  4. Fehler nach neu installation
    6.0k
9 Beiträge 2 Kommentatoren 1.3k Aufrufe
  • J Offline
    JavaMafia
    ich habe heute die neue Version des ioBrokers installieren wollen. Leider startet der ioBroker nicht, mir wird zwar das Interface angezeigt. Doch leider ist der Ladekringel nur am kringeln.
    Leider hinder mich anscheind dieser Fehler (Auszug aus dem Log).
    ` > 2018-05-01 14:31:34.872 - info: host.ioBroker iobroker.js-controller version 1.4.0 js-controller starting
    2018-05-01 14:31:34.880 - info: host.ioBroker Copyright © 2014-2018 bluefox, 2014 hobbyquaker
    2018-05-01 14:31:34.881 - info: host.ioBroker hostname: ioBroker, node: v8.11.1
    2018-05-01 14:31:34.887 - info: host.ioBroker ip addresses: 192.168.37.24 fe80::89e8:8799:4ef9:64c5
    2018-05-01 14:31:35.197 - info: host.ioBroker inMem-objects listening on port 9001
    2018-05-01 14:31:35.227 - error: Another instance is running or some application uses port!
    2018-05-01 14:31:35.227 - error: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
    2018-05-01 14:31:35.243 - info: iobroker _restart
    2018-05-01 14:31:35.282 - info: host.ioBroker States connected to redis: 127.0.0.1:6379
    2018-05-01 14:31:35.286 - info: host.ioBroker InMemoryDB connected
    2018-05-01 14:31:35.309 - info: host.ioBroker 13 instances found
    host.ioBroker check instance "system.adapter.admin.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.discovery.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.hm-rpc.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.hm-rega.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.web.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.rpi2.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.socketio.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.cloud.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.vis.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.history.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.javascript.0" for host "ioBroker"
    host.ioBroker check instance "system.adapter.mobile.0" for host "ioBroker"
    2018-05-01 14:31:35.331 - info: host.ioBroker starting 8 instances
    2018-05-01 14:31:35.389 - info: host.ioBroker instance system.adapter.admin.0 started with pid 4222
    Cannot convert undefined or null to object
    TypeError: Cannot convert undefined or null to object
    at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:863:9)
    at runCallback (timers.js:798:20)
    at tryOnImmediate (timers.js:752:5)
    at processImmediate [as _immediateCallback] (timers.js:729:5) `
    oder es wird mir das angezeigt
    ` > 2018-05-01 14:34:25.880 - info: host.ioBroker iobroker.js-controller version 1.4.0 js-controller starting
    2018-05-01 14:34:25.890 - info: host.ioBroker Copyright © 2014-2018 bluefox, 2014 hobbyquaker
    2018-05-01 14:34:25.892 - info: host.ioBroker hostname: ioBroker, node: v8.11.1
    2018-05-01 14:34:25.899 - info: host.ioBroker ip addresses: 192.168.37.24 fe80::89e8:8799:4ef9:64c5
    2018-05-01 14:34:26.230 - info: host.ioBroker inMem-objects listening on port 9001
    2018-05-01 14:34:26.285 - info: host.ioBroker States connected to redis: 127.0.0.1:6379
    2018-05-01 14:34:26.289 - info: host.ioBroker InMemoryDB connected
    2018-05-01 14:34:26.313 - info: host.ioBroker 13 instances found
    2018-05-01 14:34:26.334 - info: host.ioBroker starting 8 instances
    2018-05-01 14:34:26.389 - info: host.ioBroker instance system.adapter.admin.0 started with pid 5531
    2018-05-01 14:34:26.420 - error: uncaught exception: Cannot convert undefined or null to object
    2018-05-01 14:34:26.424 - error: TypeError: Cannot convert undefined or null to object
    2018-05-01 14:34:26.433 - info: iobroker _restart
    2018-05-01 14:34:27.210 - info: iobroker Starting node restart.js
    2018-05-01 14:34:27.273 - info: iobroker exit 0
    2018-05-01 14:34:29.976 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    2018-05-01 14:34:29.977 - info: host.ioBroker All instances are stopped.
    EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-05-01_14-34_objects.json.gz'
    Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-05-01_14-34_objects.json.gz' `
    Habe leider auch im Internet nichts zu diesem Fehler gefunden. Eine Neuinstallation habe ich auch schon vorgenommen.
      @JavaMafia:
      ich habe heute die neue Version des ioBrokers installieren wollen. `
      welche?
      ich nehme mal an du meinst ein Image? Wenn ja welches und welche Hardware?
      Rainer
      • J Offline
        JavaMafia
        Hardware ist ein RaspberryPi 3 Model B Ver.2
        Image:
        http://www.iobroker.net/docu/?page_id=2563&lang=de
        habe ich das genutzt.
        • J Offline
          JavaMafia
          komme jetzt auch den Log aus dem Interface.
          ` > admin.0
          2018-05-01 14:45:45.495
          warn
          Reconnection to DB.
          admin.0
          2018-05-01 14:45:45.438
          warn
          Reconnection to DB.
          host.ioBroker
          2018-05-01 14:45:37.631
          info
          received SIGTERM
          host.ioBroker
          2018-05-01 14:45:37.255
          info
          iobroker exit 0
          host.ioBroker
          2018-05-01 14:45:37.218
          info
          host.ioBroker
          2018-05-01 14:45:36.603
          info
          iobroker _restart
          host.ioBroker
          2018-05-01 14:45:36.602
          error
          TypeError: Cannot convert undefined or null to object at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:863:9) at runCallback (timers.js:798:20) at
          host.ioBroker
          error
          host.ioBroker
          2018-05-01 14:45:36.601
          info
          admin.0
          2018-05-01 14:45:31.905
          warn
          Reconnection to DB.
          admin.0
          2018-05-01 14:45:31.888
          warn
          Reconnection to DB. `
          • J Offline
            JavaMafia
            Jetzt klappt der ioBroker, habe noch mal die Datei runter geladen und alles neu gemacht.
              Das hätte mich auch sehr gewundert.
              892 Downloads (falls es das ist was du hast) und du bist der erste der Probleme hat.
              Rainer
              • J Offline
                JavaMafia
                der Fehler ist wieder da.
                Er taucht bei mir immer auf wenn ich die IP manuel ändere
                  @JavaMafia:
                  Er taucht bei mir immer auf wenn ich die IP manuel ändere `
                  Welche IP?
                  wie und warum änderst du sie?
                  Rainer
                  • J Offline
                    JavaMafia
                    Wenn ich die IP Adresse der RaspberryPi manuel ändere, hängt sich der ioBroker auf. Jetzt habe ich die IP im Router als DHCP festgelegt und der ioBroker funktioniert jetzt
