  2. Русский
  3. ioBroker
  4. Скрипты
  5. ioBroker скрипты
  6. Скрипт для счётчика
    2.8k
    4.8k
    4.0k
Скрипт для счётчика
Geplant Angeheftet Gesperrt Verschoben ioBroker скрипты
70 Beiträge 3 Kommentatoren 17.9k Aufrufe
  • I Offline
    I Offline
    instalator
    @smoker_vvo:
    Убейте меня!!! ОН НЕ РАБОТАЕТ….. Ну не пингуется этот ip, я поменял на свои...... `
    библиотеки последних версии?
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
      smoker_vvo
      Начнем с простого…. Какая IDE
        smoker_vvo
        в IDE 1.5.2 гружу вот этот скетч:
        Web Server
        A simple web server that shows the value of the analog input pins.
        using an Arduino Wiznet Ethernet shield.
        Circuit:
        • Ethernet shield attached to pins 10, 11, 12, 13
        • Analog inputs attached to pins A0 through A5 (optional)
        created 18 Dec 2009
        by David A. Mellis
        modified 9 Apr 2012
        by Tom Igoe
        ! #include <spi.h>#include <ethernet.h>// Enter a MAC address and IP address for your controller below.
        // The IP address will be dependent on your local network:
        byte mac[] = {
        0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
        IPAddress ip(192,168,0, 89);
        ! // Initialize the Ethernet server library
        // with the IP address and port you want to use
        // (port 80 is default for HTTP):
        EthernetServer server(80);
        ! void setup() {
        // Open serial communications and wait for port to open:
        Serial.begin(9600);
        while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
        ! // start the Ethernet connection and the server:
        Ethernet.begin(mac, ip);
        server.begin();
        Serial.print("server is at ");
        Serial.println(Ethernet.localIP());
        ! void loop() {
        // listen for incoming clients
        EthernetClient client = server.available();
        if (client) {
        Serial.println("new client");
        // an http request ends with a blank line
        boolean currentLineIsBlank = true;
        while (client.connected()) {
        if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
        // send a standard http response header
        client.println("HTTP/1.1 200 OK");
        client.println("Content-Type: text/html");
        client.println("Connection: close");
        client.println();
        client.println("");
        client.println("");
        // add a meta refresh tag, so the browser pulls again every 5 seconds:
        client.println("");
        // output the value of each analog input pin
        for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
        int sensorReading = analogRead(analogChannel);
        client.print("analog input ");
        client.print(analogChannel);
        client.print(" is ");
        client.print(sensorReading);
        client.println("
        client.println("");
        break;
        if (c == '\n') {
        // you're starting a new line
        else if (c != '\r') {
        // you've gotten a character on the current line
        currentLineIsBlank = false;
        // give the web browser time to receive the data
        delay(1);
        // close the connection:
        client.stop();
        Serial.println("client disonnected");
        }</ethernet.h></spi.h>
        Пинг - отличный, и веб пускает,
          smoker_vvo
          в 1ю8ю2 - тоже проблем нет…...
            smoker_vvo
            1ю6ю13 - полет нормальный
            и 1.0.6 - работает…...
