  4. Adapter Einstellungen Speicherort
    5.8k
15 Beiträge 5 Kommentatoren 5.6k Aufrufe
  • V Offline
    V Offline
    vore
    Hallo Bluefox,
    muss der Java-Script Adapter installiert sein? Habe ich jetzt mal gemacht und gestartet. Gleicher Fehler.
    Muss ich beim Java-Script Adapter noch etwas einstellen?
    • BluefoxB Offline
      BluefoxB Offline
      @vore:
      Hallo Bluefox,
      Gruß `
      Kannst du es hier posten?
      • V Offline
        V Offline
        vore
        Hallo Bluefox!
        Es kommt immer noch:
        ! admin-0 2016-07-23 10:18:22.044 error change ID is empty: {"scene.Garten_aus":{"common":{"name":"Gartenaus","type":"boolean","role":"scene.state","desc":"Gartenallesaus","enabled":true,"engine":"system.adapter.scenes.0"},"native":{"onTr
        ! javascript-0 2016-07-23 10:18:22.040 error change ID is empty: {"scene.Garten_aus":{"common":{"name":"Gartenaus","type":"boolean","role":"scene.state","desc":"Gartenallesaus","enabled":true,"engine":"system.adapter.scenes.0"},"native":{"onTr
        So lade ich hoch. Es muss Scene 1 in der Liste sein, sonst taucht Scenes nicht unter "Objekte" auf.
        Hier noch der Inhalt aus dem Backup:
        ! {"scene.Garten_aus":{"common":{"name":"Gartenaus","type":"boolean","role":"scene.state","desc":"Gartenallesaus","enabled":true,"engine":"system.adapter.scenes.0"},"native":{"onTrue":{"trigger":{"id":null,"condition":null,"value":null},"cron":"","astro":null},"onFalse":{"enabled":false,"trigger":{"id":null,"condition":null,"value":null},"cron":"","astro":null},"members":[{"id":"hm-rpc.1.IEQ0454412.17.STATE","setIfTrue":false,"setIfFalse":null,"stopAllDelays":true,"desc":"LichtGrillecke","disabled":false,"delay":0},{"id":"hm-rpc.1.IEQ0454412.16.STATE","setIfTrue":false,"setIfFalse":null,"stopAllDelays":true,"desc":"LichtWerkstatt","disabled":false,"delay":0},{"id":"hm-rpc.1.JEQ0015420.17.STATE","setIfTrue":false,"setIfFalse":null,"stopAllDelays":true,"desc":"SpotsTerrasse","disabled":false,"delay":0},{"id":"hm-rpc.1.JEQ0015420.19.STATE","setIfTrue":false,"setIfFalse":null,"stopAllDelays":true,"desc":"SitzeckeGarten","disabled":false,"delay":0},{"id":"hm-rpc.1.LEQ0251941.2.STATE","setIfTrue":false,"setIfFalse":null,"stopAllDelays":true,"desc":"GartenMauerSpots","disabled":false,"delay":0},{"id":"hm-rpc.1.LEQ0251941.1.STATE","setIfTrue":false,"setIfFalse":null,"stopAllDelays":true,"desc":"GartenSteckdosen","disabled":false,"delay":0}],"burstIntervall":10,"virtualGroup":false},"type":"state","_id":"scene.Garten_aus"}}
        • lobomauL Offline
          lobomauL Offline
          lobomau
          Bei mir wird kein Ordner für den Scene Adapter angelegt. Bug oder Feature? :-)
          Wie beim Vorredner das mit dem Upload einer Szene habe ich nicht hinbekommen. Ich erinnere mich daran, dass das Problem schon mal wo anders beschrieben wurde… finde es aber nicht mehr...
          Host: NUC8i3 mit Proxmox:
          • Slave: Pi4
          • lobomauL Offline
            lobomauL Offline
            lobomau
            @lobomau:
            Unbenannt.JPG `
            Geht doch. Man muss nur wenn man die Szene erstellt den Namen richtig schreiben, nämlich "0.Name". ;)
            • Slave: Pi4
            • F Offline
              Fitti
              Wollte auch mal mit dem Szene Adapter spielen:
              Nur: Wie soll das gehen?
              Habe den Adapter installiert. Finde ihn unter Instanzen und kann ihn starten.
              Und dann? Ich kann eine "Webseitenaufruf" starten - nur kommt einzig eine leere Seite.
              Die URL ist http://192.199.199.299:8081/adapter/scenes/tab.html (die IP habe ich hier verändert).
