  2. Русский
  3. ioBroker
  4. Скрипты
  5. ioBroker скрипты
  6. Вопросы по написанию скриптов
Geplant Angeheftet Gesperrt Verschoben ioBroker скрипты
358 Beiträge 29 Kommentatoren 131.9k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    #328
    Или так:
    <xml xmlns="http://www.w3.org/1999/xhtml"><block type="create" id="svECADP@D_LS~g[6T?n." x="13" y="63"><field name="NAME">motorCounter</field>
    <statement name="STATEMENT"><block type="on_ext" id="OzG(WNC}y*:JL:!bvMgN"><mutation items="1"></mutation>
    <field name="CONDITION">false</field>
    <field name="ACK_CONDITION">true</field>
    <value name="OID0"><shadow type="field_oid" id="aPODLp31t6i%07OAjKcc"><field name="oid">javascript.0.boolTest</field></shadow></value>
    <statement name="STATEMENT"><block type="controls_if" id="N(GTE?/Qq^tiAefHhGo"><value name="IF0"><block type="logic_compare" id="1ySRjIFq!qlsFEikh@9."><field name="OP">EQ</field>
    <value name="A"><block type="on_source" id="5,uId0is]chxW+2tq,l5"><field name="ATTR">oldState.val</field></block></value>
    <value name="B"><block type="logic_boolean" id="p+knOuq|Bhhp6[N0+d-A"><field name="BOOL">TRUE</field></block></value></block></value>
    <statement name="DO0"><block type="update" id="l-EoA#o@sAQW=i;.knE9"><mutation delay_input="false"></mutation>
    <field name="OID">javascript.0.motorCounter</field>
    <value name="VALUE"><block type="math_arithmetic" id=")}{oRaa%=9fTN
    .0g@,="><field name="OP">ADD</field>
    <value name="A"><shadow type="math_number" id=",f%0CvZv9qk(sbd:-hmI"><field name="NUM">1</field></shadow>
    <block type="get_value" id="Ty#h:khrIoRj/Wm@w0Q-"><field name="ATTR">val</field>
    <field name="OID">javascript.0.motorCounter</field></block></value>
    <value name="B"><shadow type="math_number" id="E7v{Kyc.pPHl^|bohgU"><field name="NUM">1</field></shadow> <block type="math_arithmetic" id="~#~514BVd(vQsjrm6-?G"><field name="OP">DIVIDE</field> <value name="A"><shadow type="math_number" id="n7-[AqhR8fGgSg6M.=cW"><field name="NUM">1</field></shadow> <block type="math_arithmetic" id="M^d?]c-+!gs%M-AWNeMk"><field name="OP">MINUS</field> <value name="A"><shadow type="math_number" id=".fyZQ/wCR9IY9MmQ=X2_"><field name="NUM">1</field></shadow> <block type="on_source" id="+1R15yCYBce/A]wmSd7b"><field name="ATTR">state.ts</field></block></value> <value name="B"><shadow type="math_number" id="xd?;d7uEQ@Fmh=%Oo(-"><field name="NUM">1</field></shadow>
    <block type="on_source" id="[Wn~yS.QQ|AZev|iD,v0"><field name="ATTR">oldState.ts</field></block></value></block></value>
    <value name="B"><shadow type="math_number" id="S-T+6}o-dVpjnGakd!K!"><field name="NUM">1000</field></shadow></value></block></value></block></value></block></statement></block></statement></block></statement></block></xml>
    • V Offline
      V Offline
      ValG
      #329
      дилетантский вопрос - а куда записывать скрипты? во вкладку "Скрипты-Показать код" ничего не записывается
      можно поправить блок Sentdo?
      • H Offline
        Haus
        #330
        @ValG:
        можно поправить блок Sentdo? `
        http://www.iobroker.net/docu/?page_id=6703&lang=ru
        blockly
        http://www.iobroker.net/docu/?s=blockly&lang=de
        js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
        admin: 3.6.0
        javascript: 4.1.10
        web: 2.4.1 vis: 1.1.10
        cloud: 2.6.2
        Server: DELL FX170 / linux: Debian 9.5 Stretch
        Adapter: MegaD-2561, Mega-ES…
          Adav
          #331
          Установил в ioBroker драйвер nut для работы с бесперебойником. Есть проблема - изредка (где-то раз в неделю) сервис nut на удаленной машине имеет свойство глючить и отваливаться. Ну и как следствие - в ioBroker в логах вижу ошибки. Есть ли какая-нибудь возможность отслеживать скриптом в логе ошибки и по данному событию отправлять команду на удаленную машину service nut-driver restart?
