  4. Sonoff.0 Adapter hat immer Fehlverbindungen
    5.8k
5 Beiträge 3 Kommentatoren 1.0k Aufrufe
    Balu0127
    Hallo
    Wie oben schon geschrieben hat der Sonoff.0 Adapter immer wieder Fehlverbindungen?
    Kann aber die Geräte teils noch schalten.
    Hat jemand eine Erklärung warum das so ist?
    sonoff.0	2018-02-11 20:00:52.658	info	Client [Esstisch] connected
    sonoff.0	2018-02-11 20:00:51.793	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 20:00:51.792	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 20:00:51.791	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 20:00:51.789	info	Client [Esstisch] closed
    sonoff.0	2018-02-11 19:38:10.269	info	Client [Versuch] connected
    sonoff.0	2018-02-11 19:38:09.496	warn	Client error [Versuch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 19:38:09.495	warn	Client error [Versuch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 19:38:09.494	info	Client [Versuch] closed
    sonoff.0	2018-02-11 19:38:03.859	info	Client [Nachttischlampe] closed
    sonoff.0	2018-02-11 19:38:03.858	error	Closed because of error
    sonoff.0	2018-02-11 19:38:03.855	warn	Client error [Nachttischlampe]: Error: This socket is closed
    sonoff.0	2018-02-11 19:38:03.852	warn	Client error [Nachttischlampe]: Error: read ECONNRESET
    sonoff.0	2018-02-11 19:38:02.404	info	Client [Nachttischlampe] connected
    sonoff.0	2018-02-11 19:33:18.628	info	Client [Vorraum] connected
    sonoff.0	2018-02-11 19:33:18.229	warn	Client error [Vorraum]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 19:33:18.228	warn	Client error [Vorraum]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 19:33:18.227	warn	Client error [Vorraum]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 19:33:18.226	warn	Client error [Vorraum]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 19:33:18.222	warn	Client error [Vorraum]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 19:33:18.221	info	Client [Vorraum] closed
    web.0	2018-02-11 17:36:31.687	info	2018-02-11T16:36:31.687Z Connected system.user.admin
    web.0	2018-02-11 17:33:27.535	info	2018-02-11T16:33:27.534Z Connected system.user.admin
    samsung.0	2018-02-11 16:46:24.029	error	Empty commands will not be excecuted.
    samsung.0	2018-02-11 16:46:23.045	error	Empty commands will not be excecuted.
    web.0	2018-02-11 16:45:57.152	info	2018-02-11T15:45:57.150Z Connected system.user.admin
    sonoff.0	2018-02-11 16:24:27.799	info	Client [Küche-Licht] connected
    sonoff.0	2018-02-11 16:24:27.002	warn	Client error [Küche-Licht]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:27.001	warn	Client error [Küche-Licht]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:27.000	warn	Client error [Küche-Licht]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:26.998	warn	Client error [Küche-Licht]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:26.997	warn	Client error [Küche-Licht]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:26.995	info	Client [Küche-Licht] closed
    sonoff.0	2018-02-11 16:24:20.322	info	Client [Esstisch] connected
    sonoff.0	2018-02-11 16:24:19.384	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:19.383	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:19.382	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
    sonoff.0	2018-02-11 16:24:19.378	info	Client [Esstisch] closed
      Milbert
      Servus Balu0127,
      hast du noch nen anderen Adapter laufen, der evtl. auf die Sonoffs zugreift?
      Ich hab gelesen, der MQTT-Adapter und der Sonoff-Adapter können sich gegenseitig ins Gehege kommen und brauchen ggf. unterschiedliche Ports…
      Milbert
        TimmBo
        ist ein bekanntes Problem.
        Wir sind in einem anderen Thread zu dieser Lösung gekommen:
        • IO Broker mit Kabel verbinden nicht Wlan
        • alle Sonoff löschen (mit ner leeren .bin flashen)
        -Dann aktuelle Tasmota aufsielen
        • allen eine neue IP Adresse vergeben
        So laufen alle 7 Sonoff bei mir ohne Abbrüche…
        mfg Timm
          Balu0127
          Hallo Sonoff Flashen, ist nicht gut hab die hälfte verbaut!
          Gehts über Aktualisieren der Software über Weboberfläche (Update) auch?
          Ist um einiges einfacher.
            TimmBo
            Bei mir war der ausschlaggebende Punkt das ich den Sonoff erst gelöscht habe und dann tasmota geflasht habe. Das geht ohne Ausbau leider nicht.
            Kannst aber auch mal versuchen einzelne Sonoff vom Netz zu nehmen. Meine Vermutung war das einzelne Sonoff die evtl nen Fehler beim Flashen abbekommen haben das ganze System zum wackeln bringen.
            Wann ist denn das Problem bei dir aufgetreten? Bei mir war es nachdem ich weitere Sonoff ins Netz gebracht habe. Evtl hätte einer ein Problem. Könnte aber nicht mehr genau sagen welcher es war. Hab zur Sicherheit gleich alles neu installiert.
            Fürchte fast das du nicht ums ausbauen rum kommst.
            Mfg Timm
