  4. [gelöst] js-controller 1.2.0 und sql 1.5.6 funktioniert nicht
24 Beiträge 7 Kommentatoren 3.9k Aufrufe
  • G Offline
    GerdSo
    Fehler tritt auch auf, wenn ich auf sql1.5.4 downgrade. Fehler ist eindeutig bei js-controller 1.2.0, bzw. dadurch wird der Fehler ausgelöst.
    Loddatei````
    2017-09-26 19:37:43.944 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.sql.0 started with pid 11292
    2017-09-26 19:37:45.709 - [32minfo[39m: sql.0 starting. Version 1.5.6 in C:/Program Files/ioBroker/node_modules/iobroker.sql, node: v6.11.2
    2017-09-26 19:37:45.974 - [32minfo[39m: sql.0 Connected to mysql
    2017-09-26 19:37:46.006 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.updated
    2017-09-26 19:38:19.209 - [32minfo[39m: javascript.0 script.js.common.YR: file written
    2017-09-26 19:39:16.444 - [32minfo[39m: host.DauerlaufLaptop object change system.adapter.sql.0
    2017-09-26 19:39:16.444 - [32minfo[39m: host.DauerlaufLaptop stopInstance system.adapter.sql.0
    2017-09-26 19:39:16.444 - [32minfo[39m: host.DauerlaufLaptop stopInstance system.adapter.sql.0 killing pid 11292
    2017-09-26 19:39:16.491 - [33mwarn[39m: host.DauerlaufLaptop instance system.adapter.sql.0 terminated due to SIGTERM
    2017-09-26 19:39:16.491 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.sql.0 terminated with code null ()
    2017-09-26 19:39:18.959 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.sql.0 started with pid 9732
    2017-09-26 19:39:20.615 - [32minfo[39m: sql.0 starting. Version 1.5.6 in C:/Program Files/ioBroker/node_modules/iobroker.sql, node: v6.11.2
    2017-09-26 19:39:20.911 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.updated
    2017-09-26 19:40:00.022 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.yr.0 started with pid 9692
    2017-09-26 19:40:00.053 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.dwd.0 started with pid 3152
    2017-09-26 19:40:01.881 - [32minfo[39m: yr.0 starting. Version 1.0.6 in C:/Program Files/ioBroker/node_modules/iobroker.yr, node: v6.11.2
    2017-09-26 19:40:02.037 - [32minfo[39m: yr.0 got weather data from yr.no
    2017-09-26 19:40:02.099 - [32minfo[39m: dwd.0 starting. Version 2.2.1 in C:/Program Files/ioBroker/node_modules/iobroker.dwd, node: v6.11.2
    2017-09-26 19:40:02.913 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.dwd.0 terminated with code 0 (OK)
    2017-09-26 19:40:07.131 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.yr.0 terminated with code 0 (OK)
    2017-09-26 19:42:56.899 - [32minfo[39m: host.DauerlaufLaptop object change system.adapter.sql.0
    2017-09-26 19:42:56.899 - [32minfo[39m: host.DauerlaufLaptop stopInstance system.adapter.sql.0
    2017-09-26 19:42:56.899 - [32minfo[39m: host.DauerlaufLaptop stopInstance system.adapter.sql.0 killing pid 9732
    2017-09-26 19:42:56.930 - [33mwarn[39m: host.DauerlaufLaptop instance system.adapter.sql.0 terminated due to SIGTERM
    2017-09-26 19:42:56.930 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.sql.0 terminated with code null ()
    2017-09-26 19:42:59.415 - [32minfo[39m: host.DauerlaufLaptop instance system.adapter.sql.0 started with pid 11572
    2017-09-26 19:43:01.274 - [32minfo[39m: sql.0 starting. Version 1.5.6 in C:/Program Files/ioBroker/node_modules/iobroker.sql, node: v6.11.2
    • BluefoxB Offline
      BluefoxB Offline
      Hast du Skripte laufend?
      Wer ändert das Objekt?
      • G Offline
        GerdSo
        Es laufen Skripte, aber keines das mit dem sql-Adapter Aktionen durchführt oder manipuliert. Die ändern nur indirekt durch Werteänderungen die sql-Adapter speichert und durch Abragen von history Informationen.
        Kann sein, dass ich in dem Moment den Adapter über die iobroker Admin-Oberfläche neu gestartet hatte, da er dort wieder als deaktiviert angezeigt wurde
        • apollon77A Offline
          Dann stoppe mal den Adapter und Starte ihn an der kommandozeile direkt: im iobroker Verzeichnis ein: node node_modules/iobroker.sql/main.js —force —logs
          Was kommt dann als Ausgabe?
