  3. Einsteigerfragen
  4. Steuerung Gecko in Touch 2 per iob möglich? (Wellis)
    5.3k
210 Beiträge 9 Kommentatoren 48.2k Aufrufe 6 Beobachtet
  • T tklein
    @rrov1
    Mhmmm ok.
    Zu1)
    von der Kommandozeile geht es, bekomme aber weitere logs:
    pi@raspberrypi-iob:~/wellis/v4 $ python3.10 spa_toggleLight.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 LI javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI.Switch
    Total arguments passed: 5
    Connecting using client id 916b0096-ab56-4344-8728-43a8259c63c2
    Connecting to spa id SPAe8:eb:1b:1c:5e:46
    Switching light: LI
    Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI.Switch
    Looking for spas on your network ...
    2023-02-15 10:01:07,024> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)]
    *** connecting to spa
    *** light count: 1
    *** found light with key LI and name: Lights with state False
    *** switching light on
    2023-02-15 10:01:17,310> INFO Value for UdLightTime changed from 0 to 60
    2023-02-15 10:01:17,313> INFO Value for UdLi changed from OFF to HI
    2023-02-15 10:01:17,315> INFO Value for inTCipDelay changed from 1800 to 900
    *** light mode is now: True
    Traceback (most recent call last):
      File "/home/pi/.local/lib/python3.10/site-packages/requests/models.py", line 434, in prepare_url
        scheme, auth, host, port, path, query, fragment = parse_url(url)
      File "/home/pi/.local/lib/python3.10/site-packages/urllib3/util/url.py", line 397, in parse_url
        return six.raise_from(LocationParseError(source_url), None)
      File "<string>", line 3, in raise_from
    urllib3.exceptions.LocationParseError: Failed to parse: http://192:168:0:20:8087/set/javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI.Switch.Switch?value=true&ack=true
    During handling of the above exception, another exception occurred:
      File "/home/pi/wellis/v4/spa_toggleLight.py", line 99, in <module>
        asyncio.run(main())
      File "/usr/local/lib/python3.10/asyncio/runners.py", line 44, in run
        return loop.run_until_complete(main)
      File "/usr/local/lib/python3.10/asyncio/base_events.py", line 649, in run_until_complete
        return future.result()
      File "/home/pi/wellis/v4/spa_toggleLight.py", line 80, in main
        requests.get(f"{IOBROKER_BASE_URL}{IOBR_LIGHT_CHANNEL}.Switch?value={str(newLightMode).lower()}&ack=true")
      File "/home/pi/.local/lib/python3.10/site-packages/requests/api.py", line 73, in get
        return request("get", url, params=params, **kwargs)
      File "/home/pi/.local/lib/python3.10/site-packages/requests/api.py", line 59, in request
        return session.request(method=method, url=url, **kwargs)
      File "/home/pi/.local/lib/python3.10/site-packages/requests/sessions.py", line 573, in request
        prep = self.prepare_request(req)
      File "/home/pi/.local/lib/python3.10/site-packages/requests/sessions.py", line 484, in prepare_request
        p.prepare(
      File "/home/pi/.local/lib/python3.10/site-packages/requests/models.py", line 368, in prepare
        self.prepare_url(url, params)
      File "/home/pi/.local/lib/python3.10/site-packages/requests/models.py", line 436, in prepare_url
        raise InvalidURL(*e.args)
    requests.exceptions.InvalidURL: Failed to parse: http://192:168:0:20:8087/set/javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI.Switch.Switch?value=true&ack=true
    Ein erneuter Aufruf toggelt das Licht immer, egal was in dem DP steht.
    Mal sehen, obich die rechte korrekt gesetzt habe:
    pi@raspberrypi-iob:~/wellis/v4 $ ls -la
    total 40
    drwxrwxrwx 2 pi pi 4096 Feb 14 17:55 .
    drwxrwxrwx 5 pi pi 4096 Feb 14 17:50 ..
    -rwxr-xr-x 1 pi pi 4371 Feb 14 17:55 spa_config.py
    -rwxr-xr-x 1 pi pi 4064 Feb 14 17:55 spa_setTargetTemp.py
    -rwxr-xr-x 1 pi pi 4737 Feb 14 17:55 spa_switchPump.py
    -rwxr-xr-x 1 pi pi 3606 Feb 14 17:55 spa_toggleLight.py
    -rwxr-xr-x 1 pi pi 4704 Feb 14 17:55 spa_updateBulk.py
    Den Aufruf in der JS-Datei habe ich so angepasst:
    exec('python3.10 /home/pi/wellis/v4 spa_toggleLight.py ' + clientId + " " + spaId + " " + lightKey + " " + obj.channelId, function (error, stdout, stderr) {
    Zu2)
    Bei Update des DP wird nix getriggered. Keine Logausgabe.
