  4. Awattar - die billigsten Strom-Stunden nutzen
    6.3k
82 Beiträge 10 Kommentatoren 18.0k Aufrufe 9 Beobachtet
    @badsnoopy667 sagte: Blockly Export des funktionierenden Scripts posten?
    Vielleicht kann ich aushelfen?
     <variables>
       <variable id="f%{MYK|pqx/msm?jLTCv">sort</variable>
       <variable id="m[W;a/*+Ku4g|deZEV$r">i</variable>
       <variable id="@!RPgtnzVwyGIa5#?5i^">id</variable>
       <variable id=":s^oe|FI,MTykE.d|vjJ">idDate</variable>
       <variable id="JU=3dvDJ]OgXqBlqGYM[">ww</variable>
       <variable id="Pw_FHmi}c0-([@-$Ax/M">fbh</variable>
       <variable id="_Nuc-_3~VS;%yQn+g$9o">stunde</variable>
       <variable id="eTgx)$hD2knDGoSo3`$M">idPreis</variable>
     </variables>
     <block type="schedule" id="t0ptX_hB3?gNErGP2-44" x="113" y="-68">
       <field name="SCHEDULE">0 * * * *</field>
       <statement name="STATEMENT">
         <block type="variables_set" id="m$Bu`}K+wC*Ia!$Q/87$">
           <field name="VAR" id="f%{MYK|pqx/msm?jLTCv">sort</field>
           <value name="VALUE">
             <block type="math_number" id="#Y.8dvJg[RZkNDtw^?ge">
               <field name="NUM">0</field>
             </block>
           </value>
           <next>
             <block type="controls_for" id="^I#Vwi@:8cPB@~p6g4[I">
               <field name="VAR" id="m[W;a/*+Ku4g|deZEV$r">i</field>
               <value name="FROM">
                 <shadow type="math_number" id="uK{nB-7z.a?d2|?NGC;Y">
                   <field name="NUM">1</field>
                 </shadow>
               </value>
               <value name="TO">
                 <shadow type="math_number" id="y!?o50tye=EtN2yfubW2">
                   <field name="NUM">10</field>
                 </shadow>
                 <block type="lists_length" id="*oxxY{FFu2$ya+KAs-wC">
                     <block type="selector" id="UvXOT+v,~RTtJ(+zw]PQ">
                       <field name="TEXT">awattar.0.pricesOrdered.*.start</field>
                     </block>
                   </value>
                 </block>
               </value>
               <value name="BY">
                 <shadow type="math_number" id="XWtiOpI~HC)?jkUGVR#Z">
                 </shadow>
               </value>
               <statement name="DO">
                 <block type="variables_set" id="@6Q{Y~(8Y@DvAP5)^:aE">
                   <field name="VAR" id="@!RPgtnzVwyGIa5#?5i^">id</field>
                     <block type="text_join" id=":S}lgn4j$S!St8ojec/%" inline="true">
                       <value name="ADD0">
                         <block type="text" id="9YR/b:Op#Q=COcF=yT$$">
                           <field name="TEXT">awattar.0.pricesOrdered.</field>
                         </block>
                       </value>
                       <value name="ADD1">
                         <block type="math_arithmetic" id="#{n:)]S0R`q*x*Zz}xDY">
                           <value name="A">
                             <shadow type="math_number" id="B(,hr0]jxUo9H6p],:.U">
                             </shadow>
                             <block type="variables_get" id="fmi9JMsXie[7AqYh!5?f">
                             </block>
                           </value>
                           <value name="B">
                             <shadow type="math_number" id="?{U^ty/@sgP38@F_w{Ga">
                             </shadow>
                           </value>
                         </block>
                       </value>
                       <value name="ADD2">
                         <block type="text" id="`O,1MghUJ^/p@hp}d.l0">
                           <field name="TEXT">.start</field>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id="]nDOX,W{}z:NK:^cE_+z">
                       <field name="VAR" id=":s^oe|FI,MTykE.d|vjJ">idDate</field>
                         <block type="text_join" id="JO^u9Ozg7[rg?[hC`|bI" inline="true">
                           <value name="ADD0">
                             <block type="variables_get" id="$HCexy7I`Z}sE30y`}Si">
                             </block>
                           </value>
                           <value name="ADD1">
                             <block type="text" id="^%_^Mo2RG**$)[JZch2-">
                               <field name="TEXT">Date</field>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="controls_if" id="Ey5j%EGWhO%gDOn^`uVS">
                           <value name="IF0">
                             <block type="logic_compare" id="8xG3/SRk,Q6)#^#9)]rM">
                               <field name="OP">EQ</field>
                               <value name="A">
                                 <block type="get_value_var" id="oM%Z$lb7%04#3?HdX9l3">
                                   <value name="OID">
                                     <shadow type="text" id="T[22+A?Ql{.;LwfBQFZ^">
                                       <field name="TEXT"></field>
                                     </shadow>
                                     <block type="variables_get" id="Y!n8IH|K)x%M{S1U6YKG">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="time_get" id=")E[gSkt[:I!t}QmJ$@@z">
                                   <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                   <field name="OPTION">custom</field>
                                   <field name="FORMAT">T.M.JJJJ</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <statement name="DO0">
                             <block type="math_change" id="t4_:*m`)g)Lm(1d9NTtt">
                               <value name="DELTA">
                                 <shadow type="math_number" id="/gPA7?+l(J60?@MMvM[b">
                                 </shadow>
                               </value>
                               <next>
                                 <block type="controls_if" id="c37l0tBG(dWgrG[_jJ*H">
                                   <value name="IF0">
                                     <block type="logic_compare" id="ggTAH!IN|c^#NP3#fe$i">
                                       <value name="A">
                                         <block type="get_value_var" id="DzQ]#W-I`,-WpvdB~r^=">
                                           <value name="OID">
                                             <shadow type="text">
                                             </shadow>
                                             <block type="variables_get" id="PzTgSjUnKn}L~+Lu7;iE">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="time_get" id="wfRYY0aB3ajC#/tjN2]d">
                                           <field name="OPTION">hh:mm:ss</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                     <block type="controls_if" id="gcRTE/pXe9yqfB@(m(ie">
                                       <mutation elseif="1" else="1"></mutation>
                                       <value name="IF0">
                                         <block type="logic_compare" id="+Gs?^;C}J@CnzUI3]It/">
                                           <field name="OP">LTE</field>
                                           <value name="A">
                                             <block type="variables_get" id="ntc!u-;4R:RVfbXoD,g3">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="Zh5JIS[O;{KFd7+dglib">
                                               <field name="NUM">6</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                         <block type="variables_set" id="oK,Vo]}VE~hn!wMb%EaQ">
                                           <field name="VAR" id="JU=3dvDJ]OgXqBlqGYM[">ww</field>
                                             <block type="logic_boolean" id="MI7#Ba{K$P~ECPrcQ8~u">
                                             </block>
                                           </value>
                                           <next>
                                             <block type="variables_set" id="GRjr1|q-qv~bZ_]x-b-V">
                                               <field name="VAR" id="Pw_FHmi}c0-([@-$Ax/M">fbh</field>
                                                 <block type="logic_boolean" id="+BKshPHTFX$)Axk,s:D3">
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                       <value name="IF1">
                                         <block type="logic_compare" id="_r:fA@(Q@C=RBwAM0*Aj">
                                           <value name="A">
                                             <block type="variables_get" id="LUO{za(7%1bLUGPXF0-I">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="7J4^!@k2T`nB=tV8earE">
