  4. History Adapter / Fehlermeldung
    6.1k
2 Beiträge 2 Kommentatoren 247 Aufrufe
  • L Offline
    LJSven
    Ich bekomme beim Update des History Adapter folgende Fehlermeldung. Was kann ich dagegen machen?
    2018-06-25 08:57:25.298 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
    compilation terminated.
    2018-06-25 08:57:25.341 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    2018-06-25 08:57:25.363 - info: iobroker gyp
    2018-06-25 08:57:25.367 - info: iobroker
    2018-06-25 08:57:25.370 - info: iobroker ERR! build error
    2018-06-25 08:57:25.385 - info: iobroker gyp
    2018-06-25 08:57:25.388 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack at emitTwo (events.js:106:13)
    gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack
    2018-06-25 08:57:25.391 - info: iobroker at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)gyp
    2018-06-25 08:57:25.394 - info: iobroker ERR! System Linux 4.14.34-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR!
    2018-06-25 08:57:25.398 - info: iobroker cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v6.14.3
    gyp ERR!
    2018-06-25 08:57:25.430 - info: iobroker node-gyp -v v3.4.0gyp ERR! not ok
    2018-06-25 08:57:31.508 - info: iobroker In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    #include
    2018-06-25 08:57:38.982 - info: iobroker make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.14.34-v7+
    gyp ERR! cwd /opt/iobroker/node_modules/mdns
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    • apollon77A Offline
      Das liegt nicht am history-Adapter, sondern du solltest diese Meldungen bei jedem Install/Update bekommen.
      Das sind optionale Abhängigkeiten von irgendeinem Deiner Adapter die erstmal nicht schlimm sind, aber npm stolpert bei jedem prüfen der Gesamt-Abhängihkeiten drüber und meckert.
      Du musst denke ich zwei Pakete nachinstallieren. Google mal nach den beiden angegebenen ".h"-Dateien und "debian". dazu. Dann sagt er dir wie die Pakete heissen.