              smoker_vvo
              IDE 1.6.13 этот скетч - работает, все пингуется и данные идут
              `#include <spi.h> // Ethernet shield
              #include <ethernet.h> // Ethernet shield
              #include <pubsubclient.h> // MQTT
              #include <servo.h>
              #include <dht.h>
              #include <onewire.h>
              #include <dallastemperature.h>
              Servo servo;
              ! byte mac[] = { 0xC1, 0x7C, 0x38, 0x41, 0x89, 0x35 };
              byte server[] = { 192, 168, 0, 11 }; //IP Брокера
              byte ip[] = { 192, 168, 0, 89 }; //IP Клиента (Arduino)
              void callback(char* topic, byte* payload, unsigned int length) {
              payload[length] = '\0';
              // Serial.print(topic);
              // Serial.print("=");
              String strTopic = String(topic);
              String strPayload = String((char*)payload);
              // Serial.println(strPayload);
              callback_iobroker(strTopic, strPayload);
              ! EthernetClient ethClient;
              PubSubClient client(server, 1883, callback, ethClient);
              #define id_connect "myhome-temp"
              #define id_connect "myhome-status"
              #define Prefix_subscribe "myhome/Temp/"
              #define Prefix_subscribe "myhome/Status/"
              ! ///////////////Объявляем порты ввода-вывода
              #define ServoPin 3 //Порт к которому подключен сервопривод
              ! const int start_DI_pin []= {2, 4, 5}; // Порты Ввода
              int n_DI_pin = sizeof(start_DI_pin) / sizeof(start_DI_pin[0])-1; //Вычисляем длинну массива
              ! const int start_DO_pin []= {6, 7}; //Порты Вывода
              int n_DO_pin = sizeof(start_DO_pin) / sizeof(start_DO_pin[0])-1; //Вычисляем длинну массива
              ! int DI[] = {0, 0, 0};
              int old_DI[] = {0, 0, 0};
              ! ///////////////////////////Переменные для работы с освещением//////////////////////////////////////
              int ServoAngle = 100; //Угол сервопривода при включении
              int flag = 0;
              int flag2 = 0;
              int pause = 0;
              ! //------------------------------------------- Sensors -------------------------------------------//
              const int MQ7_Pin = A0; // Куда подключили MQ7
              //int MQ7Value = 0;
              int MQ7Value = analogRead(MQ7_Pin);
              const int foto_Pin = A1; // устанавливаем входную ногу для Фоторезистора
              //unsigned int fotoValue = 0; // цифровое значение фоторезистора
              unsigned int fotoValue = analogRead(foto_Pin);
              ! #define ONE_WIRE_BUS 8
              //#define TEMPERATURE_PRECISION 9
              OneWire oneWire(ONE_WIRE_BUS);
              DallasTemperature DS_sensors(&oneWire);
              // 28 80 E9 3A 04 00 00 10
              //T0:28 88 AD D7 02 00 00 42
              //T1:28 14 A5 D7 02 00 00 B0
              //T2:28 72 26 7B 04 00 00 2E
              //T3:28 CA 1A 3B 04 00 00 CD
              //T4:28 E6 D5 D7 02 00 00 C1
              //T5:28 16 B4 7A 04 00 00 8A
              //T6:28 2B 86 D7 02 00 00 CF
              //T7:28 AB 9D D7 02 00 00 29
              DeviceAddress addr_T1 = { 0x28, 0x80, 0xE9, 0x3A, 0x4, 0x0, 0x0, 0x10 };//кладовка
              DeviceAddress addr_T2 = { 0x28, 0x88, 0xAD, 0xD7, 0x2, 0x0, 0x0, 0x42 };//кухня
              DeviceAddress addr_T3 = { 0x28, 0x14, 0xA5, 0xD7, 0x2, 0x0, 0x0, 0xB0 };//детская
              DeviceAddress addr_T4 = { 0x28, 0x72, 0x26, 0x7B, 0x4, 0x0, 0x0, 0x2E };//гараж