                                               <field name="NUM">12</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <statement name="DO1">
                                         <block type="variables_set" id="n.Ik|u:~_:hM36]!*QlD">
                                             <block type="logic_boolean" id="owYb%`7T54.}wrm+]u-g">
                                             </block>
                                           </value>
                                           <next>
                                             <block type="variables_set" id="E`4`IKL)y:A}rSN:Kg(p">
                                                 <block type="logic_boolean" id="S+l[m~BVrGqKTJb!u8V-">
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                       <statement name="ELSE">
                                         <block type="variables_set" id="HS:r/kU.]y/[Z]iPi_Xr">
                                             <block type="logic_boolean" id="0o]?]!J4GKIPzNqOziK%">
                                             </block>
                                           </value>
                                           <next>
                                             <block type="variables_set" id="RyL3o?ihAvyDZWomwrme">
                                                 <block type="logic_boolean" id="!QO~MyG$F#Fb;EbX.RB]">
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                       <next>
                                         <block type="controls_flow_statements" id="eWKTtP5}AB!o0E=d@X15">
                                           <field name="FLOW">BREAK</field>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
               <next>
                 <block type="control" id="2`n*#WlwbkPU!2|uD_e`" disabled="true">
                     <block type="variables_get" id="3;29{]Xqb0Tg.hordU+L">
                     </block>
                   </value>
                   <next>
                     <block type="control" id="y!s1?^8XonrSSD^d:]-|" disabled="true">
                         <block type="variables_get" id=")uE};lZj2G04W=qRg|E`">
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="~hBW|XS(8x%+xwAf%Kkv">
                           <field name="VAR" id="_Nuc-_3~VS;%yQn+g$9o">stunde</field>
                             <block type="time_get" id=":GeZIU-{w4?TE0BC@D|Y">
                               <field name="OPTION">h</field>
                             </block>
                           </value>
                           <next>
                             <block type="variables_set" id="MQ@9vpbm0twY]C|ujABd">
                                 <block type="text_join" id=",ml%b@CiFZA2:9!l,1Hd">
                                   <value name="ADD0">
                                     <block type="text" id="K!zbGiH(RdzY+?0kVwG?">
                                       <field name="TEXT">awattar.0.prices.</field>
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     <block type="variables_get" id="]`Ue]rEZm7kbr*_a,O$`">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     <block type="text" id=",|)+9AGe$r8n[(NaedI4">
                                       <field name="TEXT">.startDate</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="controls_if" id="69d^VUAHY?4b|j+@cXXw">
                                   <value name="IF0">
                                     <block type="logic_compare" id="0)RD}*w5Z$6h6O6Y{l1+">
                                       <value name="A">
                                         <block type="get_value_var" id="m`SbczVWHA#5}g,*s}x^">
                                           <value name="OID">
                                             <shadow type="text" id="3LUz^-^E[f,3{G:^Tv_x">
                                             </shadow>
                                             <block type="variables_get" id="qEhWJ_x(1|EN.#(R#t=`">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="time_get" id="5{1=BKF0rCri;MxB9KMW">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                     <block type="variables_set" id="r66/JkWBU^B+v3bwZ4N/">
                                       <field name="VAR" id="eTgx)$hD2knDGoSo3`$M">idPreis</field>
                                         <block type="text_join" id="TxKK9Mb%:ZwT;xy6`Z?#">
                                           <value name="ADD0">
                                             <block type="text" id="!i2i}@Dt?zME37}xdZ4%">
                                             </block>
                                           </value>
                                           <value name="ADD1">
                                             <block type="variables_get" id="3Rl5pi,Iqn76rA_Yw,c+">
                                             </block>
                                           </value>
                                           <value name="ADD2">
                                             <block type="text" id="bYfIMeLQIW-zILKzxG$v">
                                               <field name="TEXT">.totalPriceKwh</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                     <block type="variables_set" id="!=SM:O1]Fn%djj4I@[$@">
                                         <block type="text_join" id="=!:etc4,Sj2`LkAuWUi*">
                                           <value name="ADD0">
                                             <block type="text" id="GlFO;(aqT@I[#6XC?F@b">
                                             </block>
                                           </value>
                                           <value name="ADD1">
                                             <block type="math_arithmetic" id="J1iK){0l.}VR?9A|H6N3">
                                               <field name="OP">ADD</field>
                                               <value name="A">
                                                 <shadow type="math_number" id="S8Ud;PQu.R(l}h{a$ExG">
                                                 </shadow>
                                                 <block type="variables_get" id="/vSTWPMaL^9Zc(4Od2gk">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <shadow type="math_number" id="Whk;c?I`L0q;G{~VUpr+">
                                                   <field name="NUM">24</field>
                                                 </shadow>
                                               </value>
                                             </block>
                                           </value>
                                           <value name="ADD2">
                                             <block type="text" id="[[)x,2!m+xiek{D+}Ktx">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <next>
                                     <block type="debug" id="JdM:egWf%4hJYB{}8gx}">
                                       <value name="TEXT">
                                         <shadow type="text" id="7kGslysPGVf%Cp7dUL8I">
                                         </shadow>
                                         <block type="text_join" id="v{_niA}T~y_?=wCx#Q?M">
                                           <value name="ADD0">
                                             <block type="text" id="{-H2@_KSQrc4Y.U=oSfa">
                                               <field name="TEXT">aktueller Preis: </field>
                                             </block>
                                           </value>
                                           <value name="ADD1">
                                             <block type="math_rndfixed" id="IONixpM;:VMse8:5*@eU">
                                               <field name="n">2</field>
                                               <value name="x">
                                                 <shadow type="math_number" id="RQE~cVZF?);/~.)Q9fB*">
                                                   <field name="NUM">3.1234</field>
                                                 </shadow>
                                                 <block type="get_value_var" id="SL=6p7RH_[k]M9r45=ls">
                                                   <value name="OID">
                                                     <shadow type="text" id="7zK$!`js6l9s[Ane:X5k">
                                                     </shadow>
                                                     <block type="variables_get" id="X5LHou*mGG0^M;o3!Qi(">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    Doom.86
    @paul53 erstmal vielen Dank für das Ganze.