          • I Offline
            I Offline
            instalator
            #332
            @Adav:
            Установил в ioBroker драйвер nut для работы с бесперебойником. Есть проблема - изредка (где-то раз в неделю) сервис nut на удаленной машине имеет свойство глючить и отваливаться. Ну и как следствие - в ioBroker в логах вижу ошибки. Есть ли какая-нибудь возможность отслеживать скриптом в логе ошибки и по данному событию отправлять команду на удаленную машину service nut-driver restart? ` а какие объекты драйвер nut создаёт? Connection создаёт?
            Высокий уровень Децибел вреден для здоровья!
            http://blog.instalator.ru/
              Adav
              #333
              @instalator:
              @Adav:
              Установил в ioBroker драйвер nut для работы с бесперебойником. Есть проблема - изредка (где-то раз в неделю) сервис nut на удаленной машине имеет свойство глючить и отваливаться. Ну и как следствие - в ioBroker в логах вижу ошибки. Есть ли какая-нибудь возможность отслеживать скриптом в логе ошибки и по данному событию отправлять команду на удаленную машину service nut-driver restart? а какие объекты драйвер nut создаёт? Connection создаёт?
              Там много всякого создается, касаемо самого бесперебойника. Connection - не получится использовать, при этой ошибке как бы все нормально, драйвер зелененький. Вот поэтому и спросил про возможность отслеживать события в логе. Собственно, удаленный сервис nut работает (поэтому и драйвер не ругается на соединение), но при этом перестает отдавать данные (что и видно в логе). Помогает только рестарт сервиса.
                spectrekr
                #334
                Ну как вариант через readfile читать лог файл и парсить, при обнаружении ошибки выполнять уже необходимые действия.
                  Adav
                  #335
                  @spectrekr:
                  Ну как вариант через readfile читать лог файл и парсить, при обнаружении ошибки выполнять уже необходимые действия. `
                  Как это сделать? Есть примеры? С действием тоже вопрос - через exec надо отправить команду на удаленную машину (со своим паролем и логином), а не выполнять локально.
                  • I Offline
                    I Offline
                    instalator
                    #336
                    @spectrekr:
                    Ну как вариант через readfile читать лог файл и парсить, при обнаружении ошибки выполнять уже необходимые действия. ` лучше сделать доработку драйвера чтобы создавался объект еррор например и в него писать что нет данных от бесперебойника
                      Adav
                      #337
                      @instalator:
                      @spectrekr:
                      Ну как вариант через readfile читать лог файл и парсить, при обнаружении ошибки выполнять уже необходимые действия. лучше сделать доработку драйвера чтобы создавался объект еррор например и в него писать что нет данных от бесперебойника
                      Это было бы идеально, но тут вопрос к разработчику… Как вариант - отслеживать состояние сервиса непосредственно на удаленной машине bash скриптом, но тут я тоже не тяну сделать самостоятельно. По идее можно делать запрос upsc и если нет данных - перегружать сервис.
                        spectrekr
                        #338
                        var fs = require('fs');
                        var date = formatDate(new Date(res.result[0].ReceivingDateTime), 'YYYY-MM-DD');
                        readFile ('/opt/iobroker/log/iobroker.log.'+date, function (error, bytes) {
                        if(bytes.indexOf('Ошибка') > 0){
                        exec('/bin/bash /opt/iobroker/tmp/restart.sh');
                        Примерно так.
                        • I Offline
                          I Offline
                          instalator
                          #339
                          @Adav:
                          @instalator:
                          @spectrekr:
                          Это было бы идеально, но тут вопрос к разработчику… Как вариант - отслеживать состояние сервиса непосредственно на удаленной машине bash скриптом, но тут я тоже не тяну сделать самостоятельно. По идее можно делать запрос upsc и если нет данных - перегружать сервис. `
                          Задай ему вопрос на гитхабе https://github.com/Apollon77/ioBroker.nut/issues
                            Adav
                            #340
                            Вернулся к вопросу с рестартом сервиса nut (о чем выше). Спасибо spectrekr и instalator за два варианта решения проблемы. Но я нашел третий вариант, на мой взгляд проще. Отслеживается одна из переменных (в принципе любая, но лучше константа), приходящих от драйвера nut, и если она не обновлялась дольше, чем два цикла опроса (в моем случае цикл 5 сек), то идет команда на рестарт сервиса на удаленном сервере. Вроде работает… В скрипте это так (может кому пригодится):
                            //---------------------------Restart nut------------------
                            var nut_timer_timeout_ms = 12 * 1000;
                            var nut_timer_id = null;
                            on({id: "nut.0.input.transfer-low", change: "eq"}, function (obj) {
                            if (nut_timer_id) {
                                clearTimeout(nut_timer_id);
                                nut_timer_id = setTimeout(function () {
                                   exec('ssh root@192.168.118.115 service nut-driver restart');
                                   sendTo('telegram.0', {
                                      text:'Сервис NUT на сервере System завис и перезагружен.',
                                      disable_notification:   true
                               	}, nut_timer_timeout_ms);
                              andrey99986
                              #341
                              Есть ли возможность активировать и дезактивировать запись значений в БД (драйвер sql) объекта по условию - в зависимости от состояния другого объекта?
