  4. Huawei Sun2000 & ioBroker via JS script funktioniert
481 Beiträge 62 Kommentatoren 178.6k Aufrufe 63 Beobachtet
  • W
    W
    WILHER
    Hallo zusammen, versuche auch meinen SUN2000 ausgelesen zu bekommen, leider funktioniert es nicht. Es werde auch irgendwie keine Werte geschrieben. Habe 1 String, 1 Batteriespeicher LUNA2000 10kw. Was fehlt hier ggf noch?
    // License: Beerware! Do what ever you like with this, but I'm not liable for anything that you do with it.
    // If you like this code, feel free to buy me a beer ...
    // Have fun with it! der Kachel
    var ModbusRTU = require("modbus-serial");
    var client = new ModbusRTU();
    var modbusErrorMessages = [
    "Unknown error",
    "Illegal function (device does not support this read/write function)",
    "Illegal data address (register not supported by device)",
    "Illegal data value (value cannot be written to this register)",
    "Slave device failure (device reports internal error)",
    "Acknowledge (requested data will be available later)",
    "Slave device busy (retry request again later)"
    // open connection to a tcp line
    client.setTimeout(10000);
    // Enter your inverter modbus IP and port here:
    client.connectTCP("192.168.10.101", { port: 502 });
    // Enter the Modbus-IDs of your Sun2000 inverters here:
    const ModBusIDs = [16, 1];
    // On which Modbus-ID can we reach the power meter? (via Sun2000!)
    const PowerMeterID = 0;
    // Enter your battery stack setup. 2 dimensional array.
    // e.g. [[3, 2], [3, 0]] means:
    // First inverter has two battery stacks with 3 + 2 battery modules
    // while second inverter has only one battery stack with 3 battery modules
    const BatteryUnits = [[3, 2], [3, 0]];
    // These register spaces need to be read:
    const RegisterSpacesToReadContinuously = [[30000, 81], [37100, 114], [32000, 116], [37000, 68], [37700, 100], [37800, 100], [38200, 100], [38300, 100], [38400, 100], [35300, 40]];
    var RegisterSpacesToReadContinuouslyPtr = 0;
    var GlobalDataBuffer = new Array(2);
    for(var i=0; i<ModBusIDs.length; i++) {
    GlobalDataBuffer[i] = new Array(50000); // not optimized....
    // Some helper functions:
    function readUnsignedInt16(array) {
    var value = array[0];
    return value;
    function readUnsignedInt32(array) {
    var value = array[0] * 256 * 256 + array[1];
    return value;
    function readSignedInt16(array) {
    var value = 0;
    if (array[0] > 32767)
    value = array[0] - 65535;
    else
    value = array[0];
    return value;
    function readSignedInt32(array) {
    var value = 0;
    for (var i = 0; i < 2; i++) {
    value = (value << 16) | array[i];
    return value;
    function getU16(dataarray, index) {
    var value = readUnsignedInt16(dataarray.slice(index, index+1));
    return value;
    function getU32(dataarray, index) {
    var value = readUnsignedInt32(dataarray.slice(index, index+2));
    return value;
    function getI16(dataarray, index) {
    var value = readSignedInt16(dataarray.slice(index, index+1));
    return value;
    function getI32(dataarray, index) {
    var value = readSignedInt32(dataarray.slice(index, index+2));
    return value;
    function getString(dataarray, index, length) {
    var shortarray = dataarray.slice(index, index+length);
    var bytearray = [];
    for(var i = 0; i < length; i++) {
    bytearray.push(dataarray[index+i] >> 8);
    bytearray.push(dataarray[index+i] & 0xff);
    var value = String.fromCharCode.apply(null, bytearray);
    return value;
    function getZeroTerminatedString(dataarray, index, length) {
    var bytearray = [];
    var value2 = new String(value).trim();
    return value2;
    function forcesetState(objectname, value, options) {
    if(!existsState(objectname)) {
    createState(objectname, value, options);
    else {
    setState(objectname, value);
    // Functions to map registers into ioBreaker objects:
    function processOptimizers(id) {
    forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber", getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber", getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData", getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
    function processInverterPowerAdjustments(id) {
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode", getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue", getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand", getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode", getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue", getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower", getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
    function processBattery(id) {
    // Battery registers 1-15 (Stack 1 related)
    if(BatteryUnits[id-1][0] > 0) {
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus", getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage", getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC", getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode", getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower", getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower", getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.FaultID", getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent", getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature", getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime", getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion", getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion", getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
    // Battery registers 16+17 (Storage-related)
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumChargePower", getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumDischargePower", getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
    // Battery register 18-20 (Stack 1 related)
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SN",                         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",             getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
    // Battery register 21-31 (Stack 2 related)
    if(BatteryUnits[id-1][1] > 0) {
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SN",                     getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
    // Battery register 32-41 (Storage related)
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
    // Battery registers 42+43 (Battery stack related)
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
    // Registers 44 to 98: (Battery pack related)
    for(var i = 1; i <= 2; i++){
        if(BatteryUnits[id-1][i-1] >= 0) {
            for(var j = 1; j <= BatteryUnits[id-1][i-1]; j++) {
                //[[38200, 38242, 38284] [38326, 38368, 38410]]; (+42 for each battery pack, +126 for each stack)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                // [[38452, 38454, 38456][38458, 38460, 38462]] ( +2 for each pack, +6 for each stack)
                createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
    // Battery registers 110-141 are not supported by this script yet!