          • G Offline
            GerdSo
            @apollon77:
            Was kommt dann als Ausgabe? `
            Das klappt irgendwie nicht:````
            C:\Program Files\ioBroker>node node_modules/iobroker.sql/main.js -force -logs
            Cannot find module 'pg-native'
            2017-09-27 21:18:39.532 - error: sql.0 adapter disabled
            2017-09-27 21:19:17.156 - error: sql.0 already running
            Habe jetzt mal sauber protokolliert, zwischen Restart und Deaktivierung :````
            sql.0	2017-09-27 21:21:36.579	info	enabled logging of hm-rpc.0.updated
            sql.0	2017-09-27 21:21:36.548	info	Connected to mysql
            sql.0	2017-09-27 21:21:36.548	debug	Response: {'code':'ER_TABLE_EXISTS_ERROR','errno':1050,'sqlMessage':'Table 'ts_bool' already exists','sqlState':'42S01','index':0,'sql':'CREATE TABLE `iobroker`.ts_bool (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));'}
            sql.0	2017-09-27 21:21:36.548	debug	CREATE TABLE `iobroker`.ts_bool (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
            sql.0	2017-09-27 21:21:36.532	debug	Response: {'code':'ER_TABLE_EXISTS_ERROR','errno':1050,'sqlMessage':'Table 'ts_string' already exists','sqlState':'42S01','index':0,'sql':'CREATE TABLE `iobroker`.ts_string (id INTEGER, ts BIGINT, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));'}
            sql.0	2017-09-27 21:21:36.532	debug	CREATE TABLE `iobroker`.ts_string (id INTEGER, ts BIGINT, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
            sql.0	2017-09-27 21:21:36.517	debug	Response: {'code':'ER_TABLE_EXISTS_ERROR','errno':1050,'sqlMessage':'Table 'ts_number' already exists','sqlState':'42S01','index':0,'sql':'CREATE TABLE `iobroker`.ts_number (id INTEGER, ts BIGINT, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));'}
            sql.0	2017-09-27 21:21:36.517	debug	CREATE TABLE `iobroker`.ts_number (id INTEGER, ts BIGINT, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
            sql.0	2017-09-27 21:21:36.517	debug	Response: {'code':'ER_TABLE_EXISTS_ERROR','errno':1050,'sqlMessage':'Table 'datapoints' already exists','sqlState':'42S01','index':0,'sql':'CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);'}
            sql.0	2017-09-27 21:21:36.517	debug	CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
            sql.0	2017-09-27 21:21:36.501	debug	Response: {'code':'ER_TABLE_EXISTS_ERROR','errno':1050,'sqlMessage':'Table 'sources' already exists','sqlState':'42S01','index':0,'sql':'CREATE TABLE `iobroker`.sources (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);'}
            sql.0	2017-09-27 21:21:36.501	debug	CREATE TABLE `iobroker`.sources (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
            sql.0	2017-09-27 21:21:36.486	debug	Response: {'code':'ER_DB_CREATE_EXISTS','errno':1007,'sqlMessage':'Can't create database 'iobroker'; database exists','sqlState':'HY000','index':0,'sql':'CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;'}
            sql.0	2017-09-27 21:21:36.486	debug	CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;
            sql.0	2017-09-27 21:21:36.220	info	starting. Version 1.5.6 in C:/Program Files/ioBroker/node_modules/iobroker.sql, node: v6.11.2
            sql.0	2017-09-27 21:21:36.189	debug	statesDB connected
            sql.0	2017-09-27 21:21:36.173	debug	objectDB connected
            host.DauerlaufLaptop	2017-09-27 21:21:34.517	info	instance system.adapter.sql.0 started with pid 8548
            host.DauerlaufLaptop	2017-09-27 21:21:32.049	info	instance system.adapter.sql.0 terminated with code null ()
            host.DauerlaufLaptop	2017-09-27 21:21:32.049	warn	instance system.adapter.sql.0 terminated due to SIGTERM
              Und nach 21:21:36:579 kommt direkt wieder ein "terminated due to SIGTERM "?