    Ich habe aber durchaus noch ein Verständnis Problem. Dazu muss ich auch sagen, ist das ganze wirklich Neuland für mich.
    Ich wollte mir das ganze von Awattar auf Tibber umschreiben.
    Kannst du das ganze bitte etwas Beschriften? ich habe schon gesehen, dass dies weiter oben der Fall ist, aber irgendwie passt das nicht mit dem letzten zusammen. Oder aber ich stell mich gerade zu doof dazu an.
    Brauche ich zwei Skripte? eins was mir den Günstigstens Preis sucht und das andere zur Steuerung der Heizung?
    Mir würde es auch reichen, wenn ich die WW und FBH über eine Zeit habe. Beispiel beide für die 3 günstigsten Stunden.
    paul53P S 2 Antworten Letzte Antwort
    • D Doom.86
      @doom-86 sagte: dies weiter oben der Fall ist
      Das ist für 3 aufeinanderfolgende Stunden (Waschmaschine).
      @doom-86 sagte in Awattar - die billigsten Strom-Stunden nutzen:
      Das ist für die billigsten Stunden, die nicht aufeinander folgen müssen.
      Liefert der Adapter auch eine Sortierung nach Preisen?
        Doom.86
        schrieb am zuletzt editiert von Doom.86
        @paul53 sieht ziemlich gleich zu Awattar aus.
        Mir fehlt nur noch ein wenig das Verständnis dafür . Muss ich mir selbst datenpunkte anlegen?
        Jede Stunde hat ein extra Verzeichnis und für den morgigen Tag das selbe nochmal.
        Mir würde es für die Heizung und Warmwasser reichen. Warmwasser ist leicht in einer Stunde aufgeheizt und die fußbodenheizung ist etwas träge, da wäre es gut, wenn sie 2 bis 3 Stunden am Stück laufen kann.
        Die datenpunkte um diese zwei Werte zu erhöhen sind in dem stiebel eltron adapter schön hinterlegt.
        • D Doom.86
          @doom-86 sagte: Muss ich mir selbst datenpunkte anlegen?
          Nein. Ab wann sind die die Werte unter "PricesToday" für den aktuellen Tag gültig? Unter "PricesTomorrow" stehen die Preise von morgen?
          Adapter: Tibber oder Tibberconnect?
          • D Doom.86
            S Online
            S Online
            Schimi
            @doom-86
            Ich möchte die Arbeit von paul53 nicht schlecht machen....
            Für Tibber funktioniert das ganz gut (man muss ja nen Token anlegen)
            https://forum.iobroker.net/topic/60938/geräte-zu-stundenpreisen-epex-oder-pv-überschuss-betreiben
              Doom.86
              @paul53 die preise für den morgigen Tag sollen ab 13 in der App zur Verfügung stehen. Manchmal kann es auch erstmal 13:30 bis 14:00 Uhr sein, habe ich gemerkt.
              Ab Mitternacht steht dann bei morgigen Preis drin, dass diese ab 13:00 Uhr verfügbar sind. Somit gehe ich davon aus, dass diese um Mitternacht umgestellt werden.
              Tibberconnect nutze ich.
              • D Doom.86
                @doom-86 sagte: Manchmal kann es auch erstmal 13:30 bis 14:00 Uhr sein, habe ich gemerkt.
                Wenn man um 13:59 Uhr triggert, hat man unter "PricesToday" die Preise von 14:00 Uhr bis Mitternacht und unter "PricesTomorrow" die Preise von morgen von 0:00 Uhr bis 13:00 Uhr ?
                  Doom.86
                  @paul53 said in Awattar - die billigsten Strom-Stunden nutzen:
                  Unter Prices Today bekommst du die Preise des heutigen Tages von 0:00 - 23:00
                  Unter Prices Tomorrow die Preise von morgen von 0:00 - 23:00 Uhr.
                  Es würde somit auch reichen, wenn erst um 18 Uhr getriggert wird. Falls von tibber Seite irgendwas schief laufen sollte und die morgigen Preise länger auf sich warten lassen.
                  • D Doom.86
                    @doom-86 sagte: Es würde somit auch reichen, wenn erst um 18 Uhr getriggert wird.