    function ProcessPowerMeterStatus() {
    forcesetState("Solarpower.Huawei.Meter.Status", getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Meter.VoltageL1", getI32(GlobalDataBuffer[PowerMeterID], 37101) / 10, {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Meter.VoltageL2", getI32(GlobalDataBuffer[PowerMeterID], 37103) / 10, {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Meter.VoltageL3", getI32(GlobalDataBuffer[PowerMeterID], 37105) / 10, {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Meter.CurrentL1", getI32(GlobalDataBuffer[PowerMeterID], 37107) / 100, {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Meter.CurrentL2", getI32(GlobalDataBuffer[PowerMeterID], 37109) / 100, {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Meter.CurrentL3", getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Meter.ActivePower", getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Meter.ReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
    forcesetState("Solarpower.Huawei.Meter.PowerFactor", getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Meter.GridFrequency", getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
    forcesetState("Solarpower.Huawei.Meter.PositiveActiveEnergy", getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Meter.ReverseActiveEnergy", getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
    forcesetState("Solarpower.Huawei.Meter.MeterType", getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Meter.VoltageL1-L2", getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Meter.VoltageL2-L3", getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Meter.VoltageL3-L1", getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Meter.ActivePowerL1", getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Meter.ActivePowerL2", getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Meter.ActivePowerL3", getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
    forcesetState("Solarpower.Huawei.Meter.MeterModel", getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
    function processInverterStatus(id) {
    forcesetState("Solarpower.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage", getI16(GlobalDataBuffer[id-1], 32016) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current", getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage", getI16(GlobalDataBuffer[id-1], 32018) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current", getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".InputPower", getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage", getU16(GlobalDataBuffer[id-1], 32066) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage", getU16(GlobalDataBuffer[id-1], 32067) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage", getU16(GlobalDataBuffer[id-1], 32068) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage", getU16(GlobalDataBuffer[id-1], 32069) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage", getU16(GlobalDataBuffer[id-1], 32070) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage", getU16(GlobalDataBuffer[id-1], 32071) / 10 , {name: "", unit: "V"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current", getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current", getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current", getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay", getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActivePower", getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower", getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor", getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency", getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Efficiency", getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature", getI16(GlobalDataBuffer[id-1], 32087) / 10 , {name: "", unit: "°C"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance", getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus", getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".FaultCode", getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".StartupTime", getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime", getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield", getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield", getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
    function ProcessDeviceInfo(id) {
    // Note: Manual says its quantitiy is 15, but that is the number (+1) of 8bit characters
    forcesetState("Solarpower.Huawei.Inverter." + id + ".Model", getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".SN", getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".PN", getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".ModelID", getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".PVStrings", getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".MPPTrackers", getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxRatedPower", getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxActivePower", getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxApparentPower", getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerToGrid", getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid", getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
    function readRegisterSpace(id, address, length) {
    client.setID(ModBusIDs[id-1]);
    client.readHoldingRegisters(address, length, function(err, data) {
    if (err) {
    console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
    else
    console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
    GlobalDataBuffer[id-1][address+i] = data.data[i];
    function processData() {
    console.log("Processing new data...");
    for(var i = 1; i <= ModBusIDs.length; i++) {
    ProcessDeviceInfo(i);
    processInverterStatus(i);
    processBattery(i);
    processInverterPowerAdjustments(i);
    processOptimizers(i);
    ProcessPowerMeterStatus();
    console.log("Processing done!");
    // This is the main function triggering a read via modbus-tcp every two seconds.
