  4. JavaScript Instanz startet nicht mehr (Cannot find lexer)
    5.5k
javascript adapterjavasriptjs adapter
8 Beiträge 2 Kommentatoren 781 Aufrufe 2 Beobachtet
  • U Offline
    U Offline
    uwe72
    schrieb am zuletzt editiert von uwe72
    Von einem Moment auf den anderen startet die JS-Instanz nicht mehr? Würde wirklich nicht was ich geändert habe? Kann mir jemand helfen?
    Error: Cannot find module './lexer'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
    - /opt/iobroker/node_modules/iobroker.javascript/main.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        at Module.require (node:internal/modules/cjs/loader:1067:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:12:11)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:426:4)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
        '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    ================================== > LOG REDIRECT system.adapter.javascript.1 => false [Process stopped]
    ================================== > LOG REDIRECT system.adapter.javascript.1 => false [system.adapter.javascript.1.logging]
    U 1 Antwort Letzte Antwort
    • U uwe72
      Require stack:
        requireStack: [
      U Offline
      U Offline
      uwe72
      @uwe72
      npm update
      hat geholfen
      • U uwe72
        @uwe72
        npm update
        hat geholfen
        GlasfaserG Offline
        GlasfaserG Offline
        @uwe72 sagte in JavaScript Instanz startet nicht mehr (Cannot find lexer):
        @uwe72
        npm update
        hat geholfen
        kann ich mir nicht vorstellen , hast du danach ein sudo reboot gemacht , oder ging es einfach so nach diesem Befehl !?
        • GlasfaserG Glasfaser
          @uwe72
          npm update
          hat geholfen
          U Offline
          U Offline
          uwe72
          @glasfaser ging einfach so nach dem Neustart des Adapters
          Angelehnt an:
          https://stackoverflow.com/questions/13011290/cannot-find-module-coffee-script
          • U uwe72
            Angelehnt an:
            GlasfaserG Offline
            GlasfaserG Offline
            @uwe72
            ... weil NPM Update hat nichts mit dem JS zu tun .
            sehr komisch bei dir .
            • U uwe72
              @uwe72
              npm update
              hat geholfen
              GlasfaserG Offline
              GlasfaserG Offline
              npm update
              hat geholfen
              eher install der baut das Modul wieder neu auf !?
              macht man eher mit
              npm install --omit=dev
                npm update
                hat geholfen
                macht man eher mit
                U Offline
                U Offline
                uwe72
                @glasfaser probiere ich morgen mal aus. Danke dir!
                • U uwe72
                  GlasfaserG Offline
                  GlasfaserG Offline
                  ich dachte es geht wieder nach deinem Befehl ..
                  du schreibt doch :
                  npm update
                  hat geholfen
                  Was willst du dann Testen !?