              • G Offline
                GerdSo
                @apollon77:
                Und nach 21:21:36:579 kommt direkt wieder ein "terminated due to SIGTERM "? `
                Nein, da kommt gar nichts, das ist das seltsame. Das SIGTERM kommt erst wenn ich es wieder neu starte. Das Log zeigt den kompletten Inhalt zwischen Restart und auf der Oberfläche die Umschaltung auf rot=Deaktiviert, d.h. ich habe da nicht weggeschnitten oder rausgelöscht
                  Also um 21:21:36:579 ging der Adapter wieder auf Rot?
                  jetzt wird es komisch. hast Du überhaupt Datenpunkte für SQL-History aktiviert?
                  • G Offline
                    GerdSo
                    @apollon77:
                    jetzt wird es komisch. hast Du überhaupt Datenpunkte für SQL-History aktiviert? `
                    Ja, 1351 Stück und die funktionieren auch wenn ich wieder den alten js-controller verwende, dann ist das Log voller Einträge von sql.0 wenn der Adapter auf Debug steht
                    • G Offline
                      GerdSo
                      @GerdSo:
                      @apollon77:
                      Ja, 1351 Stück und die funktionieren auch wenn ich wieder den alten js-controller verwende, dann ist das Log voller Einträge von sql.0 wenn der Adapter auf Debug steht `
                      Ergänzung: Aktuell habe ich das Verzeichnis von js-controller 1.2.0 gesichert und ebenso mit 1.0.3, dadurch kann ich schnell zwischen diesen beiden Versionen umschalten und der Effekt ist, wenn ich das 1.0.3 verwende wird alles sauber in sql gespeichert und der Adapter läuft, im anderen Fall nicht. Die restlichen installierten Adapter funktionieren soweit mit beiden Versionen
                        baufuzzi
                        Hallöchen,
                        hat sich hier zufällig etwas bewegt? Mit dem Update auf js-controller 1.2.0 hab ich die gleichen Probleme mit dem SQL-Adapter.
                        Kann ich noch etwas zusteuern?
                        Jakob
                          Naja ein Log im Debug Modus mit 1.2.0 wäre echt hilfreich.
                          Ich kann bisher keine Probleme nachvollziehen :-(
                            baufuzzi
                            Einmal Debug-Log:
                            sql.0	2017-10-18 21:49:58.715	info	enabled logging of hm-rpc.0.updated
                            sql.0	2017-10-18 21:49:58.637	info	Connected to mysql
                            sql.0	2017-10-18 21:49:58.636	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_bool' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_bool (id INTEGER, ts BIGINT, val
                            sql.0	2017-10-18 21:49:58.635	debug	CREATE TABLE `iobroker`.ts_bool (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                            sql.0	2017-10-18 21:49:58.631	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_string' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_string (id INTEGER, ts BIGINT, v
                            sql.0	2017-10-18 21:49:58.629	debug	CREATE TABLE `iobroker`.ts_string (id INTEGER, ts BIGINT, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                            sql.0	2017-10-18 21:49:58.626	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_number' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_number (id INTEGER, ts BIGINT, v
                            sql.0	2017-10-18 21:49:58.624	debug	CREATE TABLE `iobroker`.ts_number (id INTEGER, ts BIGINT, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                            sql.0	2017-10-18 21:49:58.620	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'datapoints' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRI
                            sql.0	2017-10-18 21:49:58.618	debug	CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
                            sql.0	2017-10-18 21:49:58.613	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'sources' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.sources (id INTEGER NOT NULL PRIMAR
                            sql.0	2017-10-18 21:49:58.610	debug	CREATE TABLE `iobroker`.sources (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
                            sql.0	2017-10-18 21:49:58.593	debug	Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlMessage":"Can't create database 'iobroker'; database exists","sqlState":"HY000","index":0,"sql":"CREATE DATABASE `iobroker` DEFAULT CHARACTER
                            sql.0	2017-10-18 21:49:58.574	debug	CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;
                            sql.0	2017-10-18 21:49:58.191	info	starting. Version 1.5.6 in C:/ioBroker/node_modules/iobroker.sql, node: v4.5.0
                            sql.0	2017-10-18 21:49:58.108	debug	statesDB connected
                            sql.0	2017-10-18 21:49:58.050	debug	objectDB connected
                            Der Adapter geht dann wieder auf Rot aber keine weiteren Log-Einträge mehr.
                            Was ich jetzt kurios finde - sobald ich direkt im Anschluss über die Kommandozeile (wie weiter oben beschrieben) den Adapter mit "… -force -logs" starte, läuft er in der shell sauber und logged auch im iobroker Browser-Log los und macht seinen Job mit seinen x-Einträgen :o :?:
                            Wo könnte ich ansetzen, eine Idee? Ich weiß, ich müsste mal mein NodeJs updaten... lief bisher ohne murren.