                    Dann schau mal diese Lösung mit Trigger um 17:59 Uhr an:
                     <variables>
                       <variable id="slzz5)!d0O#p:CL?^k@l">tibber</variable>
                       <variable id="I=q`=kgBC10=WtmP[C@G">end1h</variable>
                       <variable id="y[G=0ms17p|S*%p]+B~p">preise</variable>
                       <variable id="A*CzK[pG.x4^B]b*|c[1">end3h</variable>
                       <variable id="L`VRA5|#^N/oI[|LjJqy">i</variable>
                       <variable id="ES`I}6lM2ZNSuk*`6Bt`">id</variable>
                       <variable id="6)]2##_Z9.w~~.^]:M*W">min1</variable>
                       <variable id="bpynY%@fDWCdbC?Xv*s1">min3</variable>
                       <variable id="5_aI@Kq-?t,56cb.j893">preis1</variable>
                       <variable id="FAiYO^Ty$^^g*F@vG:~j">start1h</variable>
                       <variable id="a4m{kvJ}{$=rv(H9#1J_">preis3</variable>
                       <variable id="ud88TKb=*)[?(!NqiOoj">start3h</variable>
                       <variable type="cron" id="schedule1">schedule1</variable>
                       <variable type="cron" id="schedule2">schedule2</variable>
                       <variable type="cron" id="schedule3">schedule3</variable>
                       <variable type="cron" id="schedule4">schedule4</variable>
                     </variables>
                     <block type="variables_set" id="yCwl;0ySJ|1}Q!2s=yK]" x="87" y="-87">
                       <field name="VAR" id="slzz5)!d0O#p:CL?^k@l">tibber</field>
                         <block type="text" id="Dg:|cO}z^{]x$/g4fe`1">
                           <field name="TEXT">tibberconnect.0.Homes.ef9611f1-6e89-47ae-8966-ce359e21b819.</field>
                         </block>
                       </value>
                       <next>
                         <block type="schedule" id="tt0v29t$v3Fc|sH*~qV_">
                           <field name="SCHEDULE">59 17 * * *</field>
                             <block type="controls_if" id="+g*^w|33kRI[#2ilg+zf">
                               <value name="IF0">
                                 <block type="logic_compare" id="%kEM[O!*NkR1bxYxj}La">
                                   <value name="A">
                                     <block type="variables_get" id="*RrNBWBfa}4YV^EFey:|">
                                       <field name="VAR" id="I=q`=kgBC10=WtmP[C@G">end1h</field>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="M7U.jytRxX6d-BmPUg@*">
                                       <field name="NUM">18</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="control" id="*B_t6szZgS!H$Znz$|)#">
                                     <block type="logic_boolean" id="j]D))tVtr,r_ZAC_dAY+">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                               <next>
                                 <block type="controls_if" id="a0!D]L2`|I(._P{MjZn]">
                                   <value name="IF0">
                                     <block type="logic_compare" id="X.N)Nh`lCo83t,M=g0`*">
                                       <value name="A">
                                         <block type="variables_get" id="yf%,Pvwz(hBDganu|},t">
                                           <field name="VAR" id="A*CzK[pG.x4^B]b*|c[1">end3h</field>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="O1R{)2/9M(-.8L{6@P~P">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                     <block type="control" id="c7{0Rrpn|)lA{HL$PE:`">
                                         <block type="logic_boolean" id="u2(so==`PrHNt$t,/XT#">
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <next>
                                     <block type="variables_set" id=".T%gExb0x3kzS0QkPh4_">
                                       <field name="VAR" id="y[G=0ms17p|S*%p]+B~p">preise</field>
                                         <block type="lists_create_with" id="9_QV!ty3GA(vG,y+f$PM">
                                           <mutation items="0"></mutation>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="controls_for" id="0EMe,uPv?5mH[^}O)k`i">
                                           <field name="VAR" id="L`VRA5|#^N/oI[|LjJqy">i</field>
                                           <value name="FROM">
                                             <shadow type="math_number" id="CD]PeRYFc[XnhEs5CJ#x">
                                             </shadow>
                                           </value>
                                           <value name="TO">
                                             <shadow type="math_number" id="qYc{.jy$roEsQ,Nt8vyr">
                                               <field name="NUM">23</field>
                                             </shadow>
                                           </value>
                                           <value name="BY">
                                             <shadow type="math_number" id="03:P%];Y-P#yi{L-}LKp">
                                             </shadow>
                                           </value>
                                             <block type="variables_set" id="@3TC[[E?2tnNxQ*fd~Q{">
                                               <field name="VAR" id="ES`I}6lM2ZNSuk*`6Bt`">id</field>
                                                 <block type="text_join" id="N:w]#x6G+8Bmx~)$;f8}" inline="true">
                                                   <mutation items="4"></mutation>
                                                   <value name="ADD0">
                                                     <block type="variables_get" id="LzVIIv*{^;~R(2@Lv;{E">
                                                     </block>
                                                   </value>
                                                   <value name="ADD1">
                                                     <block type="text" id="N@bdq$^6yP}vR4yYmF.x">
                                                       <field name="TEXT">PricesToday.</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD2">
                                                     <block type="variables_get" id="IcZwEk?;*^(U.C8Sj,7|">
                                                     </block>
                                                   </value>
                                                   <value name="ADD3">
                                                     <block type="text" id="e!Oo*|9/;z$t6##==xXm">
                                                       <field name="TEXT">.total</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="lists_setIndex" id="mz72D6xxndyuAarOJ^Rh">
