  4. Wiederholender Fehler im Log: error instance system.adapter.web.1 terminated with code 1 ()
    5.8k
1 Beiträge 1 Kommentatoren 544 Aufrufe
    Blackhawk
    bei mir im Log vom IOBroker läuft immer wieder der gleiche Fehler auf
    ! host.raspberrypi 2018-01-29 15:23:20.766 info Restart adapter system.adapter.web.1 because enabled
    ! host.raspberrypi 2018-01-29 15:23:20.765 error instance system.adapter.web.1 terminated with code 1 ()
    ! web.1 2018-01-29 15:23:20.611 info socket.io server listening on port 8082
    ! web.1 2018-01-29 15:23:19.509 info starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.web, node: v6.11.5
    ! host.raspberrypi 2018-01-29 15:23:15.932 info instance system.adapter.web.1 started with pid 11259
    ! host.raspberrypi 2018-01-29 15:22:45.904 info Restart adapter system.adapter.web.1 because enabled
    ! host.raspberrypi 2018-01-29 15:22:45.903 error instance system.adapter.web.1 terminated with code 1 ()
    ! web.1 2018-01-29 15:22:45.750 info socket.io server listening on port 8082
    ! web.1 2018-01-29 15:22:44.764 info starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.web, node: v6.11.5
    ! host.raspberrypi 2018-01-29 15:22:41.028 info instance system.adapter.web.1 started with pid 11193
    ! host.raspberrypi 2018-01-29 15:22:11.008 info Restart adapter system.adapter.web.1 because enabled
    ! host.raspberrypi 2018-01-29 15:22:11.006 error instance system.adapter.web.1 terminated with code 1 ()
    ! web.1 2018-01-29 15:22:10.831 info socket.io server listening on port 8082
    ! web.1 2018-01-29 15:22:09.738 info starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.web, node: v6.11.5
    ! host.raspberrypi 2018-01-29 15:22:06.023 info instance system.adapter.web.1 started with pid 11165
    ! host.raspberrypi 2018-01-29 15:21:35.989 info Restart adapter system.adapter.web.1 because enabled
    Weiß jemand, was dies bedeutet und wie ich es beheben kann?
    Raspberry Pi2B
    Homematic All-In-One mit piVCCU
    -nodejs 6.12.0
    -ioBroker
    -redis
    -piVCCU 2.29.23 mit IP-Support