    // Processing of data is triggered as soon as one complete set of registers is copied.
    var triggerprocessing = 0;
    var currentinverter = 1;
    setInterval(function() {
    if(triggerprocessing == 1) {
    processData();
    console.log("Triggering read of inverter " + currentinverter + " at address " + RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0] + " with length " +  RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
    readRegisterSpace(currentinverter, RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0], RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
    RegisterSpacesToReadContinuouslyPtr++;
    if(RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length) {
        currentinverter++
        if(currentinverter > ModBusIDs.length){
            triggerprocessing = 1;
    }, 2000);
    Wäre schön wenn mir da jemand helfen könnte.
    • W WILHER
      "Unknown error",
      return value;
      return value;
      var value = 0;
      else
      value = array[0];
      return value;
      var value = 0;
      return value;
      return value;
      return value;
      return value;
      return value;
      var bytearray = [];
      return value;
      var bytearray = [];
      return value2;
      else {
      if (err) {
      else
      processBattery(i);
      processData();
          currentinverter++
      }, 2000);
      T
      T
      Thomas42
      @wilher Hi,
      wäre eventuell hifreich, wenn Du Dein Log posten würdest und nicht das Script :-)
      • oswibzO oswibz
        @zoid1988 Hallo zusammen, gibt es hier Neuigkeiten. Hab heute mein WR angeschlossen. Datenpunkte wurden generiert aber erhalte den selben Fehler. Gibt es Lösungen? Danke an alle für die Hilfe!
        Ich habe auch den Workaround eingesetzt, erhalte immer aber die gleiche Warnung:
        21:02:25.393 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 30000 with length 81
        21:02:25.394 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 30000 from id: 1 with error: undefined
        21:02:27.393 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37100 with length 114
        21:02:27.394 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37100 from id: 1 with error: undefined
        21:02:29.394 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 32000 with length 116
        21:02:29.394 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 32000 from id: 1 with error: undefined
        21:02:31.394 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37000 with length 68
        21:02:31.395 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37000 from id: 1 with error: undefined
        21:02:33.395 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37700 with length 100
        21:02:33.396 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37700 from id: 1 with error: undefined
        21:02:35.395 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37800 with length 100
        21:02:35.396 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37800 from id: 1 with error: undefined
        21:02:37.395 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 38200 with length 100
        21:02:37.396 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 38200 from id: 1 with error: undefined
        21:02:39.406 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 38300 with length 100
        21:02:39.406 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 38300 from id: 1 with error: undefined
        21:02:41.406 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 38400 with length 100
        21:02:41.407 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 38400 from id: 1 with error: undefined
        21:02:43.407 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 35300 with length 40
        21:02:43.408 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 35300 from id: 1 with error: undefined
        @oswibz
        Leider gibt es hier bei mir nichts neues ... Es funktioniert immer noch nicht ...
        • Alex WarkentinA
          Alex WarkentinA
          Alex Warkentin
          Ich habe das Script gerade erfolgreich eingerichtet. War nicht ganz so einfach. Daher hier noch ein paar Tipps:
          Javascript Adapter und Nodejs sollten auf dem neuesten Stand sein, oder zumindest zueinander passen.
          In den Einstellungen des Javascript-Adapters muss die Erweiterung "modbus-serial" eingetragen werden (einfach reinschreiben und bestätigen). Bei mir meckert das Script danach trotzdem über die Zeile, funktioniert aber.