              DeviceAddress addr_T5 = { 0x28, 0xCA, 0x1A, 0x3B, 0x4, 0x0, 0x0, 0xCD };//ванная
              DeviceAddress addr_T6 = { 0x28, 0xE6, 0xD5, 0xD7, 0x2, 0x0, 0x0, 0xC1 };//улица
              DeviceAddress addr_T7 = { 0x28, 0x16, 0xB4, 0x7A, 0x4, 0x0, 0x0, 0x8A };//спальня2
              DeviceAddress addr_T8 = { 0x28, 0x2B, 0x86, 0xD7, 0x2, 0x0, 0x0, 0xCF };//зал
              DeviceAddress addr_T9 = { 0x28, 0xAB, 0x9D, 0xD7, 0x2, 0x0, 0x0, 0x29 };//мансарда
              ! float T1=0;
              float T2=0;
              float T3=0;
              float T4=0;
              float T5=0;
              float T6=0;
              float T7=0;
              float T8=0;
              float T9=0;
              ! //dht DHT;
              //#define DHT22_PIN 9
              //float Hout = 0;
              //float Tout = 0;
              //void callback(char* topic, byte* payload, unsigned int length) {
              // payload[length] = '\0';
              // String strTopic = String(topic);
              // String strPayload = String((char*)payload);
              // callback_iobroker(strTopic, strPayload);
              void setup() {
              Serial.begin(57600);
              Serial.println("start");
              Serial.print("Locating devices...");
              DS_sensors.begin();
              Serial.print("Found ");
              Serial.print(DS_sensors.getDeviceCount(), DEC);
              Serial.println(" devices.");
              ! // report parasite power requirements
              Serial.print("Parasite power is: ");
              if (DS_sensors.isParasitePowerMode()) Serial.println("ON");
              else Serial.println("OFF");
              //Объявляем порты Digital inputs/outputs
              for(int i=0 ;i<=n_DI_pin; i++) { pinMode (start_DI_pin [i], INPUT); }
              digitalWrite(5, HIGH); //Насос скважины
              digitalWrite(4, HIGH); //Электрика
              for(int i=0 ;i<=n_DO_pin; i++) { pinMode (start_DO_pin [i], OUTPUT); }
              ! Ethernet.begin(mac, ip);
              if (client.connect(id_connect)) {
              getSensors();
              control();
              //client.publish("myhome/Kitchen/Change_Counter", "0");
              //client.publish("myhome/Kitchen/Temp_room", "0");
              //client.publish("myhome/Kitchen/Humidity_room", "0");
              client.publish("myhome/Temp/Kladovka", "0");
              client.publish("myhome/Temp/Kitchen", "0");
              client.publish("myhome/Temp/Detskaya", "0");
              client.publish("myhome/Temp/Garage", "0");
              client.publish("myhome/Temp/Street", "0");
              client.publish("myhome/Temp/Spalnya2", "0");
              client.publish("myhome/Temp/Zal", "0");
              client.publish("myhome/Temp/Mansarda", "0");
              client.publish("myhome/Temp/Vannaya", "0");
              //client.publish("myhome/Kitchen/Lux", "0");
              //client.publish("myhome/Kitchen/Servo", "0");
              client.publish("myhome/Temp/MQ7", "0");
              client.publish("myhome/Status/Power", "0");
              client.publish("myhome/Status/Pompe", "0");
              client.subscribe("myhome/Temp/#");
              client.subscribe("myhome/Status/#");
              void loop() {
              client.loop();
              control();
              getSensors();
              if (!client.connected()) {
              control();
              getSensors();
              }</dallastemperature.h></onewire.h></dht.h></servo.h></pubsubclient.h></ethernet.h></spi.h>`
              ! А заливаем этот - и ни чего....
