  4. IoBroker absturz (scheinbar in js-controller) bei Namensänderung in Admin
12 Beiträge 3 Kommentatoren 2.1k Aufrufe
  • frankjokeF Offline
    frankjokeF Offline
    frankjoke
    Hallo mitsammen,
    bastle gerade an einem Adapter wo die Namen von Objekten nachher im admin geändert werden sollen da der Adapter States mit Zeitstempel im namen kreiert.
    Vast bei jeder Namensänderung stürzt iobroker ab, im Log sehe ich manchmal sowas:
    host.jessi4	2017-08-04 12:52:58.065	info	force terminating
    host.jessi4	2017-08-04 12:52:55.970	info	received SIGTERM
    host.jessi4	2017-08-04 12:52:50.952	info	received SIGTERM
    iobroker	2017-08-04 12:52:49.816	info	exit 0
    iobroker	2017-08-04 12:52:49.762	info	Starting node restart.js
    iobroker	2017-08-04 12:52:47.894	info	_restart
    TypeError:	2017-08-04 12:52:47.886	error	at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2053:33)
    TypeError:	2017-08-04 12:52:47.886	error	at ObjectsInMemServer.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2060:23)
    TypeError:	2017-08-04 12:52:47.886	error	at clone (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1730:29)
    TypeError:	2017-08-04 12:52:47.886	error	at clone (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1726:24)
    TypeError:	2017-08-04 12:52:47.886	error	at new Buffer (buffer.js:80:17)
    TypeError:	2017-08-04 12:52:47.886	error	at Function.Buffer.from (buffer.js:101:10)
    TypeError:	2017-08-04 12:52:47.886	error	at fromObject (buffer.js:262:9)
    TypeError:	2017-08-04 12:52:47.886	error	First argument must be a string, Buffer, ArrayBuffer, Array, or array-like object.
    uncaught	2017-08-04 12:52:47.853	error	exception: First argument must be a string, Buffer, ArrayBuffer, Array, or array-like object.
    Mein iobroker ist 1.1.2, node 6.11.1 und admin 1.8.1.
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    • apollon77A Offline
      Machst Du dazu bitte ein Github Issue auf ?! Danke!
        Scheinbar passiert da was komisches beim "clonen" des Objekts. Da ist scheinbar irgendwo ein "Buffer" Objekt drin und da knallt es.
        Wie sieht das Objekt denn genau aus?
          frankjokeF Offline
          frankjoke
          Appollon77,
          hast Recht! im common ist ein Wert mit einem Buffer. Hab das weggegeben und speichere die Daten in hex und jetzt geht's ohne Absturz!
          Trotzdem noch eine issue auf Github (bei welchen Adapter/instanz)?
          Frank,
            Wie genau sah das Common denn aus?
              frankjokeF Offline
              frankjoke
              So wie:
              { broadlink2: { data: buffer } }
              wo Buffer eine Buffer-Variable war.
              Hab diese in hex umgewandelt und als solches gespeichert.
              Übrigens, einen Änderungswunsch an den admin-Adapter:
              Sobald common etwas enthält wird das Zahnrad im objektviewer blau angezeigt.
              Es sollte wohl anzeigen welche Adapter eine History aufzeichnen!
              Wenn keine adapter.instanzen im Common aufscheinen sollte es nicht blau werden!
              Ich verwende 'adaptername' als Name aber nicht 'adaptername.instanz' und deshalb sollte klar sein dass mein Adapter nicht irgendwas aufzeichnet sonder nur was zwischenspeichert.
              Frank,
                Meinst Du "common" oder "custom"? Die History-Werte landen in "custom"
                  frankjokeF Offline
                  frankjoke
                  Genau gesagt ist es 'common.custom'!
                  Frank,
                    Jupp. ;-) der Plan von common.custom ist das dort andere Instanzen Details ablegen können und das das dann auch editiert werden kann. Aktuell nutzen das nur die History Adapter.
                    Von daher wäre in custom sauber mit der Instanz zu arbeiten. Ansonsten kannst du in common direkt durch eigene Felder erweitern. Musst ja nicht common.custom nehmen.
                      frankjokeF Offline
                      frankjoke
                      Ok,
                      hab die Daten nach native verschoben um nicht das blaue Zahnrad bei allen Objekten zu haben (sondern nur dort wo wirklich aufgezeichnet wird).
                      Nun, das funktioniert auch super aber ich wollte jetzt den custom-Eintrag mit dem admin/objects rauslöschen aber das geht nicht.
                      Admin fragt zwar ob ich es wirklich will, löscht es aber nicht :(!
                      Frank,
                      • BluefoxB Offline
                        BluefoxB Offline
                        @fsjoke:
                        Ok,
                        2017-08-06_e.png `
                        Schreibe einfach {} ins custom.
                          frankjokeF Offline
                          frankjoke
                          Ja, damit kann ich zwar custom auf ein leeres Objekt setzen aber das blaue Zahnrad bleibt da iobroker custom eben noch immer findet.
                          Einziger Ausweg schnell in den Javascript Adapter und dort mit Rohmitteln gearbeitet:
                          const id = 'xxxx.0.xxxx.xxxx';
                               s = getObject(id);
                          s.common.custom = null;
                          setObject(id, s, (err, ok) => log(err));
                          Das funktioniert nur mit 'null' als Zuweisung, eine delete oder ein undefined, oder ein leeres Objekt funktioniert auch da nicht!
                          Aber ich hab's ja geschafft…
                          Ergänzung:
                          Habe bemerkt dass die Zuweisung von {} bei manchen funktioniert hat und bei anderen nicht!
                          Aber eine andere Methode: Zuweisung von null im RAW-Fenster scheint immer zu funktionieren. Also mach ich das jetzt falls ich es jemals noch brauche nachdem ich die Objekte migriert habe.
                          Frank,