          Die IP eures Dongles muss eingetragen werden (ohne $$$)
          client.connectTCP("192.xxx.xxx.xxx", { port: 502 });
          Die IDs des WRs und der Batterien könnt ihr im Gerätemanagement in der Fusionsolar Web-Oberfläche herausfinden, oder direkt am Gerät. Dafür braucht ihr aber den Installateur-Zugang. Normalerweise hat der WR aber die ID 1 und der SmartMeter die 0. Bei der Batterie kann ich nicht weiterhelfen. Habe keine.
          const modBusIDs = [1];
          const powerMeterID = 0;
          Die existState Funktion ist fehlerhaft, da objectname nicht den vollen Pfad beinhaltet. So funktioniert es:
          if(!existsState("javascript.0." + objectname))
          Bei der Start- und Stopzeit habe ich die Sekunden in Datum umgewandelt. Bitte auf Groß-Kleinschreibung achten
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",              new Date(GetU32(globalDataBuffer[id-1], 32091)*1000),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",             new Date(GetU32(globalDataBuffer[id-1], 32093)*1000),          {name: "", unit: ""});
          • Alex WarkentinA Alex Warkentin
            S
            S
            striegel26
            schrieb am zuletzt editiert von striegel26
            Hallo zusammen
            ich brauche mal eure Hilfe. Das Script scheint soweit zu funktionieren, aber es werden leider die Werte des PowerMeters nicht aktualisiert, das erste mal hat es funktioniert. Was habe ich falsch gemacht ?
            VG Dennis
                "Unknown error",
            client.connectTCP("192.168.178.95", { port: 502 });
            const PowerMeterID = 11;
            const BatteryUnits = [[3, 0], [3, 0]];
                return value;
                return value;
                var value = 0;
                else
                    value = array[0];
                return value;
                var value = 0;
                return value;
                return value;
                return value;
                return value;
                return value;
                var bytearray = [];
                return value;
                var bytearray = [];
                return value2;
                if(!existsState("javascript.0." + objectname)) {
                    console.log("createstate " +  objectname + " to value " + value);
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",            getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",       getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",    getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime", getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",            getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",             getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",             getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SN",                         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",             getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SN",                     getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                            createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                            createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                forcesetState("Solarpower2.Huawei.Meter.Status",          getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Meter.VoltageL1",        getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Meter.VoltageL2",        getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Meter.VoltageL3",        getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Meter.CurrentL1",        getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Meter.CurrentL2",        getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Meter.CurrentL3",        getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Meter.ActivePower",     getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
                forcesetState("Solarpower2.Huawei.Meter.ReactivePower",   getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
                forcesetState("Solarpower2.Huawei.Meter.PowerFactor",     getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Meter.GridFrequency",   getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
                forcesetState("Solarpower2.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
                forcesetState("Solarpower2.Huawei.Meter.MeterType",       getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Meter.VoltageL1-L2",       getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Meter.VoltageL2-L3",       getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Meter.VoltageL3-L1",       getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Meter.ActivePowerL1",    getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
                forcesetState("Solarpower2.Huawei.Meter.ActivePowerL2",    getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
                forcesetState("Solarpower2.Huawei.Meter.ActivePowerL3",    getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
                forcesetState("Solarpower2.Huawei.Meter.MeterModel",      getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",           getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",           getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",           getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Voltage",            getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Voltage",            getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Voltage",            getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Current",         getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Current",         getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Current",         getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".DeviceStatus",              getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".FaultCode",                 getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".StartupTime",               getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ShutdownTime",              getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".DailyEnergyYield",          getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".ModelID",           getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".PVStrings",         getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".MPPTrackers",       getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxRatedPower",     getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxActivePower",    getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxApparentPower",  getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",        getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
                forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",      getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
                    if (err) {
                    else
                    processBattery(i);
                    processData();
                    currentinverter++
            }, 2000);
            Alex WarkentinA 1 Antwort Letzte Antwort
            • S striegel26
              Hallo zusammen
              VG Dennis
                  "Unknown error",
                  return value;
                  return value;
                  var value = 0;
                  else
                      value = array[0];
                  return value;
                  var value = 0;
                  return value;
                  return value;
                  return value;
                  return value;
                  return value;
                  var bytearray = [];
                  return value;
                  var bytearray = [];
                  return value2;
                      if (err) {
                      else
                      processBattery(i);
                      processData();
                      currentinverter++
              }, 2000);
              Alex WarkentinA
              Alex WarkentinA
              Alex Warkentin
              @striegel26 Bist du sicher, dass dein Powermeter die ID 11 hat und hast du zwei Wechselrichter mit 16 und 1?
              Was sagen denn deine Protokolle?
                S
                S
                striegel26
                @alex-warkentin ja mir kam das auch komisch vor mit der ID11 aber schau ...... oder verstehe ich da was falsch? WR mit 16 und 1 mein fehler 16 ist gelöscht natürlich.
