  2. Русский
  3. ioBroker
  4. Скрипты
  5. ioBroker скрипты
  6. Скрипт для счётчика
    2.8k
    4.8k
    4.0k
Скрипт для счётчика
Geplant Angeheftet Gesperrt Verschoben ioBroker скрипты
70 Beiträge 3 Kommentatoren 17.9k Aufrufe
    smoker_vvo
    Начнем с простого…. Какая IDE
      smoker_vvo
      в IDE 1.5.2 гружу вот этот скетч:
      Web Server
      A simple web server that shows the value of the analog input pins.
      using an Arduino Wiznet Ethernet shield.
      Circuit:
      • Ethernet shield attached to pins 10, 11, 12, 13
      • Analog inputs attached to pins A0 through A5 (optional)
      created 18 Dec 2009
      by David A. Mellis
      modified 9 Apr 2012
      by Tom Igoe
      ! #include <spi.h>#include <ethernet.h>// Enter a MAC address and IP address for your controller below.
      // The IP address will be dependent on your local network:
      byte mac[] = {
      0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
      IPAddress ip(192,168,0, 89);
      ! // Initialize the Ethernet server library
      // with the IP address and port you want to use
      // (port 80 is default for HTTP):
      EthernetServer server(80);
      ! void setup() {
      // Open serial communications and wait for port to open:
      Serial.begin(9600);
      while (!Serial) {
      ; // wait for serial port to connect. Needed for Leonardo only
      ! // start the Ethernet connection and the server:
      Ethernet.begin(mac, ip);
      server.begin();
      Serial.print("server is at ");
      Serial.println(Ethernet.localIP());
      ! void loop() {
      // listen for incoming clients
      EthernetClient client = server.available();
      if (client) {
      Serial.println("new client");
      // an http request ends with a blank line
      boolean currentLineIsBlank = true;
      while (client.connected()) {
      if (client.available()) {
      char c = client.read();
      Serial.write(c);
      // if you've gotten to the end of the line (received a newline
      // character) and the line is blank, the http request has ended,
      // so you can send a reply
      if (c == '\n' && currentLineIsBlank) {
      // send a standard http response header
      client.println("HTTP/1.1 200 OK");
      client.println("Content-Type: text/html");
      client.println("Connection: close");
      client.println();
      client.println("");
      client.println("");
      // add a meta refresh tag, so the browser pulls again every 5 seconds:
      client.println("");
      // output the value of each analog input pin
      for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
      int sensorReading = analogRead(analogChannel);
      client.print("analog input ");
      client.print(analogChannel);
      client.print(" is ");
      client.print(sensorReading);
      client.println("
      client.println("");
      break;
      if (c == '\n') {
      // you're starting a new line
      else if (c != '\r') {
      // you've gotten a character on the current line
      currentLineIsBlank = false;
      // give the web browser time to receive the data
      delay(1);
      // close the connection:
      client.stop();
      Serial.println("client disonnected");
      }</ethernet.h></spi.h>
      Пинг - отличный, и веб пускает,
        smoker_vvo
        в 1ю8ю2 - тоже проблем нет…...
          smoker_vvo
          1ю6ю13 - полет нормальный
          и 1.0.6 - работает…...