    Bei der Konsoleneingabe sieht es so aus:
    New target temp: 34
    Got datapoint to update: javascript.0.Datenpunkte.SwimSpa.1.ZielTemperatur
      File "spa_setTargetTemp.py", line 107, in <module>
        asyncio.run(main())
      File "/usr/lib/python3.7/asyncio/runners.py", line 43, in run
      File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
      File "spa_setTargetTemp.py", line 48, in main
        async with SampleSpaMan(CLIENT_ID, spa_identifier=SPA_ID) as spaman:
      File "/usr/local/lib/python3.7/dist-packages/geckolib/async_spa_manager.py", line 199, in __aenter__
        await AsyncTasks.__aenter__(self)
      File "/usr/local/lib/python3.7/dist-packages/geckolib/async_tasks.py", line 15, in __aenter__
        self.add_task(self._tidy(), "Tidy tasks", "ASYNC")
      File "/usr/local/lib/python3.7/dist-packages/geckolib/async_tasks.py", line 22, in add_task
        task = asyncio.create_task(coroutine, name=f"{key_}:{name_}")
    TypeError: create_task() got an unexpected keyword argument 'name'
    sys:1: RuntimeWarning: coroutine 'AsyncTasks._tidy' was never awaited`
    Der Wert wird aber nicht im Spa geupdatet (zumindest nicht mit der Info aus der Gecko App
    Zu3)
    Auch da wird nix getriggered wenn ich den DP mit "LO" oder "HI" steuer. Keine Logeinträge.
    Wie sieht da ein exemplarischer Aufruf auf der Kommandozeile aus? So korrekt?
    pi@raspberrypi-iob:~/wellis/v4 $ python3.10 spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 1 1 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch
    Total arguments passed: 6
    Switching pump id 1
    Switching pump to state id 1
    Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch
    2023-02-15 10:24:50,547> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)]
    *** pump name: Pump 2
    *** pump modes: ['OFF', 'LO', 'HI']
    *** current pump mode: OFF
    *** new pump state name: LO
    *** found: 3 pumps
    *** pump mode is now: OFF
    urllib3.exceptions.LocationParseError: Failed to parse: http://192:168:0:20:8087/set/javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch.Switch?value=0&ack=true
    File "/home/pi/wellis/v4/spa_switchPump.py", line 114, in <module>
    asyncio.run(main())
    File "/home/pi/wellis/v4/spa_switchPump.py", line 88, in main
    requests.get(f"{IOBROKER_BASE_URL}{IOBR_PUMP_CHANNEL}.Switch?value={SET_PUMP_STATE}&ack=true")
    p.prepare(
    requests.exceptions.InvalidURL: Failed to parse: http://192:168:0:20:8087/set/javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch.Switch?value=0&ack=true
    T Online
    T Online
    tklein
    Ergänzung/Update zu 2)
    Aufruf mit Python3.10. Da wird die Temp im WP geändert. Jedoch das Update im DP schlägt fehl. Müssen die Temp-Werte mit "." oder "," angegeben werden? Z.B. 34.5 oder 37,5
    pi@raspberrypi-iob:~/wellis/v4 $ python3.10 spa_setTargetTemp.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 34.0 javascript.0.Datenpunkte.SwimSpa.1.ZielTemperatur
    New target temp: 34.0
    2023-02-15 10:38:32,206> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)]
    *** water heater present
    *** current target temp: 34.0
    *** new target temp is identical to current, nothing to do
    urllib3.exceptions.LocationParseError: Failed to parse: http://192:168:0:20:8087/set/javascript.0.Datenpunkte.SwimSpa.1.ZielTemperatur?value=34.0&ack=true
      File "/home/pi/wellis/v4/spa_setTargetTemp.py", line 107, in <module>
        asyncio.run(main())
      File "/home/pi/wellis/v4/spa_setTargetTemp.py", line 88, in main
        requests.get(f"{IOBROKER_BASE_URL}{IOBR_TARGET_TEMP_DP}?value={str(spaman.facade.water_heater.target_temperature)}&ack=true")
        p.prepare(
    requests.exceptions.InvalidURL: Failed to parse: http://192:168:0:20:8087/set/javascript.0.Datenpunkte.SwimSpa.1.ZielTemperatur?value=34.0&ack=true
    • rrov1R rrov1
      @tklein Hallo,
      zu 1: Hm, ich und Python, ob wir jemals Freunde werden 🙄 . Ich kann den Fehler bei mir nicht nachvollziehen. Ich habe noch mal geprüft ob ich den richtigen Code auf github commited habe, aber alles fein. Kannst du bitte die Datei: spa_toggleLight.py noch mal von github laden, bei dir ablegen und die IP vom ioBroker eintragen. Danach an der Kommandozeile mal manuell ausführen:
      phyton3 spa_toggleLight.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 LI javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI.Switch
      und mir noch mal die Ausgabe der Kommandozeile schicken. Das Script selbst ist total simpel, es ermittelt den aktuellen Status des Lichts und schaltet entweder an oder aus. Da kann fast nix schief gehen, vor allem kein "can't find 'main' module" :-| .
