_sd.h --> libavahi-compat-libdnssd-dev
        Diese Pakete dann nachinstallieren und die Adapterinstallation neu anstoßen und schauen was passiert. Wenn neue Fehlermeldungen kommen einfach von vorne anfangen und schauen welche Dateien fehlen...
        Grüße,
        Balu