              ! >! [spoiler]`[code]#include <spi.h>
              #include <eeprom.h>
              //#include <avr wdt.h="">
              ! #define PWR_CTRL A2 //Контроль напряжения
              #define LED 9 //Светодиод
              #define CHK_ADR 100
              #define CNT_ADR 10
              #define PWR_ADR 20
              #define POLL_ADR 30
              #define RATIO_ADR 40
              ! const char* topic_err = "myhome/test/error";
              const char* topic_cnt = "myhome/test/count";
              const char* topic_pwr = "myhome/test/power";
              const char* topic_amp = "myhome/test/amp";
              const char* topic_save = "myhome/test/save";
              const char* topic_correction = "myhome/test/correction";
              const char* topic_connection = "myhome/test/connection";
              const char* topic_ip = "myhome/test/config/ip";
              const char* topic_polling = "myhome/test/config/polling";
              const char* topic_bounce = "myhome/test/config/bounce";
              const char* topic_num = "myhome/test/config/num";
              const char* topic_reset = "myhome/test/config/reset";
              const char* topic_raw = "myhome/test/RAW";
              const char* subscr = "myhome/test/#";
              ! byte mac[] = { 0xDE, 0xA3, 0xBE, 0xE4, 0xDE, 0x35 };
              byte ip[] = { 192, 168, 0, 89};
              byte server[] = { 192, 168, 0, 15};
              ! unsigned long cnt = 0;
              unsigned long prev_cnt = 2;
              unsigned long pwr = 0;
              unsigned long prev_pwr = 2;
              int amp = 0;
              int prev_amp = 2;
              int num = 0;
              int prev_num;
              int bounce = 10;
              int prev_bounce;
              int chk = 0;
              int chk_S = 0;
              unsigned long prevMillis = 0;
              unsigned long prevMillis_cnt = 0;
              int poll = 5000;
              bool error = 0;
              String cmd = "";
              bool strComplete = false;
              char buf [50];
              char buffer[100];
              char s[16];
              PubSubClient client(ethClient);
              ! void setup() {
              //MCUSR = 0;
              // wdt_disable();
              Serial.println("WDT_disable");
              cmd.reserve(100);
              delay(10000);
              Serial.println("Starting......");
              ! if (EEPROM.read(1) != 99) { //Если первый запуск
              EEPROM.write(1, 99);
              for (int i = 0 ; i < 4; i++) {
              EEPROM.write(110 + i, ip[i]);
              EEPROM.write(120 + i, server[i]);
              } else {
              chk = EEPROMReadInt(CHK_ADR);
              cnt = EEPROMReadLong(CNT_ADR);
              poll = EEPROMReadInt(POLL_ADR);
              chk_S = poll - 500;
              if (chk != chk_S) {
              error = 2;
              for (int i = 0; i < 4; i++) {
              ip[i] = EEPROM.read(110 + i);
              server[i] = EEPROM.read(120 + i);
              ! pinMode(LED, OUTPUT);
              ! client.setServer(server, 1883);
              client.setCallback(callback);
              delay(200);
              //wdt_enable(WDTO_8S);
              Serial.println("WDTO_8S");
              if (client.connect("test")){
              digitalWrite(LED, LOW);
              Public();
              ! void serialEvent() {
              while (Serial.available() > 0) {
              char inChar = (char)Serial.read();
              cmd += inChar;
              if (inChar == '\n') {
              strComplete = true;
              ! void loop() {
              // wdt_reset();
              Serial.println("WDT_reset");
              client.loop();
              reconnect();
              ! /if (analogRead(PWR_CTRL) < 1000) {
              save();
              delay(10000);
              ! if (strComplete) {
              digitalWrite(LED, !digitalRead(LED));
              cmd.toCharArray(buffer, 100);
              cnt = atoi(strtok(buffer, ";"));
              pwr = atoi(strtok(NULL, ";"));
              amp = atoi(strtok(NULL, ";"));
              bounce = atoi(strtok(NULL, ";"));
              num = atoi(strtok(NULL, ";"));
              error = atoi(strtok(NULL, ";"));
              client.publish(topic_raw, StrToChar(cmd));
              cmd = "";
              ! if (millis() - prevMillis >= poll) {
              // wdt_reset();
              Serial.println("WDT_reset-");
              prevMillis = millis();
              if (cnt != prev_cnt || pwr != prev_pwr || amp != prev_amp) {
              prev_cnt = cnt;
              prev_pwr = pwr;
              prev_amp = amp;
              client.publish(topic_cnt, IntToChar(cnt));
              client.publish(topic_pwr, IntToChar(pwr));
              client.publish(topic_amp, IntToChar(amp));
              if (num != prev_num || bounce != prev_bounce) {
              prev_num = num;
              prev_bounce = bounce;
