  4. Amazon Dash - Fehlersuche
    5.9k
1 Beiträge 1 Kommentatoren 255 Aufrufe
    Basti123
    leider bekomme ich den Dash-Adapter nicht installiert und kann mit der Fehlermeldung nichts anfangen:
    $ ./iobroker add amazon-dash
    npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
    npm WARN lifecycle iobroker.amazon-dash@0.2.8~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.8 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    host.ioBroker-RasPi install adapter amazon-dash
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.amazon-dash"
    npm
     WARN lifecycle iobroker.amazon-dash@0.2.8~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.8 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/iobroker.amazon-dash
    ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::New(const Nan::FunctionCallbackInfo<v8::value>&)’:../socket_watcher.cpp:104:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated (declared at /root/.node-gyp/6.12.3/include/node/v8.h:3276): Use maybe version [-Wdeprecated-declarations]
         info.GetReturnValue().Set(cons->NewInstance());
    ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">
    compilation terminated.
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
    gyp
    ERR!
     build error
    gyp
    ERR! stack
     Error: `make` failed with exit code: 2gyp
     ERR!
     stack
         at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp
    ERR!
    stack     at emitTwo (events.js:106:13)gyp
    ERR!
    stack     at ChildProcess.emit (events.js:191:7)gyp
    ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.9.35-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp
     ERR! cwd /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcapgyp ERR! node -v v6.12.3
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm
    ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "--production"
    npm ERR! node v6.12.3
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm
     ERR! pcap@2.0.0 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm
     ERR! If you do, this is most likely a problem with the pcap package,npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs pcap
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls pcap
    npm ERR! There is likely additional logging output above.
    npm
     ERR! Please include the following file with any support request:npm ERR!     /opt/iobroker/node_modules/iobroker.amazon-dash/npm-debug.log
    Cannot install iobroker.amazon-dash: 1
    ERROR: process exited with code 25</pcap></v8::object></v8::value>
    Jemand hier, der aushelfen kann?
    Viele Grüße
    Basti