            smoker_vvo
            IDE 1.6.13 этот скетч - работает, все пингуется и данные идут
            `#include <spi.h> // Ethernet shield
            #include <ethernet.h> // Ethernet shield
            #include <pubsubclient.h> // MQTT
            #include <servo.h>
            #include <dht.h>
            #include <onewire.h>
            #include <dallastemperature.h>
            Servo servo;
            ! byte mac[] = { 0xC1, 0x7C, 0x38, 0x41, 0x89, 0x35 };
            byte server[] = { 192, 168, 0, 11 }; //IP Брокера
            byte ip[] = { 192, 168, 0, 89 }; //IP Клиента (Arduino)
            void callback(char* topic, byte* payload, unsigned int length) {
            payload[length] = '\0';
            // Serial.print(topic);
            // Serial.print("=");
            String strTopic = String(topic);
            String strPayload = String((char*)payload);
            // Serial.println(strPayload);
            callback_iobroker(strTopic, strPayload);
            ! EthernetClient ethClient;
            PubSubClient client(server, 1883, callback, ethClient);
            #define id_connect "myhome-temp"
            #define id_connect "myhome-status"
            #define Prefix_subscribe "myhome/Temp/"
            #define Prefix_subscribe "myhome/Status/"
            ! ///////////////Объявляем порты ввода-вывода
            #define ServoPin 3 //Порт к которому подключен сервопривод
            ! const int start_DI_pin []= {2, 4, 5}; // Порты Ввода
            int n_DI_pin = sizeof(start_DI_pin) / sizeof(start_DI_pin[0])-1; //Вычисляем длинну массива
            ! const int start_DO_pin []= {6, 7}; //Порты Вывода
            int n_DO_pin = sizeof(start_DO_pin) / sizeof(start_DO_pin[0])-1; //Вычисляем длинну массива
            ! int DI[] = {0, 0, 0};
            int old_DI[] = {0, 0, 0};
            ! ///////////////////////////Переменные для работы с освещением//////////////////////////////////////
            int ServoAngle = 100; //Угол сервопривода при включении
            int flag = 0;
            int flag2 = 0;
            int pause = 0;
            ! //------------------------------------------- Sensors -------------------------------------------//
            const int MQ7_Pin = A0; // Куда подключили MQ7
            //int MQ7Value = 0;
            int MQ7Value = analogRead(MQ7_Pin);
            const int foto_Pin = A1; // устанавливаем входную ногу для Фоторезистора
            //unsigned int fotoValue = 0; // цифровое значение фоторезистора
            unsigned int fotoValue = analogRead(foto_Pin);
            ! #define ONE_WIRE_BUS 8
            //#define TEMPERATURE_PRECISION 9
            OneWire oneWire(ONE_WIRE_BUS);
            DallasTemperature DS_sensors(&oneWire);
            // 28 80 E9 3A 04 00 00 10
            //T0:28 88 AD D7 02 00 00 42
            //T1:28 14 A5 D7 02 00 00 B0
            //T2:28 72 26 7B 04 00 00 2E
            //T3:28 CA 1A 3B 04 00 00 CD
            //T4:28 E6 D5 D7 02 00 00 C1
            //T5:28 16 B4 7A 04 00 00 8A
            //T6:28 2B 86 D7 02 00 00 CF
            //T7:28 AB 9D D7 02 00 00 29
            DeviceAddress addr_T1 = { 0x28, 0x80, 0xE9, 0x3A, 0x4, 0x0, 0x0, 0x10 };//кладовка
            DeviceAddress addr_T2 = { 0x28, 0x88, 0xAD, 0xD7, 0x2, 0x0, 0x0, 0x42 };//кухня
            DeviceAddress addr_T3 = { 0x28, 0x14, 0xA5, 0xD7, 0x2, 0x0, 0x0, 0xB0 };//детская
            DeviceAddress addr_T4 = { 0x28, 0x72, 0x26, 0x7B, 0x4, 0x0, 0x0, 0x2E };//гараж