                Log_PV.txt
                • S striegel26
                  Log_PV.txt
                  Alex WarkentinA
                  Alex WarkentinA
                  Alex Warkentin
                  @striegel26 Ich bin mir da nicht sicher. Bei mir steht dort auch die 11 drin, aber ich habe die 0 von Anfang an stehen gelassen und damit funktioniert es.
                    S
                    S
                    striegel26
                    @alex-warkentin Oh man ja die 0 ist es !!! Danke dir 😊 Jetzt funktioniert alles
                    • J
                      J
                      juggi1962
                      Hallo an alle Wissenden :-)
                      Funktioniert dieses Skript auch ohne Speicher?
                      Ich hab leider keinen Speicher was muss ich dann daran ändern.
                      Für mich ist JS Neuland.
                      Wäre schön wenn mir jemand helfen könnte.
                      Danke im Voraus Gruß Jürgen.
                      javascript.0
                      2023-03-05 09:56:27.826	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38200 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:25.826	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37800 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:23.824	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37700 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:21.826	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:19.823	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 32000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:17.823	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37100 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:15.823	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 30000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:13.821	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 35300 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:11.820	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38400 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:09.820	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38300 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:07.819	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38200 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:05.819	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37800 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:03.820	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37700 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:56:01.819	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:59.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 32000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:57.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37100 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:55.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 30000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:53.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 35300 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:51.818	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38400 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:49.816	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38300 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:47.816	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38200 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:45.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37800 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:43.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37700 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:41.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:39.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 32000 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:37.814	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37100 from id: undefined with error: undefined
                      javascript.0
                      2023-03-05 09:55:35.814	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 30000 from id: undefined with error: undefined
                      A Alex WarkentinA 2 Antworten Letzte Antwort
                      • J juggi1962
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        A
                        A
                        ATARI
                        schrieb am zuletzt editiert von ATARI
                        @juggi1962
                        Bin auch nicht so fit in js..
                        ändere mal die Einstellung für den Speicher.
                        zum Bsp.:
                        const BatteryUnits = [0, 0];
                        ATARI
                        Edit:
                        Deinem Log zufolge bekommst Du keine Daten von der Anlage.
                        Hast Du in den Kom.einstellung des Wechselrichters den ModBus
                        aktiviert?
                        ATARI
                        Raspberry Pi 5B (ioB via pi OS_lite(64bit) | Synology NAS (ioB via Docker)
                        Fibaro Home Center 2 & Home Center 3 | Homematic IP | EMS-ESP32 Gateway
                        Aeotec Z-Wave | Tuya 4 in 1 Gateway | Zigbee & BLE Gateway
                        • K Kachel
                          Die Modbus-Ansteuerung vom Huawei Sun2000 Wechselrichter ist über TCP etwas speziell, da nach öffnen des TCP-Ports noch eine Pause eingehalten werden muss, da sonst keine Daten zurück geliefert werden. Auch wird nicht jede Modbus-TCP-Anfrage mit den angeforderten Registern beantwortet. Daher funktioniert die Kommunikation über den normalen Modbus-Adapter im ioBroker nicht.
                          Um die verfügbaren Register in den ioBroker zu bekommen hab ich ein js-script geschrieben, dass die Abfrage der Register über TCP macht und die Daten entsprechend parsed. Man braucht dafür im IOBroker nur die ScriptEngine und muss in deren Settings noch die modbus-serial hinzufügen. Danach legt das Script einen großen Satz an Objekten an und aktualisiert die regelmäßig (ca. 2x die Minute). Es werden nur Register gelesen - das Schreiben von Registern ist nicht eingebaut (und bei mir gerade auch nicht nötig). Damit die Netzwerkpakete möglichst groß sind werden die Registern in Blöcken abgefragt.
                          Wer möchte kann das Script gerne nutzen. . Einfach IP, Batteriekonfiguration und die Modbus-IDs eintragen und ausführen. Wer es ändern möchte darf dies auch gerne tun - es freut aber sicher alle ioBroker-Nutzer wenn ihr Änderungen auch wieder veröffentlicht.
                          Falls jemand noch eine Idee hat, wie man den Huawei File-transfer über Modbus implementieren kann (mit deren speziellem function-code 0x41), würde ich mich freuen. Der fehlt leider damit die Optimierer ihre Echtzeit-Daten in den IOBroker liefern können...