      zu 2.:
      So wie ich's verstanden habe gibt es 3 Temperaturen:
      • javascript.0.Datenpunkte.SwimSpa.0.AktuelleTemperatur -> die aktuelle Wassertemperatur, der DP ist read only
      • javascript.0.Datenpunkte.SwimSpa.0.EchteZielTemperatur -> die Temperatur die der SpaController versucht zu erreichen (durch heizen oder abkühlen), der DP ist read only
      • javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur -> die eingestellte Zieltemperatur, nur dieser DP ist read&write, den musst du verstellen über deine Visualisierung
        Dazu brauchst du im Javascript Adapter das Script: TargetTemp.js und das Python Skript: spa_setTargetTemp.py
        Das verstellen der ZielTemperatur sollte sowas im Protokoll produzieren:
      2023-02-14 20:39:01.870 - info: javascript.0 (1349656) script.js.Spa.TargetTemp: *** clientId: 4dfed1c1-457a-ed4a-9760-1b8e80c24b7a
      2023-02-14 20:39:01.871 - info: javascript.0 (1349656) script.js.Spa.TargetTemp: *** spaId: SPA68:aa:bb:cc:dd:ee
      2023-02-14 20:39:01.872 - info: javascript.0 (1349656) script.js.Spa.TargetTemp: python3 spa_setTargetTemp.py 4dfed1c1-457a-ed4a-9760-1b8e80c24b7a SPA68:aa:bb:cc:dd:ee 24 javascript.0.Datenpunkte.SwimSpa.1.ZielTemperatur
      2023-02-14 20:39:19.415 - info: javascript.0 (1349656) script.js.Spa.TargetTemp: *** stdout: Total arguments passed: 5
      Connecting using client id 4dfed1c1-457a-ed4a-9760-1b8e80c24b7a
      Connecting to spa id SPA68:aa:bb:cc:dd:ee
      New target temp: 24
      *** current target temp: 23.0
      *** target temp is now: 24.0
      *** end
      Was vielleicht noch wichtig ist, die EchteZielTemperatur ist abhängig vom aktuellen Wasserpflegemodus. Wenn der "Abwesend" ist, dann zieht der gecko Controller 10°C von deiner gewählten Zieltemperatur ab.
      zu 3.:
      genau, den DP musst du setzen, wenn du kein "LO" hast, dann bau die Visualisierung halt so, das nur OFF bzw. HIGH gesetzt wird.
      Damit das funktioniert brauchst du im Javascript Adapter: PumpSwitches.js und das Python Skript: spa_switchPump.py
      Das Log sollte dann etwas wie bei 2. enthalten.
      Mittlerweile habe ich bei allen Datenpunkten die nur Informationen enthalten die Möglichkeit zum manuellen setzen weggenommen. Du kannst das im Objektbaum auch am Icon des DP ganz gut erkennen an dem Schloss das da drinnen ist: 2023-02-14 20_47_39-Clipboard.png. Ggf. führe noch mal das aktuelle Script SpaVariablen.js aus.
      T Online
      T Online
      tklein
      #66
      @rrov1 mal was anderes. hasr du auch solche extrmen Schwankungen in dem Wert für die aktuelle Temp?