            DeviceAddress addr_T5 = { 0x28, 0xCA, 0x1A, 0x3B, 0x4, 0x0, 0x0, 0xCD };//ванная
            DeviceAddress addr_T6 = { 0x28, 0xE6, 0xD5, 0xD7, 0x2, 0x0, 0x0, 0xC1 };//улица
            DeviceAddress addr_T7 = { 0x28, 0x16, 0xB4, 0x7A, 0x4, 0x0, 0x0, 0x8A };//спальня2
            DeviceAddress addr_T8 = { 0x28, 0x2B, 0x86, 0xD7, 0x2, 0x0, 0x0, 0xCF };//зал
            DeviceAddress addr_T9 = { 0x28, 0xAB, 0x9D, 0xD7, 0x2, 0x0, 0x0, 0x29 };//мансарда
            ! float T1=0;
            float T2=0;
            float T3=0;
            float T4=0;
            float T5=0;
            float T6=0;
            float T7=0;
            float T8=0;
            float T9=0;
            ! //dht DHT;
            //#define DHT22_PIN 9
            //float Hout = 0;
            //float Tout = 0;
            //void callback(char* topic, byte* payload, unsigned int length) {
            // payload[length] = '\0';
            // String strTopic = String(topic);
            // String strPayload = String((char*)payload);
            // callback_iobroker(strTopic, strPayload);
            void setup() {
            Serial.begin(57600);
            Serial.println("start");
            Serial.print("Locating devices...");
            DS_sensors.begin();
            Serial.print("Found ");
            Serial.print(DS_sensors.getDeviceCount(), DEC);
            Serial.println(" devices.");
            ! // report parasite power requirements
            Serial.print("Parasite power is: ");
            if (DS_sensors.isParasitePowerMode()) Serial.println("ON");
            else Serial.println("OFF");
            //Объявляем порты Digital inputs/outputs
            for(int i=0 ;i<=n_DI_pin; i++) { pinMode (start_DI_pin [i], INPUT); }
            digitalWrite(5, HIGH); //Насос скважины
            digitalWrite(4, HIGH); //Электрика
            for(int i=0 ;i<=n_DO_pin; i++) { pinMode (start_DO_pin [i], OUTPUT); }
            ! Ethernet.begin(mac, ip);
            if (client.connect(id_connect)) {
            getSensors();
            control();
            //client.publish("myhome/Kitchen/Change_Counter", "0");
            //client.publish("myhome/Kitchen/Temp_room", "0");
            //client.publish("myhome/Kitchen/Humidity_room", "0");
            client.publish("myhome/Temp/Kladovka", "0");
            client.publish("myhome/Temp/Kitchen", "0");
            client.publish("myhome/Temp/Detskaya", "0");
            client.publish("myhome/Temp/Garage", "0");
            client.publish("myhome/Temp/Street", "0");
            client.publish("myhome/Temp/Spalnya2", "0");
            client.publish("myhome/Temp/Zal", "0");
            client.publish("myhome/Temp/Mansarda", "0");
            client.publish("myhome/Temp/Vannaya", "0");
            //client.publish("myhome/Kitchen/Lux", "0");
            //client.publish("myhome/Kitchen/Servo", "0");
            client.publish("myhome/Temp/MQ7", "0");
            client.publish("myhome/Status/Power", "0");
            client.publish("myhome/Status/Pompe", "0");
            client.subscribe("myhome/Temp/#");
            client.subscribe("myhome/Status/#");
            void loop() {
            client.loop();
            control();
            getSensors();
            if (!client.connected()) {
            control();
            getSensors();
            }</dallastemperature.h></onewire.h></dht.h></servo.h></pubsubclient.h></ethernet.h></spi.h>`
            ! А заливаем этот - и ни чего....
