  4. Fehler bei Installation des Harmony Adapters
    6.0k
2 Beiträge 2 Kommentatoren 370 Aufrufe
    blacktiger
    Nachdem mein Harmony Adapter immer wieder Probleme machte (verliert regelmässig Kontakt zum Harmony Hub, obwohl dieser via Ping und von anderen Geräten ohne Probleme erreichbar ist), habe ich diesen neu installiert.
    Beim Installieren bekomme ich aber folgende Fehlermeldung:
    iobroker	2018-04-02 11:06:52.083	info	got /opt/iobroker/node_modules/iobroker.harmony/admin
    iobroker	2018-04-02 11:06:38.404	info	WARN deprecated node-xmpp-jid@2.3.0: use @xmpp/jid package
    iobroker	2018-04-02 11:06:38.403	info	npm
    iobroker	2018-04-02 11:06:30.744	info	WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
    iobroker	2018-04-02 11:06:30.743	info	npm
    iobroker	2018-04-02 11:06:28.066	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.harmony"
    iobroker	2018-04-02 11:06:28.064	info	host.iobroker install adapter harmony
    iobroker	2018-04-02 11:06:27.992	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    iobroker	2018-04-02 11:06:27.992	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    iobroker	2018-04-02 11:06:27.992	info	notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPEN
    iobroker	2018-04-02 11:06:27.985	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN
    iobroker	2018-04-02 11:06:27.984	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupport
    iobroker	2018-04-02 11:06:27.983	info	npm
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! not ok
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! node-gyp -v v3.4.0
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! node -v v6.12.2
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! System Linux 3.10.102
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! stack at emitTwo (events.js:106:13)
    iobroker	2018-04-02 11:06:21.976	info	gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    iobroker	2018-04-02 11:06:21.970	info	build error
    iobroker	2018-04-02 11:06:21.966	info	gyp ERR!
    iobroker	2018-04-02 11:06:21.962	info	make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    iobroker	2018-04-02 11:06:21.962	info	compilation terminated.
    iobroker	2018-04-02 11:06:21.962	info	^
    iobroker	2018-04-02 11:06:21.962	info	../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
    host.iobroker	2018-04-02 11:06:01.859	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    tvspielfilm.0	2018-04-02 11:06:01.317	info	force terminating adapter after 1 minute
    iobroker	2018-04-02 11:05:46.140	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    iobroker	2018-04-02 11:05:44.903	info	add harmony
    Die Instanz wird trotzdem angelegt und läuft soweit, allerdings wird kein harmony.0 Objekt angelegt (auch nicht nach refresh).
    Log Info dazu:
    harmony.0	2018-04-02 11:17:12.600	info	searching for Harmony Hubs...
    harmony.0	2018-04-02 11:17:12.579	info	starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v6.12.2
    harmony.0	2018-04-02 11:17:12.542	debug	statesDB connected
    harmony.0	2018-04-02 11:17:12.495	debug	objectDB connected
    Den Harmony Hub sucht er nun bereits seit 20 Minuten. Den Harmony Hub erreiche ich mit ping ohne Probleme:
    Ping wird ausgeführt für 192.168.0.202 mit 32 Bytes Daten:
    Antwort von 192.168.0.202: Bytes=32 Zeit=5ms TTL=64
    Antwort von 192.168.0.202: Bytes=32 Zeit=1ms TTL=64
    Antwort von 192.168.0.202: Bytes=32 Zeit=2ms TTL=64
    Ping-Statistik für 192.168.0.202:
        Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
        (0% Verlust),
    Ca. Zeitangaben in Millisek.:
        Minimum = 1ms, Maximum = 5ms, Mittelwert = 2ms
    Ich verwende iobroker 2.0.9 und den Harmony Adapter 0.9.0 - iobroker läuft auf einer synology NAS mit docker image.
    Irgendwelche Ideen was hier falsch läuft?
    • HomoranH Offline
      HomoranH Offline
      @blacktiger:
      mit docker image.
      Irgendwelche Ideen was hier falsch läuft? `
      Ja, der Docker!
      der Harmony hub hat sowieso Probleme, wenn die WLAN Qualität nicht 100%ig ist. Ping geht aber die Pakete bekommt er nicht.
      Und aus dem Docker ist es außerdem noch schwieriger diese Pakete abzusetzen.
      Da müsstest du mal im Forum suchen, so richtig kenne ich mich da nicht aus.
      rainer
