  4. [Gelöst] harmony Adapter Error bei install
    6.0k
2 Beiträge 2 Kommentatoren 753 Aufrufe
    badplay
    hey
    habe mein rpi3 neu aufgesetzt alles nach anleitung installiert node -v und nodejs -v gibt auch entsprechend der anleitung richtige version aus aber der adapter schreibt error
    ! $ ./iobroker add harmony
    ! npm install iobroker.harmony –production --prefix "/opt/iobroker" (System call)
    ! npm
    ! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefinednpm
    ! ERR!
    ! npm
    ! WARN
    ! deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
    ! npm
    ! ERR!
    ! Linux 4.9.80-v7+
    ! npm ERR!
    ! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
    ! npm ERR!
    ! node v6.14.1
    ! npm ERR!
    ! npm v3.10.10
    ! npm
    ! ERR!
    ! code
    ! ENOGIT
    ! npm ERR! not found: gitnpm ERR!
    ! npm ERR! Failed using git.
    ! npm ERR! This is most likely not a problem with npm itself.
    ! npm ERR!
    ! Please check if you have git installed and in your PATH.
    ! npm
    ! ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ! host.raspberrypi install adapter harmony
    ! npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    ! npm
    ! WARN
    ! addRemoteGit
    ! Error: not found: gitnpm
    ! WARN
    ! addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm
    ! WARN
    ! addRemoteGit
    ! at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm
    ! WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! npm
    ! WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
    ! npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cd ... ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
    ! npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    ! npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    ! npm
    ! ERR!
    ! npm ERR!
    ! npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
    ! npm
    ! ERR! Linux 4.9.80-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
    ! npm ERR! node v6.14.1
    ! npm ERR! npm v3.10.10
    ! npm ERR! code ENOGIT
    ! npm ERR! Please check if you have git installed and in your PATH.
    ! npm ERR! Please include the following file with any support request:
    ! npm ERR! /npm-debug.log
    ! npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml%3Enpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
    ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
    ! npm
    ! npm ERR! node
    ! v6.14.1npm ERR! npm v3.10.10
    ! ERROR: host.raspberrypi Cannot install harmony
    ! ERROR: process exited with code 13
    hab es mir selbst beantwortet
    sudo apt-get install git-core
    sudo apt-get update
    sudo apt-get upgrade
    bekomme den adapter nun mit error installiert so weit alles gut ?
    ! harmony.0 2018-04-14 18:44:00.167 info synced hub config
    ! harmony.0 2018-04-14 18:44:00.145 info added new device: Marantz_AV-Empfänger
    ! harmony.0 2018-04-14 18:44:00.120 info added new device: Sony_TV
    ! harmony.0 2018-04-14 18:44:00.092 info added new device: Microsoft_Xbox_360
    ! harmony.0 2018-04-14 18:44:00.088 info added new activity: Iobroker
    ! harmony.0 2018-04-14 18:44:00.086 info added new activity: Kino
    ! harmony.0 2018-04-14 18:44:00.085 info added new activity: Musik_hören
    ! harmony.0 2018-04-14 18:44:00.079 info added new activity: Wiedergabe_Xbox_360
    ! harmony.0 2018-04-14 18:43:58.997 info connected to Harmony Hub
    ! harmony.0 2018-04-14 18:43:56.414 info connecting to Harmony Hub
    ! harmony.0 2018-04-14 18:43:56.396 info discovered Harmony Hub
    ! harmony.0 2018-04-14 18:43:55.039 info searching for Harmony Hubs…
    ! harmony.0 2018-04-14 18:43:54.987 info starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v6.14.1
    ! iobroker 2018-04-14 18:43:52.397 info exit 0
    ! iobroker 2018-04-14 18:43:52.376 info host.raspberrypi object system.adapter.harmony.0 created
    ! host.raspberrypi 2018-04-14 18:43:52.371 info instance system.adapter.harmony.0 started with pid 32731
    ! host.raspberrypi 2018-04-14 18:43:52.343 info object change system.adapter.harmony.0
    ! iobroker 2018-04-14 18:43:52.306 info host.raspberrypi object system.adapter.harmony.0.alive created
    ! iobroker 2018-04-14 18:43:52.270 info host.raspberrypi object system.adapter.harmony.0.connected created