      Scheint sich aber jetzt stabilisiert zu haben.
      rrov1R 1 Antwort Letzte Antwort
      • T tklein
        rrov1R Offline
        rrov1R Offline
        rrov1
        #67
        @tklein Nein, solche Ausreißer habe ich überhaupt nicht. Das wäre ja dann mein spa_BulkUpdate.py Skript, welches aus welchem Grund auch immer solche Werte dem REST API übergibt. Das kann ich ein bisschen heilen und zwar sagt mir die geckolib die minimale und maximale Temperatur die man einstellen kann (je nach dem ob Celsius oder Farenheit). Ich bau im Pyhton Skript eine Prüfung der 3 Temperaturwerte ein, damit keine Temperaturen sagen wir mal unter 0 °C und 40 °C an ioBroker gemeldet werden. Ich denke mal in dem Fall keinen Wert zu senden ist besser als einen falschen. Ich würde die falschen Werte aus der DB löschen. Bei SQL könnte ich dir sagen wie, bei InfluxDB leider nicht.
        • T tklein
          @rrov1
          Mhmmm ok.
          Zu1)
          Switching light: LI
          *** light count: 1
              asyncio.run(main())
              p.prepare(
          total 40
          Zu2)
          New target temp: 34
              asyncio.run(main())
          Zu3)
          Switching pump id 1
          *** found: 3 pumps
          asyncio.run(main())
          p.prepare(
          rrov1R Offline
          rrov1R Offline
          rrov1
          #68
          @tklein Hallo,
          zu 1.: ich sehe den Fehler :-) Du hast bei der IP-Adresse vom ioBroker als Trennzeichen einen ":" verwendet. Deswegen schaltet er zwar das Licht um kann den Datenpunkt aber nicht ändern. Dies betrifft auch spa_switchPump.py, dort ist der gleiche Fehler enthalten.
          zu 2: öffne mal das Skript TargetTemp.js im Javascript Editor. Zeile 2 müsste so lauten:
          on({id: /^javascript\.\d+\.Datenpunkte\.SwimSpa\.\d+\.ZielTemperatur$/, change: "ne", ack: false}, function (obj) {
          und drücke auf das "Restart" Icon oben drüber es müsste sowas im Protokoll stehen:
          20:25:16.549	info	javascript.0 (1349656) Stop script script.js.Spa.TargetTemp
          20:25:16.562	info	javascript.0 (1349656) Start javascript script.js.Spa.TargetTemp
          20:25:16.581	info	javascript.0 (1349656) script.js.Spa.TargetTemp: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          Wichtig ist "registred 1 subscription"
          Was mich noch ein bisschen wundert, du hast doch nur einen gecko Controller. Der müsste unter javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur
          angesteuert werden und nicht unter: javascript.0.Datenpunkte.SwimSpa.1.ZielTemperatur. Wenn du unterhalb von javascript.0.Datenpunkte.SwimSpa zwei Zweige hat (also .0 und .1), dann lösche mal den .1er Zweig komplett im Objektbaum, den brauchst du nicht.
          zu 3: der Testaufruf ist fast korrekt:
          Argument 3: Pumpen ID 0 = Pumpe 1, 1 = Pumpe 2, 3 = Pumpe 3
          Argument 4: ist der Modus OFF = 0; LO = 1, HI = 2 -> da du geschrieben hast, deine Pumpen haben keinen LO-Mode, nimm dort bitte 0 oder 2
          Argument 5: ".Switch" weglassen
          Beispiel: Pumpe 2, HI
          python3.10 spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 1 2 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1
          Beispiel: Pumpe 2, OFF
          python3.10 spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 1 0 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1
          • rrov1R rrov1
            @tklein Hallo,
            T Online
            T Online
            tklein
            #69
            @rrov1 es wir langsam.
            Zu1)
            Oh man, Das sag ich besser nix zu....
            Zu2) Sieht bei mir auch so im Code und im Log aus mit dem subscription. Passiert aber immer noch nix wenn ich den DP unter Swim.Spa.0.Zieltemperatur ändere
            zu3) Danke für die Erklärung. Per Kommandozeile klappt es jetzt. Auch hier klappt das noch nicht per DP.
            • T tklein
              Zu1)
              rrov1R Offline
              rrov1R Offline
              rrov1
              schrieb am zuletzt editiert von rrov1
              #70
              @tklein Merkwürdig, warum die beiden Subscriptions nicht laufen, habe extra einen regulären Ausdruck genommen, der bei uns beiden funktionieren sollte.