            ! >! [spoiler]`[code]#include <spi.h>
            #include <eeprom.h>
            //#include <avr wdt.h="">
            ! #define PWR_CTRL A2 //Контроль напряжения
            #define LED 9 //Светодиод
            #define CHK_ADR 100
            #define CNT_ADR 10
            #define PWR_ADR 20
            #define POLL_ADR 30
            #define RATIO_ADR 40
            ! const char* topic_err = "myhome/test/error";
            const char* topic_cnt = "myhome/test/count";
            const char* topic_pwr = "myhome/test/power";
            const char* topic_amp = "myhome/test/amp";
            const char* topic_save = "myhome/test/save";
            const char* topic_correction = "myhome/test/correction";
            const char* topic_connection = "myhome/test/connection";
            const char* topic_ip = "myhome/test/config/ip";
            const char* topic_polling = "myhome/test/config/polling";
            const char* topic_bounce = "myhome/test/config/bounce";
            const char* topic_num = "myhome/test/config/num";
            const char* topic_reset = "myhome/test/config/reset";
            const char* topic_raw = "myhome/test/RAW";
            const char* subscr = "myhome/test/#";
            ! byte mac[] = { 0xDE, 0xA3, 0xBE, 0xE4, 0xDE, 0x35 };
            byte ip[] = { 192, 168, 0, 89};
            byte server[] = { 192, 168, 0, 15};
            ! unsigned long cnt = 0;
            unsigned long prev_cnt = 2;
            unsigned long pwr = 0;
            unsigned long prev_pwr = 2;
            int amp = 0;
            int prev_amp = 2;
            int num = 0;
            int prev_num;
            int bounce = 10;
            int prev_bounce;
            int chk = 0;
            int chk_S = 0;
            unsigned long prevMillis = 0;
            unsigned long prevMillis_cnt = 0;
            int poll = 5000;
            bool error = 0;
            String cmd = "";
            bool strComplete = false;
            char buf [50];
            char buffer[100];
            char s[16];
            PubSubClient client(ethClient);
            ! void setup() {
            //MCUSR = 0;
            // wdt_disable();
            Serial.println("WDT_disable");
            cmd.reserve(100);
            delay(10000);
            Serial.println("Starting......");
            ! if (EEPROM.read(1) != 99) { //Если первый запуск
            EEPROM.write(1, 99);
            for (int i = 0 ; i < 4; i++) {
            EEPROM.write(110 + i, ip[i]);
            EEPROM.write(120 + i, server[i]);
            } else {
            chk = EEPROMReadInt(CHK_ADR);
            cnt = EEPROMReadLong(CNT_ADR);
            poll = EEPROMReadInt(POLL_ADR);
            chk_S = poll - 500;
            if (chk != chk_S) {
            error = 2;
            for (int i = 0; i < 4; i++) {
            ip[i] = EEPROM.read(110 + i);
            server[i] = EEPROM.read(120 + i);
            ! pinMode(LED, OUTPUT);
            ! client.setServer(server, 1883);
            client.setCallback(callback);
            delay(200);
            //wdt_enable(WDTO_8S);
            Serial.println("WDTO_8S");
            if (client.connect("test")){
            digitalWrite(LED, LOW);
            Public();
            ! void serialEvent() {
            while (Serial.available() > 0) {
            char inChar = (char)Serial.read();
            cmd += inChar;
            if (inChar == '\n') {
            strComplete = true;
            ! void loop() {
            // wdt_reset();
            Serial.println("WDT_reset");
            client.loop();
            reconnect();
            ! /if (analogRead(PWR_CTRL) < 1000) {
            save();
            delay(10000);
            ! if (strComplete) {
            digitalWrite(LED, !digitalRead(LED));
            cmd.toCharArray(buffer, 100);
            cnt = atoi(strtok(buffer, ";"));
            pwr = atoi(strtok(NULL, ";"));
            amp = atoi(strtok(NULL, ";"));
            bounce = atoi(strtok(NULL, ";"));
            num = atoi(strtok(NULL, ";"));
            error = atoi(strtok(NULL, ";"));
            client.publish(topic_raw, StrToChar(cmd));
            cmd = "";
            ! if (millis() - prevMillis >= poll) {
            // wdt_reset();
            Serial.println("WDT_reset-");
            prevMillis = millis();
            if (cnt != prev_cnt || pwr != prev_pwr || amp != prev_amp) {
            prev_cnt = cnt;
            prev_pwr = pwr;
            prev_amp = amp;
            client.publish(topic_cnt, IntToChar(cnt));
            client.publish(topic_pwr, IntToChar(pwr));
            client.publish(topic_amp, IntToChar(amp));
            if (num != prev_num || bounce != prev_bounce) {
            prev_num = num;
            prev_bounce = bounce;
            client.publish(topic_num, IntToChar(num));