                                                   <mutation at="false"></mutation>
                                                   <field name="MODE">INSERT</field>
                                                   <field name="WHERE">LAST</field>
                                                   <value name="LIST">
                                                     <block type="variables_get" id="IWq=s?THie/h/[7iiV}{">
                                                     </block>
                                                   </value>
                                                   <value name="TO">
                                                     <block type="get_value_var" id="GGwox!C;I%E_l1R0DqiG">
                                                       <value name="OID">
                                                         <shadow type="text" id="MyJGi(n/]qv_!IYhxy=H">
                                                         </shadow>
                                                         <block type="variables_get" id="ks=U5X[R.:5N=z(giPmt">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="controls_for" id="#IcemZu7(wpeg8hlUr;:">
                                               <value name="FROM">
                                                 <shadow type="math_number" id="XqH@jx{57kMGD#DNVXEe">
                                                 </shadow>
                                               </value>
                                               <value name="TO">
                                                 <shadow type="math_number" id="Rof~CHCPfRE}Q?+NC.R_">
                                                   <field name="NUM">17</field>
                                                 </shadow>
                                               </value>
                                               <value name="BY">
                                                 <shadow type="math_number" id="^[nSkD;0r.fX)=GB;P5=">
                                                 </shadow>
                                               </value>
                                                 <block type="variables_set" id=",140@$+*?5Q!6phadh*E">
                                                     <block type="text_join" id="f;8DEi_aVP:k8Mo2{[xZ" inline="true">
                                                       <value name="ADD0">
                                                         <block type="variables_get" id="FU7z:,?Q@2]@;WxPq8-H">
                                                         </block>
                                                       </value>
                                                       <value name="ADD1">
                                                         <block type="text" id="W5b%W`21-HBX(uY$3G|/">
                                                           <field name="TEXT">PricesTomorrow.</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD2">
                                                         <block type="variables_get" id="y91uc$|ujM0al,!9q-Xv">
                                                         </block>
                                                       </value>
                                                       <value name="ADD3">
                                                         <block type="text" id="00Ae^StCs9ZJQ]7.FgN5">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="lists_setIndex" id="C_rGEL-3J#BKOo`X4[dK">
                                                       <value name="LIST">
                                                         <block type="variables_get" id="~9N?Q5}62w)Sy!mAO)k}">
                                                         </block>
                                                       </value>
                                                       <value name="TO">
                                                         <block type="get_value_var" id="{16RqU$HDR4jR|aQ0q3%">
                                                           <value name="OID">
                                                             </shadow>
                                                             <block type="variables_get" id="l2^WVBo)dq?Syx.w5F%!">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <next>
                                                 <block type="variables_set" id="I%E4f01C`g;3p|DcmUku">
                                                   <field name="VAR" id="6)]2##_Z9.w~~.^]:M*W">min1</field>
                                                     <block type="math_number" id="3KuHw0^#,p*_2M/QP?uO">
                                                       <field name="NUM">3</field>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="variables_set" id="Dt_:-3vN.ADYN1pT.7-z">
                                                       <field name="VAR" id="bpynY%@fDWCdbC?Xv*s1">min3</field>
                                                         <block type="math_number" id="?gi`V*!@#+iuu8K3*`5L">
                                                           <field name="NUM">9</field>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="controls_for" id="W3SFx!cp:%wcO#wjjI({">
                                                           <value name="FROM">
                                                             <shadow type="math_number" id="?VS9n{p5)Sbybdj_MorR">
                                                             </shadow>
                                                           </value>
                                                           <value name="TO">
                                                             <shadow type="math_number" id="68B!zjKn/MASC]R;y}k1">
                                                             </shadow>
                                                             <block type="lists_length" id="t9HYB^`KjiNfq$x*IH,f">
        <block type="variables_get" id="fUVVK_^CL_)k4*5C*l|7">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <value name="BY">
                                                             <shadow type="math_number" id="tP+sIGUb[Wn]d+!$C*mL">
                                                             </shadow>
                                                           </value>
                                                             <block type="variables_set" id="L:[PGOztTsy}k$t*7|oA">
                                                               <field name="VAR" id="5_aI@Kq-?t,56cb.j893">preis1</field>
        <block type="lists_getIndex" id=".LJVQeHz5,l}n%R[%6~}">
        <mutation statement="false" at="true"></mutation>
        <field name="MODE">GET</field>
        <field name="WHERE">FROM_START</field>