              Plan A: Bitte ändere in der Objektansicht mal den Datenpunkt z.B. für's Licht durch klick auf die Glocke in der Spalte Value und prüfe ob das Javascript ausgeführt wird. Wenn das geht, dann ist die Ursache, dass deine Visualisierung beim setzen des DP den ack-Wert mit auf true setzt. Warum kann ich dir nicht erklären, der Normalzustand ist, dass der ack-Wert false ist.
              So eine Subscription die ich nutze hat 3 Parameter:
              1: id == Pfad zum Datenpunkt (entweder ein regulärer Ausdruck oder halt der Pfad)
              2: change == die Art der Änderung: ne -> der neue Wert des Datenpunkt muss anders sein als der alte Wert bzw. any -> es ist jeder beliebige (auch der gleiche) Wert akzeptabel um eine Reaktion auszulösen
              3: ack == der ack-Wert, bei mir muss er unbedingt false sein, damit die Subscription reagiert, wenn der true wäre, dann reagiert nichts. Der Parameter kann auch weggelassen werden.
              Plan B: Wenn Plan A nicht fruchtet, dann trägst du den Datenpunkt erst mal direkt ein:
              zu 2: öffne mal das Skript TargetTemp.js im Javascript Editor. In Zeile 2 musst du den regulären Ausdruck, welche mit "/" beginnt und mit "/" endet durch den Pfad zum Datenpunkt ersetzen (welcher von zwei doppelten Hochkomma eingeschlossen sein muss).
              ALT:
              NEU
              on({id: "javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur", change: "ne", ack: false}, function (obj) {
              zu 3: Das ist komplizierter, lösche im Skript PumpSwitches.js als erstes die Zeilen 2-4 und dann musst du, da du vmtl. ja auch 3 Pumpen hast folgendes einsetzen:
              on({id: "javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P0.Switch", change: "any", ack: false}, function (obj) {
                  switchPump(obj);
              on({id: "javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch", change: "any", ack: false}, function (obj) {
                  switchPump(obj);
              on({id: "javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P2.Switch", change: "any", ack: false}, function (obj) {
                  switchPump(obj);
              Vergleiche bitte die Pfade die ich hier eingetragen habe bei dir nach, das die auch wirklich identisch sind. Damit muss das Javascript jetzt ausgeführt werden, wenn die den Datenpunkt in der Objektansicht änderst.
              • rrov1R rrov1
                ALT:
                NEU
                    switchPump(obj);
                    switchPump(obj);
                    switchPump(obj);
                T Online
                T Online
                tklein
                #71
                @rrov1 ich rufe derzeit immer direkt die dp auf- habe noch keine vis.
                Danke für deine Top-Hilfe, aber das Problem liegt glaube ich eher beim Aufruf der Skripte. Selbst so kann ich die nicht starten.
                Andere *.py kann ich per blockly ausführen. Ich muss erst schauen, was da im argen ist.
                • T tklein
                  rrov1R Offline
                  rrov1R Offline
                  rrov1
                  #72
                  @tklein Hm, die Lösung würde mich interessieren, auch wenn ich eher nicht mit Blockly arbeite, aber soweit ich weiß wird das auch nur in Javascript umgesetzt. Ich hätte ja spontan gesagt, das im Javascript Adapter "exec ausführen" nicht aktiv ist, aber das widerspricht ja dem, das du manche Python-Skripte ausführen kanns.
                  T rrov1R 2 Antworten Letzte Antwort
                  • rrov1R rrov1
                    T Online
                    T Online
                    tklein
                    #73
                    @rrov1 es sieht so aus, als wenn ich per blockly nicht python3.10 aufrufen kann. die datei spa_updateBulk.py kann ich mit python fehlerlos aufrufen. bei den steuerungen skripten bekomme ich bei der 3er version immer errors
                    • rrov1R rrov1
                      rrov1R Offline
                      rrov1R Offline
                      rrov1
                      #74
                      @rrov1 Aber warum gehen dann einige der Scripte!?
                      Ruf mal:
                      which python3.10
                      auf, dann hast du den vollständigen Pfad. Dann bau mal ein Blockly mit einem exec wie folgt zusammen:
                      /vollständiger/pfad/zu/python3.10 -c "print('hello world.')"
                      Im Ergebnis müsstest als Ausgabe in der Blockly Variable result dann "hello world" ausgegeben bekommen.
