  4. Harmony Adapter / Lässt sich nicht Instalieren.
    5.9k
6 Beiträge 2 Kommentatoren 718 Aufrufe
  • C Offline
    Cornadius
    Kann jemand den Harmony Adapter instalieren, bei mir schlägt dauernt die Instalation fail. Alle anderen Adapter lassen sich aber Instalieren.
      Was sagt das log?
      Rainer
      • C Offline
        Cornadius
        iobroker	2018-02-20 17:03:16.129	info	exit 13
        iobroker	2018-02-20 17:03:16.125	error	host.iobroker Cannot install harmony
        iobroker	2018-02-20 17:03:16.125	info	host.iobroker install adapter harmony
        iobroker	2018-02-20 17:03:16.124	info	npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
        iobroker	2018-02-20 17:03:16.123	info
        iobroker	2018-02-20 17:03:16.111	info	npm ERR! Please check if you have git installed and in your PATH.
        iobroker	2018-02-20 17:03:16.111	info	npm ERR! This is most likely not a problem with npm itself.
        iobroker	2018-02-20 17:03:16.111	info	npm ERR! Failed using git.
        iobroker	2018-02-20 17:03:16.111	info	npm ERR! not found: git
        iobroker	2018-02-20 17:03:16.111	info	npm ERR! code ENOGIT
        iobroker	2018-02-20 17:03:16.111	info	npm ERR! npm v3.10.10
        iobroker	2018-02-20 17:03:16.111	info	"/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3
        iobroker	2018-02-20 17:03:16.102	info	npm ERR! Linux 4.13.4-1-pvenpm ERR! argv
        iobroker	2018-02-20 17:03:16.078	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
        iobroker	2018-02-20 17:03:16.076	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b becau
        iobroker	2018-02-20 17:03:16.076	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package npm WARN addRemoteGit Error: not found: git
        iobroker	2018-02-20 17:03:12.789	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
        iobroker	2018-02-20 17:03:12.744	info	host.iobroker install adapter harmony
        iobroker	2018-02-20 17:03:12.735	info	npm ERR! /npm-debug.log
        iobroker	2018-02-20 17:03:12.735	info	npm ERR! Please include the following file with any support request:
        iobroker	2018-02-20 17:03:12.729	info	npm ERR! Please check if you have git installed and in your PATH.
        iobroker	2018-02-20 17:03:12.729	info	npm ERR! This is most likely not a problem with npm itself.
        iobroker	2018-02-20 17:03:12.729	info	npm ERR! Failed using git.
        iobroker	2018-02-20 17:03:12.729	info	npm ERR! not found: git
        iobroker	2018-02-20 17:03:12.727	info	npm ERR! code ENOGIT
        iobroker	2018-02-20 17:03:12.727	info	npm ERR! npm v3.10.10
        iobroker	2018-02-20 17:03:12.727	info	"/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3
        iobroker	2018-02-20 17:03:12.725	info	npm ERR! Linux 4.13.4-1-pvenpm ERR! argv
        iobroker	2018-02-20 17:03:12.701	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b becau
        iobroker	2018-02-20 17:03:12.691	info	npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
        iobroker	2018-02-20 17:03:12.686	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
        iobroker	2018-02-20 17:03:09.377	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
        iobroker	2018-02-20 17:03:09.332	info	host.iobroker install adapter harmony
        iobroker	2018-02-20 17:03:09.317	info	npm ERR! /npm-debug.log
        iobroker	2018-02-20 17:03:09.317	info	npm ERR! Please include the following file with any support request:
        iobroker	2018-02-20 17:03:09.312	info	npm ERR! Please check if you have git installed and in your PATH.
        iobroker	2018-02-20 17:03:09.312	info	npm ERR! This is most likely not a problem with npm itself.
        iobroker	2018-02-20 17:03:09.312	info	npm ERR! Failed using git.
        iobroker	2018-02-20 17:03:09.312	info	npm ERR! not found: gitnpm ERR!
        iobroker	2018-02-20 17:03:09.310	info
        iobroker	2018-02-20 17:03:09.308	info	npm ERR! npm v3.10.10npm ERR! code ENOGIT
        iobroker	2018-02-20 17:03:09.308	info	npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3
        iobroker	2018-02-20 17:03:09.307	info	npm ERR! Linux 4.13.4-1-pve
        iobroker	2018-02-20 17:03:09.287	info	deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
        iobroker	2018-02-20 17:03:09.286	info	npm WARN
        iobroker	2018-02-20 17:03:09.273	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b becau
        iobroker	2018-02-20 17:03:09.266	info	npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
        iobroker	2018-02-20 17:03:05.658	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
        iobroker	2018-02-20 17:03:05.344	info	add harmony
        geändert: Code in Code-Tags; Homoran (Mod)
          Wie befürchtet:
          @Cornadius:
          BItte git installieren:
          sudo apt-get install git
          Rainer
          • C Offline
            Cornadius
            Super danke, wahr eigendlich der überzeugung ich hätte es schon drauf. Danke für die schnelle Hilfe
            • C Offline
              Cornadius
              Eine Frage hab ich aber noch zur Harmony, irgendwie muss ich wenn ich im Hub was ändere dauernt den Adapter deinstalieren weil er von alleine die Einstellungen nicht aktualisiert.