        <block type="variables_get" id="ZFC/#M0fU1Fj@?y8i98Y">
        </block>
        </value>
        <value name="AT">
        <block type="variables_get" id="Wq(#HzHm(]G]PaXwu4B*">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <block type="controls_if" id="Ozsx73!acF65Yh8[fRS[">
        <value name="IF0">
        <block type="logic_compare" id="]XZHpA3}P5iN%Ip1UoLZ">
        <field name="OP">LT</field>
        <value name="A">
        <block type="variables_get" id="5}g:it%7kl(5?9x*p~Gy">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="AvX)nL76,z(TOD-f#;AR">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="L4nG!:}Bi%*B9bD|U$[z">
        <block type="variables_get" id="FY@GQkmRYO[;W6rM[ayJ">
        </block>
        </value>
        <next>
        <block type="variables_set" id="b*cBRJ-9AMXYQ*U;ncQs">
        <field name="VAR" id="FAiYO^Ty$^^g*F@vG:~j">start1h</field>
        <block type="logic_ternary" id="AIR,$Z?!9$xfowz)flFt" inline="true">
        <value name="IF">
        <block type="logic_compare" id="Ij$Y[Y=A[:chL7VA%8SU">
        <value name="A">
        <block type="variables_get" id="D9Qw)FPc9e9^JDF*{dlj">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="UE*pCLL]21,C{0nywlC9">
        <field name="NUM">7</field>
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <block type="math_arithmetic" id="S(4~b~~Os#gW;Ae+7b2~">
        <value name="A">
        <shadow type="math_number" id="A0|ecpGucnJ;c=5R)QPu">
        </shadow>
        <block type="variables_get" id="VP9|C5G+m?+[S%h+L$SK">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="fRyfZ2ugekFxSbGw+|2.">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        <block type="math_arithmetic" id="}?gMK^#aT.Dg?Kq[_3gU">
        <value name="A">
        <shadow type="math_number">
        </shadow>
        <block type="variables_get" id=",m0S.DIN-i.W4qB1DKY0">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="+2H~`?hnFXE?Tue#??m[">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="z4sy3v]0;aHg8?:Gj]1q">
        <value name="IF0">
        <block type="logic_compare" id="`T=HLgrMIevH#=#3ri^+">
        <value name="A">
        <block type="variables_get" id="A+Gquk7s3kdja^=WzWZi">
        </block>
        </value>
        <value name="B">
        <block type="math_arithmetic" id="~!H6ix/juSb1QKizjMEg">
        <value name="A">
        <shadow type="math_number" id="edjc~ni75,)^-MW2eAD!">
        </shadow>
        <block type="lists_length" id="Ff!`(-2!7M#^)_WymPfp">
        <block type="variables_get" id="[13^ih^yUx~]zvixT(k1">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="pV;){(|(_g39fTA$QoY?">
        <field name="NUM">2</field>
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="93e2%SRJrBGkHVT|JK+t">
        <field name="VAR" id="a4m{kvJ}{$=rv(H9#1J_">preis3</field>
        <block type="math_arithmetic" id="Iqe~^Y]R4f5e1ZRlkTN?">
        <value name="A">
        <shadow type="math_number" id="UnCxpTSlndDmHwzJ9z]s">
        </shadow>
        <block type="variables_get" id="_#!qO(*2{1]q[,:OVuVg">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="==NQWZ*VKKYvKR1H*PsY">
        </shadow>
        <block type="math_arithmetic" id="2x[l_Q)nTYh8XdvcpT6," inline="false">
        <value name="A">
        <shadow type="math_number" id=")}0`5kIav:jNy+PjDAPX">
        </shadow>
        <block type="lists_getIndex" id="2:cxr7AvKukN|oxJ|8$s">
        <block type="variables_get" id="|QJ7IXv.fGbKjXZ:t,T0">
        </block>
        </value>
        <value name="AT">
        <block type="math_arithmetic" id=")9M=+:!*`t3:^kK@6v.U">
        <value name="A">
        <shadow type="math_number" id="d6Vs9+DCL~OyRs+WT^)b">
        </shadow>
        <block type="variables_get" id=",mdfVY1y#7OJ/LpoXugr">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id=":Azb.knUscU0Y6Y$$x~x">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="AsHxB2um+5RUQtu^VH~c">
        </shadow>
        <block type="lists_getIndex" id="{7#Y1kmCjSzA6zDM(~ec">
        <block type="variables_get" id="9Hwt/#|)CcMAry7lid|2">
        </block>
        </value>
        <value name="AT">
        <block type="math_arithmetic" id="q4sI9mLMEDuS-_`@~mqj">
        <value name="A">
        </shadow>
        <block type="variables_get" id="7f^QF_uPBzFEWj#..]P#">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="mRg/SS2z*!,s(Aza6^@9">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="controls_if" id="n1n2P:qtW6Q-lfm{Abp%">
        <value name="IF0">
        <block type="logic_compare" id="f07U,rk3tE3W/q0ofM08">
        <value name="A">
        <block type="variables_get" id="YfYeRF{7,Wn2lwJtGrgG">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="mDAJ1@=qgN$rBT_Ke}mg">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="V:[20QemZnhU63-|yYW;">
        <block type="variables_get" id="!8=qf*1+^mU_ZbC/vWo3">
        </block>
        </value>
        <next>
        <block type="variables_set" id="S~xa|f9t2Zn~XZXlbJh?">
        <field name="VAR" id="ud88TKb=*)[?(!NqiOoj">start3h</field>
        <block type="logic_ternary" id="jS-NU~7A8yY,1}|^_*,f" inline="true">
        <value name="IF">
        <block type="logic_compare" id="75?f-Y9K1`uISWR.Pr19">
        <value name="A">
        <block type="variables_get" id="IRj[~IFnc?`x7/@YGbm)">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="(V~PXIre~J(0|6y@Y;`{">
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <block type="math_arithmetic" id="gfg!EF#W,kt7-PIe.]jO">
        <value name="A">
        </shadow>
        <block type="variables_get" id="D*3tr1la5PYprIfcC:=O">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="-ES^l3#}PjLG+jjuRA@g">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        <block type="math_arithmetic" id="sii*:2njz!9TiOuc[aZe">
        <value name="A">
        </shadow>
        <block type="variables_get" id="KO$U?pP9#m.LJ8a]/ig;">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="lK$A8CNUSB8wmH)GEuTW">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                           <next>
                                                             <block type="variables_set" id="?VZnr9+1^FL]flg:=39f">
        <block type="logic_ternary" id="5hVu~,$5hYC=+)77ZnvF" inline="true">
        <value name="IF">
        <block type="logic_compare" id="{#nKoiS0A2!ds]4A_9PD">
        <value name="A">
        <block type="math_arithmetic" id="LjTp=sImVPb6`ULLeIb7">
        <value name="A">
        <shadow type="math_number" id="_J95g6~#:F9sj2VjM}Qh">
        </shadow>
        <block type="variables_get" id="pr_)NjZ{/P{9T#`IDLZh">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="#?$Un~ak7axxfE;{o{Qv">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="oiAIF1yfSH/#|RKsezHr">