              Und in den Objecten wird auch nichts angelegt. Ich hatte noch nie diesen Adapter installiert. System ist auf dem neuesten Stand.
              Was sollte also wie und wo gehen bitte?
              Danke im Voraus,
              Fitti
              "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
              Plural von Status ist auch Status!
              • F Offline
                Fitti
                Hmm, nach etlichen Versuchen wird plötzlich die Webseite angezeigt. Ich kann was eingeben - aber es funktioniert dann nicht.
                In den Objecten scheint nicht alles angelegt zu werden:
                  Hallo Fitti,
                  Ich sehe mir das morgen mal bei mir am PC an.
                  Es sollte ein weiterer Reiter im Admin erscheinen.
                  http://www.iobroker.net/docu/?page_id=1950&lang=de
                  Wenn du den Reiter nur nicht siehst, musst du ihn sichtbar machen.
                  http://www.iobroker.net/docu/?page_id=5473&lang=de#Reiter
                  • F Offline
                    Fitti
                    Hi Rainer,
                    vielen Dank. Jetzt habe ich den Reiter. Funktioniert leider dennoch nicht - trotzt etlicher Tests und Studium der Beschreibung.
                    Ich hab's so verstanden, dass die Szene startet, wenn ein Datenpunkt entsprechend der Vorgabe passt.
                    Nur interessiert sich der SzeneAdapter nicht für meine Datenpunkte. Siehe Grafiken.
                    Ich benutze hier ein CuxD Gerät zum Triggern. Im Object-Reiter wird der Status immer schön brav angezeigt, wenn ich diesen ändere (FernBedienung oder Vis).
                    Habe meiner Meinung nach alle Varianten mit "Use trigger for [false|true] probiert: Also true gesetzt, false leer gelassen. Dann false mal auf 0, dann mal auf 1 usw.
                    __Mein Ziel sollte in diesem kleinen Test: Bei Ein einer Lampe ebenso eine RGB Leiste ein + bestimmte Farbe.
                    Bei Aus dann auch LED aus.__
                    ` > scenes.0 2017-08-31 19:32:44.750 debug checkTrigger: hm-rpc.1.CUX0201233.1.STATE(false) == 1
                    scenes.0 2017-08-31 19:32:44.750 debug inMem message hm-rpc.1.CUX0201233.1.STATE hm-rpc.1.CUX0201233.1.STATE
                    HIER AUSGESCHALTET
                    scenes.0 2017-08-31 19:32:29.347 debug checkTrigger: hm-rpc.1.CUX0201233.1.STATE(true) == 1
                    scenes.0 2017-08-31 19:32:29.347 debug inMem message hm-rpc.1.CUX0201233.1.STATE hm-rpc.1.CUX0201233.1.STATE
                    HIER EINGESCHALTET
                    scenes.0 2017-08-31 19:32:20.752 debug inMem message scene.* scene.0.Szene1 val=true, ack=true, ts=1504200740746, q=0, from=system.adapter.scenes.0, lc=1504200395607
                    scenes.0 2017-08-31 19:32:20.542 debug initScenes: subscribe on hm-rpc.1.CUX0201233.1.STATE
                    scenes.0 2017-08-31 19:32:20.542 debug initScenes: subscribe on wifilight.0.192_168_1_242.rgb
                    scenes.0 2017-08-31 19:32:20.542 debug initScenes: subscribe on wifilight.0.192_168_1_242.on
                    scenes.0 2017-08-31 19:32:20.513 info restartAdapter `
                      Hallo Fitti,
                      Habe jetzt nicht richtig gelesen, nur überflogen.
                      Ich habe schon lange nichts mehr mit Szenen gemacht
                      Wenn ich es richtig verstehe hast du EINEN Datenpunkt mit zwei Zuständen (true, false)
                      dann muss IMHO auch in der Bedingung "true" oder "false" stehen
                      …und nicht 1 (??)
                      Hast du mal "use trigger for false" angehakt und dort hm-rpc.1.CUX0201233.1.STATE = false eingegeben?
                      Ja hast du, jetzt hab ich doch alles gelesen ;-) , oder doch nicht?
                      • F Offline
                        Fitti
                        Was soll ich sagen. Nachdem ich das hier gemacht hatte http://forum.iobroker.net/viewtopic.php … 687#p82687
                        geht es. Keine Ahnung warum, aber einfach so. Bin jetzt nicht unzufrieden darüber.