            client.publish(topic_bounce, IntToChar(bounce));
            if (error > 0) {
            client.publish(topic_err, "err");
            } else {
            client.publish(topic_err, " ");
            ! void callback_iobroker(String strTopic, String strPayload) {
            if (strTopic == topic_correction) {
            cnt = atol((strPayload).c_str());
            Serial.print("SC");
            Serial.println(cnt);
            client.publish(topic_correction, "0");
            else if (strTopic == topic_save) {
            if (strPayload == "true") {
            Serial.println("SS");
            save();
            client.publish(topic_save, "false");
            else if (strTopic == topic_polling) {
            poll = strPayload.toInt();
            if (poll < 1000) {
            poll = 1000;
            } else if (poll > 32767) {
            poll = 32767;
            EEPROMWriteInt(POLL_ADR, poll); //Интервал публикации
            client.publish(topic_polling, IntToChar(poll));
            else if (strTopic == topic_reset) {
            client.publish(topic_reset, "false");
            // reboot();
            Serial.println("Reboot");
            else if (strTopic == topic_bounce) {
            bounce = strPayload.toInt();
            if (bounce < 0) {
            bounce = 0;
            } else if (bounce > 10000) {
            bounce = 10000;
            Serial.print("SB");
            Serial.println(bounce);
            else if (strTopic == topic_num) {
            num = strPayload.toInt();
            if (num < 0) {
            num = 0;
            } else if (num > 32767) {
            num = 32767;
            Serial.print("SN");
            Serial.println(num);
            ! void save() {
            chk = poll - 500;
            EEPROMWriteLong(CNT_ADR, cnt); //Пишем показания счетчика в eeprom из переменной
            EEPROMWriteInt(CHK_ADR, chk); //чек
            ! void reboot() {
            //save();
            //delay(500);
            // wdt_enable(WDTO_1S);
            Serial.println("void reboot");
            //for (;;) {}
            ! char* StrToChar (String str) {
            int length = str.length();
            str.toCharArray(buf, length + 1);
            return buf;
            ! void EEPROMWriteLong(int p_address, unsigned long p_value) {
            byte four = (p_value & 0xFF);
            byte three = ((p_value >> 8) & 0xFF);
            byte two = ((p_value >> 16) & 0xFF);
            byte one = ((p_value >> 24) & 0xFF);
            EEPROM.write(p_address, four);
            EEPROM.write(p_address + 1, three);
            EEPROM.write(p_address + 2, two);
            EEPROM.write(p_address + 3, one);
            ! unsigned long EEPROMReadLong(int p_address) {
            long four = EEPROM.read(p_address);
            long three = EEPROM.read(p_address + 1);
            long two = EEPROM.read(p_address + 2);
            long one = EEPROM.read(p_address + 3);
            return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
            ! void EEPROMWriteInt(int p_address, int p_value) {
            byte lowByte = ((p_value >> 0) & 0xFF);
            byte highByte = ((p_value >> 8) & 0xFF);
            EEPROM.write(p_address, lowByte);
            EEPROM.write(p_address + 1, highByte);
            unsigned int EEPROMReadInt(int p_address) {
            byte lowByte = EEPROM.read(p_address);
            byte highByte = EEPROM.read(p_address + 1);
            return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
            ! char* IntToChar (unsigned long a) {
            sprintf(buf, "%lu", a);
            return buf;
            ! void Public() {
            sprintf(s, "%d.%d.%d.%d", ip[0], ip[1], ip[2], ip[3]);
            client.publish(topic_connection, "true");
            client.publish(topic_ip, s);
            client.subscribe(subscr);
            void reconnect() {
            int a = 0;
            while (!client.connected()) {
            a++;
            //wdt_reset();
            Serial.println("WDT reset");
            if (client.connect("test")) {
            Public();
            } else {
            delay(10000);
            if (a >= 10) {
            Serial.println("WDTO_1S");
            }</avr></eeprom.h></pubsubclient.h></ethernet.h></spi.h>`
            ! Ни пинга, ни данных....[/i][/i][/i][/i][/code][/spoiler][/i][/i]
            • I Offline
              I Offline
              instalator
              @smoker_vvo:
              Начнем с простого…. Какая IDE `
              ide 1.8.3
              Ethernet 1.1.2
              PubSubCliet 2.6.0
              Высокий уровень Децибел вреден для здоровья!
              http://blog.instalator.ru/
                smoker_vvo
                IDE 1.8.4, остальное совпадает…...
                Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100
                • I Offline
                  I Offline
                  instalator
                  @smoker_vvo:
                  Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100 `
                  Да какая разница какая ардуина, я на УНО и W5100 проверял
                    smoker_vvo
                    Хлебнуфф пивка и выкурив сигаретку, психанул и заменил Arduino MEGA на Arduino NANO- и О ЧУДО!!!! Все заработало…...
                    Теперь другие вопросы....
                    в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что??
                      smoker_vvo
                      #66
                      ан все таки есть… Щас сборка выглядит так :
                      Нано собирает инфу от счетчика - УНО обрабатывает - В5100 - отдает на Брокера
                      В предыдущем вопле ошибочка, Мега заменил на УНО
                      • I Offline
                        I Offline
                        instalator
                        #67
                        @smoker_vvo:
                        в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что?? `
                        https://github.com/instalator/Electro_C … t.ino#L278
                        https://blog.instalator.ru/archives/711
                        cnt = atoi(strtok(buffer, ";")); //счетчик
                        pwr = atoi(strtok(NULL, ";")); //мощность
                        amp = atoi(strtok(NULL, ";")); //сила тока!
                        bounce = atoi(strtok(NULL, ";")); //задержка от дребезга
                        num = atoi(strtok(NULL, ";")); //Значение передаточного числа счетчика. Количество импульсов на 1 кВт*ч
                        error = atoi(strtok(NULL, ";")); //ошибка
                        • I Offline
                          I Offline
                          instalator
                          #68
                          По скрипту для счетчика меркурий вынес в отдельную тему http://forum.iobroker.net/viewtopic.php?f=26&t=8148
                            smoker_vvo
                            #69
                            Зенкую! Я так и понял. Но проект заглох… проработав два часа......
                            и повторно запустить не удалось....
                            Не могу понять по чему........
                              smoker_vvo
                              #70
                              Вопрос не в тему, но не знаю куда закинуть.
                              Есть более важные задачи - наполнение септика..
                              Для контроля использую следующий скетч:
                              #define Trig 9
                              #define Echo 8
                              #define ledPin 13
                              ! void setup()
                              pinMode(Trig, OUTPUT); //инициируем как выход
                              pinMode(Echo, INPUT); //инициируем как вход
                              pinMode(ledPin, OUTPUT);
                              Serial.begin(9600);
                              /* задаем скорость общения. В нашем случае с компьютером /
                              unsigned int impulseTime=0;
                              unsigned int distance_sm=0;
                              ! void loop()
                              digitalWrite(Trig, HIGH);
                              Подаем импульс на вход trig дальномера */
                              delayMicroseconds(10); // равный 10 микросекундам
                              digitalWrite(Trig, LOW); // Отключаем
                              impulseTime=pulseIn(Echo, HIGH); // Замеряем длину импульса
                              distance_sm=impulseTime/58; // Пересчитываем в сантиметры
                              Serial.println(distance_sm); // Выводим на порт
                              if (distance_sm<50) // Если расстояние менее 30 сантиметром
                              digitalWrite(ledPin, HIGH); // Светодиод горит
                              else
                              digitalWrite(ledPin, LOW); // иначе не горит
                              delay(10000);
                              Подскажите как загнать его в Брокер,
                              хочется через MQTT
                              Для температуры использую вот это:
                              #include <servo.h>
                              #include <dht.h>
                              Servo servo;