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <block type="math_arithmetic" id="ly`80HF+P.9J8snCEGac">
        <value name="A">
        </shadow>
        <block type="variables_get" id="dR!V{Hse^.`K;6fXm*rL">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="i]Rfsocfn@5O57aFe3dP">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        <block type="math_number" id="MGCtCd`Yt=6@{n*~Kn]h">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <block type="variables_set" id="`yJ*RF3RXBzDcYoUf]V$">
        <block type="logic_ternary" id="@-:I|ewU=ypMKe5?#.GV" inline="true">
        <value name="IF">
        <block type="logic_compare" id="Ry;||rCNv.1Euw*UJP]M">
        <value name="A">
        <block type="math_arithmetic" id="p^@+.p)y{v5o}0C}m0.y">
        <value name="A">
        </shadow>
        <block type="variables_get" id="xH;g#MI35+/3yJQ:qQG)">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="Ok}tH`Br~A_24Nrf=sM/">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="-3@U3~j%$|hdAj[)pfB/">
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <block type="math_arithmetic" id="EUg_wq,2_Af/q7Dwldp=">
        <value name="A">
        </shadow>
        <block type="variables_get" id="nXXAXel6/+px~(.P;Xd*">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="N,vEBOefnhveJ:1*]DFC">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        <block type="math_arithmetic" id="c29R^iU`sijcK83l%^E|">
        <value name="A">
        </shadow>
        <block type="variables_get" id="d#z|7LYA@:|^q)WTo,L#">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id=".Q9)T9Rp|iH%:,Xvcv6O">
        <field name="NUM">21</field>
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="schedule_clear" id="iM7,/Ko=JX57Y0yu?-6q">
        <field name="NAME">schedule1</field>
        <next>
        <block type="schedule_clear" id="7ci5R#wHLXk]I]Erriip">
        <field name="NAME">schedule2</field>
        <next>
        <block type="schedule_clear" id="4]Ps(*w%jE%aa@U26}mw">
        <field name="NAME">schedule3</field>
        <next>
        <block type="schedule_clear" id="$ceBK{ys|)xS*f~_Z;Rp">
        <field name="NAME">schedule4</field>
        <next>
        <block type="schedule_create" id="C@%7o,Ekc,|!/a6{MkUS">
        <value name="SCHEDULE">
        <shadow type="field_cron" id="-$VctMxjGv=4)zq9N4Y0">
        <field name="CRON">* * * * *</field>
        </shadow>
        <block type="cron_builder" id="8y]GZ`$%m4$NTYjf,#_4" inline="true">
        <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation>
        <field name="LINE">TRUE</field>
        <field name="WITH_SECONDS">FALSE</field>
        <value name="DOW">
        <shadow type="text" id="5BeD0bHLs:^x0RqW5}$x">
        <field name="TEXT">*</field>
        </shadow>
        </value>
        <value name="MONTHS">
        <shadow type="text" id="lg{qvknu8,?D++21hEpf">
        </shadow>
        </value>
        <value name="DAYS">
        <shadow type="text" id="*Fw,YPls30y1W{.)Z]Zp">
        </shadow>
        </value>
        <value name="HOURS">
        <shadow type="text" id="w+jm9ay~fdBT)SuxS|y9">
        </shadow>
        <block type="variables_get" id="o(.aJHIKtOGz3%n2lxYM">
        </block>
        </value>
        <value name="MINUTES">
        <shadow type="text" id="HLI#3VJ/f!FRNZQ:n4O%">
        <field name="TEXT">0</field>
        </shadow>
        </value>
        </block>
        </value>
        <block type="control" id="R|GS:n7ms%A-8wutDCq[">
        <block type="logic_boolean" id="UYDo5xpjr03Z[HC]JciX">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="schedule_create" id="lmx|uwrCVvUbx-C09[94">
        <shadow type="field_cron">
        </shadow>
        <block type="cron_builder" id="aEX/56JjlSBU/[ipuQ8X" inline="true">
        <value name="DOW">
        <shadow type="text" id="lMH4V)Vtf+IcFdjRXkaW">
        </shadow>
        </value>
        <shadow type="text" id="AjkR{~Onh=VHFT!@jluL">
        </shadow>
        </value>
        <value name="DAYS">
        <shadow type="text" id="gX*GvSQe~+EV$/I$O,j%">
        </shadow>
        </value>
        </shadow>
        <block type="variables_get" id="~}v=cY[KUbaMt@pI}8{e">
        </block>
        </value>
        <shadow type="text" id="ijLCMJgY]v$y@,?zSo9+">
        </shadow>
        </value>
        </block>
        </value>
        <block type="control" id="F[A)xVutBB$1Yv9wQJMg">
        <block type="logic_boolean" id="Q7bdR}]i^c*s6c46-O@o">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="schedule_create" id="Uz3Pj9N9)62!ppFx*s`-">
        </shadow>
        <block type="cron_builder" id="}`t[hS]2+i@W$Kw@C;2L" inline="true">
        <value name="DOW">
        <shadow type="text" id="b:oN*ACawmZv{JQR0m7q">
        </shadow>
        </value>
        <shadow type="text" id="Ur]myA9.G$]jH22=!nx]">
        </shadow>
        </value>
        <value name="DAYS">
        <shadow type="text" id="%@r2eu#Cv7rs2*|n.0ol">
        </shadow>
        </value>
        </shadow>
        <block type="variables_get" id="p81|d/F,bF2}O`(qGaGH">
        </block>
        </value>
        <shadow type="text" id="lMv%?#YLF`haS{qw}3W!">
        </shadow>
        </value>
        </block>
        </value>
        <block type="control" id="JMt*g^rD+x|@pHw3p:5,">
        <block type="logic_boolean" id=":`WAU[k;h[|V+Pt[9W%W">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="schedule_create" id="Xu`urAC!r/9e%8Yc3?(r">
        </shadow>
        <block type="cron_builder" id="TKfvJ_4r93bJ7La7-=46" inline="true">
        <value name="DOW">
        <shadow type="text" id="A{ANH/W|%b,aS!(QRvhv">
        </shadow>
        </value>
        <shadow type="text" id="tTX%wAllx+SDy:.xMIt6">
        </shadow>
        </value>
        <value name="DAYS">
        <shadow type="text" id=".z=ARDX,g[O6@RX-8CRq">
        </shadow>
        </value>
        </shadow>
        <block type="variables_get" id="^qx9D%(sDw*tT~.|n]fE">
        </block>
        </value>
        <shadow type="text" id="%I_F`(NE8{I)Pd8.+*ZY">
        </shadow>
        </value>
        </block>
        </value>
        <block type="control" id=":Y?k,t=+Ug:-h!aRb+e~">
        <block type="logic_boolean" id="E%~He2eg5q}_wNkv%Fro">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                    </xml>
                    Für ein Bild ist es zu umfangreich.
                    Der erste Teil schaltet aus, wenn vor einem Tag als Endzeit 18:00 Uhr ermittelt wurde und es werden die Preise ab 18:00 Uhr bis morgen 17:00 chronologisch sortiert in ein Array geschrieben.
                    Im zweiten Teil werden die Startzeiten für 1 Stunde und 3 Stunden Dauer ermittelt.
                    Im letzten Teil werden die Endzeiten ermittelt, die laufenden Zeitpläne gestoppt und die neuen Zeitpläne erstellt.