                              Die Kombi läuft bei mir ohne Probleme.
                              Vielleicht reicht mal ein einfacher Reboot des ioBroker Servers.
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Versuche erst mal den Reboot … tut fast immer gut.
                                Was mich etwas irritiert, ist der Hinweis im Log, das alle Tabellen neu angelegt werden sollen, was dann natürlich so nicht geht.
                                Wo läuft denn Dein SQL-Server und was für ein Server ist es (MySQL, MS SQL, ....)?
                                Gruß,
                                Eric
                                PS: Läuft bei mir ach ohne Probleme.
                                Von unterwegs getippert
                                  Wenn er läuft und rot ist … wenn DU dann einen weiteren Datenpunkt zum logging dazu konfigurierst kommt die meldung das er enabled wurde?
                                  Wie sieht denn das Log aus wenn du es per Kommandozeile startest?
                                  @Eric: Das neu anlegen ist immer so.
                                    baufuzzi
                                    Danke fürs Feedback.
                                    Reboots hab ich einige hinter mir, leider nicht die Lösung.
                                    Ich fahre auf dem gleichen Host MySQL (okay MariaDB, ein Problem?) und funktionierte in der Vergangenheit, aktuell auch über die Kommandozeile kopfkratz.
                                    Wenn er Rot ist und ich einen weiteren Datenpunkt aktiviere, regt sich leider in keinem Log etwas und es gibt auch kein negatives Feedback beim Einrichten.
                                    So sieht das Log aus der Kommandozeile aus (nur ein Ausschnitt):
                                    C:\ioBroker>node node_modules/iobroker.sql/main.js -force -logs
                                    2017-10-18 22:27:02.579  - info: sql.0 starting. Version 1.5.6 in C:/ioBroker/node_modules/iobroker.sql, node: v4.5.0
                                    2017-10-18 22:27:02.962  - debug: sql.0 CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;
                                    2017-10-18 22:27:02.982  - debug: sql.0 Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlMessage":"Can't create database 'iobroker'; database exists","sqlState":"HY000","index":0,"sql":"CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;"}
                                    2017-10-18 22:27:03.002  - debug: sql.0 CREATE TABLE `iobroker`.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
                                    2017-10-18 22:27:03.008  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'sources' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);"}
                                    2017-10-18 22:27:03.015  - debug: sql.0 CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
                                    2017-10-18 22:27:03.018  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'datapoints' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);"}
                                    2017-10-18 22:27:03.025  - debug: sql.0 CREATE TABLE `iobroker`.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                                    2017-10-18 22:27:03.029  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_number' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));"}
                                    2017-10-18 22:27:03.035  - debug: sql.0 CREATE TABLE `iobroker`.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                                    2017-10-18 22:27:03.039  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_string' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));"}
                                    2017-10-18 22:27:03.047  - debug: sql.0 CREATE TABLE `iobroker`.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                                    2017-10-18 22:27:03.052  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_bool' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));"}
                                    2017-10-18 22:27:03.054  - info: sql.0 Connected to mysql
                                    2017-10-18 22:27:03.142  - info: sql.0 enabled logging of hm-rpc.0.updated
                                    2017-10-18 22:27:03.144  - info: sql.0 enabled logging of hm-rpc.1.updated
                                    2017-10-18 22:27:03.145  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.0.INSTALL_MODE
                                    2017-10-18 22:27:03.146  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.1.LEVEL
                                    2017-10-18 22:27:03.147  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_LONG
                                    2017-10-18 22:27:03.148  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_SHORT
                                    2017-10-18 22:27:03.149  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.2.LEVEL
                                    2017-10-18 22:27:03.151  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.2.PRESS_LONG
                                    ....... usw.
                                    • eric2905E Offline
                                      eric2905E Offline
                                      eric2905
                                      @apollon77:
                                      @Eric: Das neu anlegen ist immer so. `
                                      Ah, ok. Hatte es im Log gesehen und mich gewundert.
                                      Gruß,
                                      Eric
                                      • G Offline
                                        GerdSo
                                        Kurze Ergänzung von meiner Seite:
                                        • mySQL-DB auf dem gleichen Host wie ioBroker
                                        • G Offline
                                          GerdSo
                                          mit js-controller 1.2.3 funktioniert der sql-Adapter wieder korrekt. Danke dafür an die Entwickler
