  4. [GELÖST]Zigbee Adapter - Fehler bei Installation
3 Beiträge 2 Kommentatoren 976 Aufrufe
  • overfl0wO Offline
    overfl0wO Offline
    overfl0w
    Moin Moin, ich wollte gerade den aktuellen Zigbee Adapter in meiner Instanz installieren, da mein Stick angekommen ist.
    Beim installieren bekomme ich einen Fehler, ich bin kein Profi und denke es liegt an meinem Betriebssystem?
    Ich verwende ein ASUS Tinkerboard und bekomme folgende Fehlermeldung:
    $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee" --debug
    install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
    npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --production --prefix "/opt/iobroker" (System call)
    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
    compilation terminated.authenticate_pam.target.mk:92: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failed
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
    gyp
     ERR!
     build error
    gyp
     ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.13.14-rockchip
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v6.12.0
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    iobroker@1.0.0 /opt/iobroker└─┬ iobroker.zigbee@0.7.1
      ├── zigbee-shepherd@0.3.0
      └── zigbee-shepherd-converters@2.0.41
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    process exited with code 0
    Danke für jegliche Hilfe im Voraus
    LG
    Faulheit? Nein Smarthome :)
    • apollon77A Offline
      Lles ok, das sind warnungen von anderen optionalen Paketen von anderen Adaptern die er halt immer wieder versucht zu fixen. Aber an der Stelle sollte zigbee erfolgreich installiert sein.
      Ggf musst Du im Admin manuell auf das "+" klicken um eine Instanz anzulegen.
      • overfl0wO Offline
        overfl0wO Offline
        overfl0w
        Läuft jetzt :-) Habe die Kiste rebootet, Nochmals den Adapter installiert und „tadaa“ läuft.
        Danke nochmal
        Lg
