  4. Lets encrypt Problem
3 Beiträge 3 Kommentatoren 1.2k Aufrufe
  • a200A Offline
    a200A Offline
    a200
    moin,
    ich habe SSL laut der Anleitung (https://www.youtube.com/watch?v=H9InPtesDOU) durchgeführt. Es wurden auch folgende Dateien in meinem Zertifikatsverzeichnis erzeugt:
    ./accounts/acme-v01.api.letsencrypt.org/directory/d2277e6fexa77ffab37a5281caa5f57ed/private_key.json
    ./accounts/acme-v01.api.letsencrypt.org/directory/d2277e6fexa77ffab37a5281caa5f57ed/meta.json
    ./accounts/acme-v01.api.letsencrypt.org/directory/d2277e6fexa77ffab37a5281caa5f57ed/regr.json
    ./live/ichbins.de/privkey.pem
    Ich bekomme im Logfile folgende Meldungen:
    web.0	2018-06-24 11:52:11.774	error	- https://acme-v01.api.letsencrypt.org/acme/challenge/oax26gpUKrqSuEp1h7PO_Auh5wuBPSU2mNWVugqgDB8V18/5276426220 [invalid]
    web.0	2018-06-24 11:52:11.774	error	The key authorization file from the server did not match this challenge [41h7PO_Auh5wuBPSU2mNWVugqgfnwOLr5-j7U0QYO_Auh5wuBPSU2mNLAxq2il1kgV6rxrlLc477WKKkiw8] != [<title>ichbins.de</
    web.0	2018-06-24 11:52:11.774	error	- https://acme-v01.api.letsencrypt.org/acme/challenge/oax26gpUKrqSuEp1h7PO_Auh5wuBPSU2mNWVugqgDB8V18/5276426219 [invalid]
    web.0	2018-06-24 11:52:11.774	error	Cannot get certificates: Error: The CA was unable to validate the file you provisioned.
    web.0	2018-06-24 11:52:11.719	info	removeChallenge called for 'ichbins.de'
    web.0	2018-06-24 11:52:10.191	info	setChallenge called for 'ichbins.de'
    web.0	2018-06-24 11:52:09.567	info	calling greenlock.acme.getCertificateAsyncichbins.de
    web.0	2018-06-24 11:52:09.091	info	d2277e6fexa77ffab37a5281caa5f57ed
    web.0	2018-06-24 11:52:09.089	info	regrs.length1
    web.0	2018-06-24 11:52:09.082	info	success reading arg.accountsDir
    web.0	2018-06-24 11:52:09.057	info	checkAsync failed to find certificates
    web.0	2018-06-24 11:52:09.004	info	gl getting from disk or registering new
    web.0	2018-06-24 11:52:09.004	info	[object Object]
    web.0	2018-06-24 11:52:09.003	info	gl.approveDomains called with certs forNONEand options:
    web.0	2018-06-24 11:52:08.997	info	gl.getCertificates called forichbins.dewith certs for
    web.0	2018-06-24 11:51:58.936	info	https server listening on port 443
    web.0	2018-06-24 11:51:58.933	info	LetsEncrypt challenge server is started on 80
    web.0	2018-06-24 11:51:58.930	info	Secure socket.io server listening on port 443
    web.0	2018-06-24 11:51:58.457	info	created middleware
    web.0	2018-06-24 11:51:55.815	info	starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
    web.0	2018-06-24 11:51:23.872	info	LetsEncrypt challenge server is started on 80</pre></CODE><br /><br />Muss ich die erstellten Zertifikate nicht noch in IoBroker unter Zertifikate einbinden? Allerdings habe ich nur den einen: <B><s><strong></s>./live/ichbins.de/privkey.pem</strong></B><br/><br /><br/><br />über Unterstützung würde ich mich sehr freuen.<br/><br />a200.</title>
      speedy
      konntest du es lösen?
      habe leider auch nichts gefunden wie hier vorzugehen ist…
      ich habe noch das problem, dass ich einen fehler bekomme, wenn ich auf https usw. umstelle, log sieht wie folgt aus:
      ` > 2018-08-16 22:32:46.304 - error: Caught by controller[1]: ==========================================================
      2018-08-16 22:32:46.305 - error: Caught by controller[1]: == greenlock.js (v2.2.0+) ==
      2018-08-16 22:32:46.305 - error: Caught by controller[2]: ==========================================================
      2018-08-16 22:32:46.305 - error: Caught by controller[3]: Please specify 'version' option:
      2018-08-16 22:32:46.305 - error: Caught by controller[4]: 'draft-12' for Let's Encrypt v2 and ACME draft 12
      2018-08-16 22:32:46.305 - error: Caught by controller[4]: ('v02' is an alias of 'draft-12'
      2018-08-16 22:32:46.306 - error: Caught by controller[6]: or
      2018-08-16 22:32:46.306 - error: Caught by controller[7]: 'v01' for Let's Encrypt v1 (deprecated)
      2018-08-16 22:32:46.306 - error: Caught by controller[8]: (also 'npm install –save le-acme-core' as this legacy dependency will soon be removed)
      2018-08-16 22:32:46.306 - error: Caught by controller[9]: This will be required in versions v2.3+
      2018-08-16 22:32:46.306 - error: Caught by controller[11]: Detected Let's Encrypt v01 URL (deprecated). Changing version to v01.
      2018-08-16 22:32:46.306 - error: Caught by controller[13]: === WARNING ===
      2018-08-16 22:32:46.306 - error: Caught by controller[13]: Let's Encrypt v1 is deprecated.
      2018-08-16 22:32:46.306 - error: Caught by controller[14]: Please update to Let's Encrypt v2 (ACME draft 12)
      2018-08-16 22:32:46.306 - error: Caught by controller[16]: === Error (easy-to-fix) ===
      2018-08-16 22:32:46.306 - error: Caught by controller[17]: Hey, this isn't a big deal, but you need to manually add v1 support:
      2018-08-16 22:32:46.306 - error: Caught by controller[17]: npm install –save le-acme-core
      2018-08-16 22:32:46.306 - error: Caught by controller[18]: Just run that real quick, restart, and everything will work great.
      2018-08-16 22:32:46.307 - error: host.ioBroker-RasPi instance system.adapter.admin.0 terminated with code 0 (OK) `
      ioBroker - Neuling ;)
        thoemmes86
        Gleiches Problem hier!
        Hat irgendjemand eine Lösung dafür?
