  4. [gelöst]: sonoff.0 Error: listen EADDRINUSE 0.0.0.0:1883
    6.0k
3 Beiträge 2 Kommentatoren 2.7k Aufrufe
    der_Auge
    habe den Adapter mqtt auf meinem System laufen.
    Er empfängt von den beiden Sonoff 4CH Pro alle Informationen
    nun wollte ich den Sonoff-Adapter testen
    nach der Installation und Konfiguration kommt die Fehlermeldung im Log:
    2018-04-08 10:43:33.217  - info: host.ioServer instance system.adapter.sonoff.0 started with pid 18859
    2018-04-08 10:43:34.630  - info: sonoff.0 starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v4.8.4
    2018-04-08 10:43:34.760  - error: sonoff.0 uncaught exception: listen EADDRINUSE 0.0.0.0:1883
    2018-04-08 10:43:34.765  - error: sonoff.0 Error: listen EADDRINUSE 0.0.0.0:1883
        at Object.exports._errnoException (util.js:907:11)
        at exports._exceptionWithHostPort (util.js:930:20)
        at Server._listen2 (net.js:1253:14)
        at listen (net.js:1289:10)
        at net.js:1398:9
        at nextTickCallbackWith3Args (node.js:522:9)
        at process._tickCallback (node.js:428:17)
    2018-04-08 10:43:34.812  - info: sonoff.0 terminating
    2018-04-08 10:43:34.839  - error: host.ioServer instance system.adapter.sonoff.0 terminated with code 0 (OK)
    2018-04-08 10:43:34.842  - info: host.ioServer Restart adapter system.adapter.sonoff.0 because enabled
    2018-04-08 10:44:04.857  - info: host.ioServer instance system.adapter.sonoff.0 started with pid 18877
    2018-04-08 10:44:06.175  - info: sonoff.0 starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v4.8.4
    2018-04-08 10:44:06.284  - error: sonoff.0 uncaught exception: listen EADDRINUSE 0.0.0.0:1883
    2018-04-08 10:44:06.289  - error: sonoff.0 Error: listen EADDRINUSE 0.0.0.0:1883
        at net.js:1398:9
    2018-04-08 10:44:06.331  - info: sonoff.0 terminating
    ` > root@ioServer:/opt/iobroker# node -v
    v4.8.4
    root@ioServer:/opt/iobroker# npm -v
    2.15.11
    root@ioServer:/opt/iobroker# `
    Was mache ich falsch ?
    Jürgen
    Master: DN2820FYKH (4GB) Linux NUC 4.4.0-22-generic #40-Ubuntu x86_64
    Slave: Linux RPi2-1 4.1.19-v7+ #858 v4.4.3 # 2.15.1
    SQL-DB : Linux DS 3.10.77 #7321 x86_64 synology412+
    Test : DS916+ VM Debian
    Test : Tinker mit piVCCU
      Hallo Jürgen und schön mal wieder was von dir zu hören.
      Hast du noch andere Adapter, die auf port 1883 laufen?
      Oder andere programme suf dem ??.
      Welche Hardware?
      Evtl. Ist die zu langsam, einfach sofort nochmal probieren.
      Ganz abgesehen davon ist deine Installation von nodejs und npm ziemlich alt. Der Support für Node4 wird in den nächsten Tagen eingestellt.
      Gruß Rainer
        der_Auge
        Danke Rainer für die schnelle Antwort
        du hast recht damit, dass auf Port 1883 bereits ein Adapter läuft. Der MQTT-Adapter.
        Danke für den Denkanstoß
        Nun habe ich auch verstanden dass der Sonoff-Adapter einen eigenen MQTT-Broker bereit stellt. Das hatte ich nicht gewust.
        Wünsche noch einen schönen Sonntag
        Jürgen