                       <variables>
                       </variables>
                           </block>
                         </value>
                         <next>
                                 <value name="IF0">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                       </block>
                                     </value>
                                   </block>
                                 </statement>
                                 <next>
                                     <value name="IF0">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                     <next>
                                           </block>
                                         </value>
                                         <next>
                                             <value name="FROM">
                                               </shadow>
                                             </value>
                                             <value name="TO">
                                               </shadow>
                                             </value>
                                             <value name="BY">
                                               </shadow>
                                             </value>
                                                     <value name="ADD0">
                                                       </block>
                                                     </value>
                                                     <value name="ADD1">
                                                       </block>
                                                     </value>
                                                     <value name="ADD2">
                                                       </block>
                                                     </value>
                                                     <value name="ADD3">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                     <value name="LIST">
                                                       </block>
                                                     </value>
                                                     <value name="TO">
                                                         <value name="OID">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                                 <value name="FROM">
                                                   </shadow>
                                                 </value>
                                                 <value name="TO">
                                                   </shadow>
                                                 </value>
                                                 <value name="BY">
                                                   </shadow>
                                                 </value>
                                                         <value name="ADD0">
                                                           </block>
                                                         </value>
                                                         <value name="ADD1">
                                                           </block>
                                                         </value>
                                                         <value name="ADD2">
                                                           </block>
                                                         </value>
                                                         <value name="ADD3">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                         <value name="LIST">
                                                           </block>
                                                         </value>
                                                         <value name="TO">
                                                             <value name="OID">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                       </block>
                                                     </value>
                                                     <next>
                                                           </block>
                                                         </value>
                                                         <next>
                                                             <value name="FROM">
                                                               </shadow>
                                                             </value>
                                                             <value name="TO">
                                                               </shadow>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <value name="BY">
                                                               </shadow>
                                                             </value>
        </block>
        </value>
        <value name="AT">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        <value name="A">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="AT">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        <value name="AT">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                             <next>
        <value name="IF">
        <value name="A">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF">
        <value name="A">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="THEN">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="ELSE">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <next>
        <next>
        <next>
        <next>
        </shadow>
        <value name="DOW">
        </shadow>
        </value>
        </shadow>
        </value>
        <value name="DAYS">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        </shadow>
        <value name="DOW">
        </shadow>
        </value>
        </shadow>
        </value>
        <value name="DAYS">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        </shadow>
        <value name="DOW">
        </shadow>
        </value>
        </shadow>
        </value>
        <value name="DAYS">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        </shadow>
        <value name="DOW">
        </shadow>
        </value>
        </shadow>
        </value>
        <value name="DAYS">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                      </xml>
                      Doom.86
                      @paul53 ich sage erstmal vielen lieben Dank für deine Mühe. Ich schaue es mir an, sobald ich zuhause bin und werde dann Rückmeldung geben.
                      Edit: hab ich es an den Bildern übersehen, wo trage ich die id von Warmwasser bzw FBH ein? Dort reicht es, wenn preis günstig erhöhe aktuellen Wert zb. Um 4 nach Ablauf der Zeit veringere diesen Wert wieder um 4.
                      • D Doom.86
                        @doom-86 sagte: wo trage ich die id von Warmwasser bzw FBH ein?
                        Dort, wo die Blöcke "steuere" sitzen: FBH bei end3h, schedule3 und schedule4.
                          Doom.86
                          @paul53 ach, gleich in der dritten zeile von dem ersten screenshot?
                          Und dahinter dann den wert mit erhöhe um 4?
                          Ich probier es nachher zu hause aus. Übers handy ließ er mich nicht mal den Code kopieren.
                          • D Doom.86
                            @doom-86 sagte: gleich in der dritten zeile von dem ersten screenshot?
                            Stattdessen: Verringere den Wert um 4.
                            Und unten:
                              Und unten:
                              Doom.86
                              @paul53 So schaut es jetzt bei mir aus.
                              ich hoffe das passt so?
                              Einzige was mir unter Protokolle ausgewurfen wurde ist:
                              2023-01-10 23:10:19.125 warn State "javascript.1.scriptEnabled.Heizung_Nacht_Tibber" has no existing object, this might lead to an error in future versions
                              naja, ich hab jetzt die Zwei Werte der Heizung in die History aufgenommen. so sollte ich die Tage sehen, ob es funktioniert.
                              Edit: Die Meldung aus dem Protokoll kam jetzt nur einmal, beim ersten Start des Skripts. Als ich es gestoppt habe und nochmals gestartet, kam diese Meldung nicht mehr.
                              • D Doom.86
                                @doom-86 sagte: ich hoffe das passt so?
                                Das muss oben (Ausschalten um 17:59 Uhr) genauso gehandhabt werden wie unten
                                Es genügt, den WW-Sollwert um 4 K zu verringern?
                                  Doom.86
                                  @paul53 sagte in Awattar - die billigsten Strom-Stunden nutzen:
                                  Ich möchte ja ein überheizen. somit muss doch die WW Temp und die Raumtemperatur erhöht werden? oder habe ich jetzt einen Denkfehler?
                                  Wenn ich aktuell zB. 44°C als WW-Temperatur eingestellt habe, möchte dann in der Nacht wenn der Strom günstig ist, die WW-Temperatur auf 48°C erhöhen, dann muss ich doch +4 und nach der 1 Stunde des Zeitplans wieder -4, damit ich wieder auf meine Anfangs 44°C komme?
                                  EDIT: Ich habe eben gesehen, dass die Preise in dem Tibber Adapter von Morgen nicht gelöscht werden. Jetzt stehen bei heute und morgen die Identischen Preise drinnen.
                                  • D Doom.86
                                    @doom-86 sagte: Jetzt stehen bei heute und morgen die Identischen Preise drinnen.
                                    Hauptsache, die Preise stimmen um 17:59 Uhr.
                                    Wenn im Laufe des Tages die WW-Temperatur von 48°C auf 44°C sinkt - was nicht viel ist, schaltet der interne Regler die Heizung unabhängig vom Strompreis ein.
                                    D 2 Antworten Letzte Antwort
                                      Doom.86
                                      Richtig aktuell hab ich die Anlage im tagbetrieb und über einen Zeitplan gesteuert. Tagsüber ww-soll 40°C in der Nacht WW-Soll 48°C. Durch die hysterese heizt die wärmepumpe auf ca. 50 - 51°C auf. Tagsüber fällt die Temperatur je nach Verbrauch langsam oder schneller ab. Wenn diese am Tag auf 38°C abfällt, läuft die wärmepumpe an und heizt mit hysterese auf ca 42°C auf.
                                      Nächste bzw spätestens übernächste woche wird mein wärmepumpen Zähler ausgebaut, dann läuft diese auch über tibber.
                                      Daher auch die Steuerung.
                                        Doom.86
                                        @paul53 jetzt wurde das ganze eben ausgeführt. Nun die Frage, liegen die Fehlermeldungen daran. Dass tibber aktuell Probleme hat? Bekomme keine live Daten mehr in iobroker. Die heutigen und morgigen preise wurden allerdings noch richtig gesetzt.
                                        • D Doom.86
                                          @doom-86
                                          Nicht lesbar: Bitte in Code tags posten!
                                          Den String der Variablen tibber hast Du für Deinen Account angepasst?