                          der Kachel
                              "Unknown error",
                          client.connectTCP("$$$ADD.YOUR.IP.HERE$$$", { port: 502 });
                              return value;
                              return value;
                              var value = 0;
                              else
                                  value = array[0];
                              return value;
                              var value = 0;
                              return value;
                              return value;
                              return value;
                              return value;
                              return value;
                              var bytearray = [];
                              return value;
                              var bytearray = [];
                              return value2;
                              else {
                                  if (err) {
                                  else
                                  processBattery(i);
                                  processData();
                                  currentinverter++
                          }, 2000);
                          A
                          A
                          ATARI
                          @kachel
                          Vielen Dank für das Script und Deine Arbeit !
                          Wie kann ich den Abfrage Intervall nach einem Durchlauf verzögern
                          oder nur einmal pro Minute oder alle 5 Minuten starten lassen?
                          Ein Timer mit: von Uhrzeit bis Uhrzeit alle x Minuten wäre auch super.
                          Momentan bekommt das Script irgendwann im Laufe des Tages keine
                          Daten mehr und erzeugt nur noch Fehlermeldungen.
                          In diesem Fall hilft nur: das Script stoppen und nach einigen Minuten
                          wieder starten.
                          ATARI
                          Edit:
                          Würde Dir für Deine Arbeit 'nen Kaffee oder 'n Bier spendieren.
                          ATARI
                          Alex WarkentinA J H 3 Antworten Letzte Antwort
                          • J juggi1962
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            Alex WarkentinA
                            Alex WarkentinA
                            Alex Warkentin
                            @juggi1962
                            Der Fehler besagt, dass deine ID für den Wechselrichter "undefined" ist. Welche ID hast du im Script eingestellt und hast du sie mit deinen aktuellen Einstellungen abgeglichen?
                            • A ATARI
                              @kachel
                              wieder starten.
                              ATARI
                              Edit:
                              Alex WarkentinA
                              Alex WarkentinA
                              Alex Warkentin
                              @atari
                              Das Abfrageintervall kannst du in der letzten Zeile des Scripts in ms einstellen. Dein Problem liegt wohl aber weniger am Intervall (dann kommt zwischendurch eine Warnung, dass das Gerät beschäftigt ist), sondern, dass das Script beim Verlust der Modbus-Verbindung diese nicht wieder automatisch aufbaut.
                              J A 2 Antworten Letzte Antwort
                                @juggi1962
                                J
                                J
                                juggi1962
                                @alex-warkentin
                                Danke für deine Antwort. Soweit funktioniert jetzt alles.
                                Gibt es eigentlich eine Möglichkeit die Infos auszuschalten denn so sehe ich im Log ja nur mehr diese von dem Skript.
                                Danke für eure Hilfe
                                • A ATARI
                                  @juggi1962
                                  zum Bsp.:
                                  ATARI
                                  Edit:
                                  aktiviert?
                                  J
                                  J
                                  juggi1962
                                  @atari sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                  @juggi1962
                                  zum Bsp.:
                                  ATARI
                                  Edit:
                                  aktiviert?
                                  Danke für deine Antwort. Soweit läuft jetzt alles
                                  • J juggi1962
                                    @alex-warkentin
                                    Alex WarkentinA
                                    Alex WarkentinA
                                    Alex Warkentin
                                    @juggi1962
                                    Suche mal im Script mit STRG + F nach "console.log" und setze überall, wo dich die Information nicht interessiert "//" vor die Zeile.
                                      @juggi1962
                                      J
                                      J
                                      juggi1962
                                      @alex-warkentin
                                      Super Danke, werde ich gleich probieren
                                      • A ATARI
                                        @kachel
                                        wieder starten.
                                        ATARI
                                        Edit:
                                        J
                                        J
                                        juggi1962
                                        @kachel
                                        wieder starten.
                                        ATARI
                                        Edit:
                                        Ich habe leider das selbe Problem. Eine Weile läuft alles bestens und dann nur mehr Fehler.
                                        Neustart und es läuft wieder ein Weilchen.
                                          @atari
                                          J
                                          J
                                          juggi1962
                                          @alex-warkentin sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                          @atari
                                          Ich habe das selbe Problem.
                                          Ich habe eine LAN Verbindung also sollte fie Verbindung bleiben, oder verstehe ich da was falsch? was kann man da machen
                                          83.8k