                      Wenn das funktioniert, dann könnte er die py-Skripte nicht finden, da könntest du vor den Skriptnamen auch noch den vollständigen Pfad einfügen.
                      T 2 Antworten Letzte Antwort
                      • rrov1R rrov1
                        Ruf mal:
                        which python3.10
                        T Online
                        T Online
                        tklein
                        schrieb am zuletzt editiert von tklein
                        #75
                        @rrov1
                        Zwischenupdate:
                        es wird immer besser :-) an den Pfad habe ich gar nicht gedacht. Hatte eine Shebang am Anfang der PY-Dateien ohne Erfolg hinzugefügt gehabt.
                        Das klappt. Juhu!
                        Aufrufen kann ich die Skripte immer noch nicht aus dem blockly. Mal sehen was es noch ist
                        Derzeit sieht es so aus inkl. vollständigen Pfad zur Datei:
                        pi@raspberrypi-iob:~/wellis/v4 $ python3.10 spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 1 0 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch
                        Switching pump id 1
                        Switching pump to state id 0
                        2023-02-19 11:04:01,189> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)]
                        *** current pump mode: HI
                        *** new pump state name: OFF
                        *** found: 3 pumps
                        2023-02-19 11:04:11,461> INFO Value for UdP2 changed from HI to OFF
                        2023-02-19 11:04:11,464> INFO Value for P2 changed from HIGH to OFF
                        2023-02-19 11:04:11,467> INFO Value for UdPumpTime changed from 14 to 0
                        *** end
                        pi@raspberrypi-iob:~/wellis/v4 $ pwd
                        /home/pi/wellis/v4
                        • rrov1R rrov1
                          Ruf mal:
                          which python3.10
                          T Online
                          T Online
                          tklein
                          #76
                          @rrov1 habe den pythonpath in den *.py dateien erweitert.
                          Dennoch bekomme ich folgenden Log beim Update eines DP:
                          31288	2023-02-19 12:53:22.178	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** stderr: Error: Command failed: /usr/local/bin/python3.10 /home/pi/wellis/v4 spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 0 2 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1 /usr/local/bin/python3.10: can't find '__main__' module in '/home/pi/wellis/v4'
                          Zugriff auf diesen Ordener ist möglich. Rufe per blockly cron minütlich spa_updateBulk.py auf. jedoch mit python3
                          • T tklein
                            rrov1R Offline
                            rrov1R Offline
                            rrov1
                            #77
                            @tklein Hallo, also ich würde sagen, dass die Ursache das Leerzeichen zwischen Pfad zum Skript und dem Skriptnamen ist. Der Aufruf müsste so lauten:
                            /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 0 2 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1
                            Du kannst nicht den Pfad zum Skript vom Skriptnamen durch ein Leerzeichen trennen, damit bekommt python3.10 2 Parameter und interpretiert den Verzeichnisnamen als aufzurufendes Skript - was zu der aus meiner Sicht unpassenden und irreführenden Fehlermeldung führt.
                            Hinweis zum Blockly Screenshot:
                            Das "-c" funktioniert so nicht, das "-c" sagt dem Python Interpreter, das im nächsten Parameter Python-Quellcode kommt (siehe auch hier). Du hast aber ein Skript.
                            Wahrscheinlich kannst du dir den vollständigen Pfad zu python3.10 wieder sparen.
                            Prüfe auch mal ob nicht python3 und python3.10 nicht auf das gleiche zeigen:
                            ls -la /usr/local/bin/python3*
                            Bei mir sieht das Ergebnis so aus:
                            ls -la /usr/bin/python3*
                            lrwxrwxrwx 1 root root       9 Apr  5  2021 /usr/bin/python3 -> python3.9
                            -rwxr-xr-x 1 root root 5479736 Feb 28  2021 /usr/bin/python3.9
                            python3 ist nur ein Link der auf python3.9 zeigt. Ich benutze den Link, denn wenn bei meiner Distro doch mal Python auf eine höhere Version aktualisiert, dann wird python3 immer noch funktionieren, wohingegen python3.9 dann nicht mehr geht.