              client.publish(topic_num, IntToChar(num));
              client.publish(topic_bounce, IntToChar(bounce));
              if (error > 0) {
              client.publish(topic_err, "err");
              } else {
              client.publish(topic_err, " ");
              ! void callback_iobroker(String strTopic, String strPayload) {
              if (strTopic == topic_correction) {
              cnt = atol((strPayload).c_str());
              Serial.print("SC");
              Serial.println(cnt);
              client.publish(topic_correction, "0");
              else if (strTopic == topic_save) {
              if (strPayload == "true") {
              Serial.println("SS");
              save();
              client.publish(topic_save, "false");
              else if (strTopic == topic_polling) {
              poll = strPayload.toInt();
              if (poll < 1000) {
              poll = 1000;
              } else if (poll > 32767) {
              poll = 32767;
              EEPROMWriteInt(POLL_ADR, poll); //Интервал публикации
              client.publish(topic_polling, IntToChar(poll));
              else if (strTopic == topic_reset) {
              client.publish(topic_reset, "false");
              // reboot();
              Serial.println("Reboot");
              else if (strTopic == topic_bounce) {
              bounce = strPayload.toInt();
              if (bounce < 0) {
              bounce = 0;
              } else if (bounce > 10000) {
              bounce = 10000;
              Serial.print("SB");
              Serial.println(bounce);
              else if (strTopic == topic_num) {
              num = strPayload.toInt();
              if (num < 0) {
              num = 0;
              } else if (num > 32767) {
              num = 32767;
              Serial.print("SN");
              Serial.println(num);
              ! void save() {
              chk = poll - 500;
              EEPROMWriteLong(CNT_ADR, cnt); //Пишем показания счетчика в eeprom из переменной
              EEPROMWriteInt(CHK_ADR, chk); //чек
              ! void reboot() {
              //save();
              //delay(500);
              // wdt_enable(WDTO_1S);
              Serial.println("void reboot");
              //for (;;) {}
              ! char* StrToChar (String str) {
              int length = str.length();
              str.toCharArray(buf, length + 1);
              return buf;
              ! void EEPROMWriteLong(int p_address, unsigned long p_value) {
              byte four = (p_value & 0xFF);
              byte three = ((p_value >> 8) & 0xFF);
              byte two = ((p_value >> 16) & 0xFF);
              byte one = ((p_value >> 24) & 0xFF);
              EEPROM.write(p_address, four);
              EEPROM.write(p_address + 1, three);
              EEPROM.write(p_address + 2, two);
              EEPROM.write(p_address + 3, one);
              ! unsigned long EEPROMReadLong(int p_address) {
              long four = EEPROM.read(p_address);
              long three = EEPROM.read(p_address + 1);
              long two = EEPROM.read(p_address + 2);
              long one = EEPROM.read(p_address + 3);
              return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
              ! void EEPROMWriteInt(int p_address, int p_value) {
              byte lowByte = ((p_value >> 0) & 0xFF);
              byte highByte = ((p_value >> 8) & 0xFF);
              EEPROM.write(p_address, lowByte);
              EEPROM.write(p_address + 1, highByte);
              unsigned int EEPROMReadInt(int p_address) {
              byte lowByte = EEPROM.read(p_address);
              byte highByte = EEPROM.read(p_address + 1);
              return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
              ! char* IntToChar (unsigned long a) {
              sprintf(buf, "%lu", a);
              return buf;
              ! void Public() {
              sprintf(s, "%d.%d.%d.%d", ip[0], ip[1], ip[2], ip[3]);
              client.publish(topic_connection, "true");
              client.publish(topic_ip, s);
              client.subscribe(subscr);
              void reconnect() {
              int a = 0;
              while (!client.connected()) {
              a++;
              //wdt_reset();
              Serial.println("WDT reset");
              if (client.connect("test")) {
              Public();
              } else {
              delay(10000);
              if (a >= 10) {
              Serial.println("WDTO_1S");
              }</avr></eeprom.h></pubsubclient.h></ethernet.h></spi.h>`
              ! Ни пинга, ни данных....[/i][/i][/i][/i][/code][/spoiler][/i][/i]
              • I Offline
                I Offline
                instalator
                @smoker_vvo:
                Начнем с простого…. Какая IDE `
                ide 1.8.3
                Ethernet 1.1.2
                PubSubCliet 2.6.0
                  smoker_vvo
                  IDE 1.8.4, остальное совпадает…...