                              int flag = 0;
                              int flag2 = 0;
                              int pause = 0;
                              //int MQ7Value = 0;
                              >! float T1=0;
                              float T2=0;
                              float T3=0;
                              float T4=0;
                              float T5=0;
                              float T6=0;
                              float T7=0;
                              float T8=0;
                              float T9=0;
                              >! //dht DHT;
                              //float Hout = 0;
                              //float Tout = 0;
                              void setup() {
                                DS_sensors.begin();
                                  getSensors();
                                  control();
                              void loop() {
                                client.loop();
                                control();
                                getSensors();
                                    control();
                                    getSensors();
                              И это Function
                              >! >! ~~[spoiler]~~`~~[code]~~//--------------------------------- Functions ---------------------------------//
                              /////////////////////////////////От Брокера//////////////////////////////////////////////
                              void callback_iobroker(String strTopic, String strPayload){
                                if (strTopic == "myhome/Kitchen/Servo"){
                                      ServoAngle=strPayload.toInt();
                                  if (ServoAngle >= 0 && ServoAngle <= 255){
                                        servo.attach(ServoPin);
                                        //delay(200); //ждем 2 секунды
                                        servo.write(ServoAngle); //ставим вал под 0
                                        delay(1000); //ждем 2 секунды
                                        //client.publish("myhome/Kitchen/Servo", b);
                                        servo.detach();
                              >! ////////////////////////////////////Брокеру/////////////////////////////////////
                              void control(){
                                     if(digitalRead(5)==HIGH && flag==0) { //если насос включен
                                        client.publish("myhome/Status/Pompe", "1");
                                        flag=1;
                                     if(digitalRead(5)==LOW && flag==1){//если насос выключен
                                      flag=0;//обнуляем переменную flag
                                     if(digitalRead(4)==HIGH && flag2==0) { // Если электрика есть
                                        client.publish("myhome/Status/Power", "1");
                                        flag2=1;
                                     if(digitalRead(4)==LOW && flag2==1){// Если эректрики нет
                                      flag2=0;//обнуляем переменную flag
                              ///////////////////////////////Данные сенсоров////////////////////////////////////
                              >! void getSensors () {
                              >!   MQ7Value = analogRead(MQ7_Pin);
                                fotoValue = analogRead(foto_Pin);  // считываем значение с фоторезистора
                              // ServoAngle = analogRead(2);
                              >! //Обработка данных датчика DHT22\. Подключение к порту цифровому P9 Arduino
                              //Глобальные переменные Hout и Tout типа флоат - влажность (%) и температура (град. С)
                              //  if (DHT.read22(DHT22_PIN)== DHTLIB_OK) {
                              //    Hout = DHT.humidity;
                              //    Tout = DHT.temperature;
                              //  if (Hout == 0 || Tout == 0){
                              //    delay (1000);
                                //Обработка данных цифровых датчиков температуры типа DS18B20.
                                //Шина 1-Wire на цифровой пин P8 Arduino.
                                //Подключено 2 датчика температуры, адреса задаются в секции глобальных констант "Sensors"
                                //Три значение температуры T1, T2, типа float (град. С).