                            • rrov1R rrov1
                              T Online
                              T Online
                              tklein
                              #78
                              @rrov1 ok, jetzt sieht es so im log aus hne den blank:
                              script.js.common.Draussen.Wellis_Whirlpool.TargetTemp_js: *** stderr: Error: Command failed: /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_setTargetTemp.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 37 javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur Traceback (most recent call last): File "/home/pi/wellis/v4/spa_setTargetTemp.py", line 5, in <module> import requests ModuleNotFoundError: No module named 'requests'
                              Es wir 3.10 wohl nicht aufgerufen?
                              pi@raspberrypi-iob:/usr/local/bin $ ls -la /usr/local/bin/python3*
                              -rwxr-xr-x 1 root root 17752176 Jan  7 17:21 /usr/local/bin/python3.10
                              -rwxr-xr-x 1 root root     3096 Jan  7 17:22 /usr/local/bin/python3.10-config
                              Anderer Ordner:
                              pi@raspberrypi-iob:/usr/local/bin $ ls -la /usr/bin/python3*
                              lrwxrwxrwx 1 root root       9 Mar 26  2019 /usr/bin/python3 -> python3.7
                              -rwxr-xr-x 2 root root 4275580 Oct 31 15:04 /usr/bin/python3.7
                              lrwxrwxrwx 1 root root      36 Oct 31 15:04 /usr/bin/python3.7-config -> arm-linux-gnueabihf-python3.7-config
                              -rwxr-xr-x 2 root root 4275580 Oct 31 15:04 /usr/bin/python3.7m
                              lrwxrwxrwx 1 root root      37 Oct 31 15:04 /usr/bin/python3.7m-config -> arm-linux-gnueabihf-python3.7m-config
                              lrwxrwxrwx 1 root root      16 Mar 26  2019 /usr/bin/python3-config -> python3.7-config
                              lrwxrwxrwx 1 root root      10 Mar 26  2019 /usr/bin/python3m -> python3.7m
                              lrwxrwxrwx 1 root root      17 Mar 26  2019 /usr/bin/python3m-config -> python3.7m-config
                              • T tklein
                                Anderer Ordner:
                                rrov1R Offline
                                rrov1R Offline
                                rrov1
                                #79
                                @tklein Na die Fehlermeldung ist "besser". Du hast praktisch immer noch 2 Python3 Installationen parallel auf deinem System. Die 3.10er Version hat entsprechend der Fehlermeldung das "requests"-Modul nicht installiert. Wenn ich dem hier folge, dann müsstest du:
                                python3.10 -m pip install requests
                                aufrufen um auch in dieser Python-Installation das bereitzustellen. Ich vermute das dann noch andere Module fehlen, wenn dem so ist, findest du in der angenörgelten Quellcodezeile den Namen des Moduls das du noch installieren musst.
                                • rrov1R rrov1
                                  T Online
                                  T Online
                                  tklein
                                  #80
                                  @rrov1 said in Steuerung Gecko in Touch 2 per iob möglich? (Wellis):
                                  Dann dürfte es doch beim Aufruf direkt über die Kommandozeile auch nicht laufen. Das klappt ja:
                                  pi@raspberrypi-iob:~/wellis/v4 $ python3.10 spa_setTargetTemp.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 34 javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur
                                  New target temp: 34
                                  Got datapoint to update: javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur
                                  2023-02-20 08:25:42,352> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)]
                                  *** current target temp: 35.0
                                  2023-02-20 08:25:52,609> INFO Value for SetpointG changed from 35.0 to 34.0
                                  2023-02-20 08:25:52,995> INFO Value for CP changed from OFF to ON
                                  2023-02-20 08:25:52,995> INFO Value for Waterfall changed from OFF to ON
                                  2023-02-20 08:25:52,997> INFO Value for RealSetPointG changed from 35.0 to 34.0
                                  2023-02-20 08:25:52,999> INFO Value for CheckFlo changed from False to True
                                  2023-02-20 08:25:53,170> INFO Value for RhWaterTemp changed from 35.166666666666664 to 33.166666666666664
                                  *** target temp is now: 34.0
                                  *** end
                                  Habe dennoch mal den Befehl aufgerufen:
                                  pi@raspberrypi-iob:~ $ python3.10 -m pip install requests
                                  Defaulting to user installation because normal site-packages is not writeable
                                  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                  Requirement already satisfied: requests in ./.local/lib/python3.10/site-packages (2.28.2)
                                  Requirement already satisfied: charset-normalizer<4,>=2 in ./.local/lib/python3.10/site-packages (from requests) (3.0.1)
                                  Requirement already satisfied: idna<4,>=2.5 in ./.local/lib/python3.10/site-packages (from requests) (3.4)
                                  Requirement already satisfied: urllib3<1.27,>=1.21.1 in ./.local/lib/python3.10/site-packages (from requests) (1.26.14)
                                  Requirement already satisfied: certifi>=2017.4.17 in ./.local/lib/python3.10/site-packages (from requests) (2022.12.7)
                                  [notice] A new release of pip available: 22.3.1 -> 23.0.1
                                  [notice] To update, run: pip3.10 install --upgrade pip
                                  Kann man sich zur Lafzeit nicht als erstes die gerade verwendete Version von python ausgeben lassen? Habe das Gefühl, dass nicht die 3.10 genommen wird.