                  Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100
                  • I Offline
                    I Offline
                    instalator
                    @smoker_vvo:
                    Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100 `
                    Да какая разница какая ардуина, я на УНО и W5100 проверял
                      smoker_vvo
                      Хлебнуфф пивка и выкурив сигаретку, психанул и заменил Arduino MEGA на Arduino NANO- и О ЧУДО!!!! Все заработало…...
                      Теперь другие вопросы....
                      в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что??
                        smoker_vvo
                        #66
                        ан все таки есть… Щас сборка выглядит так :
                        Нано собирает инфу от счетчика - УНО обрабатывает - В5100 - отдает на Брокера
                        В предыдущем вопле ошибочка, Мега заменил на УНО
                        • I Offline
                          I Offline
                          instalator
                          #67
                          @smoker_vvo:
                          в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что?? `
                          https://github.com/instalator/Electro_C … t.ino#L278
                          https://blog.instalator.ru/archives/711
                          cnt = atoi(strtok(buffer, ";")); //счетчик
                          pwr = atoi(strtok(NULL, ";")); //мощность
                          amp = atoi(strtok(NULL, ";")); //сила тока!
                          bounce = atoi(strtok(NULL, ";")); //задержка от дребезга
                          num = atoi(strtok(NULL, ";")); //Значение передаточного числа счетчика. Количество импульсов на 1 кВт*ч
                          error = atoi(strtok(NULL, ";")); //ошибка
                          • I Offline
                            I Offline
                            instalator
                            #68
                            По скрипту для счетчика меркурий вынес в отдельную тему http://forum.iobroker.net/viewtopic.php?f=26&t=8148
                              smoker_vvo
                              #69
                              Зенкую! Я так и понял. Но проект заглох… проработав два часа......
                              и повторно запустить не удалось....
                              Не могу понять по чему........
                                smoker_vvo
                                #70
                                Вопрос не в тему, но не знаю куда закинуть.
                                Есть более важные задачи - наполнение септика..
                                Для контроля использую следующий скетч:
                                #define Trig 9
                                #define Echo 8
                                #define ledPin 13
                                ! void setup()
                                pinMode(Trig, OUTPUT); //инициируем как выход
                                pinMode(Echo, INPUT); //инициируем как вход
                                pinMode(ledPin, OUTPUT);
                                Serial.begin(9600);
                                /* задаем скорость общения. В нашем случае с компьютером /
                                unsigned int impulseTime=0;
                                unsigned int distance_sm=0;
                                ! void loop()
                                digitalWrite(Trig, HIGH);
                                Подаем импульс на вход trig дальномера */
                                delayMicroseconds(10); // равный 10 микросекундам
                                digitalWrite(Trig, LOW); // Отключаем
                                impulseTime=pulseIn(Echo, HIGH); // Замеряем длину импульса
                                distance_sm=impulseTime/58; // Пересчитываем в сантиметры
                                Serial.println(distance_sm); // Выводим на порт
                                if (distance_sm<50) // Если расстояние менее 30 сантиметром
                                digitalWrite(ledPin, HIGH); // Светодиод горит
                                else
                                digitalWrite(ledPin, LOW); // иначе не горит
                                delay(10000);
                                Подскажите как загнать его в Брокер,
                                хочется через MQTT
                                Для температуры использую вот это:
                                #include <servo.h>
                                #include <dht.h>