                                DS_sensors.setResolution(addr_T1, 9);
                                DS_sensors.setResolution(addr_T2, 9);
                                DS_sensors.setResolution(addr_T3, 9);
                                DS_sensors.setResolution(addr_T4, 9);
                                DS_sensors.setResolution(addr_T5, 9);
                                DS_sensors.setResolution(addr_T6, 9);
                                DS_sensors.setResolution(addr_T7, 9);
                                DS_sensors.setResolution(addr_T8, 9);
                                DS_sensors.setResolution(addr_T9, 9);
                                float T1 = DS_sensors.getTempC(addr_T1);
                                float T2 = DS_sensors.getTempC(addr_T2);
                                float T3 = DS_sensors.getTempC(addr_T3);
                                float T4 = DS_sensors.getTempC(addr_T4);
                                float T5 = DS_sensors.getTempC(addr_T5);
                                float T6 = DS_sensors.getTempC(addr_T6);
                                float T7 = DS_sensors.getTempC(addr_T7);
                                float T8 = DS_sensors.getTempC(addr_T8);
                                float T9 = DS_sensors.getTempC(addr_T9);
                                DS_sensors.requestTemperatures();
                              //Serial.print(DS_sensors.getResolution(addr_T1), DEC);
                                Serial.println();
                                Serial.print("Temp T1 C: ");
                                Serial.print(T1);
                                Serial.println();
                              >!   Serial.println();
                                Serial.print("Temp T2 C: ");
                                Serial.print(T2);
                                Serial.println();
                              Serial.println();
                                Serial.print("Temp T3 C: ");
                                Serial.print(T3);
                                Serial.println();
                              Serial.println();
                                Serial.print("Temp T4 C: ");
                                Serial.print(T4);
                                Serial.println();
                              Serial.println();
                                Serial.print("Temp T5 C: ");
                                Serial.print(T5);
                                Serial.println();
                              Serial.println();
                                Serial.print("Temp T6 C: ");
                                Serial.print(T6);
                                Serial.println();
                              Serial.println();
                                Serial.print("Temp T7 C: ");
                                Serial.print(T7);
                                Serial.println();
                              Serial.println();
                                Serial.print("Temp T8 C: ");
                                Serial.print(T8);
                                Serial.println();
                              Serial.println();
                                Serial.print("Temp T9 C: ");
                                Serial.print(T9);
                                Serial.println();
                              ///////////////////////Паблик данных сенсоров////////////////////////
                               if (pause == 50 || pause == 0){
                                char b[5];
                              //    String char_Hout = String(Hout);
                              //    char_Hout.toCharArray(b,5);
                              //    client.publish("myhome/Kitchen/Humidity_room", b);
                              //  String char_Tout = String(Tout);
                              //  char_Tout.toCharArray(b,5);
                              //  client.publish("myhome/Kitchen/Temp_room", b);
                                  String char_T1 = String(T1);
                                  char_T1.toCharArray(b,5);
                                  client.publish("myhome/Temp/Kladovka", b);
                                  String char_T2 = String(T2);
                                  char_T2.toCharArray(b,5);
                                  client.publish("myhome/Temp/Kitchen", b);
                                  String char_T3 = String(T3);
                                  char_T3.toCharArray(b,5);
                                  client.publish("myhome/Temp/Detskaya", b);
                                  String char_T4 = String(T4);
                                  char_T4.toCharArray(b,5);
                                  client.publish("myhome/Temp/Garage", b);
                                  String char_T5 = String(T5);
                                  char_T5.toCharArray(b,5);
                                  client.publish("myhome/Temp/Vannaya", b);
                                  String char_T6 = String(T6);
                                  char_T6.toCharArray(b,5);
                                  client.publish("myhome/Temp/Street", b);
                                  String char_T7 = String(T7);
                                  char_T7.toCharArray(b,5);
                                  client.publish("myhome/Temp/Spalnya2", b);
                                  String char_T8 = String(T8);
                                  char_T8.toCharArray(b,5);
                                  client.publish("myhome/Temp/Zal", b);
                                  String char_T9 = String(T9);
                                  char_T9.toCharArray(b,5);
                                  client.publish("myhome/Temp/Mansarda", b);
                                  //Serial.println(T1);
                                  String char_fotoValue = String(fotoValue);
                                  char_fotoValue.toCharArray(b,4);
                                  client.publish("myhome/Kitchen/Lux", b);
                                String char_ServoAngle = String(ServoAngle);
                                char_ServoAngle.toCharArray(b,4);
                                  String char_MQ7Value = String(MQ7Value);
                                  char_MQ7Value.toCharArray(b,4);
                                  client.publish("myhome/Temp/MQ7", b);
                                  pause = 1;
                               else pause++;
                              >! [/code]`[/spoiler]
                              >! Показания от септика получаю в значениях см, типа 160 см, 100 см.....[/i][/i]
