  4. OPC UA Server
    6.0k
OPC UA Server
3 Beiträge 2 Kommentatoren 830 Aufrufe
    tiego
    Guten Tag,
    kann es sein das der OPC UA Server unter dem aktuellen admin nicht funktioniert?
    er startet immer neu,…
    oder mach ich bei der konfig was falsch?
    host.ioBroker-Pi	2018-05-20 10:43:50.210	info	Restart adapter system.adapter.opcua.0 because enabled
    host.ioBroker-Pi	2018-05-20 10:43:50.210	error	instance system.adapter.opcua.0 terminated with code 0 (OK)
    host.ioBroker-Pi	2018-05-20 10:43:50.210	error	Caught by controller[0]: at Function.Module._load (module.js:445:3) code: 'MODULE_NOT_FOUND' }
    host.ioBroker-Pi	2018-05-20 10:43:50.210	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    host.ioBroker-Pi	2018-05-20 10:43:50.210	error	Caught by controller[0]: at Module.load (module.js:494:32)
    host.ioBroker-Pi	2018-05-20 10:43:50.209	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    host.ioBroker-Pi	2018-05-20 10:43:50.209	error	Caught by controller[0]: at Module._compile (module.js:577:32)
    host.ioBroker-Pi	2018-05-20 10:43:50.207	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.opcua/node_modules/node-opcua-data-model/src/localized_text.js:8:76)
    host.ioBroker-Pi	2018-05-20 10:43:50.205	error	Caught by controller[0]: at require (internal/module.js:20:19)
    host.ioBroker-Pi	2018-05-20 10:43:50.202	error	Caught by controller[0]: at Module.require (module.js:504:17)
    host.ioBroker-Pi	2018-05-20 10:43:50.200	error	Caught by controller[0]: at Function.Module._load (module.js:424:25)
    host.ioBroker-Pi	2018-05-20 10:43:50.198	error	Caught by controller[0]: at Function.Module._resolveFilename (module.js:476:15)
    host.ioBroker-Pi	2018-05-20 10:43:50.198	error	Caught by controller[0]: { Error: Cannot find module '../_generated_/_auto_generated_LocalizedText'
    opcua.0	2018-05-20 10:43:49.658	error	Error: Cannot find module '../_generated_/_auto_generated_LocalizedText' at Function.Module._resolveFilename (module.js:476:15) at Function.Module._load (module.js:424:25) at Module.requir
    opcua.0	2018-05-20 10:43:49.656	error	uncaught exception: Cannot find module '../_generated_/_auto_generated_LocalizedText'</anonymous>
    • apollon77A Offline
      Mal den Adapter neu installiert? Was sagt das log davon? Ansonsten Ostblock mehr im log als gepostet.
        tiego
        danke für deine Rückmeldung, hab soeben Iobroker und OPC UA auf den Testsystem neu installiert.
        das log der Installation:
        $ ./iobroker add opcua
        host.ioBroker-Pi install adapter opcua
        npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.opcua"
        npm
         WARN deprecated delayed@1.0.1: no longer maintained
        got /opt/iobroker/node_modules/iobroker.opcua/admin
        upload [2] opcua.admin /opt/iobroker/node_modules/iobroker.opcua/admin/words.js words.js application/javascript
        upload [1] opcua.admin /opt/iobroker/node_modules/iobroker.opcua/admin/opcua.png opcua.png image/png
        upload [0] opcua.admin /opt/iobroker/node_modules/iobroker.opcua/admin/index.html index.html text/html
        host.ioBroker-Pi object system.adapter.opcua created
        host.ioBroker-Pi create instance opcua
        host.ioBroker-Pi object opcua.0.info created
        host.ioBroker-Pi object system.adapter.opcua.0.outputCount created
        host.ioBroker-Pi object system.adapter.opcua.0.inputCount created
        host.ioBroker-Pi object system.adapter.opcua.0.uptime created
        host.ioBroker-Pi object system.adapter.opcua.0.memRss created
        host.ioBroker-Pi object system.adapter.opcua.0.memHeapTotal created
        host.ioBroker-Pi object system.adapter.opcua.0.memHeapUsed created
        host.ioBroker-Pi object system.adapter.opcua.0.connected created
        host.ioBroker-Pi object system.adapter.opcua.0.alive created
        host.ioBroker-Pi object system.adapter.opcua.0 created
        process exited with code 0
        Log nach dem Starten des OPC
        host.ioBroker-Pi	2018-05-25 15:48:46.822	info	Restart adapter system.adapter.opcua.0 because enabled
        host.ioBroker-Pi	2018-05-25 15:48:46.821	error	instance system.adapter.opcua.0 terminated with code 0 (OK)
        host.ioBroker-Pi	2018-05-25 15:48:46.821	error	Caught by controller[0]: at Function.Module._load (module.js:445:3) code: 'MODULE_NOT_FOUND' }
        host.ioBroker-Pi	2018-05-25 15:48:46.820	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
        host.ioBroker-Pi	2018-05-25 15:48:46.818	error	Caught by controller[0]: at Module.load (module.js:494:32)
        host.ioBroker-Pi	2018-05-25 15:48:46.817	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
        host.ioBroker-Pi	2018-05-25 15:48:46.816	error	Caught by controller[0]: at Module._compile (module.js:577:32)
        host.ioBroker-Pi	2018-05-25 15:48:46.814	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.opcua/node_modules/node-opcua-data-model/src/localized_text.js:8:76)
        host.ioBroker-Pi	2018-05-25 15:48:46.813	error	Caught by controller[0]: at require (internal/module.js:20:19)
        host.ioBroker-Pi	2018-05-25 15:48:46.811	error	Caught by controller[0]: at Module.require (module.js:504:17)
        host.ioBroker-Pi	2018-05-25 15:48:46.810	error	Caught by controller[0]: at Function.Module._load (module.js:424:25)
        host.ioBroker-Pi	2018-05-25 15:48:46.809	error	Caught by controller[0]: at Function.Module._resolveFilename (module.js:476:15)
        host.ioBroker-Pi	2018-05-25 15:48:46.807	error	Caught by controller[0]: { Error: Cannot find module '../_generated_/_auto_generated_LocalizedText'
        opcua.0	2018-05-25 15:48:46.278	error	Error: Cannot find module '../_generated_/_auto_generated_LocalizedText' at Function.Module._resolveFilename (module.js:476:15) at Function.Module._load (module.js:424:25) at Module.requir
        opcua.0	2018-05-25 15:48:46.276	error	uncaught exception: Cannot find module '../_generated_/_auto_generated_LocalizedText'
        opcua.0	2018-05-25 15:48:46.275	info	Published 1122 states
        opcua.0	2018-05-25 15:48:44.446	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.opcua, node: v6.14.2
        host.ioBroker-Pi	2018-05-25 15:48:42.721	info	instance system.adapter.opcua.0 started with pid 26040
        host.ioBroker-Pi	2018-05-25 15:48:42.655	info	"system.adapter.opcua.0" enabled
        host.ioBroker-Pi	2018-05-25 15:48:42.653	info	object change system.adapter.opcua.0</anonymous>
        reichen diese Informationen?
        danke