    ! iobroker 2018-04-14 18:43:52.237 info host.raspberrypi object system.adapter.harmony.0.memHeapUsed created
    ! iobroker 2018-04-14 18:43:52.205 info host.raspberrypi object system.adapter.harmony.0.memHeapTotal created
    ! iobroker 2018-04-14 18:43:52.171 info host.raspberrypi object system.adapter.harmony.0.memRss created
    ! iobroker 2018-04-14 18:43:52.136 info host.raspberrypi object system.adapter.harmony.0.uptime created
    ! iobroker 2018-04-14 18:43:52.097 info host.raspberrypi object system.adapter.harmony.0.inputCount created
    ! iobroker 2018-04-14 18:43:52.062 info host.raspberrypi object system.adapter.harmony.0.outputCount created
    ! iobroker 2018-04-14 18:43:52.049 info host.raspberrypi create instance harmony
    ! iobroker 2018-04-14 18:43:52.012 info host.raspberrypi object system.adapter.harmony created
    ! iobroker 2018-04-14 18:43:51.876 info upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
    ! iobroker 2018-04-14 18:43:51.770 info upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
    ! iobroker 2018-04-14 18:43:51.740 info got /opt/iobroker/node_modules/iobroker.harmony/admin
    ! iobroker 2018-04-14 18:43:27.493 info WARN deprecated node-xmpp-jid@2.3.0: use @xmpp/jid package
    ! iobroker 2018-04-14 18:43:27.491 info npm
    ! iobroker 2018-04-14 18:43:18.505 info WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
    ! iobroker 2018-04-14 18:43:18.503 info npm
    ! iobroker 2018-04-14 18:43:14.199 info npm install –production (System call) in "/opt/iobroker/node_modules/iobroker.harmony"
    ! iobroker 2018-04-14 18:43:14.192 info host.raspberrypi install adapter harmony
    ! iobroker 2018-04-14 18:42:47.832 info node-xmpp-jid@2.3.0: use @xmpp/jid package
    ! iobroker 2018-04-14 18:42:47.830 info WARN deprecated
    ! iobroker 2018-04-14 18:42:47.828 info npm
    ! iobroker 2018-04-14 18:42:36.468 info npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
    ! iobroker 2018-04-14 18:42:36.359 info npm WARN addRemoteGit cmd: 'git config --get remote.origin.url' }
    ! iobroker 2018-04-14 18:42:36.359 info code: 1,npm WARN addRemoteGit signal: null,
    ! iobroker 2018-04-14 18:42:36.355 info addRemoteGit killed: false,npm WARN addRemoteGit
    ! iobroker 2018-04-14 18:42:36.350 info npm WARN
    ! iobroker 2018-04-14 18:42:36.350 info npm WARN addRemoteGit at Pipe._handle.close [as _onclose] (net.js:509:12)
    ! iobroker 2018-04-14 18:42:36.350 info npm WARN addRemoteGit at Socket.emit (events.js:188:7)
    ! iobroker 2018-04-14 18:42:36.350 info WARN addRemoteGit at Socket. (internal/child_process.js:351:11)npm WARN addRemoteGit at emitOne (events.js:96:13)
    ! iobroker 2018-04-14 18:42:36.340 info npm
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at maybeClose (internal/child_process.js:920:16)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at ChildProcess.emit (events.js:191:7)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at emitTwo (events.js:106:13)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at ChildProcess.exithandler (child_process.js:199:12)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cd … ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b becau
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at Pipe._handle.close [as _onclose] (net.js:509:12)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at Socket.emit (events.js:188:7)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at emitOne (events.js:96:13)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit at Socket. (internal/child_process.js:351:11)
    ! iobroker 2018-04-14 18:42:36.340 info npm WARN addRemoteGit Error: Command failed: git config –get remote.origin.urlnpm WARN addRemoteGit
    ! iobroker 2018-04-14 18:42:20.512 info npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    ! iobroker 2018-04-14 18:42:18.549 info add harmony
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      Auch wenn es jetzt läuft.
      Wenn du den PI neu installiert hast gehe ich von Jessie oder Stretch aus.
      Dann wäre der richtige Befehl zum installieren von GIT dieser:
      sudo apt install git
      Und für ein Upgrade der Linux Pakete sollte man das „-get“ weglassen.
      Laut deinem Log wurden ja Devices und Aktionen gefunden. Somit sollte jetzt alles gut sein.
      Kannst du dann bitte den Titel vom ersten Post um ein````
      [Gelöst]
      Schönen Sonntag