                                Servo servo;
                                int flag = 0;
                                int flag2 = 0;
                                int pause = 0;
                                //int MQ7Value = 0;
                                >! float T1=0;
                                float T2=0;
                                float T3=0;
                                float T4=0;
                                float T5=0;
                                float T6=0;
                                float T7=0;
                                float T8=0;
                                float T9=0;
                                >! //dht DHT;
                                //float Hout = 0;
                                //float Tout = 0;
                                void setup() {
                                  DS_sensors.begin();
                                    getSensors();
                                    control();
                                void loop() {
                                  client.loop();
                                  control();
                                  getSensors();
                                      control();
                                      getSensors();
                                И это Function
                                >! >! ~~[spoiler]~~`~~[code]~~//--------------------------------- Functions ---------------------------------//
                                /////////////////////////////////От Брокера//////////////////////////////////////////////
                                void callback_iobroker(String strTopic, String strPayload){
                                  if (strTopic == "myhome/Kitchen/Servo"){
                                        ServoAngle=strPayload.toInt();
                                    if (ServoAngle >= 0 && ServoAngle <= 255){
                                          servo.attach(ServoPin);
                                          //delay(200); //ждем 2 секунды
                                          servo.write(ServoAngle); //ставим вал под 0
                                          delay(1000); //ждем 2 секунды
                                          //client.publish("myhome/Kitchen/Servo", b);
                                          servo.detach();
                                >! ////////////////////////////////////Брокеру/////////////////////////////////////
                                void control(){
                                       if(digitalRead(5)==HIGH && flag==0) { //если насос включен
                                          client.publish("myhome/Status/Pompe", "1");
                                          flag=1;
                                       if(digitalRead(5)==LOW && flag==1){//если насос выключен
                                        flag=0;//обнуляем переменную flag
                                       if(digitalRead(4)==HIGH && flag2==0) { // Если электрика есть
                                          client.publish("myhome/Status/Power", "1");
                                          flag2=1;
                                       if(digitalRead(4)==LOW && flag2==1){// Если эректрики нет
                                        flag2=0;//обнуляем переменную flag
                                ///////////////////////////////Данные сенсоров////////////////////////////////////
                                >! void getSensors () {
                                >!   MQ7Value = analogRead(MQ7_Pin);
                                  fotoValue = analogRead(foto_Pin);  // считываем значение с фоторезистора
                                // ServoAngle = analogRead(2);
                                >! //Обработка данных датчика DHT22\. Подключение к порту цифровому P9 Arduino
                                //Глобальные переменные Hout и Tout типа флоат - влажность (%) и температура (град. С)
                                //  if (DHT.read22(DHT22_PIN)== DHTLIB_OK) {
                                //    Hout = DHT.humidity;
                                //    Tout = DHT.temperature;
                                //  if (Hout == 0 || Tout == 0){
                                //    delay (1000);
                                  //Обработка данных цифровых датчиков температуры типа DS18B20.
                                  //Шина 1-Wire на цифровой пин P8 Arduino.
                                  //Подключено 2 датчика температуры, адреса задаются в секции глобальных констант "Sensors"
                                  //Три значение температуры T1, T2, типа float (град. С).