                                  Beim Kommandozeilenaufruf mit 3.7 bekomme ich das:
                                  pi@raspberrypi-iob:~/wellis/v4 $ python3.7 spa_setTargetTemp.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 34 javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur
                                  New target temp: 34
                                    File "spa_setTargetTemp.py", line 108, in <module>
                                      asyncio.run(main())
                                    File "spa_setTargetTemp.py", line 49, in main
                                  • rrov1R rrov1
                                    T Online
                                    T Online
                                    tklein
                                    #81
                                    @rrov1 da hast du mit mir echt eine harte nuss :-)
                                    • T tklein
                                      rrov1R Offline
                                      rrov1R Offline
                                      rrov1
                                      #82
                                      @tklein Das bekommen wir schon noch raus, manchmal braucht es viel Geduld.
                                      Mit folgenden 2 Zeilen bekommst du die Python Version und das Verzeichnis des Interpreters raus:
                                      print(f"current version: {sys.version}")
                                      print(f"interpreter directory: {sys.executable}")
                                      Füge die Zeilen im Skript deiner Wahl gleich nach der Zeile "import sys" ein, bei spa_setTargetTemp.py z.B. gleich in Zeile 2.
                                      Du bekommst dann als Ausgabe sowas in der Art:
                                      current version: 3.9.2 (default, Feb 28 2021, 17:03:44)
                                      [GCC 10.2.1 20210110]
                                      interpreter directory: /usr/bin/python3
                                      ausgegeben.
                                      Ich bin mal gespannt. Nach der Fehlermeldung:
                                      Hätte ich schon die 3.10er Version in Verdacht gehabt.
                                      • rrov1R rrov1
                                        ausgegeben.
                                        T Online
                                        T Online
                                        tklein
                                        #83
                                        da kann ich ja noch hoffen. :-)
                                        Hier der Log nach der Ergänzung:
                                        31288	2023-02-20 22:36:21.615	info	script.js.common.Draussen.Wellis_Whirlpool.TargetTemp_js: *** setting state of:javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur to old value: 33
                                        31288	2023-02-20 22:36:21.603	info	script.js.common.Draussen.Wellis_Whirlpool.TargetTemp_js: *** stderr: Error: Command failed: /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_setTargetTemp.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 34 javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur Traceback (most recent call last): File "/home/pi/wellis/v4/spa_setTargetTemp.py", line 8, in <module> import requests ModuleNotFoundError: No module named 'requests'
                                        31288	2023-02-20 22:36:21.603	info	script.js.common.Draussen.Wellis_Whirlpool.TargetTemp_js: *** stdout: current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10
                                        Hier der Log nach dem Kommandozeilenaufruf:
                                        Echt spannend warum das via Kommandozeile klappt, aber per js nicht.
                                        • T Online
                                          T Online
                                          tklein
                                          #84
                                          warum das mit dem dp für das licht nicht geklappt hat, habe ich herausgefunden.
                                          In meiner version stand noch das drin:
                                          on({id: /^javascript.\d+.Datenpunkte.SwimSpa.\d+.Lichter.LI.Switch**$**/, change: "any", ack: false}, function (obj) {
                                          Dennoch das gleiche problem wie bei den anderen skripten:
                                          31288	2023-02-21 15:43:34.559	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** setting state of:javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI.Switch to old value: false
                                          31288	2023-02-21 15:43:34.559	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** stderr: Error: Command failed: /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_toggleLight.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 LI javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI Traceback (most recent call last): File "/home/pi/wellis/v4/spa_toggleLight.py", line 7, in <module> import requests ModuleNotFoundError: No module named 'requests'
                                          31288	2023-02-21 15:43:34.558	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** stdout: current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10