                              Например есть объект "Security" и "megad.0.Sensor1".
                              Надо чтобы состояние объекта "megad.0.Sensor1" писалось в БД только когда getState("Security").val == true.
                              • H Offline
                                Haba
                                #342
                                оно?
                                  "_id": "mysensors.0.61.255_ARDUINO_NODE.I_BATTERY_LEVEL",
                                  "common": {
                                    "name": "2.2.0-beta.I_BATTERY_LEVEL",
                                    "type": "number",
                                    "role": "value",
                                    "min": 0,
                                    "max": 100,
                                    "unit": "%",
                                    "def": 100,
                                    "read": true,
                                    "write": false,
                                    "custom": {
                                      "sql.0": {
                                "enabled": true,
                                       "changesOnly": true,
                                        "debounce": 1000,
                                        "retention": 31536000,
                                        "changesRelogInterval": 0,
                                        "changesMinDelta": "",
                                        "storageType": ""
                                  "native": {
                                    "id": "61",
                                    "childId": "255",
                                    "subType": "S_ARDUINO_NODE",
                                    "subTypeNum": 17,
                                    "varType": "I_BATTERY_LEVEL",
                                    "varTypeNum": 0
                                  "type": "state",
                                  "acl": {
                                    "object": 1638,
                                    "state": 1638
                                  andrey99986
                                  #343
                                  @Haba:
                                  оно?
                                  "sql.0": {
                                  "enabled": true, `
                                  Похоже что да. Как менять этот параметр в скрипте js ?
                                  • H Offline
                                    Haba
                                    #344
                                    Получилось?
                                    Предполагаю что так: https://github.com/iobroker/ioBroker.ja … #setobject
                                    или https://github.com/iobroker/ioBroker.ja ... tendobject
                                    сам не пробовал, но скорей всего так:
                                    extendObject('mysensors.0.63.255_ARDUINO_NODE.I_BATTERY_LEVEL', {common: {custom: {sql.0 {enabled: false}}}});
                                      andrey99986
                                      #345
                                      @Haba:
                                      Получилось?
                                      Вот так заработало:
                                      extendObject('megad.0.p0', {common: {custom: {"sql.0":{enabled: false}}}});
                                        smoker_vvo
                                        #346
                                        Уважаемые коллеги по увлечению, прошу оказать помощь в решении следующей задачи:
                                        Система автоматически отправляет сообщения о своем статусе, о работе системы и температуру, но возникла необходимость получать некую сводку о состоянии охраны, насосов и прочего, при восстановлении пром сети.
                                        Сообщение о том что свет отключили Соня успевает отправить, а при включении - получаю сообщение Бот запущен.
                                        Работаем с Телеграммом.
                                        Ну и совсем фантастика - как бы научить Соню озвучивать события разными текстами, ну типа при включении насоса проговаривать текст из какого то списка…. Типа: Насос включен, Я тут насос запустила, У вас закончилась вода, решила подкачать......
                                        Хочу что бы при событии текст отличался от предыдущего... ;) ;) ;)
                                        • E Offline
                                          electric
                                          #347
                                          @smoker_vvo:
                                          Хочу что бы при событии текст отличался от предыдущего... ;) ;) ;) `
                                          Мою Катя зовут.
                                          Я пользуюсь драйвером http://www.iobroker.net/docu/?page_id=4459&lang=ru.
                                          Вот https://github.com/ioBroker/ioBroker.text2command на гитхаб, там самое последнее описание.
                                          Скриншот вопросов и ответов и настройки в самом text2command прикрепил.
                                          В тексте подтверждения через слэш варианты накидываешь…
