  4. IoBroker Simple Web Adapter und Visualisierung läuft nicht
    5.4k
5 Beiträge 2 Kommentatoren 1.4k Aufrufe
  • F Offline
    Fonzo
    Ich habe mal versucht ioBroker auf einem Raspberry PI 2 zu installieren. IoBroker läuft auch allerdings startet die Visulaisierung nicht. Woran kann das denn liegen? Der simple Web Adapter läuft auch nicht.
    raspberrypi 2015-10-11 14:48:10 info host.raspberrypi Restart adapter system.adapter.web.0 because enabled
    raspberrypi 2015-10-11 14:48:10 error host.raspberrypi instance system.adapter.web.0 terminated with code 6 (uncaught exception)
    web.0 2015-10-11 14:48:10 info web.0 http server listening on port 8082
    web.0 2015-10-11 14:48:10 error Error: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' at Function.Module._resolveFilename (module.js:336:15) at Function.Modu
    web.0 2015-10-11 14:48:10 error uncaught exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js'
    web.0 2015-10-11 14:48:10 info web.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.web
    raspberrypi 2015-10-11 14:48:07 info host.raspberrypi instance system.adapter.web.0 started with pid 18657
    raspberrypi 2015-10-11 14:47:46 info host.raspberrypi Restart adapter system.adapter.web.0 because enabled
    raspberrypi 2015-10-11 14:47:46 error host.raspberrypi instance system.adapter.web.0 terminated with code 6 (uncaught exception)
    web.0 2015-10-11 14:47:45 info web.0 http server listening on port 8082
    web.0 2015-10-11 14:47:45 error Error: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' at Function.Module._resolveFilename (module.js:336:15) at Function.Modu
    web.0 2015-10-11 14:47:45 error uncaught exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js'
    web.0 2015-10-11 14:47:45 info web.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.web
      Hast du das Image von der Website genommen?
      Kann sein, dass da ein Bug drin ist.
      Rainer
      • F Offline
        Fonzo
        Ne kein Image genommen. Jessie installiert, dann Node.js und dann ioBroker über npm
          Auch hier:
          welches node?
          Habe damit auch Probleme gehabt bei der Erstellung der Images und daher bisher auf Jessie verzichtet.
          Gibt es Fehlermeldungen im log?
          Rainer
          • F Offline
            Fonzo
            @Homoran:
            Auch hier:
            welches node? `
            4.1.2