                                  DS_sensors.setResolution(addr_T1, 9);
                                  DS_sensors.setResolution(addr_T2, 9);
                                  DS_sensors.setResolution(addr_T3, 9);
                                  DS_sensors.setResolution(addr_T4, 9);
                                  DS_sensors.setResolution(addr_T5, 9);
                                  DS_sensors.setResolution(addr_T6, 9);
                                  DS_sensors.setResolution(addr_T7, 9);
                                  DS_sensors.setResolution(addr_T8, 9);
                                  DS_sensors.setResolution(addr_T9, 9);
                                  float T1 = DS_sensors.getTempC(addr_T1);
                                  float T2 = DS_sensors.getTempC(addr_T2);
                                  float T3 = DS_sensors.getTempC(addr_T3);
                                  float T4 = DS_sensors.getTempC(addr_T4);
                                  float T5 = DS_sensors.getTempC(addr_T5);
                                  float T6 = DS_sensors.getTempC(addr_T6);
                                  float T7 = DS_sensors.getTempC(addr_T7);
                                  float T8 = DS_sensors.getTempC(addr_T8);
                                  float T9 = DS_sensors.getTempC(addr_T9);
                                  DS_sensors.requestTemperatures();
                                //Serial.print(DS_sensors.getResolution(addr_T1), DEC);
                                  Serial.println();
                                  Serial.print("Temp T1 C: ");
                                  Serial.print(T1);
                                  Serial.println();
                                >!   Serial.println();
                                  Serial.print("Temp T2 C: ");
                                  Serial.print(T2);
                                  Serial.println();
                                Serial.println();
                                  Serial.print("Temp T3 C: ");
                                  Serial.print(T3);
                                  Serial.println();
                                Serial.println();
                                  Serial.print("Temp T4 C: ");
                                  Serial.print(T4);
                                  Serial.println();
                                Serial.println();
                                  Serial.print("Temp T5 C: ");
                                  Serial.print(T5);
                                  Serial.println();
                                Serial.println();
                                  Serial.print("Temp T6 C: ");
                                  Serial.print(T6);
                                  Serial.println();
                                Serial.println();
                                  Serial.print("Temp T7 C: ");
                                  Serial.print(T7);
                                  Serial.println();
                                Serial.println();
                                  Serial.print("Temp T8 C: ");
                                  Serial.print(T8);
                                  Serial.println();
                                Serial.println();
                                  Serial.print("Temp T9 C: ");
                                  Serial.print(T9);
                                  Serial.println();
                                ///////////////////////Паблик данных сенсоров////////////////////////
                                 if (pause == 50 || pause == 0){
                                  char b[5];
                                //    String char_Hout = String(Hout);
                                //    char_Hout.toCharArray(b,5);
                                //    client.publish("myhome/Kitchen/Humidity_room", b);
                                //  String char_Tout = String(Tout);
                                //  char_Tout.toCharArray(b,5);
                                //  client.publish("myhome/Kitchen/Temp_room", b);
                                    String char_T1 = String(T1);
                                    char_T1.toCharArray(b,5);
                                    client.publish("myhome/Temp/Kladovka", b);
                                    String char_T2 = String(T2);
                                    char_T2.toCharArray(b,5);
                                    client.publish("myhome/Temp/Kitchen", b);
                                    String char_T3 = String(T3);
                                    char_T3.toCharArray(b,5);
                                    client.publish("myhome/Temp/Detskaya", b);
                                    String char_T4 = String(T4);
                                    char_T4.toCharArray(b,5);
                                    client.publish("myhome/Temp/Garage", b);
                                    String char_T5 = String(T5);
                                    char_T5.toCharArray(b,5);
                                    client.publish("myhome/Temp/Vannaya", b);
                                    String char_T6 = String(T6);
                                    char_T6.toCharArray(b,5);
                                    client.publish("myhome/Temp/Street", b);
                                    String char_T7 = String(T7);
                                    char_T7.toCharArray(b,5);
                                    client.publish("myhome/Temp/Spalnya2", b);
                                    String char_T8 = String(T8);
                                    char_T8.toCharArray(b,5);
                                    client.publish("myhome/Temp/Zal", b);
                                    String char_T9 = String(T9);
                                    char_T9.toCharArray(b,5);
                                    client.publish("myhome/Temp/Mansarda", b);
                                    //Serial.println(T1);
                                    String char_fotoValue = String(fotoValue);
                                    char_fotoValue.toCharArray(b,4);
                                    client.publish("myhome/Kitchen/Lux", b);
                                  String char_ServoAngle = String(ServoAngle);
                                  char_ServoAngle.toCharArray(b,4);
                                    String char_MQ7Value = String(MQ7Value);
                                    char_MQ7Value.toCharArray(b,4);
                                    client.publish("myhome/Temp/MQ7", b);
                                    pause = 1;
                                 else pause++;
                                >! [/code]`[/spoiler]
                                >! Показания от септика получаю в значениях см, типа 160 см, 100 см.....[/i][/i]
